1 | library ieee;
2 | use ieee.std_logic_1164.all;
3 | use ieee.std_logic_unsigned.all;
4 | use ieee.std_logic_arith.all;
5 |
6 |
7 | entity uart is
8 |
9 | port (
10 | clk : in std_logic;
11 | reset : in std_logic;
12 | seriell_in : in std_logic;
13 | seriell_out : out std_logic_vector(7 downto 0) := (others => '0');
14 | seriell_ctr_out : out std_logic := '0';
15 | test_out : out std_logic_vector(7 downto 0):= (others => '0'));
16 |
17 | end uart;
18 |
19 |
20 | architecture rtl of uart is
21 |
22 | --type and signal for the finit state machine
23 | type t_state is (IDLE, START, DATS, PARITY, STOP);
24 | signal presentstate : t_state;
25 | signal nextstate : t_state;
26 |
27 | --Signal for the prescaler
28 | signal precount : std_logic := '0';
29 |
30 | --Signal for puffering the input
31 | signal mem_input : std_logic_vector(7 downto 0) := (others => '0');
32 |
33 | --constant for the baudrate
34 | constant baudrate : std_logic_vector(5 downto 0) := conv_std_logic_vector(13,6);--baudrate = 8*460,8kBit/s
35 |
36 | begin -- rtl
37 |
38 | -- purpose: Prescaler for the uart
39 | -- type : sequential
40 | -- inputs : clk48, reset_n
41 | -- outputs: precount
42 | Prescaler: process (clk, reset)
43 | variable count : std_logic_vector(5 downto 0) := (others => '0');
44 | begin -- process Prescaler
45 | if reset = '0' then -- asynchronous reset (active low)
46 | count := (others => '0');
47 | presentstate <= IDLE;
48 | elsif clk'event and clk = '1' then -- rising clock edge
49 | presentstate <= nextstate; -- set the presentstate to the nextstate
50 | precount <= '0'; -- reset of the variable precount
51 | count := count + 1;
52 | if count = baudrate then
53 | count := (others => '0');
54 | precount <= '1'; --set of the variable precount
55 | end if;
56 |
57 | end if;
58 | end process Prescaler;
59 |
60 |
61 | -- purpose: Sequential Process for the fsm
62 | -- type : sequential
63 | -- inputs : clk48, reset_n
64 | -- outputs: presentstate
65 | seqfsm2: process (clk, reset)
66 |
67 | variable count : std_logic_vector(3 downto 0) := (others => '0');
68 | variable dat1 : std_logic_vector(2 downto 0) := (others => '0');
69 | variable dat0 : std_logic_vector(2 downto 0) := (others => '1');
70 | variable pos : integer range 0 to 8 := 0;
71 |
72 | begin -- process seqfsm2
73 | if reset = '0' then -- asynchronous reset (active low)
74 |
75 | elsif clk'event and clk = '1' then -- rising clock edge
76 | seriell_ctr_out <= '0';
77 | if precount = '1' then
78 | case presentstate is
79 | -------------------------------------------------------------------------------
80 | -- IDLE State
81 | -------------------------------------------------------------------------------
82 | when IDLE =>
83 | mem_input <= (others => '0');
84 | if seriell_in = '0' then -- if seriell_in = 0 the receiving starts
85 | nextstate <= START;
86 | end if;
87 | -------------------------------------------------------------------
88 | -- START State
89 | -------------------------------------------------------------------
90 | when START =>
91 | pos := 0;
92 | if seriell_in = '0' then
93 | count := count + 1;
94 | if count = conv_std_logic_vector(7,4) then -- when there were 8 zeros the startbit is finished
95 | nextstate <= DATS;
96 | dat1 := (others => '0') ;
97 | dat0 := (others => '1');
98 | count := (others => '0');
99 | end if;
100 | else
101 | nextstate <= IDLE; -- when there is a error bei the startbis change back to IDLE Mode
102 | end if;
103 | ---------------------------------------------------------------------
104 | -- DATS State
105 | ---------------------------------------------------------------------
106 | when DATS =>
107 | if seriell_in = '0' then
108 | dat0 := dat0 - 1;
109 | count := count + 1;
110 | end if;
111 | if seriell_in = '1' then
112 | dat1 := dat1 + 1;
113 | count := count + 1;
114 | end if;
115 |
116 | if count = conv_std_logic_vector(5,4) and dat1 = conv_std_logic_vector(5,3) then
117 | mem_input(pos) <= '1'; --when ther were five times a one the Bitis set to 1
118 | end if;
119 | if count = conv_std_logic_vector(5,4) and dat0 = conv_std_logic_vector(2,3) then
120 | mem_input(pos) <= '0'; --when there were five times a zero the Bit is set to 0
121 | end if;
122 |
123 | if count = conv_std_logic_vector(8,4) then
124 | pos := pos + 1;
125 | dat1 := (others => '0');
126 | dat0 := (others => '1');
127 | count := (others => '0');
128 | if pos = 8 then -- if 8 Bits are received he change to the STOP State
129 | nextstate <= PARITY;
130 | end if;
131 | end if;
132 | ---------------------------------------------------------------------
133 | -- PARITY State
134 | ---------------------------------------------------------------------
135 | when PARITY =>
136 | --In this state you have the possibility to control the message
137 | --with the parity bit.
138 | count := count + 1;
139 | if count = conv_std_logic_vector(8,4) then --if he received the Stopbit he change to the IDLE State
140 | nextstate <= STOP;
141 | count := (others => '0');
142 | end if;
143 | ---------------------------------------------------------------------
144 | -- STOP State
145 | ---------------------------------------------------------------------
146 | when STOP => -- STOP State
147 | if seriell_in = '1' then
148 | count := count + 1;
149 | if count = conv_std_logic_vector(8,4) then --if he received the Stopbit he change to the IDLE State
150 | nextstate <= IDLE;
151 | count := (others => '0');
152 | dat1 := (others => '0');
153 | dat0 := (others => '1');
154 | seriell_out <= mem_input;
155 | test_out <= mem_input;
156 | seriell_ctr_out <= '1';
157 | end if;
158 | end if;
159 | when others => nextstate <= IDLE; --if there is an error the fsm go
160 | --back to the IDLE state
161 | end case;
162 | end if;
163 | end if;
164 | end process seqfsm2;
165 |
166 |
167 | end rtl;
