1 | $regfile = "m8def.dat"
2 | $crystal = 3579545 ' default use 40 for the frame space
3 | $lib "mcsbyte.lbx" ' for smaller code
4 | $lib "ds1307clock.lib" ' modified lib
5 |
6 | 'configure the scl and sda pins
7 | Config Sda = Portc.4
8 | Config Scl = Portc.5
9 | Config Lcdpin = Pin , Db4 = Portd.0 , Db5 = Portd.1 , Db6 = Portd.2 , Db7 = Portd.3 , E = Portd.5 , Rs = Portd.4
10 | Config Lcd = 16 * 2
11 | Config Lcdbus = 4 '4 Bit Modus
12 | Cursor Off Noblink 'LCD = Cursor aus
13 | 'address of ds1307
14 | Const Ds1307w = &HD0 ' Addresses of Ds1307 clock
15 | Const Ds1307r = &HD1
16 |
17 | Config Clock = User ' this will dim the bytes automatic
18 | 'dim other needed variables
19 | Dim Weekday As Byte
20 | Cls
21 | Lcd "test"
22 |
23 | ' assigning the time will call the SetTime routine
24 | Time$ = "23:58:59" ' to watch the day changing value
25 | Date$ = "11-13-02" ' 13 november 2002
26 | Do
27 | Cls
28 | Lcd Date$ ; " " ; Time$
29 | Waitms 500
30 | Loop
31 |
32 | End
33 |
34 | 'called from ds1307clock.lib
35 | Getdatetime:
36 | I2cstart ' Generate start code
37 | I2cwbyte Ds1307w ' send address
38 | I2cwbyte 0 ' start address in 1307
39 |
40 | I2cstart ' Generate start code
41 | I2cwbyte Ds1307r ' send address
42 | I2crbyte _sec , Ack
43 | I2crbyte _min , Ack ' MINUTES
44 | I2crbyte _hour , Ack ' Hours
45 | I2crbyte Weekday , Ack ' Day of Week
46 | I2crbyte _day , Ack ' Day of Month
47 | I2crbyte _month , Ack ' Month of Year
48 | I2crbyte _year , Nack ' Year
49 | I2cstop
50 | _sec = Makedec(_sec) : _min = Makedec(_min) : _hour = Makedec(_hour)
51 | _day = Makedec(_day) : _month = Makedec(_month) : _year = Makedec(_year)
52 | Return
53 |
54 | Setdate:
55 | _day = Makebcd(_day) : _month = Makebcd(_month) : _year = Makebcd(_year)
56 | I2cstart ' Generate start code
57 | I2cwbyte Ds1307w ' send address
58 | I2cwbyte 4 ' starting address in 1307
59 | I2cwbyte _day ' Send Data to SECONDS
60 | I2cwbyte _month ' MINUTES
61 | I2cwbyte _year ' Hours
62 | I2cstop
63 | Return
64 |
65 | Settime:
66 | _sec = Makebcd(_sec) : _min = Makebcd(_min) : _hour = Makebcd(_hour)
67 | I2cstart ' Generate start code
68 | I2cwbyte Ds1307w ' send address
69 | I2cwbyte 0 ' starting address in 1307
70 | I2cwbyte _sec ' Send Data to SECONDS
71 | I2cwbyte _min ' MINUTES
72 | I2cwbyte _hour ' Hours
73 | I2cstop
74 | Return
