i need to transmit a can message from PIC18f45f. cann anoyone please
tell me what is wrong here. This is my code. I use CAN-MCP2551.
# include <p18f458.h>
# include <p18cxxx.h>
# include <can2510.h>
# define RXF5 101
# define RXF4 100
# define RXF3 011
# define RXF2 010
# define RXF1 001 \\ only possible when RXB0DBENbit is set
# define RXF0 000 \\ only possible when RXB0DBENbit is set
# define CAN_TX_PRIORITY_0 0
# define CAN_TX_STD_FRAME 0
# define CAN_TX_NO_RTR_FRAME 0
typedef struct CANMessage {
unsigned long Address;
unsigned char MessageData[8];
unsigned char NoOfBytes;
unsigned char Priority;
unsigned Ext:1;
unsigned Remote:1;
char CANPut(CANMessage)
void Can_Config (void);
void Can_Init (void);
void Can_Txmsg (void);
void Can_Txinit (void);
/* for can_message receive
unsigned char NewMessage[8];
unsigned char NewMessageData[8];
unsigned char NewMessageLen;
unsigned int NewMessageFlags;*/
unsigned char bus_free;
unsigned char r ;
void main()
Can_Config(); // to configure CANRX and TX as interface
Can_Init(); // can_initialising and configuring
CANCON = 0x00; // Normal mode , to send or receive a message ,can
should be in the normal mode
CANSTAT = 0x00; // Normal mode
Can_Txinit();// initialising to transmit message
TXB0CONbits.TXREQ = 1; // TXREQ is set, the TXABT, TXLARB and TXERR
bits will be cleared
if(bus_free == 0)
r = 1; // breakpoint
CANPut(0x02,0x01,1,CAN_TX_PRIORITY_0 &
CAN_TX_STD_FRAME & CAN_TX_NO_RTR_FRAME);
while(bus_free == 0)
continue;
r = 0;
void Can_Txinit()
TXB0CON = 0x00;
PIE3bits.TXB0IE = 0;
TXB0SIDL = 0; // lower byte transmit buffer with standard identifier
TXB0SIDH = 0; // higher byte transmit buffer with standard
identifier
TXB0DLC = 0; // data length code
void Can_Config()
TRISBbits.TRISB3 = 1; //to configure CANRX as interface
TRISBbits.TRISB2 = 0; //to configure CANTX as interface
void Can_Init()
CANCON = 0x10; //Request configuration mode
CANSTAT = 0x10; // Configuration mode
RXB0CON = 0x64; // Receive all messages (including those with errors,
Roll over from receive buffer0to1
RXB1CON = 0x60; // Receive all messages (including those with errors,
BRGCON1 = 0x01;
BRGCON2 = 0x00;
BRGCON3 = 0x00;
Antworten können aud Deutsch, Englich oder Französisch erfolgen
besten Dank
