Forum: Compiler & IDEs Int to Str Konvertierung
Autor: Rudi (Gast)
hi,
wie kann ich am schnellsten einen Integer Wert in einen String
konvertieren?
Autor: Peter (Gast)
Müsste in jedem Programmierhandbuch für C zu finden sein: itoa()
_______________________________________
char* itoa (int __val, char * __s, int __radix)
Convert an integer to a string.
The function itoa() converts the integer value from val into an ASCII
representation that will be stored under s. The caller is responsible
for providing sufficient storage in s.
Note:
The minimal size of the buffer s depends on the choice of radix. For
example, if the radix is 2 (binary), you need to supply a buffer with a
minimal length of 8 * sizeof (int) + 1 characters, i.e. one character
for each bit plus one for the string terminator. Using a larger radix
will require a smaller minimal buffer size.
Warning:
If the buffer is too small, you risk a buffer overflow. Conversion is
done using the radix as base, which may be a number between 2 (binary
conversion) and up to 36. If radix is greater than 10, the next digit
after
’9’ will be the letter ’a’.
If radix is 10 and val is negative, a minus sign will be prepended. The
itoa() function returns the pointer passed as s.
Autor: Karl Heinz (kbuchegg) (Moderator)
Autor: Luther Blissett (luther-blissett)
Karl heinz Buchegger wrote:
http://www.mikrocontroller.net/articles/FAQ#Wie_ka...
Oha. die ItoA ist kaputt. Ich erlaube mir mal das zu korrigieren.
