hier mal der Teil des Quellcodes der den Fehler verursacht: #pragma vector=USART_RX_vect __interrupt void rx_buffer_full(void) // <-- diese Zeile verursacht den Fehler !!! { unsigned char ucValue; static unsigned char ucRXPrompt = 0; // yes -> reset transmission ucValue = UDR2; // read character from RX-buffer if(ucRXI == WAIT_STATE) // last instruction evaluated? { if( ucValue == 0x3e ) // Prompt (>) detected { ucRXPrompt = 1; // set flag, that prompt was received } if( (ucValue == 0x0d) && (ucRXPrompt == 1) ) // Carriage Return detected { ucRXI = PROMPT_DETECTED; // set flag, that answer was received completely ucRXPrompt = 0; ucSioPointer = 0; } else if(ucValue == 0x0d) { PORTH ^= (1<<PB5); if( (ucSioBuffer[ucSioPointer-2] == 'B') && ( ucSioBuffer[ucSioPointer-1] == 'C') ) { PORTH ^= (1<<PB5); ucRXI = BAD_COMMAND; } else if( (ucSioBuffer[ucSioPointer-2] == 'C') && ( ucSioBuffer[ucSioPointer-1] == 'F') ) { PORTH ^= (1<<PB5); ucRXI = COMMAND_FAILURE; } else if( (ucSioBuffer[ucSioPointer-2] == 'N') && ( ucSioBuffer[ucSioPointer-1] == 'D') ) { PORTH ^= (1<<PB5); mode = 3; ucRXI = NO_DISK; PORTH ^= (1<<PB5); } ucSioPointer = 0; } else { if(ucSioPointer < SIO_BUFFER_SIZE) // buffer full? ucSioBuffer[ucSioPointer++] = ucValue;// no->save character else // yes -> buffer overflow (error) { ucRXI = WAIT_STATE; ucRXPrompt = 0; ucSioPointer = 0; } } } } Die Fehlermeldung ist wie folgt: ../uart.c:76: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'void' ??? Was will er mir damit bloß sagen??
1 | #pragma vector=USART_RX_vect |
2 | __interrupt void rx_buffer_full(void) |
Bist Du Dir sicher, daß das die von Deinem Compiler verstandene Art der Deklaration/Definition eines Interrupthandlers ist? Mir riecht das arg nach IAR-Syntax.
sollte dass
nicht eher
1 | ISR (USART_EXC_vect) |
heißen? Hruß, Markus
Rufus t. Firefly wrote:
1 | > #pragma vector=USART_RX_vect |
2 | > __interrupt void rx_buffer_full(void) |
3 | > |
> > Bist Du Dir sicher, daß das die von Deinem Compiler verstandene Art der > Deklaration/Definition eines Interrupthandlers ist? Mir riecht das arg > nach IAR-Syntax. Nein, bin ich nicht. Du hast recht, das Prog wurde in IAR-Syntax geschrieben. Ich hab da echt fast keine Erfahrung mit und dachte ich bekomms unter AVR Studio zum laufen...aber...falsch gedacht.
