1 | void I2C_Init(void)
2 | {
3 | // Configure TWI PIOs
4 | AT91F_TWI_CfgPIO ();
5 |
6 | // Configure PMC by enabling TWI clock
7 | AT91F_TWI_CfgPMC ();
8 |
9 | // Configure TWI in master mode
10 | AT91F_TWI_Configure (AT91C_BASE_TWI);
11 |
12 | // Set TWI Clock Waveform Generator Register
13 | I2C_SetClock();
14 |
15 | //TWI NACK Bug workaround
16 | AT91F_AIC_ConfigureIt ( AT91C_BASE_AIC,
17 | AT91C_ID_TWI,
18 | 7,
19 | AT91C_AIC_SRCTYPE_INT_POSITIVE_EDGE,
20 | dummy_irq);
21 | *AT91C_TWI_IER = (1<<0);
22 |
23 | *AT91C_TWI_CR = AT91C_TWI_MSEN;
24 | }
25 |
26 | unsigned char I2C_read(unsigned char dev_adr, // slave address
27 | unsigned char mem_adr, // internal memory address
28 | unsigned char *data, // datapointer for the return data
29 | unsigned int n_byte){ // count of bytes to read
30 | unsigned int timeout = 0;
31 | unsigned char counter;
32 | unsigned int uiByteCounter = 0;
33 | timeout = 0;
34 |
35 | *AT91C_TWI_CR = AT91C_TWI_MSEN; //Enable the TWI Master Mode
36 | *AT91C_TWI_IADR = mem_adr; //Set the TWI Slave memory address
37 | *AT91C_TWI_MMR = ((dev_adr<<16) //Slave address
38 | | AT91C_TWI_MREAD); //Master read mode
39 | //| AT91C_TWI_IADRSZ_1_BYTE); //Slave internal addtess site 1 byte
40 | *AT91C_TWI_CR = AT91C_TWI_START; //Send the start condition slave address and set read mode
41 | while(!(*AT91C_AIC_IPR & (1<<AT91C_ID_TWI))) //TX Complete TWI irq polling
42 | {
43 | timeout++;
44 | if(timeout >= 10000000){
45 | I2C_stop();
46 | return TWI_TXTIMEOUT; //Exit on TXCOMP timeout
47 | }
48 | }
49 | I2C_nack_wait();
50 | if(*AT91C_TWI_SR & AT91C_TWI_NACK){ //Slave exist and send ACK?
51 | I2C_stop();
52 | return TWI_NACK; //Exit on NACK
53 | }
54 | counter = 0;
55 |
56 | while(uiByteCounter != n_byte)
57 | { //Recive
58 | timeout = 0;
59 | while((!(*AT91C_TWI_SR & AT91C_TWI_RXRDY))){ //Wait for data redady
60 | timeout++;
61 | if(timeout>=1000000){
62 | I2C_stop();
63 | return TWI_TXTIMEOUT_READ; //Exit on RXRDY timeout
64 | }
65 | }
66 | data[uiByteCounter++] = AT91C_BASE_TWI->TWI_RHR;//(unsigned char) *AT91C_TWI_RHR; //Read data
67 | uiByteCounter++;
68 | }
69 |
70 | I2C_stop();
71 |
72 | return 0;
73 | }
74 |
75 | static void dummy_irq(void)
76 | {
77 | volatile unsigned int uiStatus = 0;
78 | volatile unsigned int uiDelay = 0;
79 |
80 | // signal start of Interrupt Service Routine
81 | uiStatus = AT91C_BASE_AIC->AIC_IVR;
82 | uiStatus = uiStatus;
83 |
84 |
85 |
86 | // signal end of Interrupt Service Routine
87 | uiStatus = AT91C_BASE_AIC->AIC_EOICR;
88 | uiStatus = uiStatus;
89 | }
90 |
91 | Danke und Gruss
