1 | # Hey Emacs, this is a -*- makefile -*-
2 | #----------------------------------------------------------------------------
3 | # WinAVR Makefile Template written by Eric B. Weddington, Jörg Wunsch, et al.
4 | #
5 | # Released to the Public Domain
6 | #
7 | # Additional material for this makefile was written by:
8 | # Peter Fleury
9 | # Tim Henigan
10 | # Colin O'Flynn
11 | # Reiner Patommel
12 | # Markus Pfaff
13 | # Sander Pool
14 | # Frederik Rouleau
15 | # Carlos Lamas
16 | #
17 | #----------------------------------------------------------------------------
18 | # On command line:
19 | #
20 | # make all = Make software.
21 | #
22 | # make clean = Clean out built project files.
23 | #
24 | # make coff = Convert ELF to AVR COFF.
25 | #
26 | # make extcoff = Convert ELF to AVR Extended COFF.
27 | #
28 | # make program = Download the hex file to the device, using avrdude.
29 | # Please customize the avrdude settings below first!
30 | #
31 | # make debug = Start either simulavr or avarice as specified for debugging,
32 | # with avr-gdb or avr-insight as the front end for debugging.
33 | #
34 | # make filename.s = Just compile filename.c into the assembler code only.
35 | #
36 | # make filename.i = Create a preprocessed source file for use in submitting
37 | # bug reports to the GCC project.
38 | #
39 | # To rebuild project do "make clean" then "make all".
40 | #----------------------------------------------------------------------------
41 |
42 |
43 | # MCU name
44 | MCU = atmega128
45 |
46 |
47 | # Processor frequency.
48 | # This will define a symbol, F_CPU, in all source code files equal to the
49 | # processor frequency. You can then use this symbol in your source code to
50 | # calculate timings. Do NOT tack on a 'UL' at the end, this will be done
51 | # automatically to create a 32-bit value in your source code.
52 | # Typical values are:
53 | # F_CPU = 1000000
54 | # F_CPU = 1843200
55 | # F_CPU = 2000000
56 | # F_CPU = 3686400
57 | # F_CPU = 4000000
58 | # F_CPU = 7372800
59 | # F_CPU = 8000000
60 | # F_CPU = 11059200
61 | # F_CPU = 14745600
62 | # F_CPU = 16000000
63 | # F_CPU = 18432000
64 | # F_CPU = 20000000
65 | F_CPU = 16000000
66 |
67 |
68 | # Output format. (can be srec, ihex, binary)
69 | FORMAT = ihex
70 |
71 |
72 | # Target file name (without extension).
73 | TARGET = main
74 |
75 |
76 | # Object files directory
77 | # To put object files in current directory, use a dot (.), do NOT make
78 | # this an empty or blank macro!
79 | OBJDIR = .
80 |
81 |
82 | # List C source files here. (C dependencies are automatically generated.)
83 | SRC = $(TARGET).c
84 |
85 | # List C++ source files here. (C dependencies are automatically generated.)
86 | CPPSRC =
87 |
88 |
89 | # List Assembler source files here.
90 | # Make them always end in a capital .S. Files ending in a lowercase .s
91 | # will not be considered source files but generated files (assembler
92 | # output from the compiler), and will be deleted upon "make clean"!
93 | # Even though the DOS/Win* filesystem matches both .s and .S the same,
94 | # it will preserve the spelling of the filenames, and gcc itself does
95 | # care about how the name is spelled on its command-line.
96 | ASRC = i2cmaster.S
97 |
98 |
99 | # Optimization level, can be [0, 1, 2, 3, s].
100 | # 0 = turn off optimization. s = optimize for size.
101 | # (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
102 | OPT = s
103 |
104 |
105 | # Debugging format.
106 | # Native formats for AVR-GCC's -g are dwarf-2 [default] or stabs.
107 | # AVR Studio 4.10 requires dwarf-2.
108 | # AVR [Extended] COFF format requires stabs, plus an avr-objcopy run.
109 | DEBUG = dwarf-2
110 |
111 |
112 | # List any extra directories to look for include files here.
113 | # Each directory must be seperated by a space.
114 | # Use forward slashes for directory separators.
115 | # For a directory that has spaces, enclose it in quotes.
116 | EXTRAINCDIRS =
117 |
118 |
119 | # Compiler flag to set the C Standard level.
120 | # c89 = "ANSI" C
121 | # gnu89 = c89 plus GCC extensions
122 | # c99 = ISO C99 standard (not yet fully implemented)
123 | # gnu99 = c99 plus GCC extensions
124 | CSTANDARD = -std=gnu99
125 |
126 |
127 | # Place -D or -U options here for C sources
128 | CDEFS = -DF_CPU=$(F_CPU)UL
129 |
130 |
131 | # Place -D or -U options here for ASM sources
132 | ADEFS = -DF_CPU=$(F_CPU)
133 |
134 |
135 | # Place -D or -U options here for C++ sources
136 | CPPDEFS = -DF_CPU=$(F_CPU)UL
137 | #CPPDEFS += -D__STDC_LIMIT_MACROS
138 | #CPPDEFS += -D__STDC_CONSTANT_MACROS
139 |
140 |
141 |
142 | #---------------- Compiler Options C ----------------
143 | # -g*: generate debugging information
144 | # -O*: optimization level
145 | # -f...: tuning, see GCC manual and avr-libc documentation
146 | # -Wall...: warning level
147 | # -Wa,...: tell GCC to pass this to the assembler.
148 | # -adhlns...: create assembler listing
149 | CFLAGS = -g$(DEBUG)
150 | CFLAGS += $(CDEFS)
151 | CFLAGS += -O$(OPT)
152 | CFLAGS += -funsigned-char
153 | CFLAGS += -funsigned-bitfields
154 | CFLAGS += -fpack-struct
155 | CFLAGS += -fshort-enums
156 | CFLAGS += -Wall
157 | CFLAGS += -Wstrict-prototypes
158 | #CFLAGS += -mshort-calls
159 | #CFLAGS += -fno-unit-at-a-time
160 | #CFLAGS += -Wundef
161 | #CFLAGS += -Wunreachable-code
162 | #CFLAGS += -Wsign-compare
163 | CFLAGS += -Wa,-adhlns=$(<:%.c=$(OBJDIR)/%.lst)
164 | CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
165 | CFLAGS += $(CSTANDARD)
166 |
167 |
168 | #---------------- Compiler Options C++ ----------------
169 | # -g*: generate debugging information
170 | # -O*: optimization level
171 | # -f...: tuning, see GCC manual and avr-libc documentation
172 | # -Wall...: warning level
173 | # -Wa,...: tell GCC to pass this to the assembler.
174 | # -adhlns...: create assembler listing
175 | CPPFLAGS = -g$(DEBUG)
176 | CPPFLAGS += $(CPPDEFS)
177 | CPPFLAGS += -O$(OPT)
178 | CPPFLAGS += -funsigned-char
179 | CPPFLAGS += -funsigned-bitfields
180 | CPPFLAGS += -fpack-struct
181 | CPPFLAGS += -fshort-enums
182 | CPPFLAGS += -fno-exceptions
183 | CPPFLAGS += -Wall
184 | CFLAGS += -Wundef
185 | #CPPFLAGS += -mshort-calls
186 | #CPPFLAGS += -fno-unit-at-a-time
187 | #CPPFLAGS += -Wstrict-prototypes
188 | #CPPFLAGS += -Wunreachable-code
189 | #CPPFLAGS += -Wsign-compare
190 | CPPFLAGS += -Wa,-adhlns=$(<:%.cpp=$(OBJDIR)/%.lst)
191 | CPPFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
192 | #CPPFLAGS += $(CSTANDARD)
193 |
194 |
195 | #---------------- Assembler Options ----------------
196 | # -Wa,...: tell GCC to pass this to the assembler.
197 | # -adhlns: create listing
198 | # -gstabs: have the assembler create line number information; note that
199 | # for use in COFF files, additional information about filenames
200 | # and function names needs to be present in the assembler source
201 | # files -- see avr-libc docs [FIXME: not yet described there]
202 | # -listing-cont-lines: Sets the maximum number of continuation lines of hex
203 | # dump that will be displayed for a given single line of source input.
204 | ASFLAGS = $(ADEFS) -Wa,-adhlns=$(<:%.S=$(OBJDIR)/%.lst),-gstabs,--listing-cont-lines=100
205 |
206 |
207 | #---------------- Library Options ----------------
208 | # Minimalistic printf version
209 | PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
210 |
211 | # Floating point printf version (requires MATH_LIB = -lm below)
212 | PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
213 |
214 | # If this is left blank, then it will use the Standard printf version.
215 | PRINTF_LIB =
216 | #PRINTF_LIB = $(PRINTF_LIB_MIN)
217 | #PRINTF_LIB = $(PRINTF_LIB_FLOAT)
218 |
219 |
220 | # Minimalistic scanf version
221 | SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
222 |
223 | # Floating point + %[ scanf version (requires MATH_LIB = -lm below)
224 | SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
225 |
226 | # If this is left blank, then it will use the Standard scanf version.
227 | SCANF_LIB =
228 | #SCANF_LIB = $(SCANF_LIB_MIN)
229 | #SCANF_LIB = $(SCANF_LIB_FLOAT)
230 |
231 |
232 | MATH_LIB = -lm
233 |
234 |
235 | # List any extra directories to look for libraries here.
236 | # Each directory must be seperated by a space.
237 | # Use forward slashes for directory separators.
238 | # For a directory that has spaces, enclose it in quotes.
239 | EXTRALIBDIRS =
240 |
241 |
242 |
243 | #---------------- External Memory Options ----------------
244 |
245 | # 64 KB of external RAM, starting after internal RAM (ATmega128!),
246 | # used for variables (.data/.bss) and heap (malloc()).
247 | #EXTMEMOPTS = -Wl,-Tdata=0x801100,--defsym=__heap_end=0x80ffff
248 |
249 | # 64 KB of external RAM, starting after internal RAM (ATmega128!),
250 | # only used for heap (malloc()).
251 | #EXTMEMOPTS = -Wl,--section-start,.data=0x801100,--defsym=__heap_end=0x80ffff
252 |
253 | EXTMEMOPTS =
254 |
255 |
256 |
257 | #---------------- Linker Options ----------------
258 | # -Wl,...: tell GCC to pass this to linker.
259 | # -Map: create map file
260 | # --cref: add cross reference to map file
261 | LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
262 | LDFLAGS += $(EXTMEMOPTS)
263 | LDFLAGS += $(patsubst %,-L%,$(EXTRALIBDIRS))
264 | LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
265 | #LDFLAGS += -T linker_script.x
266 |
267 |
268 |
269 | #---------------- Programming Options (avrdude) ----------------
270 |
271 | # Programming hardware: alf avr910 avrisp bascom bsd
272 | # dt006 pavr picoweb pony-stk200 sp12 stk200 stk500
273 | #
274 | # Type: avrdude -c ?
275 | # to get a full listing.
276 | #
277 | AVRDUDE_PROGRAMMER = stk200
278 |
279 | # com1 = serial port. Use lpt1 to connect to parallel port.
280 | AVRDUDE_PORT = lpt1
281 |
282 | AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
283 | #AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
284 |
285 |
286 | # Uncomment the following if you want avrdude's erase cycle counter.
287 | # Note that this counter needs to be initialized first using -Yn,
288 | # see avrdude manual.
289 | #AVRDUDE_ERASE_COUNTER = -y
290 |
291 | # Uncomment the following if you do /not/ wish a verification to be
292 | # performed after programming the device.
293 | #AVRDUDE_NO_VERIFY = -V
294 |
295 | # Increase verbosity level. Please use this when submitting bug
296 | # reports about avrdude. See <http://savannah.nongnu.org/projects/avrdude>
297 | # to submit bug reports.
298 | #AVRDUDE_VERBOSE = -v -v
299 |
300 | AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
301 | AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
302 | AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
303 | AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
304 |
305 |
306 |
307 | #---------------- Debugging Options ----------------
308 |
309 | # For simulavr only - target MCU frequency.
310 | DEBUG_MFREQ = $(F_CPU)
311 |
312 | # Set the DEBUG_UI to either gdb or insight.
313 | # DEBUG_UI = gdb
314 | DEBUG_UI = insight
315 |
316 | # Set the debugging back-end to either avarice, simulavr.
317 | DEBUG_BACKEND = avarice
318 | #DEBUG_BACKEND = simulavr
319 |
320 | # GDB Init Filename.
321 | GDBINIT_FILE = __avr_gdbinit
322 |
323 | # When using avarice settings for the JTAG
324 | JTAG_DEV = /dev/com1
325 |
326 | # Debugging port used to communicate between GDB / avarice / simulavr.
327 | DEBUG_PORT = 4242
328 |
329 | # Debugging host used to communicate between GDB / avarice / simulavr, normally
330 | # just set to localhost unless doing some sort of crazy debugging when
331 | # avarice is running on a different computer.
332 | DEBUG_HOST = localhost
333 |
334 |
335 |
336 | #============================================================================
337 |
338 |
339 | # Define programs and commands.
340 | SHELL = sh
341 | CC = avr-gcc
342 | OBJCOPY = avr-objcopy
343 | OBJDUMP = avr-objdump
344 | SIZE = avr-size
345 | AR = avr-ar rcs
346 | NM = avr-nm
347 | AVRDUDE = avrdude
348 | REMOVE = rm -f
349 | REMOVEDIR = rm -rf
350 | COPY = cp
351 | WINSHELL = cmd
352 |
353 |
354 | # Define Messages
355 | # English
356 | MSG_ERRORS_NONE = Errors: none
357 | MSG_BEGIN = -------- begin --------
358 | MSG_END = -------- end --------
359 | MSG_SIZE_BEFORE = Size before:
360 | MSG_SIZE_AFTER = Size after:
361 | MSG_COFF = Converting to AVR COFF:
362 | MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
363 | MSG_FLASH = Creating load file for Flash:
364 | MSG_EEPROM = Creating load file for EEPROM:
365 | MSG_EXTENDED_LISTING = Creating Extended Listing:
366 | MSG_SYMBOL_TABLE = Creating Symbol Table:
367 | MSG_LINKING = Linking:
368 | MSG_COMPILING = Compiling C:
369 | MSG_COMPILING_CPP = Compiling C++:
370 | MSG_ASSEMBLING = Assembling:
371 | MSG_CLEANING = Cleaning project:
372 | MSG_CREATING_LIBRARY = Creating library:
373 |
374 |
375 |
376 |
377 | # Define all object files.
378 | OBJ = $(SRC:%.c=$(OBJDIR)/%.o) $(CPPSRC:%.cpp=$(OBJDIR)/%.o) $(ASRC:%.S=$(OBJDIR)/%.o)
379 |
380 | # Define all listing files.
381 | LST = $(SRC:%.c=$(OBJDIR)/%.lst) $(CPPSRC:%.cpp=$(OBJDIR)/%.lst) $(ASRC:%.S=$(OBJDIR)/%.lst)
382 |
383 |
384 | # Compiler flags to generate dependency files.
385 | GENDEPFLAGS = -MMD -MP -MF .dep/$(@F).d
386 |
387 |
388 | # Combine all necessary flags and optional flags.
389 | # Add target processor to flags.
390 | ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
391 | ALL_CPPFLAGS = -mmcu=$(MCU) -I. -x c++ $(CPPFLAGS) $(GENDEPFLAGS)
392 | ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
393 |
394 |
395 |
396 |
397 |
398 | # Default target.
399 | all: begin gccversion sizebefore build sizeafter end
400 |
401 | # Change the build target to build a HEX file or a library.
402 | build: elf hex eep lss sym
403 | #build: lib
404 |
405 |
406 | elf: $(TARGET).elf
407 | #eld: $SDR_Trx_AVRStudio.elf
408 | hex: $(TARGET).hex
409 | eep: $(TARGET).eep
410 | lss: $(TARGET).lss
411 | sym: $(TARGET).sym
412 | LIBNAME=lib$(TARGET).a
413 | lib: $(LIBNAME)
414 |
415 |
416 |
417 |
418 | # Eye candy.
419 | # AVR Studio 3.x does not check make's exit code but relies on
420 | # the following magic strings to be generated by the compile job.
421 | begin:
422 | @echo
423 | @echo $(MSG_BEGIN)
424 |
425 | end:
426 | @echo $(MSG_END)
427 | @echo
428 |
429 |
430 | # Display size of file.
431 | HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
432 | ELFSIZE = $(SIZE) --mcu=$(MCU) --format=avr $(TARGET).elf
433 |
434 | sizebefore:
435 | @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); \
436 | 2>/dev/null; echo; fi
437 |
438 | sizeafter:
439 | @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); \
440 | 2>/dev/null; echo; fi
441 |
442 |
443 |
444 | # Display compiler version information.
445 | gccversion :
446 | @$(CC) --version
447 |
448 |
449 |
450 | # Program the device.
451 | program: $(TARGET).hex $(TARGET).eep
452 | $(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
453 |
454 |
455 | # Generate avr-gdb config/init file which does the following:
456 | # define the reset signal, load the target file, connect to target, and set
457 | # a breakpoint at main().
458 | gdb-config:
459 | @$(REMOVE) $(GDBINIT_FILE)
460 | @echo define reset >> $(GDBINIT_FILE)
461 | @echo SIGNAL SIGHUP >> $(GDBINIT_FILE)
462 | @echo end >> $(GDBINIT_FILE)
463 | @echo file $(TARGET).elf >> $(GDBINIT_FILE)
464 | @echo target remote $(DEBUG_HOST):$(DEBUG_PORT) >> $(GDBINIT_FILE)
465 | ifeq ($(DEBUG_BACKEND),simulavr)
466 | @echo load >> $(GDBINIT_FILE)
467 | endif
468 | @echo break main >> $(GDBINIT_FILE)
469 |
470 | debug: gdb-config $(TARGET).elf
471 | ifeq ($(DEBUG_BACKEND), avarice)
472 | @echo Starting AVaRICE - Press enter when "waiting to connect" message displays.
473 | @$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \
474 | $(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT)
475 | @$(WINSHELL) /c pause
476 |
477 | else
478 | @$(WINSHELL) /c start simulavr --gdbserver --device $(MCU) --clock-freq \
479 | $(DEBUG_MFREQ) --port $(DEBUG_PORT)
480 | endif
481 | @$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE)
482 |
483 |
484 |
485 |
486 | # Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
487 | COFFCONVERT = $(OBJCOPY) --debugging
488 | COFFCONVERT += --change-section-address .data-0x800000
489 | COFFCONVERT += --change-section-address .bss-0x800000
490 | COFFCONVERT += --change-section-address .noinit-0x800000
491 | COFFCONVERT += --change-section-address .eeprom-0x810000
492 |
493 |
494 |
495 | coff: $(TARGET).elf
496 | @echo
497 | @echo $(MSG_COFF) $(TARGET).cof
498 | $(COFFCONVERT) -O coff-avr $< $(TARGET).cof
499 |
500 |
501 | extcoff: $(TARGET).elf
502 | @echo
503 | @echo $(MSG_EXTENDED_COFF) $(TARGET).cof
504 | $(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
505 |
506 |
507 |
508 | # Create final output files (.hex, .eep) from ELF output file.
509 | %.hex: %.elf
510 | @echo
511 | @echo $(MSG_FLASH) $@
512 | $(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
513 |
514 | %.eep: %.elf
515 | @echo
516 | @echo $(MSG_EEPROM) $@
517 | -$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
518 | --change-section-lma .eeprom=0 --no-change-warnings -O $(FORMAT) $< $@ || exit 0
519 |
520 | # Create extended listing file from ELF output file.
521 | %.lss: %.elf
522 | @echo
523 | @echo $(MSG_EXTENDED_LISTING) $@
524 | $(OBJDUMP) -h -S $< > $@
525 |
526 | # Create a symbol table from ELF output file.
527 | %.sym: %.elf
528 | @echo
529 | @echo $(MSG_SYMBOL_TABLE) $@
530 | $(NM) -n $< > $@
531 |
532 |
533 |
534 | # Create library from object files.
535 | .SECONDARY : $(TARGET).a
536 | .PRECIOUS : $(OBJ)
537 | %.a: $(OBJ)
538 | @echo
539 | @echo $(MSG_CREATING_LIBRARY) $@
540 | $(AR) $@ $(OBJ)
541 |
542 |
543 | # Link: create ELF output file from object files.
544 | .SECONDARY : $(TARGET).elf
545 | .PRECIOUS : $(OBJ)
546 | %.elf: $(OBJ)
547 | @echo
548 | @echo $(MSG_LINKING) $@
549 | $(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS)
550 |
551 |
552 | # Compile: create object files from C source files.
553 | $(OBJDIR)/%.o : %.c
554 | @echo
555 | @echo $(MSG_COMPILING) $<
556 | $(CC) -c $(ALL_CFLAGS) $< -o $@
557 |
558 |
559 | # Compile: create object files from C++ source files.
560 | $(OBJDIR)/%.o : %.cpp
561 | @echo
562 | @echo $(MSG_COMPILING_CPP) $<
563 | $(CC) -c $(ALL_CPPFLAGS) $< -o $@
564 |
565 |
566 | # Compile: create assembler files from C source files.
567 | %.s : %.c
568 | $(CC) -S $(ALL_CFLAGS) $< -o $@
569 |
570 |
571 | # Compile: create assembler files from C++ source files.
572 | %.s : %.cpp
573 | $(CC) -S $(ALL_CPPFLAGS) $< -o $@
574 |
575 |
576 | # Assemble: create object files from assembler source files.
577 | $(OBJDIR)/%.o : %.S
578 | @echo
579 | @echo $(MSG_ASSEMBLING) $<
580 | $(CC) -c $(ALL_ASFLAGS) $< -o $@
581 |
582 |
583 | # Create preprocessed source for use in sending a bug report.
584 | %.i : %.c
585 | $(CC) -E -mmcu=$(MCU) -I. $(CFLAGS) $< -o $@
586 |
587 |
588 | # Target: clean project.
589 | clean: begin clean_list end
590 |
591 | clean_list :
592 | @echo
593 | @echo $(MSG_CLEANING)
594 | $(REMOVE) $(TARGET).hex
595 | $(REMOVE) $(TARGET).eep
596 | $(REMOVE) $(TARGET).cof
597 | $(REMOVE) $(TARGET).elf
598 | $(REMOVE) $(TARGET).map
599 | $(REMOVE) $(TARGET).sym
600 | $(REMOVE) $(TARGET).lss
601 | $(REMOVE) $(SRC:%.c=$(OBJDIR)/%.o)
602 | $(REMOVE) $(SRC:%.c=$(OBJDIR)/%.lst)
603 | $(REMOVE) $(SRC:.c=.s)
604 | $(REMOVE) $(SRC:.c=.d)
605 | $(REMOVE) $(SRC:.c=.i)
606 | $(REMOVEDIR) .dep
607 |
608 |
609 | # Create object files directory
610 | $(shell mkdir $(OBJDIR) 2>/dev/null)
611 |
612 |
613 | # Include the dependency files.
614 | -include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
615 |
616 |
617 | # Listing of phony targets.
618 | .PHONY : all begin finish end sizebefore sizeafter gccversion \
619 | build elf hex eep lss sym coff extcoff \
620 | clean clean_list program debug gdb-config
