Daten senden mit RS232 zum DE1.
Gast #3662294
Hallo, guten Tag.
Ich kann mit dem Programm unten Daten(Byte) empfangen die dann in das
RAM geschrieben werden. Klappt wunderbar.
Beim Senden wird beanstandet das ich  "speicher_ram" benutze im Process
darunter:
Die Fehlermeldung:
Error (10028): Can't resolve multiple constant drivers for net
"RamAddr[7]" at ram_rs232.vhd(52)
Error (10029): Constant driver at ram_rs232.vhd(43)
"RamAddr[6]" at ram_rs232.vhd(52)
"RamAddr[5]" at ram_rs232.vhd(52)
"RamAddr[4]" at ram_rs232.vhd(52)
"RamAddr[3]" at ram_rs232.vhd(52)
"RamAddr[2]" at ram_rs232.vhd(52)
"RamAddr[1]" at ram_rs232.vhd(52)
"RamAddr[0]" at ram_rs232.vhd(52)
Dieses wird beanstanded nach dem ich es eingebaut hatte:
process(clk)
begin
  if rising_edge(clk) then
    if (c<9000000 ) then
      c <= c+1;
      Tx_Start <= '0';
    else
      c <= 0;
      if (RamAddr < 100) and (sw(1) = '1') then
        RamAddr <= RamAddr + 1;
        TX_Data <= speicher_ram(RamAddr);
        Tx_Start <= '1';
      end if;
    end if;
  end if;
end process;
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity ram_rs232 is
  Generic ( Quarz_Taktfrequenz : integer   := 50000000;
              Baudrate           : integer   := 9600
  port(
    clk    : in  std_logic;
    led_g  : out std_logic_vector(7 downto 0);
    sw     : in std_logic_vector(1 downto 0);
    RXD    : in   STD_LOGIC;
    TXD    : out  STD_LOGIC
end ram_rs232;
architecture Behavioral of ram_rs232 is
Type ram is ARRAY (0 to 127) OF std_logic_vector(7 downto 0);
signal speicher_ram : ram;
signal RamAddr : integer range 0 to 128 := 0;
23
24
signal RX_Data : STD_LOGIC_VECTOR (7 downto 0);
25
signal rxd_sr  : std_logic_vector (3 downto 0) := "1111";
26
signal rxsr    : std_logic_vector (7 downto 0) := "00000000";
27
signal rxbitcnt: integer range 0 to 9 := 9;
28
signal rxcnt   : integer range 0 to (Quarz_Taktfrequenz/Baudrate)-1;
29
30
signal TX_Data  : STD_LOGIC_VECTOR (7 downto 0);
31
signal txstart : std_logic := '0';
32
signal txsr    : std_logic_vector  (9 downto 0) := "1111111111";
33
signal txbitcnt : integer range 0 to 10 := 10;
34
signal txcnt    : integer range 0 to (Quarz_Taktfrequenz/Baudrate)-1;
35
signal TX_Start : STD_LOGIC;
36
37
signal c : integer range 0 to 10000000 := 0;
38
39
begin
40
41
process(clk)
42
begin
43
44
    if sw(0) = '1' then
45
      RamAddr <= 0;
46
    end if;
47
  end if;
48
end process;
49
50
process(clk)
51
begin
52
53
54
      c <= c+1;
55
      Tx_Start <= '0';
56
    else
57
      c <= 0;
58
59
60
61
        Tx_Start <= '1';
62
      end if;
63
    end if;
64
  end if;
65
end process;
66
67
process(clk)
68
begin
69
70
    if RX_Data > "00000000" then
71
72
      speicher_ram(RamAddr) <= RX_Data;
73
      led_g <= RX_Data;
74
    end if;
75
  end if;
76
end process;
77
78
process(clk)
79
begin
80
81
    txstart <= TX_Start;
82
    if (TX_Start='1' and txstart='0') then
83
       txcnt    <= 0;
84
       txbitcnt <= 0;
85
       txsr     <= '1' & TX_Data & '0';
86
    else
87
       if(txcnt<(Quarz_Taktfrequenz/Baudrate)-1) then
88
          txcnt <= txcnt+1;
89
       else
90
          if (txbitcnt<10) then
91
            txcnt    <= 0;
92
            txbitcnt <= txbitcnt+1;
93
            txsr     <= '1' & txsr(txsr'left downto 1);
94
          end if;
95
        end if;
96
     end if;
97
   end if;
98
end process;
99
100
process(clk)
101
begin
102
103
    rxd_sr <= rxd_sr(rxd_sr'left-1 downto 0) & RXD;
104
    if (rxbitcnt<9) then
105
      if(rxcnt<(Quarz_Taktfrequenz/Baudrate)-1) then
106
        rxcnt    <= rxcnt+1;
107
      else
108
        rxcnt    <= 0;
109
        rxbitcnt <= rxbitcnt+1;
110
        rxsr     <= rxd_sr(rxd_sr'left-1) & rxsr(rxsr'left downto 1);
111
      end if;
112
    else
113
      if (rxd_sr(3 downto 2) = "10") then
114
        rxcnt    <= ((Quarz_Taktfrequenz/Baudrate)-1)/2;
115
        rxbitcnt <= 0;
116
      end if;
117
    end if;
118
  end if;
119
end process;
120
121
TXD     <= txsr(0);
122
RX_Data <= rxsr;
123
124
end Behavioral;
Danke.
Gruss
#3662543
Hallo Peter,
ich versuch mal Dir zu beschreiben wo das Problem ist.
Du hast selber geschrieben das erst nach einer Änderung das Problem
aufgetreten ist. Was hast Du geändert?
process(clk)
begin
      c <= c+1;
      Tx_Start <= '0';
    else
      c <= 0;
        Tx_Start <= '1';
      end if;
    end if;
  end if;
end process;
Danach hast Du folgende Fehlermeldung bekommen:
Was sagt diese? Sie sagt in etwa: "da werden mehrere Treiber für ein
Signal verwendet". Und es wird auch noch das Signal angegeben,
"RamAddr".
D.h. das Signal RamAddr wird an mehreren Stellen beschrieben. So etwas
ist erlaubt wenn das in einem "process" gemacht wird, aber nicht wenn
es von mehreren Prozessen versucht wird.
Viele Grüße,
Michael
