AVR ATmega1284p JTAG per Software diasabeln
#3941117
MCUCR Bit 7  JTD
Bits 7 – JTD: JTAG Interface Disable
When this bit is zero, the JTAG interface is enabled if the JTAGEN Fuse is programmed. If this
bit is one, the JTAG interface is disabled. In order to avoid unintentional disabling or enabling of
the JTAG interface, a timed sequence must be followed when changing this bit: The application
software must write this bit to the desired value twice within four cycles to change its value. Note
that this bit must not be altered when using the On-chip Debug system.
OP #3941132
holger schrieb:
> Datenblatt öffnen, auf Suche gehen und JTAG eingeben.
> Dann wirst du die Stelle schon finden;)
witzig, das hatte ich zuerst getan, aber nicht wirklich verstanden was
die da faseln, ein einfach ja hätte gereicht
MCUCR
10.12.2 MCUCR – MCU Control Register
Note: 1. Only available in the Atmel ATmega164PA/324PA/644PA/1284P.
• Bit 6 – BODS: BOD Sleep
The BODS bit must be written to logic one in order to turn off BOD during sleep, see Table 10-1 on page 42.
Writing to the BODS bit is controlled by a timed sequence and an enable bit, BODSE in MCUCR. To disable
BOD in relevant sleep modes, both BODS and BODSE must first be set to one. Then, to set the BODS bit,
BODS must be set to one and BODSE must be set to zero within four clock cycles.
The BODS bit is active three clock cycles after it is set. A sleep instruction must be executed while BODS is
active in order to turn off the BOD for the actual sleep mode. The BODS bit is automatically cleared after three
clock cycles.
• Bit 5 – BODSE: BOD Sleep Enable
kein Wort über Bit 7
Bit 7 ist JTD
und
10.11.7 On-chip Debug System
If the On-chip debug system is enabled by the OCDEN Fuse and the chip enters sleep mode, the main clock
source is enabled, and hence, always consumes power. In the deeper sleep modes, this will contribute
significantly to the total current consumption.
There are three alternative ways to disable the OCD system:
. Disable the OCDEN Fuse
. Disable the JTAGEN Fuse
. Write one to the JTD bit in MCUCR
also brauche ich nur das Bit setzen?
Das ist die dünnste Erklärung die ich in den Atmel Blättern je sah,
deswegen frage ich ja hier.
und der Namenswechsel von JTAG zu OCD war auch nicht hilfreicher zum
Verständnis.
Gast #3941138
Doch, musst nur an der richtigen Stelle schauen (nämlich da wos
dokumentiert ist):
When this bit is zero, the JTAG interface is enabled if the JTAGEN Fuse is programmed. If this bit is one, the
JTAG interface is disabled. In order to avoid unintentional disabling or enabling of the JTAG interface, a timed
sequence must be followed when changing this bit: The application software must write this bit to the desired
value twice within four cycles to change its value. Note that this bit must not be altered when using the On-chip
Debug system.
HTH
OP #3941153
Detlef Kunz schrieb:
> Beitrag "AVR ATmega1284p JTAG per Software diasabeln"
hatte ich abgeschickt und nicht wiedergefunden, dachte mein Browser
spinnt.
> is programmed.
ich verstehe es nicht,
normalerweise schalte ich das JTAG immer per ISP aus, entweder ich habe
es vergessen oder den Chip verfused
angenommen JTAG ist per ISP enabled, dann sollte das helfen, tuts aber
nicht
  MCUCR|=(1<<JTD);
  DDR_KWEISS |= (1<<KWEISS);
  KWEISS_OFF;
kalt weisse LED leuchtet prächtig
angenommen JTAG ist per ISP disabled,
warum leuchtet die immer?
und das betrifft alle Pins TDI TDO TMS und TCK eben alle die mit OCD
oder JTAG zu tun haben.
#3941161
WICHTIG!!!
Du must zweimal hindereinander das Bit setzen, am besten in Assembler
und Interrupts ausgeschaltet dabei, damit der Vorgang nicht unterbrochen
wird.
in r16,MCUCR
ori r16,0x80
cli
out MCUCR,r16
out MCUCR,r16
sei
Gast #3941164
> nicht
Nein, natürlich geht das so nicht. Du musst die Doku schon bis zum Ende
lesen, nicht nur die erste Hälfte vom ersten Satz.
