1 | E:\NeuOrga\Programmieren\c_cpp\github_os\input\tools>REM
2 |
3 | E:\NeuOrga\Programmieren\c_cpp\github_os\input\tools>REM
4 |
5 | E:\NeuOrga\Programmieren\c_cpp\github_os\input\tools>REM
6 |
7 | E:\NeuOrga\Programmieren\c_cpp\github_os\input\tools>REM change the working dir
8 |
9 |
10 | E:\NeuOrga\Programmieren\c_cpp\github_os\input\tools>SET OPENOCD_DIR="E:\NeuOrga
11 | \Programmieren\c_cpp\github_os\input\tools\misc\openocd-0.10.0"
12 |
13 | E:\NeuOrga\Programmieren\c_cpp\github_os\input\tools>SET WRK_DIR="D:\Programm\GN
14 | U Tools ARM Embedded\4.9 2015q1\bin"
15 |
16 | E:\NeuOrga\Programmieren\c_cpp\github_os\input\tools>SET SRC_DIR="E:\NeuOrga\Pro
17 | grammieren\c_cpp\github_os\output\VERSION_ARM"
18 |
19 | E:\NeuOrga\Programmieren\c_cpp\github_os\input\tools>cd /D "E:\NeuOrga\Programmi
20 | eren\c_cpp\github_os\input\tools\misc\openocd-0.10.0"
21 |
22 | E:\NeuOrga\Programmieren\c_cpp\github_os\input\tools\misc\openocd-0.10.0>"E:\Neu
23 | Orga\Programmieren\c_cpp\github_os\input\tools\misc\openocd-0.10.0"\bin-x64\open
24 | ocd.exe -f "E:\NeuOrga\Programmieren\c_cpp\github_os\input\tools\misc\openocd-0.
25 | 10.0"\scripts\board\stm32f4discovery.cfg -c "gdb_port 49624" -c "telnet_port 496
26 | 23" -c init -c "reset init"
27 | Open On-Chip Debugger 0.10.0
28 | Licensed under GNU GPL v2
29 | For bug reports, read
30 | http://openocd.org/doc/doxygen/bugs.html
31 | Info : The selected transport took over low-level target control. The results mi
32 | ght differ compared to plain JTAG/SWD
33 | adapter speed: 2000 kHz
34 | adapter_nsrst_delay: 100
35 | none separate
36 | srst_only separate srst_nogate srst_open_drain connect_deassert_srst
37 | Info : Unable to match requested speed 2000 kHz, using 1800 kHz
38 | Info : Unable to match requested speed 2000 kHz, using 1800 kHz
39 | Info : clock speed 1800 kHz
40 | Info : STLINK v2 JTAG v29 API v2 SWIM v0 VID 0x0483 PID 0x3748
41 | Info : using stlink api v2
42 | Info : Target voltage: 2.909307
43 | Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
44 | Info : Unable to match requested speed 2000 kHz, using 1800 kHz
45 | Info : Unable to match requested speed 2000 kHz, using 1800 kHz
46 | adapter speed: 1800 kHz
47 | target halted due to debug-request, current mode: Thread
48 | xPSR: 00000000 pc: 0x08006468 msp: 0x2000304c
49 | Info : Unable to match requested speed 8000 kHz, using 4000 kHz
50 | Info : Unable to match requested speed 8000 kHz, using 4000 kHz
51 | adapter speed: 4000 kHz
52 | Batchvorgang abbrechen (J/N)? N
53 |
54 | E:\NeuOrga\Programmieren\c_cpp\github_os\input\tools\misc\openocd-0.10.0>netstat
55 | -an
56 |
57 | Aktive Verbindungen
58 |
59 | Proto Lokale Adresse Remoteadresse Status
60 | TCP 0.0.0.0:135 0.0.0.0:0 ABHÖREN
61 | TCP 0.0.0.0:445 0.0.0.0:0 ABHÖREN
62 | TCP 0.0.0.0:17500 0.0.0.0:0 ABHÖREN
63 | TCP 0.0.0.0:23443 0.0.0.0:0 ABHÖREN
64 | TCP 0.0.0.0:27036 0.0.0.0:0 ABHÖREN
65 | TCP 0.0.0.0:49152 0.0.0.0:0 ABHÖREN
66 | TCP 0.0.0.0:49153 0.0.0.0:0 ABHÖREN
67 | TCP 0.0.0.0:49154 0.0.0.0:0 ABHÖREN
68 | TCP 0.0.0.0:49155 0.0.0.0:0 ABHÖREN
69 | TCP 0.0.0.0:49156 0.0.0.0:0 ABHÖREN
70 | TCP 0.0.0.0:49227 0.0.0.0:0 ABHÖREN
71 | TCP 127.0.0.1:843 0.0.0.0:0 ABHÖREN
72 | TCP 127.0.0.1:3213 0.0.0.0:0 ABHÖREN
73 | TCP 127.0.0.1:3215 0.0.0.0:0 ABHÖREN
74 | TCP 127.0.0.1:3216 0.0.0.0:0 ABHÖREN
75 | TCP 127.0.0.1:3217 0.0.0.0:0 ABHÖREN
76 | TCP 127.0.0.1:17600 0.0.0.0:0 ABHÖREN
77 | TCP 127.0.0.1:27060 0.0.0.0:0 ABHÖREN
78 | TCP 127.0.0.1:49165 127.0.0.1:49166 HERGESTELLT
79 | TCP 127.0.0.1:49166 127.0.0.1:49165 HERGESTELLT
80 | TCP 127.0.0.1:49170 127.0.0.1:49171 HERGESTELLT
81 | TCP 127.0.0.1:49171 127.0.0.1:49170 HERGESTELLT
82 | TCP 127.0.0.1:49182 127.0.0.1:49183 HERGESTELLT
83 | TCP 127.0.0.1:49183 127.0.0.1:49182 HERGESTELLT
84 | TCP 127.0.0.1:49242 127.0.0.1:65001 HERGESTELLT
85 | TCP 127.0.0.1:49293 0.0.0.0:0 ABHÖREN
86 | TCP 127.0.0.1:49302 127.0.0.1:49303 HERGESTELLT
87 | TCP 127.0.0.1:49303 127.0.0.1:49302 HERGESTELLT
88 | TCP 127.0.0.1:49311 127.0.0.1:49312 HERGESTELLT
89 | TCP 127.0.0.1:49312 127.0.0.1:49311 HERGESTELLT
90 | TCP 127.0.0.1:49315 127.0.0.1:49316 HERGESTELLT
91 | TCP 127.0.0.1:49316 127.0.0.1:49315 HERGESTELLT
92 | TCP 127.0.0.1:49341 127.0.0.1:49342 HERGESTELLT
93 | TCP 127.0.0.1:49342 127.0.0.1:49341 HERGESTELLT
94 | TCP 127.0.0.1:50060 127.0.0.1:50061 HERGESTELLT
95 | TCP 127.0.0.1:50061 127.0.0.1:50060 HERGESTELLT
96 | TCP 127.0.0.1:50066 127.0.0.1:50067 HERGESTELLT
97 | TCP 127.0.0.1:50067 127.0.0.1:50066 HERGESTELLT
98 | TCP 127.0.0.1:65000 0.0.0.0:0 ABHÖREN
99 | TCP 127.0.0.1:65001 0.0.0.0:0 ABHÖREN
100 | TCP 127.0.0.1:65001 127.0.0.1:49242 HERGESTELLT
101 | TCP 192.168.0.213:139 0.0.0.0:0 ABHÖREN
102 | TCP 192.168.0.213:49254 162.254.196.83:443 HERGESTELLT
103 | TCP 192.168.0.213:49265 159.153.191.240:443 HERGESTELLT
104 | TCP 192.168.0.213:49266 159.153.191.239:443 HERGESTELLT
105 | TCP 192.168.0.213:49307 54.164.231.203:443 SCHLIESSEN_WARTEN
106 | TCP 192.168.0.213:49310 162.125.18.133:443 HERGESTELLT
107 | TCP 192.168.0.213:49313 162.125.18.133:443 HERGESTELLT
108 | TCP 192.168.0.213:49334 54.167.12.94:80 HERGESTELLT
109 | TCP 192.168.0.213:50071 162.125.33.7:443 SCHLIESSEN_WARTEN
110 | TCP 192.168.0.213:50073 40.67.251.134:443 HERGESTELLT
111 | TCP 192.168.0.213:50074 54.148.54.224:443 HERGESTELLT
112 | TCP 192.168.0.213:50076 13.107.3.128:443 HERGESTELLT
113 | TCP 192.168.56.1:139 0.0.0.0:0 ABHÖREN
114 | TCP [::]:135 [::]:0 ABHÖREN
115 | TCP [::]:445 [::]:0 ABHÖREN
116 | TCP [::]:17500 [::]:0 ABHÖREN
117 | TCP [::]:49152 [::]:0 ABHÖREN
118 | TCP [::]:49153 [::]:0 ABHÖREN
119 | TCP [::]:49154 [::]:0 ABHÖREN
120 | TCP [::]:49155 [::]:0 ABHÖREN
121 | TCP [::]:49156 [::]:0 ABHÖREN
122 | TCP [::]:49227 [::]:0 ABHÖREN
123 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:49300 [2620:100:6022:3::a27d:4
124 | 203]:443 SCHLIESSEN_WARTEN
125 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:49301 [2620:100:6022:3::a27d:4
126 | 203]:443 SCHLIESSEN_WARTEN
127 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:49309 [2620:100:6022:7::a27d:4
128 | 207]:443 SCHLIESSEN_WARTEN
129 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:49314 [2620:100:6022:3::a27d:4
130 | 203]:443 SCHLIESSEN_WARTEN
131 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:49344 [2a00:1450:400c:c0a::6c]
132 | :993 HERGESTELLT
133 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:49345 [2a00:1450:400c:c0a::6c]
134 | :993 HERGESTELLT
135 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:50035 [2a00:1450:4013:c01::6d]
136 | :993 HERGESTELLT
137 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:50047 [2a00:1450:4013:c01::6d]
138 | :993 HERGESTELLT
139 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:50048 [2a00:1450:4013:c01::6d]
140 | :993 HERGESTELLT
141 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:50050 [2a00:1450:4013:c01::6d]
142 | :993 HERGESTELLT
143 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:50055 [2a00:1450:4013:c00::69]
144 | :443 WARTEND
145 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:50056 [2a02:26f0:ee::58dd:74f9
146 | ]:80 WARTEND
147 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:50059 [2a00:1450:4001:806::200
148 | a]:443 WARTEND
149 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:50062 [2a00:1450:4001:80b::200
150 | e]:80 WARTEND
151 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:50063 [2a00:1450:4001:80b::200
152 | e]:443 WARTEND
153 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:50064 [2a00:1450:4001:80b::200
154 | 2]:443 WARTEND
155 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:50078 [2a00:1450:4001:806::200
156 | 2]:443 HERGESTELLT
157 | TCP [2a02:908:1c1:2b60:fdf2:ba65:2717:40ea]:50079 [2a00:1450:4001:80b::200
158 | e]:80 HERGESTELLT
159 | UDP 0.0.0.0:5355 *:*
160 | UDP 0.0.0.0:17500 *:*
161 | UDP 0.0.0.0:17500 *:*
162 | UDP 0.0.0.0:27036 *:*
163 | UDP 0.0.0.0:58406 *:*
164 | UDP 0.0.0.0:59391 *:*
165 | UDP 0.0.0.0:59475 *:*
166 | UDP 127.0.0.1:1900 *:*
167 | UDP 127.0.0.1:48201 *:*
168 | UDP 127.0.0.1:53496 *:*
169 | UDP 127.0.0.1:54357 *:*
170 | UDP 127.0.0.1:54358 *:*
171 | UDP 127.0.0.1:54566 *:*
172 | UDP 127.0.0.1:56593 *:*
173 | UDP 127.0.0.1:56627 *:*
174 | UDP 127.0.0.1:56720 *:*
175 | UDP 127.0.0.1:56721 *:*
176 | UDP 127.0.0.1:61298 *:*
177 | UDP 127.0.0.1:63377 *:*
178 | UDP 127.0.0.1:65000 *:*
179 | UDP 192.168.0.213:137 *:*
180 | UDP 192.168.0.213:138 *:*
181 | UDP 192.168.0.213:1900 *:*
182 | UDP 192.168.0.213:5353 *:*
183 | UDP 192.168.56.1:137 *:*
184 | UDP 192.168.56.1:138 *:*
185 | UDP 192.168.56.1:1900 *:*
186 | UDP 192.168.56.1:5353 *:*
187 | UDP [::]:5355 *:*
188 | UDP [::]:27036 *:*
189 | UDP [::]:59392 *:*
190 | UDP [::1]:1900 *:*
191 | UDP [::1]:5353 *:*
192 | UDP [::1]:56626 *:*
193 | UDP [fe80::5947:e917:7fca:1997%6]:1900 *:*
194 | UDP [fe80::f8b2:34a6:3328:3587%3]:1900 *:*
195 |
196 | E:\NeuOrga\Programmieren\c_cpp\github_os\input\tools\misc\openocd-0.10.0>cd /D "
197 | D:\Programm\GNU Tools ARM Embedded\4.9 2015q1\bin"
198 |
199 | D:\Programm\GNU Tools ARM Embedded\4.9 2015q1\bin>"D:\Programm\GNU Tools ARM Emb
200 | edded\4.9 2015q1\bin"\arm-none-eabi-gdb.exe "E:\NeuOrga\Programmieren\c_cpp\gith
201 | ub_os\output\VERSION_ARM"\operating_system.elf
202 | GNU gdb (GNU Tools for ARM Embedded Processors) 7.8.0.20150304-cvs
203 | Copyright (C) 2014 Free Software Foundation, Inc.
204 | License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
205 | This is free software: you are free to change and redistribute it.
206 | There is NO WARRANTY, to the extent permitted by law. Type "show copying"
207 | and "show warranty" for details.
208 | This GDB was configured as "--host=i686-w64-mingw32 --target=arm-none-eabi".
209 | Type "show configuration" for configuration details.
210 | For bug reporting instructions, please see:
211 | <http://www.gnu.org/software/gdb/bugs/>.
212 | Find the GDB manual and other documentation resources online at:
213 | <http://www.gnu.org/software/gdb/documentation/>.
214 | For help, type "help".
215 | Type "apropos word" to search for commands related to "word"...
216 | Reading symbols from E:\NeuOrga\Programmieren\c_cpp\github_os\output\VERSION_ARM
217 | \operating_system.elf...(no debugging symbols found)...done.
218 | (gdb) target remote localhost:3333
219 | localhost:3333: Es konnte keine Verbindung hergestellt werden, da der Zielcomput
220 | er die Verbindung verweigerte.
221 | (gdb)
