LVDS Clock at Artix7?.
OP #6036566
Hello,
I have a 500 MHz oscillator, which is on a clock divider AD9508
connected. From the clock divider several bars go out to ADC, DAC,
but also to the FPGA .
The clock divider is configured for output to the FPGA :
Register 0x27 to 0x2C, in the datasheet
on page 38.
0x27: x "04"
0x28: x "00"
0x29: x "00"
0x2A: x "00"
0x2B: x "14"
0x2C: x "00"
Concrete:
x "04" in register 0x27 is divisor -1. It is divided by 5.
The 500 MHz will become 100 MHz.
The registers 0x28 ... 0x2A make are only continue for divisor and
phase.
x "14" b "00010100" in register 0x2B says:
Divider 3 power-down: 0
0 = divider 3 is synchronized during output sync (default): 0
These bits determine the phase of the OUT3 driver: 01 = noninverting
These bits determine the OUT3 driver mode: 010 = LVDS 1 × 3.5 mA
(default)
Reserved: 0b = default
This is connected to the Artix7 as LVDS and as in the appendix. 100
Ohm between the lines and then per line 100 nF to the FPGA .
I have that from the ADC data sheet:
Figure 90 Page 33.
In the FPGA I have the following:
In XDC:
## Clock signal Sch name = CLK_AD9508_OUT3
set_property PACKAGE_PIN G4 [get_ports CLK_AD9508_OUT3p]
set_property PACKAGE_PIN F4 [get_ports CLK_AD9508_OUT3n]
set_property IOSTANDARD DIFF_SSTL15 [get_ports CLK_AD9508_OUT3p]
set_property IOSTANDARD DIFF_SSTL15 [get_ports CLK_AD9508_OUT3n]
There is also the first question:
I used DIFF_SSTL15 because I found no LVDS or anything like that
have. What should I use at this point?
In VHDL I have this:
IBUFGDS_inst : IBUFGDS
generic map (
DIFF_TERM => FALSE, -- Differential Termination
IBUF_LOW_PWR => FALSE, -- Low power (TRUE) vs. performance (FALSE)
setting for referenced I/O standards
IOSTANDARD => "DIFF_SSTL15")
port map (
O => CLK_AD9508_OUT3, -- Clock buffer output
I => CLK_AD9508_OUT3p, -- Diff_p clock buffer input (connect directly to
top-level port)
IB => CLK_AD9508_OUT3n -- Diff_n clock buffer input (connect directly to
top-level port)
So far, I use the clock in the FPGA only for a counter of an LED
flashes. And there's the problem: sometimes it stops flashing
or has a short break. When I measure the beat with the Oszi, so
Probe to the 100 ohm resistor, then I see beautiful 100 MHz without
Dropouts with an amplitude of almost 500 mV and a DC offset of
about 1.2 V. Otherwise, the voltages also fit, the FPGA gets 1.8 V, 1.0
V and 3.3 V.
Am I doing something grossly wrong? A little rum grinding would not be a
problem. to
I also configure the clock divider to CMOS and use only one
Lead for the CMOS clock.
thanks
iosman
#6036737
I have a dejavu: Beitrag "LVDS Clock am Artix7"
The conclusion was, that the input of the Xilinx FPGA and the input of
your ADC are different. You can not apply the ADC application note to
the FPGA!
In short, the ADC input is self-biasing and therefor you can AC couple
without additional components. For the FPGA either replace the the 100
nF capacitor with a 0 Ohm resistor or add a proper biasing network to
the FPGA input.
#6037456
So, now i can look at my code:
The Registers:
x"01",x"00",x"00",x"00",x"14",x"00", -- 21 to 26: AD9508 OUT0 to DAC
x"09",x"00",x"00",x"00",x"1E",x"A0", -- 27 to 32: AD9508 OUT1
unused/disabled
x"13",x"00",x"00",x"00",x"14",x"00", -- 33 to 38: AD9508 OUT2 to ADC
x"13",x"00",x"00",x"00",x"14",x"00", -- 39 to 44: AD9508 OUT3 to FPGA
So ... i disabled OUT1 because it is unused. Divide by 2 gives 250 MHz
to the AD9747 DAC, for the FPGA and the ADC i use divide by 20 for 25
MHz.
To configure the Clockdivider AD9508 i use a carefully crafted el'cheapo
SPIish interface:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity AD9508_SPI is Port(
  clk: in std_logic;
  start: in std_logic;
  data: in std_logic_vector(8*6*4-1 downto 0);
  SCLK: out std_logic;
  SDIO: out std_logic;
  SDO: in std_logic;
  nCS: out std_logic;
  nRESET: out std_logic;
  nSYNC: out std_logic);
end AD9508_SPI;
architecture Behavioral of AD9508_SPI is
type s_control_type is(s_wait, s_init, s_send_conf);
signal s_control: s_control_type:= s_wait;
signal INIT: std_logic:='0';
signal INSTHEADER: std_logic_vector(15 downto 0):=x"602C";
23
signal SENDREG: std_logic_vector(0 to 16+8*6*4-1):=(others => '0');
24
signal counter: unsigned(10 downto 0):=(others => '0');
25
signal waitcounter: unsigned(19 downto 0):=(others => '0');
26
signal adr: integer range 0 to 207:=0;
27
28
begin
29
30
nRESET <= '1';
31
nSYNC <= '1';
32
process begin
33
  wait until rising_edge(clk);
34
  if    s_control = s_wait then
35
    waitcounter <= waitcounter +1;
36
    if (INIT = '0' and waitcounter = 2**10) or (start = '1' and INIT = '1') then
37
      counter <= (others => '0');
38
      SENDREG <= INSTHEADER & data;
39
      s_control <= s_send_conf;
40
    end if;
41
  elsif s_control = s_send_conf then
42
    if counter < 1663 then
43
      counter <= counter +1;
44
    end if;
45
    if counter = 1663 then
46
      s_control <= s_wait;
47
      INIT <= '1';
48
    end if;
49
  end if;
50
end process;
51
adr <= to_integer(counter(10 downto 3));
52
SDIO <= SENDREG(adr);
53
SCLK <= counter(2) when counter < 1663 else '1';
54
nCS <= '0' when s_control = s_send_conf else '1';
55
56
end Behavioral;
clk: in std_logic; that is a 100 MHz Clock in the FPGA
start: in std_logic; is a start signal, it starts the SPI action
data: in std_logic_vector(8*6*4-1 downto 0); are the 6*4 Bytes,
Registers 21 to 44.
### Schematic ###
The ADC Clock input is self biased at the ADC I use. But i don't know
which ADC you are using, so it may depend.
The FPGA Inputs are not biased internally. But the AD9508 delivers a
LVDS Signal with a nice DC offset. So just connect it to the FPGA
without capacitors.
I use an external 100 Ohm Termination becaus i supply the FPGA Bank with
1.8 V, so i can not use the internal Termination. [citation needed *]
In my VHDL i use:
generic map (
IBUF_LOW_PWR => FALSE, -- Low power (TRUE) vs. performance (FALSE) setting for referenced I/O standards
IOSTANDARD => "LVDS_25")
port map (
I => CLK_AD9508_OUT3p, -- Diff_p clock buffer input (connect directly to top-level port)
IB => CLK_AD9508_OUT3n -- Diff_n clock buffer input (connect directly to top-level port)
And in the .xdc File:
set_property IOSTANDARD LVDS_25 [get_ports CLK_AD9508_OUT3p]
set_property IOSTANDARD LVDS_25 [get_ports CLK_AD9508_OUT3n]
* https://www.xilinx.com/support/answers/43989.html there are two flow
charts, one (the upper) for the HP Banks, and one, the lower, for the HR
banks. I use an HR Bank at the Spartan7 with 1.8 V. So i cannot use the
internal Termination. So if you use an HR bank you either must supply
2.5 V or use external termination.
OP #6041472
Sunny L. schrieb:
> Hello,
> https://engineoilforbikes.com https://bestcordlessvacuumx.com
> V and 3.3 V.
> thanks
> iosman
thanks for the information.
