Hallo
Gemeinde
Mein Spicemodel für die 6AS7GT.
Bringt eine Fehlermeldung
ich glaube es ist fehlerhaft
Hätte jemand eine Funktionierende Datei?
Oder weiß Jemand von euch
an welcher "schraube" zu drehen ist, wenn Spice als Fehlermeldung: "Lib
nicht aufrufbar "" bringt?
Vielen Dank vorab..
Jens 2
Klaus R. schrieb:> Zeig doch mal was Du hast. ASC, Lib, usw..> mfg Klaus
zum 1. wo , ich nicht sicherbin, ob beide teile zusammen gehören
oila
.SUBCKT 6AS7_6080 A G K
XV1 A G K TRIODENH
+PARAMS: LIP= 1 LIF= 0.01 RAF= 0.0058 RAS= 0.7 CDO= 0
+ RAP= 0.035 ERP= 1.5
+ MU0= 2.05 MUR= 0.0017 EMC= 0.0005
+ GCO= 0 GCF= 0
+ CGA=1.10E-11 CGK=8.00E-12 CAK=3.00E-12
.ENDS
Report Post Reply With Quote Multi-Quote This Message
Old 10th December 2011, 09:12 AM #3
bpetcavage is offline bpetcavage
diyAudio Member
Thanks!
Old 11th December 2011, 10:23 PM #4
yagoolar is offline yagoolar Poland
diyAudio Member
yagoolar's Avatar
6AS7 Model
That is no heater model.
"Jeśli nie wiesz dokąd zmierzasz, każda droga jest równie dobra"
Old 26th December 2011, 07:08 PM #5
kees52 is offline kees52 Netherlands
diyAudio Member
I have tryed this for multisim, but no id did not work, only faults like
refdes U3 .
I have almost not a model working in these simulator, why I don,t now
but it is just buggy
of its own, and the pcb maker ultiboard is a lot more worse, a lot of
components ware wrong, but it works very easy that is what I like.
But maybe here somebody know why it gives that errrors,..
regards
Old 26th December 2011, 07:58 PM #6
Aiace is offline Aiace Italy
diyAudio Member
I have multisim too and I use this:
* Filename: SV6AS7.inc V1 25/8/97
* Simulator: PSpice
* Device type: Power triode
* Device model: Svetlana 6AS7
* Author: Duncan Munro
* Date: 25/8/97
* Copyright: (C)1997-2000 Duncan Amplification
* The following parameters are not modelled:
* (1) Heater is not modelled.
* (2) Grid current is not modelled.
* Please note that this model is provided "as is" and
* no warranty is provided in respect of its suitability
* for any application.
* This model is provided for educational and non-profit use.
* Email queries to postmaster@duncanamps.com
* Pins A Anode
* G Grid
* K Cathode
.SUBCKT 6AS7 A G K
* Calculate reduction in mu at large negative
* grid voltages
Emu mu 0 VALUE={PWRS(V(G,K),0.88)}
* Emission reduction due to low Va
Eel el 0 VALUE={ATAN(LIMIT(V(A,K),0,1E6)/10)}
* Calculate change in shape with reducing grid voltage
Eshape shape 0 VALUE={(220+V(G,K))/220}
Egs gs 0 VALUE={LIMIT(V(A,K)+V(mu)*2.8,0,1E6)}
Egs2 gs2 0 VALUE={PWRS(V(gs)*V(shape),1.5)*410E-6}
Ecath cc 0 VALUE={V(gs2)*V(el)}
* Calculate anode current
Ga A K VALUE={V(cc)}
* Capacitances
Cgk G K 8p
Cga A G 11p
Cak A K 3p
.ENDS
und hir zum 2. welches dicht geöffnet werden kann
* Generic triode model: 6080
* Copyright 2003--2006 by Ayumi Nakabayashi, All rights reserved.
* Version 3.01, Generated on Wed Mar 22 17:22:49 2006
.SUBCKT 6080 A G K
BGG GG 0 V=V(G,K)+1
BEP EP 0 V=URAMP(V(A,K))+1e-10
BEG EG 0 V=URAMP(V(G,K))+1e-10
BM1 M1 0 V=(0.37781455*(URAMP(V(EP)-1e-10)+1e-10))**-1.6383781
BM2 M2 0 V=(0.47795388*(URAMP(V(GG)+V(EP)/1.3817523)+1e-10))**3.1383781
BP P 0 V=0.0026607218*(URAMP(V(GG)+V(EP)/2.8909741)+1e-10)**1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0030745874*V(M1)*V(M2)
BIG IG 0 V=0.0013303609*V(EG)**1.5*(V(EG)/(V(EP)+V(EG))*1.2+0.4)
BIAK A K
I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0028241574*V(EP)**1.5)))+1e-10*V(A,K)
BIGK G K I=V(IG)
* CAPS
CGA G A 8.6p
CGK G K 6p
CAK A K 2.2p
.ENDS
beide von dieser webpage :
https://www.diyaudio.com/forums/tubes-valves/201644-6as7-model.htmlhttps://www.diyaudio.com/forums/tubes-valves/309328-tube-ltspice-model.html
Vieleicht kannst du es Integrieren??
das 1. hab ich 2x versucht und das 2. hab ich 9x versucht zu integrieren
und alles wieder gelöscht
best wishes Jens2
hinz schrieb:> hinz schrieb:>> Klar, dass das nicht klappt. Du willst das Modell einer Diode für>> eine>> Heptode verwenden.>> s/Diode/Triode
Da war der TO sich doch selbst nicht einig. Thread Titel 6SA7GT ..das
ist ein Pentagridconverter, im Text 6AS7GT das ist ne Doppeltriode 6080
oder 6N13S, und dann wurde es ganz hübsch mit der 6ASGT ..die überhaupt
nicht existiert.
Pille
hinz schrieb:> Er scheint recht verwirrt zu sein.
Vielleicht hilft das zur Klärung:
> Note: no 6AS7GT was ever registered. The 6AS7G was registered in January 1946
and
> the first tubular envelope variant, the 6AS7GA, was registered in 1955.> Almoste certainly this tube was created due to a mistyping, 6AS7GT instead> of the well known converter 6SA7GT.
(https://www.radiomuseum.org/tubes/tube_6as7gt.html)
Mohandes H. schrieb:> hinz schrieb:>> Er scheint recht verwirrt zu sein.>> Vielleicht hilft das zur Klärung:>>> Note: no 6AS7GT was ever registered. The 6AS7G was registered in January 1946> and>> the first tubular envelope variant, the 6AS7GA, was registered in 1955.>> Almoste certainly this tube was created due to a mistyping, 6AS7GT instead>> of the well known converter 6SA7GT.>> (https://www.radiomuseum.org/tubes/tube_6as7gt.html)
Moin
Wie gesagt , jungs
bei mir geht keines dieser subcircuits , und im Radiomuseum bin ich
nicht angemeldet..
Dh ,nun
das keiner ein spice Modell hatt,
und keiner ein richtiges Sucircuit weiss, stimmt das?
Die 6S19P sieht ziemich ähnlich aus am Datenblatt , wie die 6SA7Gt
oder wass meint Ihr dazu?, ich verweise hier auf
:https://frank.pocnet.net/sheets66.html , die Seite ist mir lieber für
Datenblätter ,
lg Jens2
Jens2 schrieb:> Mein Spicemodel für die 6AS7GT.
Die internationale Usergroup für LTspice hat folgenden Link.
https://groups.io/g/LTspice
Aber eine 6SA7GT ist dort auch nicht zu finden. Melde Dich dort an und
stöbere dort herum. Es gibt dort einige Modelle für Röhren.
mfg Klaus
Klaus R. schrieb:> Jens2 schrieb:>> Mein Spicemodel für die 6AS7GT.>> Die internationale Usergroup für LTspice hat folgenden Link.>> https://groups.io/g/LTspice>> Aber eine 6SA7GT ist dort auch nicht zu finden. Melde Dich dort an und> stöbere dort herum. Es gibt dort einige Modelle für Röhren.> mfg Klaus
Ah , das ist gut , das es sowas gibt ,
ich Danke dir Vielmals..
mfg Jensi2
Carlo schrieb:> Tool zum spice-Modell erstellen> bei www.trioda.com/>> http://www.trioda.com/tools/tube.html> http://www.trioda.com/tools/triode.html> https://www.trioda.com/index.php/pl/narzedzia/2131-program-wspomagajacy-dobor-punktu-pracy-triody>> und der> Optimizer> der Spice-Modell ausgibt> https://www.trioda.com/tools/optimizer/optimizer.htm>> Interessant wenn es mit bestehenden Modellen verglichen werden könnte> ....?!
Das ist egal , da mann für ein Spiceröhrenmodel, die kennlinien in eine
Formel Packen muss , und es ist aber so das verschidene
kennliniensteigungen im datenblatt sind ,,
zudem hatt ne Röhre 20+- % tolleranz , und Ausschlaggebend ist der
Arbeitspunkt , an dieser Stelle mus, bzw sollte die funktion richtig
sein
Im diesem Sinne ,, sind im Bereich von +- 20% , alle Modelle Falsch,
aber auch wieder Richtig , da ja das Datenblatt nur ein en
Durchschnitswert verwendet.
Am fertigen Amp, muss mann am schluss immer noch nach Messen und die
Schaltung Einstellen
Daraus resultiert wieder ,das mann keine "gemachten" Röhren haben muss ,
und im Gegensatz , erleichtern "gemachte Röhren" immense Justier und
abstimmarbeit...
Die Erklärung kam von meim "schnuckelchen" Jens(Physiker mit lauer
einsen im Diplom?
Mfg Jens2
je nach Art wie du Modelle von Trioden Entwirfst , hasst du etwas
abweichende Modelle, Wichtig ist das die Kennlinien im Arbeitsbereich
der Röhre Richtig ist.
Mein Pysiker sagte , das es nicht Möglich sei, alle Kennlienien aus den
Datenblatt , in eine funktion zu bringen, da Jede Kurfe eine Eigene
Steigung hatt , und eine eigene Funktion ist , und somit sei es
unmöglich...
und im Gegenzug ist es so , das die Kennlinien +- 20% real
schwanken,und darum , ist es wiederum egal , wie genau nun diese
Angenäherte Funktion ist , welche man für das Modell braucht ,
Entscheident ist der Arbeitspunkt in dem mann die Röhre betreibt.
so sagt es mein Physiker (mit lauter einesn im diplom)
Bis jetzt hatt alles gestimmt , was er errechnet und gemessen hatt
Spicemodele , Induktionverhalten , von gehäusen, und TSP parameter für
Lautsprecher..
mfg Jens2
unmöglich...
Lautsprecher..
mfg Jens2C
Jens2 schrieb:> so sagt es mein Physiker (mit lauter einesn im diplom)> Bis jetzt hatt alles gestimmt , was er errechnet und gemessen hatt
Spicemodele ...
Jaaa ... dann frag doch mal Deinen Physiker (mit lauter Einsen im
Diplom) wo das Problem mit Deiner 6SA7GT oder 6AS7GT (entscheide Dich
für eine) liegt und dann verkünde hier die Lösung %-\
Mädels
ich habs
es Sind sämtliche Bezeichnugen vertauscht:
6SA7 6AS7 , 6s13p
Und eigentlich brauch ich die 6N13S
Und diese ist schon lange in meiner Bib
ich bedanke mich trotzdem recht herzlich
und wünsche allen alles Gute .
Liebe Grüße
Jens der 2.
Eine eigene Frage?
Dieser Thread ist über 5 Jahre alt.
