Forum: Analoge Elektronik und Schaltungstechnik Controlling DC DC converter with STM32
von Kranthi Kumar B. (kranthikumar_b)
Hello,
I am using a Bidirectional buck boost dc dc converter for charging and
discharging battery. I had MPQ4210 evaluation board, its ouput voltage
is programmble through I2C.
Actually, what I want to do is connecting a battery at the output
terminals of the converter board. There I need to control the dc dc
converter using MCU, voltage and current sesnors and PWM.
Now I do not know how to use STM32 to control the board.
Can anyone help me to do this task.
I am using NUCLEOF070RB as a MCU.
von Stefan F. (Gast)
The document does not contain the needed information. Ask the
manufacturer for help.
Are you familiar with programming the I²C interface of your
microcontroller? If not, you should practise this first with a simple
microchip, for example a PCF8574.
Maybe my homepage helps. I don't know how good google translates it:
https://translate.google.com/translate?hl=en&sl=de&tl=en&u=http%3A%2F%2Fstefanfrings.de%2Fstm32%2Fstm32l0.html%23i2c&sandbox=1
Hello,
Thanks for your response. I did get some output voltage from the dc dc
converter I used the I2C software given by the MPS i.e., Virtual bench.
So, I can measure the battery voltage using voltage divider and current
using ACS712 sensor that can be given to the MCU.
But how can I control the converter module. I did not have much
experience in the coding that to I2C is very hard for me in STM32.
I know how to generate the PWM signal using MCU. But how can I use this
signal on the converter module. The gate drivers are already installed
in the Converter board.
I am uploading another document of the converter board.
Kranthi Kumar B. schrieb:
> I did not have much experience in the coding
The (second) attached dcoument contains the description of the I²C
protocol which is pretty much standard. It contains alos the description
of the registers, that's everything you need.
See also the I²C Bus specification UM10204
(https://www.nxp.com/docs/en/user-guide/UM10204.pdf).
You habe to learn it starting with a asimple peripheral as I suggested
above.
Or do you want to offer a development Job here? If yes, then write down
all requirements and prepare to send a working hardware setup package,
so one can make an offer.
We are talking about thousands of EUR, I hope that is clear.
