Forum: Mikrocontroller und Digitale Elektronik How to check if a microcontroller is broken?
Autor: peekel (Gast)
Hi all,
I know it's a German forum so sorry for the English post. I'm in the
learning period of German I can read it roughly but can't write.
Now I'm using atmega128 to do a project. Before the uC worked totally
okay, however from this week it just stops working. I dont know what
went wrong so I  used a simple method to check it, by which I attached a
LED to the I/O port.
My circuit is truely simple, connect the PORTB.1 with a 470ohm resistor
and the longer end of the LED, the shorter end of the LED was connected
to the GND. I use 5V Vcc and JTAGICE.
my program is like this:
.INCLUDE "m128def.inc"
.CSEG
.ORG 0x00
  RJMP main
main:
  ldi r16, low(ramend)
  out spl, r16
  ldi r16, high(ramend)
  out sph, r16
repeat:
        ldi r16,0x01
  out ddrb,r16
  ldi r16,0x01
  out portb,r16
    jmp repeat
After all the uC didnt work any more, I was wondering if the
microcontroller is broken. So I checked the voltage between Vcc and GND,
and it is okay. So now I'm in no where. Could anyone tell me how to
check if the microcontroller is broken? Dank!
Anyone with any suggestion is great appreciated!
Autor: Otto (Gast)
Hi peekel,
> connect the PORTB.1
-> Port B.1
>  ldi r16,0x01
>  out ddrb,r16
>  ldi r16,0x01
>  out portb,r16
-> This is Port B.0
Otto
Autor: Bernhard (Gast)
Another good method is to put one PORT into output mode (using the DDR),
and then give it some pattern like 0b10101010. Then just measure with a
voltmeter, if you can see this pattern on the used port.
aha, hi, otto, thanks for the quick reply and pointing out the mistake.
It is a writen mistake, I did connect it to the PORTB.0.
Autor: Otto (Gast)
then try "Bernhard"s method - maybe only one pin is broken....
Otto
Thank Bernhard for the hint, I just did what u suggested, set the DDRB
as 0xff, and PORTB as 0b10101010, and measure the voltage between each
pin and GND, but I didnt see any pattern coming out, all the voltages
stay constant which arounds zero.
Autor: Otto (Gast)
did you change any fuse ?
Otto
Autor: Otto (Gast)
hi, otto, the fuse is staying as it was before, I didnt change it. I
think it should be no problem. Now I think I really have some problem
with either the microcontroller or the JTAG, but dont know where to
start to fix it.
Autor: Andreas Schwarz (andreas) (Admin) Benutzerseite Flattr this
