Hallo zusammen, Ich verwende die Yagarto Toolchain also OpenOCD und Eclipse um einen STR912 Controller zu flashen. Beim versuch den Controller zu flashen kommt folgende Meldung: Open On-Chip Debugger (2008-03-22 12:00 CET) svn: r520 URL: http://svn.berlios.de/svnroot/repos/openocd/trunk/ Info: jtag.c:1329 jtag_examine_chain(): JTAG device found: 0x108d8041 (Manufacturer: 0x020, Part: 0x08d8, Version: 0x1) Info: jtag.c:1329 jtag_examine_chain(): JTAG device found: 0x20a52cc1 (Manufacturer: 0x660, Part: 0x0a52, Version: 0x2) Info: jtag.c:1329 jtag_examine_chain(): JTAG device found: 0x01ff24ff (Manufacturer: 0x27f, Part: 0x1ff2, Version: 0x0) Info: jtag.c:1329 jtag_examine_chain(): JTAG device found: 0x0000007f (Manufacturer: 0x03f, Part: 0x0000, Version: 0x0) Error: jtag.c:1339 jtag_examine_chain(): number of discovered devices in JTAG chain (32) doesn't match configuration (3) Error: jtag.c:1340 jtag_examine_chain(): check the config file and ensure proper JTAG communication (connections, speed, ...) Error: jtag.c:1487 jtag_init(): trying to validate configured JTAG chain anyway... Error: jtag.c:1384 jtag_validate_chain(): Error validating JTAG scan chain, IR mismatch, scan returned 0x078811 Error: jtag.c:1384 jtag_validate_chain(): Error validating JTAG scan chain, IR mismatch, scan returned 0x070099 Error: jtag.c:1384 jtag_validate_chain(): Error validating JTAG scan chain, IR mismatch, scan returned 0x078011 Error: jtag.c:1384 jtag_validate_chain(): Error validating JTAG scan chain, IR mismatch, scan returned 0x078099 Error: jtag.c:1384 jtag_validate_chain(): Error validating JTAG scan chain, IR mismatch, scan returned 0x070819 Error: jtag.c:1384 jtag_validate_chain(): Error validating JTAG scan chain, IR mismatch, scan returned 0x078099 Error: jtag.c:1495 jtag_init(): Could not validate JTAG chain, exit make: *** [program] Error 1 Es scheint wohl, dass er in der JTAG chain etwas findet, aber zu viele ? Der STR912 Controller hat 3 JTAG Devices die auch konfiguriert sind. Bei dem .cfg File bin ich (fast) sicher dass diese korrekt sind. Ich habe noch eine andere Hardware mit der das flashen funktioniert. Ist etwas mit der JTAG Schnittstelle "faul" ? Kennt jemand diese Fehlermeldung oder hat eine Lösung für dieses Problem? Habe auch schon mit der JTAG Speed experimentiert hat aber leider keine Besserung gebracht... Grüße Paul
