Forum: FPGA, VHDL & Co. Fehlermeldung bei float_pkg sqrt(x) synthese
Autor: Youssef .a (Firma: privat) (youssef)
ich habe volgende Meldung bei der Synthese des codes (sehe unten) :
Analyzing Entity <float_sqrt> in library <work> (Architecture
<behavioral>).
WARNING:Xst:1748 - "D:/Xilinx92i/AlgorithmDonald/float_pkg_c.vhdl" line
1448: VHDL Assertion Statement with non constant condition is ignored.
INFO:Xst:1749 - "D:/Xilinx92i/AlgorithmDonald/fixed_pkg_c.vhdl" line
2556: report: fixed_pkgDIVIDE(ufixed) Division by zero
ERROR:Xst:769 - "D:/Xilinx92i/AlgorithmDonald/fixed_pkg_c.vhdl" line
2559: Operator <INVALID OPERATOR> must have constant operands or first
operand must be power of 2
mein code :
float16 ist float (6 downto -9) definiert in uniform_pkg
library IEEE,ieee_proposed;
USE ieee.std_logic_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee_proposed.math_utility_pkg.all;
use ieee_proposed.float_pkg.all;
use ieee_proposed.fixed_pkg.all;
use ieee_proposed.uniform_pkg.all;
entity float_sqrt is
    Port ( a : in  float16;
       clk: in bit;
           Q : out  float16);
end float_sqrt;
architecture Behavioral of float_sqrt is
begin
process(clk,a)
begin
if clk ='1' then
if a >0 then
    Q <= sqrt(a);
else
Q <= (others=>'0');
end if;
end if ;
end process;
end Behavioral;
wie kann ich das umgehen ?? die sqrt funktion ist definiert in float_pkg
aber weiss nicht was in fixed_pkg dieses fehler erzeugt
  • [vhdl]VHDL-Code[/vhdl]
