Hallo! Ich habe ein NGW100, welches sich nicht mehr erreichen lässt. Es bekommt keine IP, ist auf der Standard-IP nicht erreichbar, und die serielle Konsole antwortet auch nicht. Daher versuche ich, das NGW100 neu zu flashen via JTAGICE mkII. Ich folge dieser Anleitung: <http://support.atmel.no/knowledgebase/avr32studiohelp/com.atmel.avr32.tool.ngw100/html/upgrading_u_boot.html#NGW> Dabei tritt folgendes Problem auf: (Ubuntu Intrepid) beni@humpback:~$ sudo avr32program erase -fcfi@0 Connected to JTAGICE mkII version 5.44, 5.44 at USB. Failed getting chip information. Missing or wrong part description file for part with JTAG ID 0xffffffff in folder /usr/share/avr32. beni@humpback:~$ sudo avr32program erase -fcfi@0 Connected to JTAGICE mkII version 5.44, 5.44 at USB. Flash chip was not added. Unkown flash type (Manufacturer ID 0x3000, VCS Major version 0x31, VCS Minor version 0x30, Device ID= 0x1D6). beni@humpback:~$ sudo avr32program erase -fcfi@0 Connected to JTAGICE mkII version 5.44, 5.44 at USB. Failed writing 0xc0003000 (ABORT|RES|DBE|DBR) to OCD register 2 (DC) SAB write failed writing 0xc0003000 to 0x100000008. sabWrite: The command was not understood by the JTAGICE mkII unit. beni@humpback:~$ sudo avr32program erase -fcfi@0 Connected to JTAGICE mkII version 5.44, 5.44 at USB. Flash chip was not added. Reading CFI data failed. Doing CFI Query failed. Failed writing to CPU register file index 11. Failed writing 0x00000000 (???) to OCD register 69 (DCEMU) SAB write failed writing 0x00000000 to 0x100000114. sabWrite: The command was not understood by the JTAGICE mkII unit. beni@humpback:~$ sudo avr32program erase -fcfi@0 Connected to JTAGICE mkII version 5.44, 5.44 at USB. Flash chip was not added. Reading CFI data failed. Doing CFI Query failed. Write memory failed. Failed writing 64 bytes to address 0x24000000. jtagBlockWrite: The command was not understood by the JTAGICE mkII unit. Mich erstaunt, dass es jedes mal woanders klemmt. Firmware-Upgrade habe ich via Windows gemacht, auf Version 5.44. avr32program hat Version 3.1.4. Andere Befehle funktionieren aber ohne Probleme: beni@humpback:~$ sudo avr32program cpuinfo Connected to JTAGICE mkII version 5.44, 5.44 at USB. Device information: Device Name AP7002 AP7001 AP7000 Device Revision C JTAG ID 0x21e8203f SRAM size 32 kB Kennt das Problem jemand? Wie bringe ich meinen JTAGICE mkII mit dem NGW100 in Verbindung? Wie kann ich uBoot und Linux zurück aufs NGW100 bringen? Liebe Grüsse und vielen Dank im Voraus! Benedikt Köppel
kann der Fehler daher kommen weil du nicht als root angemeldet bist?
Hm darum führe ich ja alle Befehle mit 'sudo' aus. Das kommt doch aufs Gleiche raus.
nicht unbedingt, hängt davon ab, was der root in der sudoers für Rechte gegeben hat
und welcher Gruppe gehört "beni" zu? Wäre es nicht einfacher, um evtl. Fehler aus dieser Quelle auszuschließen, sich als direkt als root anzumelden?
Ok, ich werde heute Abend versuchen, direkt als root auszuführen und dann meine Resultat hier posten.
vielleicht hilft dir das hier: http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=73440
Hallo, leider klappt es auch als User root nicht. Ziemlich genau die selben Meldungen wie oben, die sich immer mal ein bisschen abwechseln. Gibts noch Hoffnung für mein NGW und JTAG? Liebe Grüsse Benedikt Köppel
