Hallo, nach der 1.11.9.1 BASCOM-AVR Demo Version (von 2008-02-22) gibt es seit dem 10. Juli 2009 die neue BASCOM-AVR Demo Version 1.11.9.5 . Die Größe der Demo ist 21 MB. Unter http://www.mcselec.com ... unter Downloads steht zwar noch, dass es die Version 1.11.9.1 sei. Aber wenn man sie herunterlädt, bekommt man die 1.11.9.5 Version.
Hallo, hat schon jemand herausgekriegt was der Unterschied zwischen der alten und neuen Bascom-Version ist? -Ok, das neue Bascom hat einen neuen Startbildschirm - aber das kann wohl nicht alles sein.
>hat schon jemand herausgekriegt was der Unterschied zwischen der alten >und neuen Bascom-Version ist? Hier die Änderungen (vom MCS-UpdateWizard) 1.11.9.5 - added support for KS108 with 3 chips : 192 * 64 - The timeout for the USB programmers that need LIBUSB can be adjusted in the options. Some USB1.1 hubs in combination with a lot of USB devices connected, need a bigger timeout. Default is 100 (msec). But you can increase in steps till it works properly. - M128can and M32CAN used wrong timer2 definition when configuring the timer2. - m165 dat file needed the TCCR2 alias for TCCR2A. - attiny13 did not start when using START TIMER0 - generated files are in same case as the source file - tiny25,tiny45,tiny85 used the wrong register when updating the prescaler - simulator with real RS-232 data, did not set data receive interrupt. So when using buffered serial IO, it would not be read. - cls LINE for KS108 did not worked for the entire line(different chips) - tiny2313 compare config for OC0A did not send portb.2 but portd.6 - ___LTMPC was created twice. Does not have impact but looks odd in the report. - .DEF will now report error 358 if a def is used twice - M88PDEF.DAT had a wrong interrupt table(wrong address), WRAP value was wrong too. - Instead of a label or number, you can also use relative jumps + will jump forward, - backward rjmp +1 ; address +1 rcall -2 ; call address at address -2 rjmp 0 ; goto RESET address ! - display accepts 3 parameters : DISPLAY ON|OFF , CURSOR|NOCURSOR , BLINK|NOBLINK while you can also use cursor for this, the cursor commands uses an internal variable, which in some cases can get confused. The display statements will write the value that reflects the parameters and does not use an internal variable to maintain the state. - M124P,324P and 644P had TCCR2 mapped to the wrong register in the def file. it should map to TCCR2A and not to TCCR2B - M48,88,168 did not used AS2 bit to set the Async mode
Hallo, ich wollte kenen neuen Threat aufmachen, also schreib ich hier: Es gibt eine neue Version von Bascom: 1.11.9.6 Allerdings ist auf der Homepage kein Hinweis darauf zu sehen. Wenn man seine (gekaufte) Bascom-Version auf "Registration/Updates" registriert hat, kann man sich dort das neue LIC-File runterladen. Hier noch die Veränderungen (vom MCS-Update-Wizzard): 1.11.9.6 - Elektor ATM18 LCD driver added. Use $lib "lcd4-elektor.lbx". See also sample elektor-lcd-final.bas ### XMEGA NOTES ### ! In XMEGA the memory is not lineair, you can not access the registers with a pointer! registers are in a separate dataspace ! In XMEGA the access order of 16/24/32 bit registers is changed. It is now from LSB-MSB for both reading and writing ! Following comment is for XMEGA only. Please look in the help for a full description. - CONFIG COM starts at 0 for xmega , other parameters differ slightly too Config Com0 = 38400 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0 - When using EEPROM, you need to add : Config Eeprom = Mapped - CONFIG DACA|DACB : Config Daca = Enabled , Io0 = Enabled , Channel = Single , Reference = Int1v , Interval = 64 , Refresh = 64 - Config Osc = Enabled , 32mhzosc = Enabled - Config Sysclock = 32mhz , Prescalea = 1 , Prescalebc = 1_1 - Config Priority = Static , Vector = Application , Lo = Enabled Notice that Xmega support is not fully implemented. But it is well enough to use it and get familiair with it. In the coming period there will be a number of xmega updates that will implement all 8 UARTS, ADC, multiple SPI , TWI and timers. - Notice that while JTAG programming is supported now, it does NOT support Xmega JTAG. Atmel has changed the protocol and they could not give an update yet that describes the changes related to XMEGA. So JTAG will work for non-xmega but not for Xmega. We advise to use stk600 programmer and load the/a bootloader. Da Mark Alberts momentan damit beschäftigt ist an der neuen IDE zu arbeiten, gibt es nur wenig Neuerungen für die "normalen" AVRs. Der Xmega-Support wurde ein wenig verbessert. MfG, Der Gast minus 1
Hi, ich vergess auch immer, wie Bascom geupdatet wird. Aber 10 Sec. Google: Bascom updaten -> http://www.display3000.com/downloads/bascom_update.pdf ist immer wieder Hilfreich Wigbert
Gerade zufällig entdeckt: Bascom 1.11.9.7 ist da! Hier noch die Veränderungen: 1.11.9.7 - This is a new Xmega update but also included some fixes and features for non Xmega. - CONFIG ADCA of CONFIG ADCB added for ADC converter - config INPUT|INPUT1|INPUT2.... INPUT8, is supported by Xmega - all uarts are supported now. use COM1-COM8. While all UARTS are supported, some options are not implemented such as buffered serial COM. - new power mode support. the IDLE, POWERSAVE and POWERDOWN are replaced by POWER MODE the old modes still work but will be removed in a future version. It is advised to use the new POWER command which supports all modes. The supported modes depend on the micro hardware. For example in the M88DEF.DAT for the Mega88 you will find : Powermodes=5 PM1=Idle,SMCR.SM0-0,SMCR.SM1-0,SMCR.SM2-0 PM2=Powerdown,SMCR.SM0-0,SMCR.SM1-1,SMCR.SM2-0 PM3=Standby,SMCR.SM0-0,SMCR.SM1-1,SMCR.SM2-1 PM4=ADCnoise,SMCR.SM0-1,SMCR.SM1-0,SMCR.SM2-0 PM5=Powersave,SMCR.SM0-1,SMCR.SM1-1,SMCR.SM2-0 In this case the modes are IDLE, POWERDOWN,STANDBY,ADCNOISE,POWERSAVE Use as : POWER IDLE Other chips might have more modes. - m328P has some fusebits on a different fuse compared to m88, m168p. this is now corrected. - number of include files increased to 500. It was actual 500, but a type error resulted in 50 instead of 500. - a bug in an update of a third party component caused an error on windows 2000. - portQ, portR added to CONFIG for Xmega - added COM5,6 and 7 for Xmega. Notice that for Xmega you can dynamic change the COM at run time. - CONFIG COM for xmega changed : instead of using COM0 it is better for compatibility with other commands to start with COM1 So the range for xmega is now the same as for normal AVR : COM1-COM8 Internally, the uart channel is working with 0-7. The TX pin is set to output in this release. MfG, der Gast -1
Und schon wieder eine neue Version: Bascom 1.11.9.8 & neue Demo Hier noch die Veränderungen: 1.11.9.8 - #AUTOCODE, #ENDAUTOCODE and #DEFINE added - xmega inkey() for COM4-7 did not work. - LCD simulator did not clear CGRAM. - an update in a component caused the atmel programmers, autoprogram option to fail - RND() function improved so it wont give the same sequence - xmega uart support created bug in chr() function for channel 1. MfG, Der Gast -1
hm, könnte man die ganze Energie, die in BASCOM gesteckt wird nicht auch für sinnvolle Projekte nutzen?
JA - in FastAVR zum Beispiel ;)) Wird schon lange nicht mehr weiterentwickelt - schade eigentlich. Der ASM Output dort sieht sehr gut aus (bis auf einige Bugs natürlich), daher mein Post... Gruß Axelr.
@Klaus, was verstehst du unter "Sinnvolle Projekte"? Ich hoffe doch du willst hier nicht wieder das dämliche Bascom-Bashing lostreten oder? Wenn ich die Verkorkste Syntax von C anschaue kann ich durchaus verstehen warum einige Neueinsteiger zu Bascom greifen. Das ist Anfänglich einfacher zu verstehen und man kommt schneller zum ersten Erfolgserlebnis. Die Motivation ist dabei ja auch eine wichtige Sache... Wie war das noch mal, Leben und leben lassen.... Rolle
Whenever.. Jemand der sich nicht völlig selbstüberschätzt als C-PeDa..nt sieht, die Vorteile von C schätzt aber auch pragmatisch genug ist, um die Vorteile von Bascom zu sehen, dann sei er als persona non grata von C-Peda..nten zu steinigen. Oder er suche ein anderes Land, in dem Ergebnisse höher zählen als der Selbstprotektionismus eines gewissen Industriestandards.
Die Diskussion ob C- Pascal oder Basic-Dialekt ist in der heutigen Zeit sowieso obolet. Das beste Beispiel ist Visual Basic, hier wird derselbe Code erzeugt wie bei Visual C. Es ist nur eine andere Schreibweise. C ist krankhaft, dennoch kommt man hier und da nicht drum herum. Wichtig und entscheidend sind die Ergebnisse. Ich habe schon einige "C-Professionals" gesehen die rein gar nichts kreatives und anständiges zustandegebracht haben, sie scheinen wohl zu sehr mit ihrer C-verliebtheit beschäftigt gewesen zu sein. Solche Leute fliegen sofort wieder raus.
Stimme zu! Jetzt kommt noch die Frage: Bloatware oder nicht? Es gibt ..nten, die printf in C verewigt haben. Die sind nicht rausgeflogen!
> Das beste Beispiel ist Visual Basic, hier wird derselbe > Code erzeugt wie bei Visual C. Es ist nur eine andere Schreibweise. Was natürlich nicht stimmt, es sei denn, man meint die .Net-Perversion "Managed C++" oder das Java-Imitat C#. Der C/C++-Compiler von MS hingegen erzeugt nach wie vor nativen x86-Code. Im übrigen bitte ich Programmiersprachbashings in einen anderen Forenbereich zu verlagern. Das gilt auch für Bascom-Bashings.
Oh sorry Euer Ehren, Rufus (Moderator) - eigentlich wollte ich mich ausklinken! Stimme zu! Aber!: Sind wir nicht in einem Forum, wo es um µCs geht? Bloatware.Net spielt bei PCs doch eigentlich keine Rolle (Moore) - aber bei den kleinen eingebetteten Krabbelkindern, die unsere Welt verändern soll es doch heissen: Kreativ, kreativ, kreativ und gleichzeitig billig, billig, billig und gleichzeitig schnell, schnell, schnell! Wieder also die eierlegende Wollmilchsau, die es nicht gibt! Ihre Approximation ist aber mit einem "lean compiler" (BASCOM) möglicherweise doch schneller als mit unserem geliebten Standard - zumal "Kreative" oder besser "Andersdenkende" oder (mehr oder minder) "Neudenkende" damit schneller zurecht kommen. Jetzt sag bloß nicht Ardu.. - das wäre die "fat alternative" dazu - sozusagen die Popularisierung unseres geliebten (weil selbstschützenden) Standards. Im Ardu-Modell machen "wir" für die "Neudenkenden" die Tools und erfreuen uns an "unserer Kreativität?!", die nun für andere verbindlich wird. Im Bascom-Modell dürfen es die ..Anderen sein, die uns mal zeigen, wo es lang geht. Competition from the non-C idiots, oh shit! So, jetzt muß ich flüchten, weil ich schon die Steine fliegen sehe! CLover
