Hallo, ich bekomme beim Implementieren meines Design (mit Microblaze) in ISE folgende Fehlermeldung: ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:661 - LUT2 symbol ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT3 symbol ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:661 - LUT4 symbol ERROR:MapLib:820 - LUT4 symbol ERROR:MapLib:820 - LUT2 symbol ERROR:MapLib:820 - LUT4 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT4 symbol ERROR:MapLib:820 - LUT4 symbol ERROR:MapLib:820 - LUT4 symbol ERROR:MapLib:820 - LUT4 symbol ERROR:MapLib:820 - LUT4 symbol ERROR:MapLib:820 - LUT4 symbol ERROR:MapLib:820 - LUT4 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT3 symbol ERROR:MapLib:820 - LUT4 symbol ERROR:MapLib:820 - LUT4 symbol ERROR:MapLib:820 - LUT4 symbol ERROR:MapLib:820 - LUT4 symbol ERROR:MapLib:820 - LUT4 symbol weiß vielleicht jemand was das ist und wie sie koriigiert werden kann?
Mit was?
Worauf?
Was hast du geändert?
Ich habe zum Microblaze, der in EDK9.2.i erstellt wurde noch Module in ISE 9.2.i dazugebaut, die in einem Toplevel verbunden werden sollen. Syntax ist korrekt. Es hat schon vor ca 1 Wochen funktioniert, habe jetzt noch ein Modul hinzugefügt. Compilieren/Sysnthese/Imlemetation alls in ISE 9.2.i
Solution: This error may be obtained when the CLIP node consists of VHDL structures that have been defined for a later target and have not been defined for older target. Visit the following link to check if the targeted FPGA family supports the structures that maybe defined in the CLIP node: http://www.xilinx.com/support/documentation/index.htm If the structure has not been mentioned for the target FPGA family, then the compilation error is a result of the missing support for the structure on the FPGA target. The Xilinx SDK is not backward compatible and it is not possible to compile structures that were not supported for older targets.
