1 | library IEEE;
2 | use IEEE.std_logic_1164.all;
3 | use IEEE.numeric_std.all;
4 | use work.test_pack.all;
5 |
6 | entity sram_controller_e is
7 | port(
8 | clk_i : in std_ulogic;
9 | reset_n_i : in std_ulogic;
10 | fsm_start_addr_i : in std_ulogic_vector(18 downto 0);
11 | fsm_we_i : in std_ulogic;
12 | fsm_re_i : in std_ulogic;
13 | state_out : out fsm_t; --- Ausgang
14 | srctr_idle_o : out std_ulogic;
15 | srctr_we_reg_n_o : out std_ulogic;
16 | srctr_ce_reg_n_o : out std_ulogic;
17 | srctr_oe_reg_n_o : out std_ulogic;
18 | srctr_lb_reg_n_o : out std_ulogic;
19 | srctr_ub_reg_n_o : out std_ulogic;
20 | mem_data_b : inout std_logic_vector(15 downto 0));
21 | end sram_controller_e;
22 |
23 | architecture sram_controller_a of sram_controller_e is
24 |
25 | signal state : fsm_t;
26 | signal addr_next : std_ulogic_vector(18 downto 0);
27 | signal addr_inc : std_ulogic_vector(18 downto 0);
28 | signal addr_reg : std_ulogic_vector(18 downto 0);
29 |
30 | begin
31 | state_out <= state; -- state ausgeben
32 | .
33 | .
34 | .
35 | end sram_controller_a;
36 |
37 | :
38 | :
39 | :
40 |
41 | library IEEE;
42 | use IEEE.std_logic_1164.all;
43 | use IEEE.numeric_std.all;
44 | use work.test_pack.all;
45 |
46 | entity sram_controller_data_e is
47 | port(
48 | clk_i : in std_ulogic;
49 | reset_n_i : in std_ulogic;
50 | audio_data_i : in std_ulogic_vector(23 downto 0);
51 | srctr_data_o : out std_ulogic_vector(23 downto 0);
52 | fsm_we_i : in std_ulogic;
53 | state_in : in fsm_t; --- Eingang
54 | srctr_end_addr_plus1_o : out std_ulogic_vector(18 downto 0);
55 | srctr_addr_reg_o : out std_ulogic_vector(18 downto 0);
56 | mem_data_b : inout std_logic_vector(15 downto 0));
57 | end sram_controller_data_e;
58 |
59 | architecture sram_controller_data_a of sram_controller_data_e is
60 | .
61 | .
62 | .
63 | begin
64 | .
65 | .
66 | .
67 | end sram_controller_data_a;
68 |
69 |
70 | :
71 | :
72 | :
73 |
74 | library IEEE;
75 | use IEEE.std_logic_1164.all;
76 | use IEEE.numeric_std.all;
77 | use work.test_pack.all;
78 |
79 | entity top_e is
80 | :
81 | :
82 | end top_e;
83 |
84 | architecture ... is
85 | :
86 | component sram_controller_data_e is -- Komponente deklarieren
87 | port(...
88 | end component;
89 |
90 | component sram_controller_e is -- Komponente deklarieren
91 | port(...
92 | end component;
93 |
94 | signal state : fsm_t -- Verbindungssignal
95 | :
96 |
97 | begin
98 | -- hier erfolgt die eigentliche Verbindung mit dem Signal state
99 | sram_controller : sram_controller_e
100 | PORT MAP ( ..., state_out => state , ...);
101 |
102 | sram_controller_data : sram_controller_data_e
103 | PORT MAP ( ..., state_in => state , ...);
104 | :
105 | :
