1 | LIBRARY ieee;
2 | USE ieee.std_logic_1164.ALL;
3 | USE ieee.std_logic_unsigned.all;
4 | USE ieee.numeric_std.ALL;
5 |
6 | ENTITY FLASH_BRAM_BENCH_16 IS
7 | END FLASH_BRAM_BENCH_16;
8 |
9 | ARCHITECTURE behavior OF FLASH_BRAM_BENCH_16 IS
10 |
11 | -- Component Declaration for the Unit Under Test (UUT)
12 |
13 | COMPONENT FLASH_CONTROLLER
14 | PORT(
15 | DA_H : OUT std_logic_vector(7 downto 0);
16 | DA_L : OUT std_logic_vector(7 downto 0);
17 | DATA_EN_H : OUT std_logic;
18 | DATA_EN_L : OUT std_logic;
19 | BYTE_SR : OUT std_logic;
20 | ADD_ZE : OUT std_logic;
21 | ADD_K_VOLL : OUT std_logic;
22 | ADD_EN : OUT std_logic;
23 | ADD_D_VOLL : OUT std_logic;
24 | FL_DURCHLAUF_ADD : OUT std_logic_vector(14 downto 0);
25 | FL_ADD_DURCHLAUF_ZERO : OUT std_logic;
26 | BRAM_WR_RD_ENABLE : OUT std_logic;
27 | BRAM_WR_RD_DISABLE : OUT std_logic;
28 | BRAM_R_ADD_COUNT_ENABLE : OUT std_logic;
29 | BRAM_R_ADD_COUNT_VOLL : OUT std_logic;
30 | BRAM_R_ADD : OUT std_logic_vector(13 downto 0);
31 | BRAM_R_ADD_ZERO : OUT std_logic;
32 | BRAM_CLK_1 : OUT std_logic;
33 | BRAM_A_1 : OUT std_logic_vector(13 downto 0);
34 | BRAM_IN_DA_1 : OUT std_logic_vector(11 downto 0);
35 | BRAM_OUT_DA_1 : OUT std_logic_vector(11 downto 0);
36 | BRAM_WR_ENABLE_1 : OUT std_logic_vector(0 downto 0);
37 | BRAM_CLK_2 : OUT std_logic;
38 | BRAM_A_2 : OUT std_logic_vector(13 downto 0);
39 | BRAM_IN_DA_2 : OUT std_logic_vector(11 downto 0);
40 | BRAM_OUT_DA_2 : OUT std_logic_vector(11 downto 0);
41 | BRAM_WR_ENABLE_2 : OUT std_logic_vector(0 downto 0);
42 | DA_FROM_FLASH : OUT std_logic_vector(11 downto 0);
43 | BADD : OUT std_logic_vector(13 downto 0);
44 | AUSGABE_AN_DA_WANDLER_CLK : IN std_logic;
45 | FLASH_ENABLE : IN std_logic;
46 | FLASH_RESET : IN std_logic;
47 | FLASH_CLK : IN std_logic;
48 | FLASH_ADDRESS : OUT std_logic_vector(23 downto 0);
49 | FLASH_RP : OUT std_logic;
50 | FLASH_CE : OUT std_logic;
51 | FLASH_OE : OUT std_logic;
52 | STORED_FLASH_DATA : IN std_logic_vector(7 downto 0);
53 | AUSGABE_DATEN_BRAM : OUT std_logic_vector(11 downto 0);
54 | AUSGABE_DATEN_FLASH : OUT std_logic_vector(11 downto 0)
55 | );
56 | END COMPONENT;
57 |
58 |
59 | --Inputs
60 | signal AUSGABE_AN_DA_WANDLER_CLK : std_logic := '0';
61 | signal FLASH_ENABLE : std_logic := '0';
62 | signal FLASH_RESET : std_logic := '0';
63 | signal FLASH_CLK : std_logic := '0';
64 | signal STORED_FLASH_DATA : std_logic_vector(7 downto 0) := (others => '0');
65 |
66 | --Outputs
67 | signal DA_H : std_logic_vector(7 downto 0);
68 | signal DA_L : std_logic_vector(7 downto 0);
69 | signal DATA_EN_H : std_logic;
70 | signal DATA_EN_L : std_logic;
71 | signal BYTE_SR : std_logic;
72 | signal ADD_ZE : std_logic;
73 | signal ADD_K_VOLL : std_logic;
74 | signal ADD_EN : std_logic;
75 | signal ADD_D_VOLL : std_logic;
76 | signal FL_DURCHLAUF_ADD : std_logic_vector(14 downto 0);
77 | signal FL_ADD_DURCHLAUF_ZERO : std_logic;
78 | signal BRAM_WR_RD_ENABLE : std_logic;
79 | signal BRAM_WR_RD_DISABLE : std_logic;
80 | signal BRAM_R_ADD_COUNT_ENABLE : std_logic;
81 | signal BRAM_R_ADD_COUNT_VOLL : std_logic;
82 | signal BRAM_R_ADD : std_logic_vector(13 downto 0);
83 | signal BRAM_R_ADD_ZERO : std_logic;
84 | signal BRAM_CLK_1 : std_logic;
85 | signal BRAM_A_1 : std_logic_vector(13 downto 0);
86 | signal BRAM_IN_DA_1 : std_logic_vector(11 downto 0);
87 | signal BRAM_OUT_DA_1 : std_logic_vector(11 downto 0);
88 | signal BRAM_WR_ENABLE_1 : std_logic_vector(0 downto 0);
89 | signal BRAM_CLK_2 : std_logic;
90 | signal BRAM_A_2 : std_logic_vector(13 downto 0);
91 | signal BRAM_IN_DA_2 : std_logic_vector(11 downto 0);
92 | signal BRAM_OUT_DA_2 : std_logic_vector(11 downto 0);
93 | signal BRAM_WR_ENABLE_2 : std_logic_vector(0 downto 0);
94 | signal DA_FROM_FLASH : std_logic_vector(11 downto 0);
95 | signal BADD : std_logic_vector(13 downto 0);
96 | signal FLASH_ADDRESS : std_logic_vector(23 downto 0);
97 | signal FLASH_RP : std_logic;
98 | signal FLASH_CE : std_logic;
99 | signal FLASH_OE : std_logic;
100 | signal AUSGABE_DATEN_BRAM : std_logic_vector(11 downto 0);
101 | signal AUSGABE_DATEN_FLASH : std_logic_vector(11 downto 0);
102 |
103 | -- Clock period definitions
104 | constant AUSGABE_AN_DA_WANDLER_CLK_period : time := 50000 ps; -- DIESE HIER!!
105 | constant FLASH_CLK_period : time := 25000 ps; -- UND DIESE HIER!!!
106 |
107 | BEGIN
108 |
109 | -- Instantiate the Unit Under Test (UUT)
110 | uut: FLASH_CONTROLLER PORT MAP (
111 | DA_H => DA_H,
112 | DA_L => DA_L,
113 | DATA_EN_H => DATA_EN_H,
114 | DATA_EN_L => DATA_EN_L,
115 | BYTE_SR => BYTE_SR,
116 | ADD_ZE => ADD_ZE,
117 | ADD_K_VOLL => ADD_K_VOLL,
118 | ADD_EN => ADD_EN,
119 | ADD_D_VOLL => ADD_D_VOLL,
120 | FL_DURCHLAUF_ADD => FL_DURCHLAUF_ADD,
121 | FL_ADD_DURCHLAUF_ZERO => FL_ADD_DURCHLAUF_ZERO,
122 | BRAM_WR_RD_ENABLE => BRAM_WR_RD_ENABLE,
123 | BRAM_WR_RD_DISABLE => BRAM_WR_RD_DISABLE,
124 | BRAM_R_ADD_COUNT_ENABLE => BRAM_R_ADD_COUNT_ENABLE,
125 | BRAM_R_ADD_COUNT_VOLL => BRAM_R_ADD_COUNT_VOLL,
126 | BRAM_R_ADD => BRAM_R_ADD,
127 | BRAM_R_ADD_ZERO => BRAM_R_ADD_ZERO,
128 | BRAM_CLK_1 => BRAM_CLK_1,
129 | BRAM_A_1 => BRAM_A_1,
130 | BRAM_IN_DA_1 => BRAM_IN_DA_1,
131 | BRAM_OUT_DA_1 => BRAM_OUT_DA_1,
132 | BRAM_WR_ENABLE_1 => BRAM_WR_ENABLE_1,
133 | BRAM_CLK_2 => BRAM_CLK_2,
134 | BRAM_A_2 => BRAM_A_2,
135 | BRAM_IN_DA_2 => BRAM_IN_DA_2,
136 | BRAM_OUT_DA_2 => BRAM_OUT_DA_2,
137 | BRAM_WR_ENABLE_2 => BRAM_WR_ENABLE_2,
138 | DA_FROM_FLASH => DA_FROM_FLASH,
139 | BADD => BADD,
140 | AUSGABE_AN_DA_WANDLER_CLK => AUSGABE_AN_DA_WANDLER_CLK,
141 | FLASH_ENABLE => FLASH_ENABLE,
142 | FLASH_RESET => FLASH_RESET,
143 | FLASH_CLK => FLASH_CLK,
144 | FLASH_ADDRESS => FLASH_ADDRESS,
145 | FLASH_RP => FLASH_RP,
146 | FLASH_CE => FLASH_CE,
147 | FLASH_OE => FLASH_OE,
148 | STORED_FLASH_DATA => STORED_FLASH_DATA,
149 | AUSGABE_DATEN_BRAM => AUSGABE_DATEN_BRAM,
150 | AUSGABE_DATEN_FLASH => AUSGABE_DATEN_FLASH
151 | );
152 |
153 | -- Clock process definitions
154 | AUSGABE_AN_DA_WANDLER_CLK_process :process
155 | begin
156 | AUSGABE_AN_DA_WANDLER_CLK <= '0';
157 | wait for AUSGABE_AN_DA_WANDLER_CLK_period/2;
158 | AUSGABE_AN_DA_WANDLER_CLK <= '1';
159 | wait for AUSGABE_AN_DA_WANDLER_CLK_period/2;
160 | end process;
161 |
162 | FLASH_CLK_process :process
163 | begin
164 | FLASH_CLK <= '0';
165 | wait for FLASH_CLK_period/2;
166 | FLASH_CLK <= '1';
167 | wait for FLASH_CLK_period/2;
168 | end process;
169 |
170 |
171 | -- Stimulus process
172 | stim_proc: process
173 | begin
174 | FLASH_RESET <= '1';
175 | FLASH_ENABLE <= '0';
176 | wait for 500000 ns;
177 | FLASH_RESET <= '0';
178 | FLASH_ENABLE <= '0';
179 | wait for 500000 ns;
180 | -----------------
181 | FLASH_RESET <= '0';
182 | FLASH_ENABLE <= '1';
183 | wait for 1000000 ns;
184 | FLASH_RESET <= '0';
185 | FLASH_ENABLE <= '0';
186 | wait for 800000 ns;
187 | ---------------------
188 | FLASH_RESET <= '0';
189 | FLASH_ENABLE <= '1';
190 | wait for 1000000 ns;
191 | FLASH_RESET <= '0';
192 | FLASH_ENABLE <= '0';
193 | wait for 500000 ns;
194 | ---------------------
195 | FLASH_RESET <= '0';
196 | FLASH_ENABLE <= '1';
197 | wait for 1000000 ns;
198 | FLASH_RESET <= '0';
199 | FLASH_ENABLE <= '0';
200 | wait for 1000000 ns;
201 | ---------------------
202 | FLASH_RESET <= '0';
203 | FLASH_ENABLE <= '1';
204 | wait for 1000000 ns;
205 | FLASH_RESET <= '0';
206 | FLASH_ENABLE <= '0';
207 | wait for 500000 ns;
208 | ---------------------
209 | FLASH_RESET <= '0';
210 | FLASH_ENABLE <= '1';
211 | wait for 1000000 ns;
212 | FLASH_RESET <= '0';
213 | FLASH_ENABLE <= '0';
214 | wait for 500000 ns;
215 | ---------------------
216 | FLASH_RESET <= '0';
217 | FLASH_ENABLE <= '1';
218 | wait for 1000000 ns;
219 | FLASH_RESET <= '0';
220 | FLASH_ENABLE <= '0';
221 | wait for 500000 ns;
222 | ---------------------
223 | FLASH_RESET <= '0';
224 | FLASH_ENABLE <= '1';
225 | wait for 1000000 ns;
226 | FLASH_RESET <= '0';
227 | FLASH_ENABLE <= '0';
228 | wait for 500000 ns;
229 | --------------------
230 | FLASH_RESET <= '0';
231 | FLASH_ENABLE <= '1';
232 | wait for 1000000 ns;
233 | FLASH_RESET <= '0';
234 | FLASH_ENABLE <= '0';
235 | wait for 800000 ns;
236 | FLASH_RESET <= '0';
237 | FLASH_ENABLE <= '1';
238 | wait for 500000 ns;
239 | --------------------
240 | FLASH_RESET <= '0';
241 | FLASH_ENABLE <= '0';
242 | wait for 800000 ns;
243 | FLASH_RESET <= '0';
244 | FLASH_ENABLE <= '1';
245 | wait;
246 | end process;
247 |
248 | END;
