Bei Interesse bitte Nachricht(PM) an mich senden. Die folgenden beiden Artikel sind nagelneu: [v] OVP - Microchip DM240001 Explorer 16 Development Board Verkaufe ein original Versiegeltes und damit unberührtes Explorer16-Board in ungeöffneter OVP. Versand oder Abholung mit Treffpunkt in Wien möglich. Preis: 60€ Auszug aus der Beschreibung des Herstellers Microchip: The Explorer 16 is a low cost, efficient development board to evaluate the features and performance of Microchip's new PIC24 Microcontroller, the dsPIC33 Digital Signal Controller (DSC) families, and the new 32-bit PIC32MX devices. Coupled with the MPLAB ICD 2 In Circuit Debugger or MPLAB REAL ICE, real-time emulation and debug facilities speed evaluation and prototyping of application circuitry. The Explorer 16 100-pin features two interchangeable Plug-In Modules (PIMs), one each for the PIC24FJ128GA010 and the dsPIC33FJ256GP710 DSC. The Explorer 16 44-pin features a Plug-In Module (PIM) for the PIC24FJ64GA004. Features • Includes PIC24FJ128GA010 and the dsPIC33FJ256GP710 DSC Digital Signal Controller PIMs (100-pin version) or the PIC24FJ64GA004 PIM (44-pin version). • Alpha-numeric 16 x 2 LCD display • Interfaces to MPLAB ICD 2, MPLAB REAL ICE, USB, and RS-232 • Includes Microchip's TC1047A high accuracy, analog output temperature sensor • Expansion connector to access full devices pin-out and bread board prototyping area • PICTailTM Plus connector for expansion boards • Full documentation CD includes user's guide, schematics and PWB layoutMicrochip DV164005 - MPLAB ICD 2 MODULE [V] OVP - Microchip DV164005 - MPLAB ICD 2 MODULE Verkaufe ein original Versiegeltes und damit unberührtes ICD2-Modul in ungeöffneter OVP. Versand oder Abholung mit Treffpunkt in Wien möglich. Preis: 60€ Auszug aus der Beschreibung des Herstellers Microchip: The MPLAB ICD 2 module is a low-cost development tool that connects between the PC and the designers target board, allowing direct in-circuit debugging of a target PICmicro MCU or dsPIC DSC. Programs can be executed in real time or single step, watch variables established, break points set, memory read/writes accomplished and more. It can also be used as a development programmer. This kit contains the MPLAB ICD 2 module, an ICD interface cable and USB cable. Features: USB (Full Speed 2 M bits/s) & RS-232 interface to host PC Real time background debugging MPLAB IDE GUI (free copy included) Built in over-voltage/short circuit monitor Firmware upgradeable from PC Totally enclosed Supports low voltage to 2.0 volts. (2.0 to 6.0 range) Diagnostic LEDs (Power, Busy, Error) Reading/Writing memory space and EEDATA areas of target microcontroller Programs configuration bits Erase of program memory space with verification Peripheral freeze-on-halt stops timers at breakpoints Dieses Set ist (wenig) gebraucht: [v] Microchip DM240001 Explorer 16 Development Board + MPLAB ICD 2 MODULE Verkaufe ein neuwertiges Explorer16-Board sowie das passende ICD2 Modul. Das Set diente für zwei Monate zur Entwicklung einer Anwendung und funktioniert einwandfrei. Versand oder Abholung mit Treffpunkt in Wien möglich. Preis: 100€ Und nun der klassische Text: Da es sich um einen Privatverkauf handelt, gebe ich keine Garantie/Gewährleistung auf die Ware. Eine Rücknahme ist in jedem Fall ausgeschlossen. Mit der Abgabe eines Gebots erklären Sie sich als Käufer damit einverstanden, auf Garantie und Gewährleistung zu verzichten.
Bert K. schrieb: > Und nun der klassische Text: > Da es sich um einen Privatverkauf handelt, gebe ich keine > Garantie/Gewährleistung auf die Ware. Eine Rücknahme ist in jedem Fall > ausgeschlossen. Entgegen einer weitverbreiteten Ansicht, muss man als Privatverkäufer weder die Garantie oder eine Gewährleistung ausschliessen, noch eine Rücknahme. > Mit der Abgabe eines Gebots erklären Sie sich als Käufer > damit einverstanden, auf Garantie und Gewährleistung zu verzichten. Was heisst hier Gebot? Geh' zu Ebay. Da kannst Du so ne Geschichten mit machen. Steht jeden Morgen ein Dummer auf. Ohne Garantie/Gewährleistung auf ein nagelneues originalverpacktes Gerät und Rückgabemöglichkeite kein Kauf! Wo san mer dann?
