Forum: Mikrocontroller und Digitale Elektronik At Mega 8 Codeabfrage
Autor: Andre (Gast)
Anbei erstmal mein Quelltext den ich bisher erstellt habe mit dem myAVR
Workpad Plus in Verbindung mit dem myAVRMK2 Board .
Daran angeschlossen haben ich eine Tastaturmatrix :
Betrieben wird das ganze mit einem ATMega8 .
main ()            // Hauptprogramm, startet bei Power ON und Reset
  DDRD  = 0b10000000;
  PORTD = 0b00000000;
  DDRB  = 0b000011;
  PORTB = 0b111100;
  DDRC  = 0xFF;
  while (true)
    switch(PINB & 0b111100)
      case 0b111000  :
      DDRD  = 0b00000000;
      PORTD = 0b10000000;
      DDRB  = 0b111100;
      PORTB = 0b000011;
      switch(PINB & 0b000011)
        case 0b000001 :
        DDRD  = 0b10000000;
        PORTD = 0b00000000;
        DDRB  = 0b000011;
        PORTB = 0b111100;
        PORTC = 0b100000;
        waitMs(200);     //3
        break;
        case 0b000010 :
        DDRD  = 0b10000000;
        PORTD = 0b00000000;
        DDRB  = 0b000011;
        PORTB = 0b111100;
        PORTC = 0b010000;
        waitMs(200);     //2
        break;
        default :
        DDRD  = 0b10000000;
        PORTD = 0b00000000;
        DDRB  = 0b000011;
        PORTB = 0b111100;
        PORTC = 0b001000;
        waitMs(200);    // 1
        break;
      break;
      case 0b110100  :
      DDRD  = 0b00000000;
      PORTD = 0b10000000;
      DDRB  = 0b111100;
      PORTB = 0b000011;
        case 0b000001 :
        DDRD  = 0b10000000;
        PORTD = 0b00000000;
        DDRB  = 0b000011;
        PORTB = 0b111100;
        PORTC = 0b100000;
        waitMs(200);     // 6
        break;
        case 0b000010 :
        DDRD  = 0b10000000;
        PORTD = 0b00000000;
        DDRB  = 0b000011;
        PORTB = 0b111100;
        PORTC = 0b010000;
        waitMs(200);     // 5
        break;
        default :
        DDRD  = 0b10000000;
        PORTD = 0b00000000;
        DDRB  = 0b000011;
        PORTB = 0b111100;
        PORTC = 0b001000;
        waitMs(200);     // 4
        break;
      break;
      case 0b101100  :
      DDRD  = 0b00000000;
      PORTD = 0b10000000;
      DDRB  = 0b111100;
      PORTB = 0b000011;
        case 0b000001 :
        DDRD  = 0b10000000;
        PORTD = 0b00000000;
        DDRB  = 0b000011;
        PORTB = 0b111100;
        PORTC = 0b100000;
        waitMs(200);      // 9
        break;
        case 0b000010 :
        DDRD  = 0b10000000;
        PORTD = 0b00000000;
        DDRB  = 0b000011;
        PORTB = 0b111100;
        PORTC = 0b010000;
        waitMs(200);     // 8
        break;
        default :
        DDRD  = 0b10000000;
        PORTD = 0b00000000;
        DDRB  = 0b000011;
        PORTB = 0b111100;
        PORTC = 0b001000;
        waitMs(200);     // 7
        break;
      break;
      case 0b011100  :
      DDRD  = 0b00000000;
      PORTD = 0b10000000;
      DDRB  = 0b111100;
      PORTB = 0b000011;
        case 0b000001 :
        DDRD  = 0b10000000;
        PORTD = 0b00000000;
        DDRB  = 0b000011;
        PORTB = 0b111100;
        PORTC = 0b100000;
        waitMs(200);       // #
        break;
        case 0b000010 :
        DDRD  = 0b10000000;
        PORTD = 0b00000000;
        DDRB  = 0b000011;
        PORTB = 0b111100;
        PORTC = 0b010000;
        waitMs(200);     // 0
        break;
        default :
        DDRD  = 0b10000000;
        PORTD = 0b00000000;
        DDRB  = 0b000011;
        PORTB = 0b111100;
        PORTC = 0b001000;
        waitMs(200);     //  *
        break;
      break;
      default :
      PORTC = 0x00;
      break;
Leider bin ich noch recht unerfahren im Programmieren von
Mikrocontrollern .
Der Quelltext kann bereits genau unterscheiden welche Taste genau
gedrückt wird auch wenn ich denke das ich das ziemlich umständlich
umgesetzt habe .
Soweit so gut allerdings kommt mir keine Idee wie ich jetzt einen Code
einprogrammieren könnte der nach richtiger Eingabe beispielsweise eine
LED schaltet .
Vielleicht kann mir hier jemand mal einen Ansatz bzw ein Stichwort geben
wie ich das umsetzten könnte .
Lieben Dank schonmal und Gruß
Autor: Flo (Gast)
du speicherst die Werte (ich nehme mal Zahlen von 0-9 an) in einer
Variable.
Dabei kannst du die Zahlen entweder verschieben oder mit einem Faktor
multiplizieren:
z.B.
Wert = 0;
Taste 2 gedrückt
-> Wert *= 10;     //"verschoben" um 10, hier egal, da 0
-> Wert += 2;      // Wert ist 2
Taste 4 gedrückt
-> Wert * 10;
-> Wert += 4;      //Wert ist jetzt 24
Taste bestätigen
-> if Wert == Code
-> Piepen
Autor: Karl Heinz (kbuchegg) (Moderator)
Wie ist die angeschlossen (Schaltplan)
Der Code schreit förmlich danach mit ein paar Schleifen und sonstigen
Sachen drastisch vereinfacht zu werden.
> LED schaltet .
Warte noch.
Sieh erst mal zu, dass die Matrixabfrage einfacher wird
Letztenendes willst du bei einer Funktion landen, die dir sagt welche
Taste gedrückt ist. Das ist dein erstes Zwischenziel. Aber der jetzige
Code ist mit seinen vielen Port Zugriffen und Binärkonstanten soweit
undurchschaubar, dass sich diese Funktion nicht wirkich aufdrängt.
Der Code agiert so ähnlich wie in einer Analogie jemand der nicht
Multiplizeren kann und 3 * 4 bestimmt indem er 3 + 3 + 3 + 3 ausrechnet.
Nicht wirklich falsch aber deutlich zu kompliziert.
Autor: Andre (Gast)
Ich habe mal etwas überlegt allerdings fällt mir einfach nichts anderes
ein .
Am besten wären natürlich Befehle bzw Abfragen die direkt aus der
Binärkombination der Matrix erkennt welche Taste genau gedrückt ist .
Ich wollte ja zb auch einen Lernmodus einbauen mit dem ich dann einen
neuen Code einprogrammieren kann .
Ich brächte da echt Hilfe von euch zumindest ein Stichwort womit ich es
umsetzen kann .
Ich wurschtel mich dann irgendwie durch wenn ich die grobe Richtung
kenne .
Kann man sowas nicht am besten mit Interrups realisieren ? .
So würden die Tastenabfragen nicht in der ständig wiederholenden
Programmschleife liegen .
Ja.
Aber erst mal eins nach dem anderen.
Also: Wie ist die Matrix verschaltet?
Autor: Andre (Gast)
Also die Spalten liegen jeweils an PIN 1..3 und die Zeilen an 4..7 .
Daher habe ich quasi in den case Abfragen erst ausgelesen welche Zeile
gedrückt wurde und innerhalb dessen dann welche Spalte genau damit ich
am Ende die Zuordnung für exakt eine Zahl bekomme .
Autor: Andre (Gast)
Ich bin jetzt soweit das ich mir Gedanken mache wie ich den Code den nun
wirklich "vergleichen" kann .
Ich habe zwar schon mit Rechnungen versucht aber z.B. wenn ich 1234
nehme und es rückwärts eingebe wird es auch als richtig erkannt .
Wie könnte man sowas denn umsetzen ? Die Lösung von "Flo" habe ich nicht
ganz verstanden bzw wenn ich sie richtig verstanden habe komme ich zum
selben Problem .
Es darf einfach nur ein einziger Code auch richtig sein .
Habe es mal mit Strings versucht da denn der Code an sich verglichen
wird bin dann aber daran gescheitert das ich mein tmpCode = "0" nicht
ausführen konnte weil irgendwas mit char und const char nicht passt ?!.
Wäre für jede Idee dankbar
Du könntest zb so etwas machen:
Du hast eine Funktion, die dir einen Tastendruck liefert. Das ist
schon mal einer der wichtigen Punkte: Wird eine Taste gedrückt, dann
liefert dir die Funktion den Code für diese Taste nur ein einziges mal.
OK. Ich gehe davon aus, dass du so etwas hast.
Vergiss auch erst mal die Werte, die auf den Tasten stehen. Jede Taste
hat einen Code, nur der ist wichtig (damit man die Ziffern von den
restlichen Tasten unterscheiden kann)
Die Frage lautet daher:
Dein Benutzer drückt nacheinander Tasten. Wie kannst du feststellen,
dass zb die letzten 4 Tastendrücke genau einer vorgegebenen Sequenz
entsprechen?
In der Fragestellung ist in einem gewissen Umfang auch schon die Lösung
enthalten. 'die letzten 4 Tastendrücke'
Die wird man sich zwischenspeichern müssen. Bei jedem Tastendruck wird
die älteste entfernt, dafür kommt die neu gedrückte Taste dazu. Und dann
schaut man einfach, ob die 4 Tastendrücke der vorgegebenen Sequenz
entsprechen. Wenn ja: Bingo
Lösungsansatz 1:
Du hast ein Array von 4 Werten. Nennen wir es
  unsigned char Input[4];
Input[0] sei dabei der 'älteste' Tastendruck (ausgedrückt als der dieser
Taste zugeordnete Code). Input[3] sie die zuletzt gedrückte.
Drückt der Benutzer eine Taste, dann wird sie 'hinten im Array
angehängt'. Dies geschieht, indem der älteste Tastendruck verworfen
wird, alle anderen um 1 Stelle im Array nach vorne rutschen und der neue
Tastendruck an die Position Input[3] kommt
  for( i = 1; i < 4; ++i )
    Input[i-1] = Input[i];
  Input[3] = neuer_Tasten_Code;
Dann hat man natürlich noch ein 2-tes Array, in dem die korrekte
Tastenkombination drinnensteht
  unsigned char Code[4] = { 1, 8, 5, 3 };
und nachdem die neu gedrückte Taste im Input Array gelandet ist,
vergleicht man einfach, ob alle Stellen in Input damit mit Code
übereinstimmen. Das macht man in einer Schleife indem man jeweils
korrespondierende Arrayelemente miteinander vergeleicht. Ausgansgpunkt
ist die Annahme: der Code ist korrekt und sobald man ein Pärchen
gefunden hat, welches nicht übereinstimmt revidiert man diese Annahme:
der eingegebene Code ist nicht korrekt. Nach der Schleife prüft man
einfach, ob die ursprüngliche Annahme gehalten hat oder nicht.
  korrekt = TRUE;
  for( i = 0; i < 4; ++i ) {
    if( Input[i] != Code[i] )
      korrekt = FALSE;
  if( korrekt )
    öffne_Tür
Das ist eine Möglichkeit.
Eine andere sieht so aus, das man sich die bisher eingegebenen Tasten
nicht merkt, sondern nur wieviele Stellen bisher korrekt waren. Kommt
ein neuer Tastendruck der stimmt (mit dem Code vergleichen), dann hat
man wieder eine korrekte Taste mehr. Stimmen sie nicht überein, dann
wird die Anzahl der korrekten Tasten wieder auf 0 gesetzt
unsigned char bisher_korrekt;
  while( 1 ) {
    if( neuer_Tasten_Code == Code[ bisher_korrekt ] )
      bisher_korrekt++;
    else
      bisher_korrekt = 0;
    if( bisher_korrekt == 4 )
      öffne_Tür
Die zweite Variante ist signifikant kürzer und auch ein wenig
trickreicher als die erste. Hat man aber das Prinzip erst mal so
einigermassen, ist sie aber denk ich auch nicht schwieriger als die
erste.
Autor: Andre (Gast)
Naja habe jetzt wieder das ganze über den Haufen geworfen .
Die Abfrage der einzelnen Tasten ist immernoch totaler Mist .
Zb dürfte die Taste ja auch nicht mehrfach gezählt werden wenn man sie
länger hält .
Den Abgleich vom Code habe ich insofern erstmal gelöst gehabt als das
ich strcat bei Tastendruck immer ein Zeichen also z.B. eine 1,2 etc in
einen Leerstring schreiben lassen habe .
Am Ende wurde dann immer der String mit dem eingespeicherten String
verglichen usw.
Hat super geklappt aber wie gesagt diese Tastenmatrix macht mir doch zu
schaffen weil man sie ja in erster Linie nichtmal direkt ansprechen kann
Gibt es nicht irgendeine Möglichkeit ausser zB. ADC die Tasten auf
Anhieb zu erkennen .Bzw eine Funktion die nur die Taste annimmt wenn man
sie auch wieder losgelassen hat würde ja meiner Meinung nach schon
helfen .
> länger hält .
Richtig.
Schau dir mal diesen Artikel an. Der stammt zwar aus dem Assembler
Tutorial, die Gedankengänge sind aber hoffentlich gut genug beschrieben
um die Ideen nachvollziehen zu können.
http://www.mikrocontroller.net/articles/AVR-Tutorial:_Tasten
Solange du dieses Teilproblem nicht zufriedenstellend gelöst hast, hat
es keinen Sinn darauf aufbeuend weiterzuarbeiten.
