Hallo allerseits,
für ein Projekt benötige ich einen true dual port asynchronous ram. Da
das ganze auf verschiedenen Plattformen (Xilinx, Altera, Lattice) laufen
soll, muss der RAM-Block über Inferenz vom Synthesetool erzeugt werden.
folgenden VHDL-Code habe ich dazu genutzt:
1 | --
2 | -- Dual-Port Block RAM with Two Write Ports
3 | --
4 |
5 | library IEEE;
6 | use IEEE.std_logic_1164.all;
7 | use IEEE.std_logic_unsigned.all;
8 |
9 | entity TDPR is
10 | generic( width : natural := 16;
11 | depth : natural := 6);
12 |
13 | port ( clka : in std_logic;
14 | clkb : in std_logic;
15 | ena : in std_logic;
16 | enb : in std_logic;
17 | wea : in std_logic;
18 | web : in std_logic;
19 | rsta : in std_logic;
20 | rstb : in std_logic;
21 | addra : in std_logic_vector(depth-1 downto 0);
22 | addrb : in std_logic_vector(depth-1 downto 0);
23 | dia : in std_logic_vector(width-1 downto 0);
24 | dib : in std_logic_vector(width-1 downto 0);
25 | doa : out std_logic_vector(width-1 downto 0);
26 | dob : out std_logic_vector(width-1 downto 0));
27 | end TDPR;
28 |
29 | architecture syn of TDPR is
30 | type ram_type is array ((2**depth)-1 downto 0) of std_logic_vector(width-1 downto 0);
31 | shared variable RAM : ram_type;
32 | begin
33 | process(CLKA)
34 | begin
35 | if CLKA'event and CLKA = '1' then
36 | if ENA = '1' then
37 | if WEA = '1' then
38 | RAM(conv_integer(ADDRA)) := DIA;
39 | end if;
40 | if rsta = '1' then -- optional reset
41 | doa <= (others => '0');
42 | else
43 | doa <= ram(conv_integer(addra)) ;
44 | end if;
45 | end if;
46 | end if;
47 | end process;
48 |
49 | process (CLKB)
50 | begin
51 | if CLKB'event and CLKB = '1' then
52 | if ENB = '1' then
53 | if WEB = '1' then
54 | RAM(conv_integer(ADDRB)) := DIB;
55 | end if;
56 | if rstb = '1' then -- optional reset
57 | dob <= (others => '0');
58 | else
59 | dob <= ram(conv_integer(addrb)) ;
60 | end if;
61 | end if;
62 | end if;
63 | end process;
64 | end syn;
Das ganze wird von Xilinx ISE auch wie gewünscht umgesetzt. Quartus
hingegen spuckt mir die Fehlermeldung "Error: Cannot synthesize
dual-port RAM logic "TDPR:inst|RAM"" mit einem internal Error aus,
scheinbar kann Quartus die shared variable RAM nicht korrekt umsetzen.
Hat jemand damit schon Erfahrungen? Gibt es vllt ne andere Möglichkeit
den RAM-Block zu beschreiben?
mit besten Grüßen, exor
