1 | /*********************************************************************
2 | * FileName: user.c
3 | * Dependencies: See INCLUDES section below
4 | * Processor: PIC18
5 | * Compiler: C18 2.30.01+
6 | * Company: Microchip Technology, Inc.
7 | *
8 | * modified by sprut
9 | *
10 | ********************************************************************/
11 |
12 | /** I N C L U D E S **********************************************************/
13 | #include <p18cxxx.h>
14 | #include <usart.h>
15 | #include "system\typedefs.h"
16 | #include "system\usb\usb.h"
17 | #include "io_cfg.h" // I/O pin mapping
18 | #include "user\user.h"
19 | #include "lcd.h"
20 |
21 |
22 | /** Configuration ********************************************************/
23 | #pragma config PLLDIV = 5 // (20 MHz input)
24 | #pragma config CPUDIV = OSC1_PLL2
25 | #pragma config USBDIV = 2 // Clock source from 96MHz PLL/2
26 | #pragma config FOSC = HSPLL_HS
27 | //#pragma config FCMEN = OFF
28 | #pragma config IESO = OFF
29 | #pragma config PWRT = ON
30 | #pragma config BOR = OFF
31 | //#pragma config BORV = 3
32 | #pragma config VREGEN = ON
33 | #pragma config WDT = OFF
34 | #pragma config WDTPS = 32768
35 | #pragma config MCLRE = OFF
36 | #pragma config LPT1OSC = OFF
37 | #pragma config PBADEN = OFF
38 | #pragma config CCP2MX = ON
39 | #pragma config STVREN = ON
40 | #pragma config LVP = OFF
41 | //#pragma config ICPRT = OFF // Dedicated In-Circuit Debug/Programming
42 | #pragma config XINST = OFF // Extended Instruction Set
43 | #pragma config CP0 = OFF
44 | #pragma config CP1 = OFF
45 | #pragma config CP2 = OFF
46 | //#pragma config CP3 = OFF
47 | #pragma config CPB = OFF
48 | #pragma config CPD = OFF
49 | #pragma config WRT0 = OFF
50 | #pragma config WRT1 = OFF
51 | #pragma config WRT2 = OFF
52 | //#pragma config WRT3 = OFF
53 | #pragma config WRTB = OFF // Boot Block Write Protection
54 | #pragma config WRTC = OFF
55 | #pragma config WRTD = OFF
56 | #pragma config EBTR0 = OFF
57 | #pragma config EBTR1 = OFF
58 | #pragma config EBTR2 = OFF
59 | //#pragma config EBTR3 = OFF
60 | #pragma config EBTRB = OFF
61 |
62 |
63 |
64 |
65 | /** V A R I A B L E S ********************************************************/
66 | // hier die variablen definieren...
67 | #pragma udata
68 | byte data[20]; // bis 64bytes möglich, oder dann descriptor(?) ändern
69 | BYTE _data[1];
70 | typedef unsigned char T_Bitvar;
71 |
72 | typedef struct
73 | {
74 | unsigned bit0:1;
75 | unsigned bit1:1;
76 | unsigned bit2:1;
77 | unsigned bit3:1;
78 | unsigned bit4:1;
79 | unsigned bit5:1;
80 | unsigned bit6:1;
81 | unsigned bit7:1;
82 | } T_Bitvar;
83 |
84 | T_Bitvar bitvar1[1];
85 |
86 |
87 |
88 |
89 | /** D E C L A R A T I O N S **************************************************/
90 | // hier persönliche initialisierungen definieren...
91 | #pragma code
92 | void UserInit(void) {
93 | LATB &= 0x00;
94 | TRISB = 0x00;
95 | //LCD_Init();
96 | ADCON1 &= 0x0F;
97 | }//end UserInit
98 |
99 |
100 | void setpin (void)
101 | {
102 | // data[1] = port
103 | // data[2] = pin
104 | // data[3] = level
105 |
106 | int x;
107 | x = (int)data[3];
108 | switch ((int)data[1])
109 | {
110 | case 92:
111 | //LATA &= 0x00;
112 | //TRISA = 0x00;
113 | switch ((int)data[2])
114 | {
115 | case 3: TRISAbits.TRISA3 = 0; Delay10KTCYx(10); LATAbits.LATA3 = x; break;
116 | case 4: TRISAbits.TRISA4 = 0; Delay10KTCYx(10); LATAbits.LATA4 = x; break;
117 | case 5: TRISAbits.TRISA5 = 0; Delay10KTCYx(10); LATAbits.LATA5 = x; break;
118 | case 6: TRISAbits.TRISA6 = 0; Delay10KTCYx(10); LATAbits.LATA6 = x; break;
119 | }
120 | break;//end port a
121 |
122 | case 93:
123 | //LATB &= 0x00;
124 | //TRISB = 0x00;
125 | switch ((int)data[2])
126 | {
127 | case 0: TRISBbits.TRISB0 = 0; Delay10KTCYx(10); LATBbits.LATB0 = x; break;
128 | case 1: TRISBbits.TRISB1 = 0; Delay10KTCYx(10); LATBbits.LATB1 = x; break;
129 | case 2: TRISBbits.TRISB2 = 0; Delay10KTCYx(10); LATBbits.LATB2 = x; break;
130 | case 3: TRISBbits.TRISB3 = 0; Delay10KTCYx(10); LATBbits.LATB3 = x; break;
131 | case 4: TRISBbits.TRISB4 = 0; Delay10KTCYx(10); LATBbits.LATB4 = x; break;
132 | case 5: TRISBbits.TRISB5 = 0; Delay10KTCYx(10); LATBbits.LATB5 = x; break;
133 | case 6: TRISBbits.TRISB6 = 0; Delay10KTCYx(10); LATBbits.LATB6 = x; break;
134 | case 7: TRISBbits.TRISB7 = 0; Delay10KTCYx(10); LATBbits.LATB7 = x; break;
135 | default: break;
136 | }
137 | break;// end port b
138 | case 94:
139 | //LATC &= 0x00;
140 | //TRISC = 0x00;
141 | switch ((int)data[2])
142 | {
143 | case 1: TRISCbits.TRISC1 = 0; Delay10KTCYx(10); LATCbits.LATC1 = x; break;
144 | case 2: TRISCbits.TRISC2 = 0; Delay10KTCYx(10); LATCbits.LATC2 = x; break;
145 | case 6: TRISCbits.TRISC6 = 0; Delay10KTCYx(10); LATCbits.LATC6 = x; break;
146 | case 7: TRISCbits.TRISC7 = 0; Delay10KTCYx(10); LATCbits.LATC7 = x; break;
147 | break;
148 | }
149 | break;// end port c
150 | case 95:
151 | //LATD &= 0x00;
152 | //TRISD = 0x00;
153 | switch ((int)data[2])
154 | {
155 | case 0: TRISDbits.TRISD0 = 0; Delay10KTCYx(10); LATDbits.LATD0 = x; break;
156 | case 1: TRISDbits.TRISD1 = 0; Delay10KTCYx(10); LATDbits.LATD1 = x; break;
157 | case 2: TRISDbits.TRISD2 = 0; Delay10KTCYx(10); LATDbits.LATD2 = x; break;
158 | case 3: TRISDbits.TRISD3 = 0; Delay10KTCYx(10); LATDbits.LATD3 = x; break;
159 | case 4: TRISDbits.TRISD4 = 0; Delay10KTCYx(10); LATDbits.LATD4 = x; break;
160 | case 5: TRISDbits.TRISD5 = 0; Delay10KTCYx(10); LATDbits.LATD5 = x; break;
161 | case 6: TRISDbits.TRISD6 = 0; Delay10KTCYx(10); LATDbits.LATD6 = x; break;
162 | case 7: TRISDbits.TRISD7 = 0; Delay10KTCYx(10); LATDbits.LATD7 = x; break;
163 | break;
164 | }
165 | break;// end port d
166 | case 96:
167 | //LATE &= 0x00;
168 | //TRISE = 0x00;
169 | switch ((int)data[2])
170 | {
171 | case 0: TRISEbits.TRISE0 = 0; Delay10KTCYx(10); LATEbits.LATE0 = x; break;
172 | case 1: TRISEbits.TRISE1 = 0; Delay10KTCYx(10); LATEbits.LATE1 = x; break;
173 | case 2: TRISEbits.TRISE2 = 0; Delay10KTCYx(10); LATEbits.LATE2 = x; break;
174 | break; }
175 | break;// end port e
176 | }
177 | }
178 |
179 | void setport (void)
180 | {
181 | //data[1] = port
182 | //data[2]-[9] = bitfolge
183 |
184 | int bit0;
185 | int bit1;
186 | int bit2;
187 | int bit3;
188 | int bit4;
189 | int bit5;
190 | int bit6;
191 | int bit7;
192 |
193 | bit0 = (int)data[2];
194 | bit1 = (int)data[3];
195 | bit2 = (int)data[4];
196 | bit3 = (int)data[5];
197 | bit4 = (int)data[6];
198 | bit5 = (int)data[7];
199 | bit6 = (int)data[8];
200 | bit7 = (int)data[9];
201 |
202 | switch ((int)data[1])
203 | {
204 | case 92:
205 | break;
206 | case 93: LATB &= 0x00;
207 | TRISB = 0x00;
208 | LATBbits.LATB0 = bit0;
209 | LATBbits.LATB1 = bit1;
210 | LATBbits.LATB2 = bit2;
211 | LATBbits.LATB3 = bit3;
212 | LATBbits.LATB4 = bit4;
213 | LATBbits.LATB5 = bit5;
214 | LATBbits.LATB6 = bit6;
215 | LATBbits.LATB7 = bit7;
216 | break;
217 | case 94:
218 | break;
219 | case 95: LATD &= 0x00;
220 | TRISD = 0x00;
221 | LATDbits.LATD0 = bit0;
222 | LATDbits.LATD1 = bit1;
223 | LATDbits.LATD2 = bit2;
224 | LATDbits.LATD3 = bit3;
225 | LATDbits.LATD4 = bit4;
226 | LATDbits.LATD5 = bit5;
227 | LATDbits.LATD6 = bit6;
228 | LATDbits.LATD7 = bit7;
229 | break;
230 | case 96: LATE &= 0x00;
231 | TRISE = 0x00;
232 | LATEbits.LATE0 = bit0;
233 | LATEbits.LATE1 = bit1;
234 | LATEbits.LATE2 = bit2;;
235 | break;
236 | }
237 | }
238 |
239 |
240 |
241 | void getport (void)
242 | {
243 | // data[1] = Port
244 |
245 | switch ((int)data[1]){
246 | case 92: TRISA = 0xFF;
247 | Delay10KTCYx(100);
248 | data[0] = PORTA;
249 | break;
250 | case 93: TRISB = 0xFF;
251 | Delay10KTCYx(100);
252 | data[0] = PORTB;
253 | break;
254 | case 94: TRISC = 0xFF;
255 | Delay10KTCYx(100);
256 | data[0] = PORTC;
257 | break;
258 | case 95: TRISD = 0xFF;
259 | Delay10KTCYx(100);
260 | data[0] = PORTD;
261 | break;
262 | case 96: TRISE = 0xFF;
263 | Delay10KTCYx(100);
264 | data[0] = PORTE;
265 | break;
266 | }
267 | }
268 |
269 | void getpin (void)
270 | {
271 | // data[1] = port
272 | // data[2] = Pin
273 |
274 | switch ((int)data[1])
275 | {
276 | case 92: //TRISA = 0xFF;
277 | switch ((int)data[2]){
278 | case 0: TRISAbits.TRISA0 = 1; Delay10KTCYx(10); data[0] =PORTAbits.RA0; break;
279 | case 1: TRISAbits.TRISA1 = 1; Delay10KTCYx(10); data[0] =PORTAbits.RA1; break;
280 | case 2: TRISAbits.TRISA2 = 1; Delay10KTCYx(10); data[0] =PORTAbits.RA2; break;
281 | case 3: TRISAbits.TRISA3 = 1; Delay10KTCYx(10); data[0] =PORTAbits.RA3; break;
282 | case 4: TRISAbits.TRISA4 = 1; Delay10KTCYx(10); data[0] =PORTAbits.RA4; break;
283 | case 5: TRISAbits.TRISA5 = 1; Delay10KTCYx(10); data[0] =PORTAbits.RA5; break;
284 | case 6: TRISAbits.TRISA6 = 1; Delay10KTCYx(10); data[0] =PORTAbits.RA6; break;
285 | }
286 | break;
287 | case 93: //PORTB = 0;
288 | //TRISB = 0xFF;
289 | switch ((int)data[2]){
290 | case 0: TRISBbits.TRISB0 = 1; Delay10KTCYx(10); data[0] =PORTBbits.RB0; break;
291 | case 1: TRISBbits.TRISB1 = 1; Delay10KTCYx(10); data[0] =PORTBbits.RB1; break;
292 | case 2: TRISBbits.TRISB2 = 1; Delay10KTCYx(10); data[0] =PORTBbits.RB2; break;
293 | case 3: TRISBbits.TRISB3 = 1; Delay10KTCYx(10); data[0] =PORTBbits.RB3; break;
294 | case 4: TRISBbits.TRISB4 = 1; Delay10KTCYx(10); data[0] =PORTBbits.RB4; break;
295 | case 5: TRISBbits.TRISB5 = 1; Delay10KTCYx(10); data[0] =PORTBbits.RB5; break;
296 | case 6: TRISBbits.TRISB6 = 1; Delay10KTCYx(10); data[0] =PORTBbits.RB6; break;
297 | case 7: TRISBbits.TRISB7 = 1; Delay10KTCYx(10); data[0] =PORTBbits.RB7; break;
298 | }
299 | break;
300 | case 94: //TRISC = 0xFF;
301 | switch ((int)data[2]){
302 | case 0: TRISCbits.TRISC0 = 1; Delay10KTCYx(10); data[0] =PORTCbits.RC0; break;
303 | case 1: TRISCbits.TRISC1 = 1; Delay10KTCYx(10); data[0] =PORTCbits.RC1; break;
304 | case 2: TRISCbits.TRISC2 = 1; Delay10KTCYx(10); data[0] =PORTCbits.RC2; break;
305 | case 6: TRISCbits.TRISC6 = 1; Delay10KTCYx(10); data[0] =PORTCbits.RC6; break;
306 | case 7: TRISCbits.TRISC7 = 1; Delay10KTCYx(10); data[0] =PORTCbits.RC7; break;
307 | }
308 | break;
309 | case 95: //TRISD = 0xFF;
310 | switch ((int)data[2]){
311 | case 0: TRISDbits.TRISD0 = 1; Delay10KTCYx(10); data[0] =PORTDbits.RD0; break;
312 | case 1: TRISDbits.TRISD1 = 1; Delay10KTCYx(10); data[0] =PORTDbits.RD1; break;
313 | case 2: TRISDbits.TRISD2 = 1; Delay10KTCYx(10); data[0] =PORTDbits.RD2; break;
314 | case 3: TRISDbits.TRISD3 = 1; Delay10KTCYx(10); data[0] =PORTDbits.RD3; break;
315 | case 4: TRISDbits.TRISD4 = 1; Delay10KTCYx(10); data[0] =PORTDbits.RD4; break;
316 | case 5: TRISDbits.TRISD5 = 1; Delay10KTCYx(10); data[0] =PORTDbits.RD5; break;
317 | case 6: TRISDbits.TRISD6 = 1; Delay10KTCYx(10); data[0] =PORTDbits.RD6; break;
318 | case 7: TRISDbits.TRISD7 = 1; Delay10KTCYx(10); data[0] =PORTDbits.RD7; break;
319 | }
320 | break;
321 | case 96: //TRISE = 0xFF;
322 | switch ((int)data[2]){
323 | case 0: TRISEbits.TRISE0 = 1; Delay10KTCYx(10); data[0] =PORTEbits.RE0; break;
324 | case 1: TRISEbits.TRISE1 = 1; Delay10KTCYx(10); data[0] =PORTEbits.RE1; break;
325 | case 2: TRISEbits.TRISE2 = 1; Delay10KTCYx(10); data[0] =PORTEbits.RE2; break;
326 | }
327 | break;
328 | }
329 |
330 | }
331 |
332 | void pause(void)
333 | {
334 | Delay10KTCYx(10);
335 | }
336 |
337 |
338 | /** " M A I N " - P R O G R A M ********************************************/
339 |
340 | void ProcessIO(void) {
341 | if(USBGenRead(data,20)) {
342 | switch ((int)data[0]) { // entscheidet anhand des ersten Bytes um welchen fall
343 | case 0: pause();
344 | break;
345 | case 1: setpin(); // port, pin, zustand
346 | break;
347 | case 2: setport();
348 | break; // port, bitfolge
349 | case 3: getpin();
350 | if(!mUSBGenTxIsBusy())
351 | USBGenWrite(data,1);
352 | break; // pin, port
353 | case 4: getport();
354 | if(!mUSBGenTxIsBusy())
355 | USBGenWrite(data,1); // port
356 | break;
357 | case 5: getpin();
358 | if(!mUSBGenTxIsBusy())
359 | USBGenWrite(data,1); // port
360 | break;
361 | }
362 | }
363 | }//end ProcessIO
