1 | /*****************************************************************************
2 | * can.c: CAN module API file for NXP LPC17xx Family Microprocessors
3 | *
4 | * Copyright(C) 2009, NXP Semiconductor
5 | * All rights reserved.
6 | *
7 | * History
8 | * 2009.05.27 ver 1.00 Prelimnary version, first Release
9 | * 13.10.2010 ver 1.1 Änderung bezüglich CAN2
10 | *****************************************************************************/
11 | #include "lpc17xx.h"
12 | #include "type.h"
13 | #include "can.h"
14 |
15 | /* Receive Queue: one queue for each CAN port */
16 | extern CAN_MSG MsgBuf_RX1;
17 | extern volatile uint32_t CAN1RxDone;
18 | volatile uint32_t CANStatus;
19 | uint32_t CAN1RxCount = 0;
20 | uint32_t CAN1ErrCount = 0;
21 |
22 | /******************************************************************************
23 | ** Function name: CAN_ISR_Rx1
24 | **
25 | ** Descriptions: CAN Rx1 interrupt handler
26 | **
27 | ** parameters: None
28 | ** Returned value: None
29 | **
30 | ******************************************************************************/
31 | void CAN_ISR_Rx1( void )
32 | {
33 | uint32_t * pDest;
34 |
35 | /* initialize destination pointer */
36 | pDest = (uint32_t *)&MsgBuf_RX1;
37 | *pDest = LPC_CAN1->RFS; /* Frame */
38 |
39 | pDest++;
40 | *pDest = LPC_CAN1->RID; /* ID */
41 |
42 |
43 | pDest++;
44 | *pDest = LPC_CAN1->RDA; /* Data A */
45 |
46 |
47 | pDest++;
48 | *pDest = LPC_CAN1->RDB; /* Data B */
49 |
50 |
51 | CAN1RxDone = TRUE;
52 | LPC_CAN1->CMR = 0x04; /* release receive buffer */
53 | return;
54 | }
55 |
56 | /*****************************************************************************
57 | ** Function name: CAN_Handler
58 | **
59 | ** Descriptions: CAN interrupt handler
60 | **
61 | ** parameters: None
62 | ** Returned value: None
63 | **
64 | *****************************************************************************/
65 | void CAN_IRQHandler(void)
66 | {
67 |
68 | CANStatus = LPC_CANCR->CANRxSR;
69 | if ( CANStatus & (1 << 8) )
70 | {
71 | CAN1RxCount++;
72 | CAN_ISR_Rx1();
73 | }
74 |
75 | if ( LPC_CAN1->GSR & (1 << 6 ) )
76 | {
77 | /* The error count includes both TX and RX */
78 | CAN1ErrCount = LPC_CAN1->GSR >> 16;
79 | }
80 | return;
81 | }
82 |
83 | /******************************************************************************
84 | ** Function name: CAN_Init
85 | **
86 | ** Descriptions: Initialize CAN, install CAN interrupt handler
87 | **
88 | ** parameters: bitrate
89 | ** Returned value: true or false, false if initialization failed.
90 | **
91 | ******************************************************************************/
92 | uint32_t CAN_Init( uint32_t can_btr )
93 | {
94 | CAN1RxDone = FALSE;
95 |
96 | LPC_SC->PCONP |= ((1<<13)|(1<<14)); /* Enable CAN1 and CAN2 clock */
97 |
98 | LPC_PINCON->PINSEL0 &= ~0x0000000F; /* CAN1 is p0.0 and p0.1 */
99 | LPC_PINCON->PINSEL0 |= 0x00000005;
100 |
101 | LPC_CAN1->MOD = 1; /* Reset CAN */
102 | LPC_CAN1->IER = 0; /* Disable Receive Interrupt */
103 | LPC_CAN1->GSR = 0; /* Reset error counter when CANxMOD is in reset */
104 |
105 | LPC_CAN1->BTR = can_btr;
106 | LPC_CAN1->MOD = 0x0; /* CAN in normal operation mode */
107 |
108 | LPC_CAN1->IER = 0x01; /* Enable receive interrupts */
109 | return( TRUE );
110 | }
111 |
112 | /******************************************************************************
113 | ** Function name: CAN_SetACCF_Lookup
114 | **
115 | ** Descriptions: Initialize CAN, install CAN interrupt handler
116 | **
117 | ** parameters: bitrate
118 | ** Returned value: true or false, false if initialization failed.
119 | **
120 | ******************************************************************************/
121 | void CAN_SetACCF_Lookup( void )
122 | {
123 | uint32_t address = 0;
124 | uint32_t i;
125 | uint32_t ID_high, ID_low;
126 |
127 | /* Set explicit standard Frame */
128 | LPC_CANAF->SFF_sa = address;
129 | for ( i = 0; i < ACCF_IDEN_NUM; i += 2 )
130 | {
131 | ID_low = (i << 29) | (EXP_STD_ID << 16);
132 | ID_high = ((i+1) << 13) | (EXP_STD_ID << 0);
133 | *((volatile uint32_t *)(LPC_CANAF_RAM_BASE + address)) = ID_low | ID_high;
134 | address += 4;
135 | }
136 |
137 | /* Set group standard Frame */
138 | LPC_CANAF->SFF_GRP_sa = address;
139 | for ( i = 0; i < ACCF_IDEN_NUM; i += 2 )
140 | {
141 | ID_low = (i << 29) | (GRP_STD_ID << 16);
142 | ID_high = ((i+1) << 13) | (GRP_STD_ID << 0);
143 | *((volatile uint32_t *)(LPC_CANAF_RAM_BASE + address)) = ID_low | ID_high;
144 | address += 4;
145 | }
146 |
147 | /* Set explicit extended Frame */
148 | LPC_CANAF->EFF_sa = address;
149 | for ( i = 0; i < ACCF_IDEN_NUM; i++ )
150 | {
151 | ID_low = (i << 29) | (EXP_EXT_ID << 0);
152 | *((volatile uint32_t *)(LPC_CANAF_RAM_BASE + address)) = ID_low;
153 | address += 4;
154 | }
155 |
156 | /* Set group extended Frame */
157 | LPC_CANAF->EFF_GRP_sa = address;
158 | for ( i = 0; i < ACCF_IDEN_NUM; i++ )
159 | {
160 | ID_low = (i << 29) | (GRP_EXT_ID << 0);
161 | *((volatile uint32_t *)(LPC_CANAF_RAM_BASE + address)) = ID_low;
162 | address += 4;
163 | }
164 |
165 | /* Set End of Table */
166 | LPC_CANAF->ENDofTable = address;
167 | return;
168 | }
169 |
170 | /******************************************************************************
171 | ** Function name: CAN_SetACCF
172 | **
173 | ** Descriptions: Set acceptance filter and SRAM associated with
174 | **
175 | ** parameters: ACMF mode
176 | ** Returned value: None
177 | **
178 | **
179 | ******************************************************************************/
180 | void CAN_SetACCF( uint32_t ACCFMode )
181 | {
182 | switch ( ACCFMode )
183 | {
184 | case ACCF_OFF:
185 | LPC_CANAF->AFMR = ACCFMode;
186 | LPC_CAN1->MOD = LPC_CAN2->MOD = 1; // Reset CAN
187 | LPC_CAN1->IER = LPC_CAN2->IER = 0; // Disable Receive Interrupt
188 | LPC_CAN1->GSR = LPC_CAN2->GSR = 0; // Reset error counter when CANxMOD is in reset
189 | break;
190 |
191 | case ACCF_BYPASS:
192 | LPC_CANAF->AFMR = ACCFMode;
193 | break;
194 |
195 | case ACCF_ON:
196 | case ACCF_FULLCAN:
197 | LPC_CANAF->AFMR = ACCF_OFF;
198 | CAN_SetACCF_Lookup();
199 | LPC_CANAF->AFMR = ACCFMode;
200 | break;
201 |
202 | default:
203 | break;
204 | }
205 | return;
206 | }
207 |
208 | /******************************************************************************
209 | ** Function name: CAN1_SendMessage
210 | **
211 | ** Descriptions: Send message block to CAN1
212 | **
213 | ** parameters: pointer to the CAN message
214 | ** Returned value: true or false, if message buffer is available,
215 | ** message can be sent successfully, return TRUE,
216 | ** otherwise, return FALSE.
217 | **
218 | ******************************************************************************/
219 | uint32_t CAN1_SendMessage( CAN_MSG *pTxBuf )
220 | {
221 | uint32_t CANStatus;
222 |
223 | CANStatus = LPC_CAN1->SR;
224 | if ( CANStatus & 0x00000004 )
225 | {
226 | LPC_CAN1->TFI1 = pTxBuf->Frame & 0xC00F0000;
227 | LPC_CAN1->TID1 = pTxBuf->MsgID;
228 | LPC_CAN1->TDA1 = pTxBuf->DataA;
229 | LPC_CAN1->TDB1 = pTxBuf->DataB;
230 | LPC_CAN1->CMR = 0x21;
231 | return ( TRUE );
232 | }
233 | else if ( CANStatus & 0x00000400 )
234 | {
235 | LPC_CAN1->TFI2 = pTxBuf->Frame & 0xC00F0000;
236 | LPC_CAN1->TID2 = pTxBuf->MsgID;
237 | LPC_CAN1->TDA2 = pTxBuf->DataA;
238 | LPC_CAN1->TDB2 = pTxBuf->DataB;
239 | LPC_CAN1->CMR = 0x41;
240 | return ( TRUE );
241 | }
242 | else if ( CANStatus & 0x00040000 )
243 | {
244 | LPC_CAN1->TFI3 = pTxBuf->Frame & 0xC00F0000;
245 | LPC_CAN1->TID3 = pTxBuf->MsgID;
246 | LPC_CAN1->TDA3 = pTxBuf->DataA;
247 | LPC_CAN1->TDB3 = pTxBuf->DataB;
248 | LPC_CAN1->CMR = 0x81;
249 | return ( TRUE );
250 | }
251 | return ( FALSE );
252 | }
253 |
254 | /******************************************************************************
255 | ** End Of File
256 | ******************************************************************************/
257 |
258 |
259 | und hier mein main Programm wobei ich weiß das dieses mit Sicherheit so nicht korrekt ist aber deshalb brauch ich ja eure Hilfe =)
260 |
261 | [c]
262 |
263 | /******************************Header Dateien einbinden***********************************/
264 | #include "lpc17xx.h"
265 | #include "type.h"
266 | #include "can.h"
267 |
268 | CAN_MSG MsgBuf_TX1, MsgBuf_TX2; /* TX and RX Buffers for CAN message */
269 | CAN_MSG MsgBuf_RX1, MsgBuf_RX2; /* TX and RX Buffers for CAN message */
270 |
271 | volatile uint32_t CAN1RxDone = FALSE, CAN2RxDone = FALSE;
272 |
273 |
274 | /*****************************************************************************
275 | ** Function name: main
276 | **
277 | ** Descriptions: main routine for CAN module test
278 | **
279 | ** parameters: None
280 | ** Returned value: int
281 | **
282 | *****************************************************************************/
283 | int main( void )
284 | {
285 |
286 | SystemInit();
287 | INOUT_Def();
288 |
289 | /* Please note, the bit timing is based on the setting of the
290 | PCLK, if different PCLK is used, please read can.h carefully
291 | and set your CAN bit timing accordingly. */
292 | //CAN_Init( BITRATE100K24MHZ );
293 | CAN_Init(BITRATE500K15MHZ);
294 | NVIC_EnableIRQ(CAN_IRQn);
295 | CAN_SetACCF(ACCF_BYPASS);
296 | CAN_SetACCF_Lookup();
297 | while(1)
298 | {
299 |
300 | if(!(LPC_CAN1->RID & 0x23))
301 | {
302 | LPC_GPIO2->FIOPIN &= ~(0x000000FF);
303 | }
304 |
305 | }
306 |
307 | }
