Hi, ich sitze nun schon eine Weile an der Labnode (https://www.das-labor.org/wiki/Labnode) und versuche da den USBaspLoader drauf laufen zu lassen. Doch irgendwie will das nicht so recht. Das Original-Makefile ist nur passend für einen ATmega328p geschrieben, und ich bin mir nicht ganz sicher, welche Punkte ich da drin ändern muss, damit der Bootloader startet. Ich habe mich dazu entschieden, den Jumper auf PA1 zu legen. Die Änderungen habe ich entsprechend in der bootloaderconfig.h, main.c und der Makefile gemacht. Hier die Quellcodes der modifizierten Dateien... bootloaderconfig.h:
1 | /* Name: bootloaderconfig.h
2 | * Project: USBaspLoader
3 | * Author: Christian Starkjohann
4 | * Creation Date: 2007-12-08
5 | * Tabsize: 4
6 | * Copyright: (c) 2007 by OBJECTIVE DEVELOPMENT Software GmbH
7 | * License: GNU GPL v2 (see License.txt)
8 | * This Revision: $Id: bootloaderconfig.h 729 2009-03-20 09:03:58Z cs $
9 | */
10 | |
11 | #ifndef __bootloaderconfig_h_included__
12 | #define __bootloaderconfig_h_included__
13 | |
14 | /*
15 | General Description:
16 | This file (together with some settings in Makefile) configures the boot loader
17 | according to the hardware.
18 | |
19 | This file contains (besides the hardware configuration normally found in
20 | usbconfig.h) two functions or macros: bootLoaderInit() and
21 | bootLoaderCondition(). Whether you implement them as macros or as static
22 | inline functions is up to you, decide based on code size and convenience.
23 | |
24 | bootLoaderInit() is called as one of the first actions after reset. It should
25 | be a minimum initialization of the hardware so that the boot loader condition
26 | can be read. This will usually consist of activating a pull-up resistor for an
27 | external jumper which selects boot loader mode.
28 | |
29 | bootLoaderCondition() is called immediately after initialization and in each
30 | main loop iteration. If it returns TRUE, the boot loader will be active. If it
31 | returns FALSE, the boot loader jumps to address 0 (the loaded application)
32 | immediately.
33 | |
34 | For compatibility with Thomas Fischl's avrusbboot, we also support the macro
35 | names BOOTLOADER_INIT and BOOTLOADER_CONDITION for this functionality. If
36 | these macros are defined, the boot loader usees them.
37 | */
38 | |
39 | /* ---------------------------- Hardware Config ---------------------------- */
40 | |
41 | #define USB_CFG_IOPORTNAME C
42 | /* This is the port where the USB bus is connected. When you configure it to
43 | * "B", the registers PORTB, PINB and DDRB will be used.
44 | */
45 | #define USB_CFG_DMINUS_BIT 3
46 | /* This is the bit number in USB_CFG_IOPORT where the USB D- line is connected.
47 | * This may be any bit in the port.
48 | */
49 | #define USB_CFG_DPLUS_BIT 2
50 | /* This is the bit number in USB_CFG_IOPORT where the USB D+ line is connected.
51 | * This may be any bit in the port. Please note that D+ must also be connected
52 | * to interrupt pin INT0!
53 | */
54 | #define USB_CFG_CLOCK_KHZ (F_CPU/1000)
55 | /* Clock rate of the AVR in MHz. Legal values are 12000, 16000 or 16500.
56 | * The 16.5 MHz version of the code requires no crystal, it tolerates +/- 1%
57 | * deviation from the nominal frequency. All other rates require a precision
58 | * of 2000 ppm and thus a crystal!
59 | * Default if not specified: 12 MHz
60 | */
61 | |
62 | /* ----------------------- Optional Hardware Config ------------------------ */
63 | |
64 | /* #define USB_CFG_PULLUP_IOPORTNAME D */
65 | /* If you connect the 1.5k pullup resistor from D- to a port pin instead of
66 | * V+, you can connect and disconnect the device from firmware by calling
67 | * the macros usbDeviceConnect() and usbDeviceDisconnect() (see usbdrv.h).
68 | * This constant defines the port on which the pullup resistor is connected.
69 | */
70 | /* #define USB_CFG_PULLUP_BIT 4 */
71 | /* This constant defines the bit number in USB_CFG_PULLUP_IOPORT (defined
72 | * above) where the 1.5k pullup resistor is connected. See description
73 | * above for details.
74 | */
75 | |
76 | /* ------------------------------------------------------------------------- */
77 | /* ---------------------- feature / code size options ---------------------- */
78 | /* ------------------------------------------------------------------------- */
79 | |
80 | #define HAVE_EEPROM_PAGED_ACCESS 1
81 | /* If HAVE_EEPROM_PAGED_ACCESS is defined to 1, page mode access to EEPROM is
82 | * compiled in. Whether page mode or byte mode access is used by AVRDUDE
83 | * depends on the target device. Page mode is only used if the device supports
84 | * it, e.g. for the ATMega88, 168 etc. You can save quite a bit of memory by
85 | * disabling page mode EEPROM access. Costs ~ 138 bytes.
86 | */
87 | #define HAVE_EEPROM_BYTE_ACCESS 1
88 | /* If HAVE_EEPROM_BYTE_ACCESS is defined to 1, byte mode access to EEPROM is
89 | * compiled in. Byte mode is only used if the device (as identified by its
90 | * signature) does not support page mode for EEPROM. It is required for
91 | * accessing the EEPROM on the ATMega8. Costs ~54 bytes.
92 | */
93 | #define BOOTLOADER_CAN_EXIT 1
94 | /* If this macro is defined to 1, the boot loader will exit shortly after the
95 | * programmer closes the connection to the device. Costs ~36 bytes.
96 | */
97 | #define HAVE_CHIP_ERASE 0
98 | /* If this macro is defined to 1, the boot loader implements the Chip Erase
99 | * ISP command. Otherwise pages are erased on demand before they are written.
100 | */
101 | //#define SIGNATURE_BYTES 0x1e, 0x93, 0x07, 0 /* ATMega8 */
102 | /* This macro defines the signature bytes returned by the emulated USBasp to
103 | * the programmer software. They should match the actual device at least in
104 | * memory size and features. If you don't define this, values for ATMega8,
105 | * ATMega88, ATMega168 and ATMega328 are guessed correctly.
106 | */
107 | |
108 | /* The following block guesses feature options so that the resulting code
109 | * should fit into 2k bytes boot block with the given device and clock rate.
110 | * Activate by passing "-DUSE_AUTOCONFIG=1" to the compiler.
111 | * This requires gcc 3.4.6 for small enough code size!
112 | */
113 | #if USE_AUTOCONFIG
114 | # undef HAVE_EEPROM_PAGED_ACCESS
115 | # define HAVE_EEPROM_PAGED_ACCESS (USB_CFG_CLOCK_KHZ >= 16000)
116 | # undef HAVE_EEPROM_BYTE_ACCESS
117 | # define HAVE_EEPROM_BYTE_ACCESS 1
118 | # undef BOOTLOADER_CAN_EXIT
119 | # define BOOTLOADER_CAN_EXIT 1
120 | # undef SIGNATURE_BYTES
121 | #endif /* USE_AUTOCONFIG */ |
122 | |
123 | /* ------------------------------------------------------------------------- */
124 | |
125 | /* Example configuration: Port C bit 0 is connected to a jumper which ties
126 | * this pin to GND if the boot loader is requested. Initialization allows
127 | * several clock cycles for the input voltage to stabilize before
128 | * bootLoaderCondition() samples the value.
129 | * We use a function for bootLoaderInit() for convenience and a macro for
130 | * bootLoaderCondition() for efficiency.
131 | */
132 | |
133 | #ifndef __ASSEMBLER__ /* assembler cannot parse function definitions */ |
134 | |
135 | #define JUMPER_BIT PA1 /* jumper is connected to this bit in port C, active low */ |
136 | |
137 | #ifndef MCUCSR /* compatibility between ATMega8 and ATMega88 */ |
138 | # define MCUCSR MCUSR
139 | #endif
140 | |
141 | static inline void bootLoaderInit(void) |
142 | {
143 | PORTA |= (1 << JUMPER_BIT); /* activate pull-up */ |
144 | if(!(MCUCSR & (1 << EXTRF))) /* If this was not an external reset, ignore */ |
145 | leaveBootloader(); |
146 | MCUCSR = 0; /* clear all reset flags for next time */ |
147 | }
148 | |
149 | static inline void bootLoaderExit(void) |
150 | {
151 | PORTA = 0; /* undo bootLoaderInit() changes */ |
152 | }
153 | |
154 | #define bootLoaderCondition() ((PINA & (1 << JUMPER_BIT)) == 0)
155 | |
156 | #endif /* __ASSEMBLER__ */ |
157 | |
158 | /* ------------------------------------------------------------------------- */
159 | |
160 | #endif /* __bootloader_h_included__ */ |
main.c:
1 | /* Name: main.c
5 | * Tabsize: 4
8 | * This Revision: $Id: main.c 786 2010-05-30 20:41:40Z cs $
9 | */
10 | |
11 | #include <avr/io.h> |
12 | #include <avr/interrupt.h> |
13 | #include <avr/pgmspace.h> |
14 | #include <avr/wdt.h> |
15 | #include <avr/boot.h> |
16 | #include <avr/eeprom.h> |
17 | #include <util/delay.h> |
18 | #include <string.h> |
19 | |
20 | static void leaveBootloader() __attribute__((__noreturn__)); |
21 | |
22 | #include "bootloaderconfig.h" |
23 | #include "usbdrv/usbdrv.c" |
24 | |
25 | /* ------------------------------------------------------------------------ */
26 | |
27 | /* Request constants used by USBasp */
28 | #define USBASP_FUNC_CONNECT 1
29 | #define USBASP_FUNC_DISCONNECT 2
30 | #define USBASP_FUNC_TRANSMIT 3
31 | #define USBASP_FUNC_READFLASH 4
32 | #define USBASP_FUNC_ENABLEPROG 5
33 | #define USBASP_FUNC_WRITEFLASH 6
34 | #define USBASP_FUNC_READEEPROM 7
35 | #define USBASP_FUNC_WRITEEEPROM 8
36 | #define USBASP_FUNC_SETLONGADDRESS 9
37 | |
38 | /* ------------------------------------------------------------------------ */
39 | |
40 | #ifndef ulong
41 | # define ulong unsigned long
42 | #endif
43 | #ifndef uint
44 | # define uint unsigned int
45 | #endif
46 | |
47 | /* defaults if not in config file: */
48 | #ifndef HAVE_EEPROM_PAGED_ACCESS
49 | # define HAVE_EEPROM_PAGED_ACCESS 0
50 | #endif
51 | #ifndef HAVE_EEPROM_BYTE_ACCESS
52 | # define HAVE_EEPROM_BYTE_ACCESS 0
53 | #endif
54 | #ifndef BOOTLOADER_CAN_EXIT
55 | # define BOOTLOADER_CAN_EXIT 0
56 | #endif
57 | |
58 | /* allow compatibility with avrusbboot's bootloaderconfig.h: */
59 | #ifdef BOOTLOADER_INIT
60 | # define bootLoaderInit() BOOTLOADER_INIT
61 | # define bootLoaderExit()
62 | #endif
63 | #ifdef BOOTLOADER_CONDITION
64 | # define bootLoaderCondition() BOOTLOADER_CONDITION
65 | #endif
66 | |
67 | /* device compatibility: */
68 | #ifndef GICR /* ATMega*8 don't have GICR, use MCUCR instead */ |
69 | # define GICR MCUCR
70 | #endif
71 | |
72 | /* ------------------------------------------------------------------------ */
73 | |
74 | #if (FLASHEND) > 0xffff /* we need long addressing */ |
75 | # define CURRENT_ADDRESS currentAddress.l
76 | # define addr_t ulong
77 | #else
78 | # define CURRENT_ADDRESS currentAddress.w[0]
79 | # define addr_t uint
80 | #endif
81 | |
82 | typedef union longConverter{ |
83 | addr_t l; |
84 | uint w[sizeof(addr_t)/2]; |
85 | uchar b[sizeof(addr_t)]; |
86 | }longConverter_t; |
87 | |
88 | static uchar requestBootLoaderExit; |
89 | static longConverter_t currentAddress; /* in bytes */ |
90 | static uchar bytesRemaining; |
91 | static uchar isLastPage; |
92 | #if HAVE_EEPROM_PAGED_ACCESS
93 | static uchar currentRequest; |
94 | #else
95 | static const uchar currentRequest = 0; |
96 | #endif
97 | |
98 | static const uchar signatureBytes[4] = { |
99 | #ifdef SIGNATURE_BYTES
100 | SIGNATURE_BYTES
101 | #elif defined (__AVR_ATmega8__) || defined (__AVR_ATmega8HVA__)
102 | 0x1e, 0x93, 0x07, 0 |
103 | #elif defined (__AVR_ATmega48__) || defined (__AVR_ATmega48P__)
104 | 0x1e, 0x92, 0x05, 0 |
105 | #elif defined (__AVR_ATmega88__) || defined (__AVR_ATmega88P__)
106 | 0x1e, 0x93, 0x0a, 0 |
107 | #elif defined (__AVR_ATmega168__) || defined (__AVR_ATmega168P__)
108 | 0x1e, 0x94, 0x06, 0 |
109 | #elif defined (__AVR_ATmega328P__)
110 | 0x1e, 0x95, 0x0f, 0 |
111 | #elif defined (__AVR_ATmega32__)
112 | 0x1e, 0x95, 0x02, 0 |
113 | #else
114 | # error "Device signature is not known, please edit main.c!"
115 | #endif
116 | };
117 | |
118 | /* ------------------------------------------------------------------------ */
119 | |
120 | static void (*nullVector)(void) __attribute__((__noreturn__)); |
121 | |
122 | static void leaveBootloader() |
123 | {
124 | DBG1(0x01, 0, 0); |
125 | bootLoaderExit(); |
126 | cli(); |
127 | USB_INTR_ENABLE = 0; |
128 | USB_INTR_CFG = 0; /* also reset config bits */ |
129 | GICR = (1 << IVCE); /* enable change of interrupt vectors */ |
130 | GICR = (0 << IVSEL); /* move interrupts to application flash section */ |
131 | /* We must go through a global function pointer variable instead of writing
132 | * ((void (*)(void))0)();
133 | * because the compiler optimizes a constant 0 to "rcall 0" which is not
134 | * handled correctly by the assembler.
135 | */
136 | nullVector(); |
137 | }
138 | |
139 | /* ------------------------------------------------------------------------ */
140 | |
141 | uchar usbFunctionSetup(uchar data[8]) |
142 | {
143 | usbRequest_t *rq = (void *)data; |
144 | uchar len = 0; |
145 | static uchar replyBuffer[4]; |
146 | |
147 | usbMsgPtr = replyBuffer; |
148 | if(rq->bRequest == USBASP_FUNC_TRANSMIT){ /* emulate parts of ISP protocol */ |
149 | uchar rval = 0; |
150 | usbWord_t address; |
151 | address.bytes[1] = rq->wValue.bytes[1]; |
152 | address.bytes[0] = rq->wIndex.bytes[0]; |
153 | if(rq->wValue.bytes[0] == 0x30){ /* read signature */ |
154 | rval = rq->wIndex.bytes[0] & 3; |
155 | rval = signatureBytes[rval]; |
156 | #if HAVE_EEPROM_BYTE_ACCESS
157 | }else if(rq->wValue.bytes[0] == 0xa0){ /* read EEPROM byte */ |
158 | rval = eeprom_read_byte((void *)address.word); |
159 | }else if(rq->wValue.bytes[0] == 0xc0){ /* write EEPROM byte */ |
160 | eeprom_write_byte((void *)address.word, rq->wIndex.bytes[1]); |
161 | #endif
162 | #if HAVE_CHIP_ERASE
163 | }else if(rq->wValue.bytes[0] == 0xac && rq->wValue.bytes[1] == 0x80){ /* chip erase */ |
164 | addr_t addr; |
165 | for(addr = 0; addr < FLASHEND + 1 - 2048; addr += SPM_PAGESIZE) { |
166 | /* wait and erase page */
167 | DBG1(0x33, 0, 0); |
168 | # ifndef NO_FLASH_WRITE
169 | boot_spm_busy_wait(); |
170 | cli(); |
171 | boot_page_erase(addr); |
172 | sei(); |
173 | # endif
174 | }
175 | #endif
176 | }else{ |
177 | /* ignore all others, return default value == 0 */
178 | }
179 | replyBuffer[3] = rval; |
180 | len = 4; |
181 | }else if(rq->bRequest == USBASP_FUNC_ENABLEPROG){ |
182 | /* replyBuffer[0] = 0; is never touched and thus always 0 which means success */
183 | len = 1; |
184 | }else if(rq->bRequest >= USBASP_FUNC_READFLASH && rq->bRequest <= USBASP_FUNC_SETLONGADDRESS){ |
185 | currentAddress.w[0] = rq->wValue.word; |
186 | if(rq->bRequest == USBASP_FUNC_SETLONGADDRESS){ |
187 | #if (FLASHEND) > 0xffff
188 | currentAddress.w[1] = rq->wIndex.word; |
189 | #endif
190 | }else{ |
191 | bytesRemaining = rq->wLength.bytes[0]; |
192 | /* if(rq->bRequest == USBASP_FUNC_WRITEFLASH) only evaluated during writeFlash anyway */
193 | isLastPage = rq->wIndex.bytes[1] & 0x02; |
194 | #if HAVE_EEPROM_PAGED_ACCESS
195 | currentRequest = rq->bRequest; |
196 | #endif
197 | len = 0xff; /* hand over to usbFunctionRead() / usbFunctionWrite() */ |
198 | }
199 | #if BOOTLOADER_CAN_EXIT
200 | }else if(rq->bRequest == USBASP_FUNC_DISCONNECT){ |
201 | requestBootLoaderExit = 1; /* allow proper shutdown/close of connection */ |
202 | #endif
203 | }else{ |
204 | /* ignore: USBASP_FUNC_CONNECT */
205 | }
206 | return len; |
207 | }
208 | |
209 | uchar usbFunctionWrite(uchar *data, uchar len) |
210 | {
211 | uchar isLast; |
212 | |
213 | DBG1(0x31, (void *)¤tAddress.l, 4); |
214 | if(len > bytesRemaining) |
215 | len = bytesRemaining; |
216 | bytesRemaining -= len; |
217 | isLast = bytesRemaining == 0; |
218 | if(currentRequest >= USBASP_FUNC_READEEPROM){ |
219 | uchar i; |
220 | for(i = 0; i < len; i++){ |
221 | eeprom_write_byte((void *)(currentAddress.w[0]++), *data++); |
222 | }
223 | }else{ |
224 | uchar i; |
225 | for(i = 0; i < len;){ |
226 | #if !HAVE_CHIP_ERASE
227 | if((currentAddress.w[0] & (SPM_PAGESIZE - 1)) == 0){ /* if page start: erase */ |
228 | DBG1(0x33, 0, 0); |
229 | # ifndef NO_FLASH_WRITE
230 | cli(); |
231 | boot_page_erase(CURRENT_ADDRESS); /* erase page */ |
232 | sei(); |
233 | boot_spm_busy_wait(); /* wait until page is erased */ |
234 | # endif
235 | }
236 | #endif
237 | i += 2; |
238 | DBG1(0x32, 0, 0); |
239 | cli(); |
240 | boot_page_fill(CURRENT_ADDRESS, *(short *)data); |
241 | sei(); |
242 | CURRENT_ADDRESS += 2; |
243 | data += 2; |
244 | /* write page when we cross page boundary or we have the last partial page */
245 | if((currentAddress.w[0] & (SPM_PAGESIZE - 1)) == 0 || (isLast && i >= len && isLastPage)){ |
246 | DBG1(0x34, 0, 0); |
247 | #ifndef NO_FLASH_WRITE
248 | cli(); |
249 | boot_page_write(CURRENT_ADDRESS - 2); |
250 | sei(); |
251 | boot_spm_busy_wait(); |
252 | cli(); |
253 | boot_rww_enable(); |
254 | sei(); |
255 | #endif
256 | }
257 | }
258 | DBG1(0x35, (void *)¤tAddress.l, 4); |
259 | }
260 | return isLast; |
261 | }
262 | |
263 | uchar usbFunctionRead(uchar *data, uchar len) |
264 | {
265 | uchar i; |
266 | |
267 | if(len > bytesRemaining) |
268 | len = bytesRemaining; |
269 | bytesRemaining -= len; |
270 | for(i = 0; i < len; i++){ |
271 | if(currentRequest >= USBASP_FUNC_READEEPROM){ |
272 | *data = eeprom_read_byte((void *)currentAddress.w[0]); |
273 | }else{ |
274 | *data = pgm_read_byte((void *)CURRENT_ADDRESS); |
275 | }
276 | data++; |
277 | CURRENT_ADDRESS++; |
278 | }
279 | return len; |
280 | }
281 | |
282 | /* ------------------------------------------------------------------------ */
283 | |
284 | static void initForUsbConnectivity(void) |
285 | {
286 | uchar i = 0; |
287 | |
288 | usbInit(); |
289 | /* enforce USB re-enumerate: */
290 | usbDeviceDisconnect(); /* do this while interrupts are disabled */ |
291 | while(--i){ /* fake USB disconnect for > 250 ms */ |
292 | wdt_reset(); |
293 | _delay_ms(1); |
294 | }
295 | usbDeviceConnect(); |
296 | sei(); |
297 | }
298 | |
299 | int __attribute__((noreturn)) main(void) |
300 | {
301 | /* initialize */
302 | wdt_disable(); /* main app may have enabled watchdog */ |
303 | bootLoaderInit(); |
304 | odDebugInit(); |
305 | DBG1(0x00, 0, 0); |
306 | |
307 | #ifndef NO_FLASH_WRITE
308 | GICR = (1 << IVCE); /* enable change of interrupt vectors */ |
309 | GICR = (1 << IVSEL); /* move interrupts to boot flash section */ |
310 | #endif
311 | if(bootLoaderCondition()){ |
312 | uchar i = 0, j = 0; |
313 | initForUsbConnectivity(); |
314 | do{ |
315 | usbPoll(); |
316 | #if BOOTLOADER_CAN_EXIT
317 | if(requestBootLoaderExit){ |
318 | if(--i == 0){ |
319 | if(--j == 0) |
320 | break; |
321 | }
322 | }
323 | #endif
324 | }while(bootLoaderCondition()); /* main event loop */ |
325 | }
326 | leaveBootloader(); |
327 | }
328 | |
329 | /* ------------------------------------------------------------------------ */
Makefile:
1 | # Name: Makefile |
2 | # Project: USBaspLoader |
3 | # Author: Christian Starkjohann |
4 | # Creation Date: 2007-12-10 |
5 | # Tabsize: 4 |
6 | # Copyright: (c) 2007 by OBJECTIVE DEVELOPMENT Software GmbH |
7 | # License: GNU GPL v2 (see License.txt) |
8 | # This Revision: $Id: Makefile 798 2010-07-27 17:29:28Z cs $ |
9 | |
10 | ############################################################################### |
11 | # Configure the following variables according to your AVR. |
12 | # Program the device with |
13 | # make fuse # to set the clock generator, boot section size etc. |
14 | # make flash # to load the boot loader into flash |
15 | # make lock # to protect the boot loader from overwriting |
16 | |
17 | F_CPU = 16000000 |
18 | DEVICE = atmega32 |
19 | # BOOTLOADER_ADDRESS is 1800 for 8k devices, 3800 for 16k and 7800 for 32k. |
20 | BOOTLOADER_ADDRESS = 7800 |
21 | FUSEOPT = $(FUSEOPT_32) |
22 | LOCKOPT = -U lock:w:0x2f:m |
23 | |
24 | PROGRAMMER = -c stk500v2 -P avrdoper |
25 | # PROGRAMMER contains AVRDUDE options to address your programmer |
26 | |
27 | FUSEOPT_8 = -U hfuse:w:0xc0:m -U lfuse:w:0x9f:m |
28 | FUSEOPT_88 = -U hfuse:w:0xd6:m -U lfuse:w:0xdf:m -U efuse:w:0x00:m |
29 | FUSEOPT_168 = -U hfuse:w:0xd6:m -U lfuse:w:0xdf:m -U efuse:w:0x00:m |
30 | FUSEOPT_32 = -U lfuse:w:0x7f:m -U hfuse:w:0xda:m |
31 | FUSEOPT_328 = -U lfuse:w:0xf7:m -U hfuse:w:0xda:m -U efuse:w:0x03:m |
32 | # You may have to change the order of these -U commands. |
33 | |
34 | #--------------------------------------------------------------------- |
35 | # ATMega8 |
36 | #--------------------------------------------------------------------- |
37 | # Fuse high byte: |
38 | # 0xc0 = 1 1 0 0 0 0 0 0 <-- BOOTRST (boot reset vector at 0x1800) |
39 | # ^ ^ ^ ^ ^ ^ ^------ BOOTSZ0 |
40 | # | | | | | +-------- BOOTSZ1 |
41 | # | | | | + --------- EESAVE (preserve EEPROM over chip erase) |
42 | # | | | +-------------- CKOPT (full output swing) |
43 | # | | +---------------- SPIEN (allow serial programming) |
44 | # | +------------------ WDTON (WDT not always on) |
45 | # +-------------------- RSTDISBL (reset pin is enabled) |
46 | # Fuse low byte: |
47 | # 0x9f = 1 0 0 1 1 1 1 1 |
48 | # ^ ^ \ / \--+--/ |
49 | # | | | +------- CKSEL 3..0 (external >8M crystal) |
50 | # | | +--------------- SUT 1..0 (crystal osc, BOD enabled) |
51 | # | +------------------ BODEN (BrownOut Detector enabled) |
52 | # +-------------------- BODLEVEL (2.7V) |
53 | #--------------------------------------------------------------------- |
54 | # ATMega88, ATMega168 |
55 | #--------------------------------------------------------------------- |
56 | # Fuse extended byte: |
57 | # 0x00 = 0 0 0 0 0 0 0 0 <-- BOOTRST (boot reset vector at 0x1800) |
58 | # \+/ |
59 | # +------- BOOTSZ (00 = 2k bytes) |
60 | # Fuse high byte: |
61 | # 0xd6 = 1 1 0 1 0 1 1 0 |
62 | # ^ ^ ^ ^ ^ \-+-/ |
63 | # | | | | | +------ BODLEVEL 0..2 (110 = 1.8 V) |
64 | # | | | | + --------- EESAVE (preserve EEPROM over chip erase) |
65 | # | | | +-------------- WDTON (if 0: watchdog always on) |
66 | # | | +---------------- SPIEN (allow serial programming) |
67 | # | +------------------ DWEN (debug wire enable) |
68 | # +-------------------- RSTDISBL (reset pin is enabled) |
69 | # Fuse low byte: |
70 | # 0xdf = 1 1 0 1 1 1 1 1 |
71 | # ^ ^ \ / \--+--/ |
72 | # | | | +------- CKSEL 3..0 (external >8M crystal) |
73 | # | | +--------------- SUT 1..0 (crystal osc, BOD enabled) |
74 | # | +------------------ CKOUT (if 0: Clock output enabled) |
75 | # +-------------------- CKDIV8 (if 0: divide by 8) |
76 | #--------------------------------------------------------------------- |
77 | # ATMega328P |
78 | #--------------------------------------------------------------------- |
79 | # Fuse extended byte: |
80 | # 0x03 = - - - - - 0 1 1 |
81 | # \-+-/ |
82 | # +------ BODLEVEL 0..2 (011 = 4.3V) |
83 | # Fuse high byte: |
84 | # 0xda = 1 1 0 1 1 0 1 0 <-- BOOTRST (0 = jump to bootloader at start) |
85 | # ^ ^ ^ ^ ^ \+/ |
86 | # | | | | | +------- BOOTSZ 0..1 (01 = 2KB starting at 0x7800) |
87 | # | | | | + --------- EESAVE (don't preserve EEPROM over chip erase) |
88 | # | | | +-------------- WDTON (1 = watchdog disabled at start) |
89 | # | | +---------------- SPIEN (0 = allow serial programming) |
90 | # | +------------------ DWEN (1 = debug wire disable) |
91 | # +-------------------- RSTDISBL (1 = reset pin is enabled) |
92 | # Fuse low byte: |
93 | # 0xf7 = 1 1 1 1 0 1 1 1 |
94 | # ^ ^ \ / \--+--/ |
95 | # | | | +------- CKSEL 3..0 (0111 = external full-swing crystal) |
96 | # | | +--------------- SUT 1..0 (11 = startup time 16K CK/14K + 65ms) |
97 | # | +------------------ CKOUT (1 = clock output disabled) |
98 | # +-------------------- CKDIV8 (1 = do not divide clock by 8) |
99 | |
100 | |
101 | ############################################################################### |
102 | |
103 | # Tools: |
104 | AVRDUDE = avrdude $(PROGRAMMER) -p $(DEVICE) |
105 | CC = avr-gcc |
106 | |
107 | # Options: |
108 | DEFINES = #-DDEBUG_LEVEL=2 |
109 | # Remove the -fno-* options when you use gcc 3, it does not understand them |
110 | CFLAGS = -Wall -Os -fno-move-loop-invariants -fno-tree-scev-cprop -fno-inline-small-functions -I. -mmcu=$(DEVICE) -DF_CPU=$(F_CPU) $(DEFINES) |
111 | LDFLAGS = -Wl,--relax,--gc-sections -Wl,--section-start=.text=$(BOOTLOADER_ADDRESS) |
112 | |
113 | OBJECTS = usbdrv/usbdrvasm.o usbdrv/oddebug.o main.o |
114 | |
115 | # symbolic targets: |
116 | all: main.hex |
117 | |
118 | .c.o: |
119 | $(CC) $(CFLAGS) -c $< -o $@ |
120 | |
121 | .S.o: |
122 | $(CC) $(CFLAGS) -x assembler-with-cpp -c $< -o $@ |
123 | # "-x assembler-with-cpp" should not be necessary since this is the default |
124 | # file type for the .S (with capital S) extension. However, upper case |
125 | # characters are not always preserved on Windows. To ensure WinAVR |
126 | # compatibility define the file type manually. |
127 | |
128 | .c.s: |
129 | $(CC) $(CFLAGS) -S $< -o $@ |
130 | |
131 | flash: all |
132 | $(AVRDUDE) -U flash:w:main.hex:i |
133 | |
134 | readflash: |
135 | $(AVRDUDE) -U flash:r:read.hex:i |
136 | |
137 | fuse: |
138 | $(AVRDUDE) $(FUSEOPT) |
139 | |
140 | lock: |
141 | $(AVRDUDE) $(LOCKOPT) |
142 | |
143 | read_fuses: |
144 | $(UISP) --rd_fuses |
145 | |
146 | clean: |
147 | rm -f main.hex main.bin *.o usbdrv/*.o main.s usbdrv/oddebug.s usbdrv/usbdrv.s |
148 | |
149 | # file targets: |
150 | main.bin: $(OBJECTS) |
151 | $(CC) $(CFLAGS) -o main.bin $(OBJECTS) $(LDFLAGS) |
152 | |
153 | main.hex: main.bin |
154 | rm -f main.hex main.eep.hex |
155 | avr-objcopy -j .text -j .data -O ihex main.bin main.hex |
156 | avr-size main.hex |
157 | |
158 | disasm: main.bin |
159 | avr-objdump -d main.bin |
160 | |
161 | cpp: |
162 | $(CC) $(CFLAGS) -E main.c |
163 | |
164 | # Special rules for generating hex files for various devices and clock speeds |
165 | ALLHEXFILES = hexfiles/mega8_12mhz.hex hexfiles/mega8_15mhz.hex hexfiles/mega8_16mhz.hex \ |
166 | hexfiles/mega88_12mhz.hex hexfiles/mega88_15mhz.hex hexfiles/mega88_16mhz.hex hexfiles/mega88_20mhz.hex\ |
167 | hexfiles/mega168_12mhz.hex hexfiles/mega168_15mhz.hex hexfiles/mega168_16mhz.hex hexfiles/mega168_20mhz.hex\ |
168 | hexfiles/mega328p_12mhz.hex hexfiles/mega328p_15mhz.hex hexfiles/mega328p_16mhz.hex hexfiles/mega328p_20mhz.hex |
169 | |
170 | allhexfiles: $(ALLHEXFILES) |
171 | $(MAKE) clean |
172 | avr-size hexfiles/*.hex |
173 | |
174 | $(ALLHEXFILES): |
175 | @[ -d hexfiles ] || mkdir hexfiles |
176 | @device=`echo $@ | sed -e 's|.*/mega||g' -e 's|_.*||g'`; \ |
177 | clock=`echo $@ | sed -e 's|.*_||g' -e 's|mhz.*||g'`; \ |
178 | addr=`echo $$device | sed -e 's/\([0-9]\)8/\1/g' | awk '{printf("%x", ($$1 - 2) * 1024)}'`; \ |
179 | echo "### Make with F_CPU=$${clock}000000 DEVICE=atmega$$device BOOTLOADER_ADDRESS=$$addr"; \ |
180 | $(MAKE) clean; \ |
181 | $(MAKE) main.hex F_CPU=$${clock}000000 DEVICE=atmega$$device BOOTLOADER_ADDRESS=$$addr DEFINES=-DUSE_AUTOCONFIG=1 |
182 | mv main.hex $@ |
Die anderen Dateien wurden nicht geändert. Fuses: High Fuse 0xDA Low Fuse 0x7F avrdude: Device signature = 0x1e9502 Ausgabe von WINAVR:
1 | > "make.exe" all |
2 | avr-gcc -Wall -Os -fno-move-loop-invariants -fno-tree-scev-cprop -fno-inline-small-functions -I. -mmcu=atmega32 -DF_CPU=16000000 -x assembler-with-cpp -c usbdrv/usbdrvasm.s -o usbdrv/usbdrvasm.o |
3 | avr-gcc -Wall -Os -fno-move-loop-invariants -fno-tree-scev-cprop -fno-inline-small-functions -I. -mmcu=atmega32 -DF_CPU=16000000 -c usbdrv/oddebug.c -o usbdrv/oddebug.o |
4 | avr-gcc -Wall -Os -fno-move-loop-invariants -fno-tree-scev-cprop -fno-inline-small-functions -I. -mmcu=atmega32 -DF_CPU=16000000 -c main.c -o main.o |
5 | usbdrv/usbdrv.h:213: warning: 'usbFunctionDescriptor' used but never defined |
6 | avr-gcc -Wall -Os -fno-move-loop-invariants -fno-tree-scev-cprop -fno-inline-small-functions -I. -mmcu=atmega32 -DF_CPU=16000000 -o main.bin usbdrv/usbdrvasm.o usbdrv/oddebug.o main.o -Wl,--relax,--gc-sections -Wl,--section-start=.text=7800 |
7 | rm -f main.hex main.eep.hex |
8 | avr-objcopy -j .text -j .data -O ihex main.bin main.hex |
9 | avr-size main.hex |
10 | text data bss dec hex filename |
11 | 0 1966 0 1966 7ae main.hex |
12 | |
13 | > Process Exit Code: 0 |
14 | > Time Taken: 00:02 |
P.S.: Das CRC-232 Projekt habe ich bereits erfolgreich auf dem selben Board zum Laufen gebracht, an der Hardware sollte es demnach nicht liegen.
