1 | void uC_init(void)
2 | {
3 | unsigned char i = 0;
4 |
5 | // Crystal Oscillator division factor: 1
6 | #pragma optsize-
7 | CLKPR = 0x80;
8 | CLKPR = 0;
9 | #ifdef _OPTIMIZE_SIZE_
10 | #pragma optsize+
11 | #endif
12 |
13 | // Input/Output Ports initialization
14 | // Ports A & C - not available in ATmega128RFA1
15 | // All digital inputs pulled up for now
16 |
17 | // Port B initialization
18 | PORTB = PORT_B_VAL;
19 | DDRB = PORT_B_DIR;
20 |
21 | // Port D initialization
22 | PORTD = PORT_D_VAL;
23 | DDRD = PORT_D_DIR;
24 |
25 | // Port E initialization
26 | PORTE = PORT_E_VAL;
27 | DDRE = PORT_E_DIR;
28 |
29 | // Port F initialization
30 | PORTF = PORT_F_VAL;
31 | DDRF = PORT_F_DIR;
32 |
33 | // Port G initialization
34 | PORTG = PORT_G_VAL;
35 | DDRG = PORT_G_DIR;
36 |
37 | // Timer/Counter 0 initialization
38 | // Clock source: System Clock
39 | // Clock value: 2000,000 kHz
40 | // Mode: Fast PWM top=OCR0A
41 | // OC0A output: Non-Inverted PWM
42 | // OC0B output: Disconnected
43 | #ifdef RF_COORDINATOR
44 | TCCR0A = TIMER0_FAST_PWM_TOP_FF;
45 | TCCR0B = TIMER0_DEFAULT_FREQ;
46 | TCNT0 = 0;
47 | OCR0A = 0x80;
48 | OCR0B = 0;
49 |
50 | // set current tone for PWM:
51 | ptr_tone = &sine_0dB_8bit[0];
52 | #endif
53 |
54 | #ifdef RF_NODE
55 | TCCR0A = 0;
56 | TCCR0B = 0;
57 | TCNT0 = 0;
58 | OCR0A = 0;
59 | OCR0B = 0;
60 | #endif
61 |
62 | // Timer1 initialization: 1ms
63 | // Clock source: System Clock; Clock value: 250,000 kHz
64 | // Mode: CTC top=OCR1A
65 | // Compare A Match Interrupt: On
66 | TCCR1A = 0;
67 | TCCR1B = 0x0B;
68 | TCNT1H = 0;
69 | TCNT1L = 0;
70 | ICR1H = 0;
71 | ICR1L = 0;
72 | OCR1AH = 0;
73 | OCR1AL = 0xFA;
74 | OCR1BH = 0;
75 | OCR1BL = 0;
76 | OCR1CH = 0;
77 | OCR1CL = 0;
78 |
79 | // Timer/Counter 2 initialization
80 | // Clock source: Crystal on TOSC1 pin
81 | // Clock value: PCK2/1024 => 32 ticks per second
82 | // Mode: Normal top=0xFF => 8sec
83 | ASSR = 0x20;
84 | TCCR2A = 0;
85 | TCCR2B = 0x07;
86 | TCNT2 = 0;
87 | OCR2A = 0;
88 | OCR2B = 0;
89 | while((ASSR & (1 << TCN2UB)));
90 |
91 | // Timer/Counter 3 initialization
92 | // Clock source: System Clock
93 | // Clock value: 15,625 kHz
94 | // Mode: CTC top=OCR3A
95 | TCCR3A = 0;
96 | TCCR3B = 0x0D;
97 | TCNT3H = 0;
98 | TCNT3L = 0;
99 | ICR3H = 0;
100 | ICR3L = 0;
101 | OCR3AH = 0x3D;
102 | OCR3AL = 0x09;
103 | OCR3BH = 0;
104 | OCR3BL = 0;
105 | OCR3CH = 0;
106 | OCR3CL = 0;
107 |
108 | // Timer/Counter 4 unused
109 | TCCR4A = 0;
110 | TCCR4B = 0;
111 | TCNT4H = 0;
112 | TCNT4L = 0;
113 | ICR4H = 0;
114 | ICR4L = 0;
115 | OCR4AH = 0;
116 | OCR4AL = 0;
117 | OCR4BH = 0;
118 | OCR4BL = 0;
119 | OCR4CH = 0;
120 | OCR4CL = 0;
121 |
122 | // Timer/Counter 5 unused
123 | TCCR5A = 0;
124 | TCCR5B = 0;
125 | TCNT5H = 0;
126 | TCNT5L = 0;
127 | ICR5H = 0;
128 | ICR5L = 0;
129 | OCR5AH = 0;
130 | OCR5AL = 0;
131 | OCR5BH = 0;
132 | OCR5BL = 0;
133 | OCR5CH = 0;
134 | OCR5CL = 0;
135 |
136 | // External Interrupt(s) initialization
137 | // INT0: On
138 | // INT0 Mode: Low level
139 | // others off
140 | EICRA = 0x00;
141 | EICRB = 0x00;
142 | EIMSK = 0x01;
143 | EIFR = 0x01;
144 | PCMSK0 = 0;
145 | PCMSK1 = 0;
146 | PCMSK2 = 0;
147 | PCICR = 0;
148 |
149 | // Timer/Counter 0-5 Interrupt(s) initializations
150 | #ifdef RF_COORDINATOR
151 | TIMSK0 = 0x02; // Fast PWM
152 | #endif
153 |
154 | #ifdef RF_NODE
155 | TIMSK0 = 0; // none
156 | #endif
157 |
158 | TIMSK1 = 0x02; // CTC interrupt - 1ms
159 | TIMSK2 = 0x01; // Overflow interrupt
160 | TIMSK3 = 0x02; // CTC interrupt - 1s
161 | TIMSK4 = 0;
162 | TIMSK5 = 0;
163 |
164 | //+++++++++++++++++++++++++++++++++++++++
165 | // USART0 initialization
166 | // Communication Parameters: 8 Data, 1 Stop, No Parity
167 | // USART0 Receiver: On
168 | // USART0 Transmitter: On
169 | // USART0 Mode: Asynchronous
170 | UCSR0A = 0;
171 | UCSR0B = 0xD8;
172 | UCSR0C = 0x06;
173 | UBRR0H = 0;
174 | #ifdef BAUD38K4
175 | // USART0 Baud Rate: 38400
176 | UBRR0L = 0x19;
177 | #else
178 | // USART0 Baud Rate: 9600
179 | UBRR0L = 0x67;
180 | #endif
181 |
182 | // Analog Comparator unused
183 | ACSR = 0x80;
184 |
185 | //+++++++++++++++++++++++++++++++++++++++
186 | // ADC initialization
187 | // ADC Clock frequency: 125,000 kHz
188 | // ADC Voltage Reference: 1.6V internal
189 | // ADC Auto Trigger Source: Free Running
190 | ADMUX = ADC_INTREF1V6_10BIT;
191 | ADCSRA = ADA_FREE_ICC_125K;
192 | ADCSRB = ADB_FREE_RUN;
193 | ADCSRC = ADC_TIMING;
194 | // Digital input buffers on ADC0-ADC7: Off
195 | // Digital input buffers on ADC8-ADC15: On
196 | DIDR0 = 0xFF;
197 | DIDR2 = 0;
198 |
199 | //+++++++++++++++++++++++++++++++++++++++
200 | // Power savings, everything not needed turned OFF
201 | PRR0 = OFF_TWI_PRPGA_SPI;
202 | PRR1 = OFF_TIM5_TIM4_USART1;
203 | PRR2 = 0;
204 |
205 | // Watchdog Timer initialization
206 | // Watchdog Timer Prescaler: OSC/1024k
207 | // Watchdog Timer interrupt: Off
208 | #pragma optsize-
209 | #asm("wdr")
210 | WDTCSR = 0x39;
211 | WDTCSR = 0x29;
212 | #ifdef _OPTIMIZE_SIZE_
213 | #pragma optsize+
214 | #endif
215 |
216 | TX_length = 0;
217 | TX0_go = 0;
218 | RX0_counter = 0;
219 | RX0_state = RX_IDLE;
220 | for( i = 0; i < 8; i++ ) adc_valid[i] = 0;
221 | }
