1 | $ avrdude -B10 -D -p 8535 -P usb -c jtag2isp -U flash:w:main-1.5rc1.hex:r -vv
2 |
3 | avrdude: Version 5.10, compiled on Mar 23 2010 at 15:03:00
4 | Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
5 | Copyright (c) 2007-2009 Joerg Wunsch
6 |
7 | System wide configuration file is "/etc/avrdude.conf"
8 | User configuration file is "/home/ed/.avrduderc"
9 | User configuration file does not exist or is not a regular file, skipping
10 |
11 | Using Port : usb
12 | Using Programmer : jtag2isp
13 | Setting bit clk period : 10.0
14 | avrdude: stk500v2_jtagmkII_open()
15 | avrdude: usbdev_open(): Found JTAGICE mkII, serno: 0900000068CB
16 | avrdude: usbdev_open(): using read endpoint 0x82
17 | avrdude: jtagmkII_getsync(): Sending sign-on command: 0x86 (28 bytes msg)
18 | JTAG ICE mkII sign-on message:
19 | Communications protocol version: 1
20 | M_MCU:
21 | boot-loader FW version: 255
22 | firmware version: 6.07
23 | hardware version: 0
24 | S_MCU:
25 | boot-loader FW version: 255
26 | firmware version: 6.07
27 | hardware version: 1
28 | Serial number: 09:00:00:00:68:cb
29 | Device ID: JTAGICEmkII
30 | avrdude: jtagmkII_setparm()
31 | avrdude: jtagmkII_setparm(): Sending set parameter command (parm 0x03, 1 bytes): 0x80 (1 bytes msg)
32 | avrdude: jtagmkII_getsync(): Sending get sync command: 0x80 (1 bytes msg)
33 | AVR Part : AT90S8535
34 | Chip Erase delay : 20000 us
35 | PAGEL : P00
36 | BS2 : P00
37 | RESET disposition : dedicated
38 | RETRY pulse : SCK
39 | serial program mode : yes
40 | parallel program mode : yes
41 | Timeout : 200
42 | StabDelay : 100
43 | CmdexeDelay : 25
44 | SyncLoops : 32
45 | ByteDelay : 0
46 | PollIndex : 3
47 | PollValue : 0x53
48 | Memory Detail :
49 |
50 | Block Poll Page Polled
51 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
52 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
53 | eeprom 4 12 128 0 no 512 0 0 9000 20000 0x00 0xff
54 | flash 4 12 128 0 no 8192 0 0 9000 20000 0xff 0xff
55 | signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
56 | fuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
57 | lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
58 |
59 | Programmer Type : JTAGMKII_ISP
60 | Description : Atmel JTAG ICE mkII in ISP mode
61 | avrdude: jtagmkII_getparm()
62 | avrdude: jtagmkII_getparm(): Sending get parameter command (parm 0x06): 0x81 (3 bytes msg)
63 | Vtarget : 4.2 V
64 | SCK period : 10.37 us
65 |
66 | avrdude: AVR device initialized and ready to accept instructions
67 |
68 | Reading | ################################################## | 100% 0.15s
69 | avrdude: Device signature = 0x1e9303
70 | avrdude: safemode: fuse reads as 1
71 | avrdude: reading input file "main-1.5rc1.hex"
72 | avrdude: writing flash (5758 bytes):
73 |
74 | Writing | ################################################## | 100% 872.76s
75 |
76 | avrdude: 5758 bytes of flash written
77 | avrdude: verifying flash memory against main-1.5rc1.hex:
78 | avrdude: load data flash data from input file main-1.5rc1.hex:
79 | avrdude: input file main-1.5rc1.hex contains 5758 bytes
80 | avrdude: reading on-chip flash data:
81 |
82 | Reading | ################################################## | 100% 292.14s
83 |
84 | avrdude: verifying ...
85 | avrdude: 5758 bytes of flash verified
86 |
87 | avrdude: safemode: fuse reads as 1
88 | avrdude: safemode: Fuses OK
89 | avrdude: stk500v2_jtagmkII_close()
90 | avrdude: jtagmkII_close()
91 | avrdude: jtagmkII_close(): Sending sign-off command: 0x80 (1 bytes msg)
92 |
93 | avrdude done. Thank you.
94 |
95 | ed@summini:~/Projekte/Embedded/AVR/AVR-CTRL/t$ avrdude -D -p 8535 -P usb -c jtag2isp -e
96 |
97 | avrdude: AVR device initialized and ready to accept instructions
98 |
99 | Reading | ################################################## | 100% 0.15s
100 |
101 | avrdude: Device signature = 0x1e9303
102 | avrdude: erasing chip
103 |
104 | avrdude: safemode: Fuses OK
105 |
106 | avrdude done. Thank you.
