Hallo, ich suche die *.asy und die *.sub für den LM7805 um damit in LTSpice zu simulieren. Ich hab bei google schon kräftig gesucht, aber nirgends die asy und die sub gefunden. Hat die hier jmd. und kann sie mir bitte hochladen? Vielen Dank Tom
hat keiner eine Idee? Ich hab jetzt mal das hier gefunden:
1 | ..SUBCKT x_LM78XX Input Output Ground PARAMS: |
2 | + Av_feedback=1665, R1_Value=1020 |
3 | * |
4 | * SERIES 3-TERMINAL POSITIVE REGULATOR |
5 | * |
6 | * Note: This regulator is based on the LM78XX series of |
7 | * regulators (also the LM140 and LM340). The model |
8 | * will cause some current to flow to Node 0 which |
9 | * is not part of the actual voltage regulator circuit. |
10 | * |
11 | * Band-gap voltage source: |
12 | * |
13 | * The source is off when Vin<3V and fully on when Vin>3.7V. |
14 | * Line regulation and ripple rejection) are set with |
15 | * Rreg= 0.5 * dVin/dVbg. The temperature dependence of this |
16 | * circuit is a quadratic fit to the following points: |
17 | * |
18 | * T Vbg(T)/Vbg(nom) |
19 | * --- --------------- |
20 | * 0 .999 |
21 | * 37.5 1 |
22 | * 125 .990 |
23 | * |
24 | * The temperature coefficient of Rbg is set to 2 * the band gap |
25 | * temperature coefficient. Tnom is assumed to be 27 deg. C and |
26 | * Vnom is 3.7V |
27 | * |
28 | Vbg 100 0 DC 7.4V |
29 | Sbg (100,101),(Input,Ground) Sbg1 |
30 | Rbg 101 0 1 TC=1.612E-5,-2.255E-6 |
31 | Ebg (102,0),(Input,Ground) 1 |
32 | Rreg 102 101 7k |
33 | ..MODEL Sbg1 VSWITCH (Ron=1 Roff=1MEG Von=3.7 Voff=3) |
34 | * |
35 | * Feedback stage |
36 | * |
37 | * Diodes D1,D2 limit the excursion of the amplifier |
38 | * outputs to being near the rails. Rfb, Cfb Set the |
39 | * corner frequency for roll-off of ripple rejection. |
40 | |
41 | * |
42 | * The opamp gain is given by: Av = (Fores/Freg) * (Vout/Vbg) |
43 | * where Fores = output impedance corner frequency |
44 | * with Cl=0 (typical value about 1MHz) |
45 | * Freg = corner frequency in ripple rejection |
46 | * (typical value about 600 Hz) |
47 | * Vout = regulator output voltage (5,12,15V) |
48 | * Vbg = bandgap voltage (3.7V) |
49 | * |
50 | * Note: Av is constant for all output voltages, but the |
51 | * feedback factor changes. If Av=2250, then the |
52 | * Av*Feedback factor is as given below: |
53 | * |
54 | * Vout Av*Feedback factor |
55 | * ---- ------------------ |
56 | * 5 1665 |
57 | * 12 694 |
58 | * 15 550 |
59 | * |
60 | Rfb 9 8 1MEG |
61 | Cfb 8 Ground 265PF |
62 | Eopamp 105 0 VALUE={2250*v(101,0)+Av_feedback*v(Ground,8)} |
63 | Vgainf 200 0 {Av_feedback} |
64 | Rgainf 200 0 1 |
65 | *Eopamp 105 0 POLY(3),(101,0),(Ground,8),(200,0) 0 2250 0 0 0 0 0 0 1 |
66 | Ro 105 106 1k |
67 | D1 106 108 Dlim |
68 | D2 107 106 Dlim |
69 | ..MODEL Dlim D (Vj=0.7) |
70 | Vl1 102 108 DC 1 |
71 | Vl2 107 0 DC 1 |
72 | * |
73 | * Quiescent current modelling |
74 | * |
75 | * Quiescent current is set by Gq, which draws a current |
76 | * proportional to the voltage drop across the regulator and |
77 | * R1 (temperature coefficient .1%/deg C). R1 must change |
78 | * with output voltage as follows: R1 = R1(5v) * Vout/5v. |
79 | * |
80 | Gq (Input,Ground),(Input,9) 2.0E-5 |
81 | R1 9 Ground {R1_Value} TC=0.001 |
82 | * |
83 | * Output Stage |
84 | * |
85 | * Rout is used to set both the low frequency output impedence |
86 | * and the load regulation. |
87 | * |
88 | Q1 Input 5 6 Npn1 |
89 | Q2 Input 6 7 Npn1 10 |
90 | ..MODEL Npn1 NPN (Bf=50 Is=1E-14) |
91 | * Efb Input 4 VALUE={v(Input,Ground)+v(0,106)} |
92 | Efb Input 4 POLY(2),(Input,Ground),(0,106) 0 1 1 |
93 | Rb 4 5 1k TC=0.003 |
94 | Re 6 7 2k |
95 | Rsc 7 9 0.275 TC=1.136E-3,-7.806E-6 |
96 | Rout 9 Output 0.008 |
97 | * |
98 | * Current Limit |
99 | * |
100 | Rbcl 7 55 290 |
101 | Qcl 5 55 9 Npn1 |
102 | Rcldz 56 55 10k |
103 | Dz1 56 Input Dz |
104 | ..MODEL Dz D (Is=0.05p Rs=3 Bv=7.11 Ibv=0.05u) |
105 | ..ENDS |
106 | *$ |
und versuche daraus mir jetzt was zu pasteln, aber iwie komme ich nicht wirklich vorran.
Wenn Du die Doppelpunkte vor den Spice-Befehlen durch einfache ersetzt (".MODEL" etc), dann klappt das auch. Wie man so ein Modell einbindet steht im FAQ-Teil der Onlinehilfe von LTspice. Wichtig ist, im Schaltzeichen (*.asy) müssen die Pins in der gleichen Reihenfolge definiert sein wie im Modell. Die Namen zählen nicht, sondern die Reihenfolge! Patrick
Hi, ich hab gerade nochmal mein Glück versucht. Leider komme ich nicht weiter. Kannst du mir bitte den direkten Link schicken? Ich finde das auch auf der homepage nicht. Läuft das Model bei dir? Vielen Dank für die Antworten. Thomas
Die drei Files habe ich bei mir auf der Platte gefunden, vielleicht helfen sie dir weiter ....
ok, danke. ob deine gehen weiß ich jetzt leider nicht, weil ich grad die gefunden habe, die ich angehängt habe und die gehen ;) Fals irgendjmd. sonst noch andere models sucht kann ich die Gruppe http://tech.groups.yahoo.com/group/LTspice/ nur empfehlen ;) Grüße Tom
G.H. schrieb: > Hallöchen, ich suche eine ASY_Datei für LM78l05 und LM78M05 Was für Besonderheiten benötigst du, dass du nicht die vom LM780x nehmen kannst und dort SpiceModel, Value2 und vielleicht einen passenden Text eintragen kannst?
http://ltwiki.org/index.php?title=Most_frequently_asked_questions_for_beginners .asy ist auch selbst erstellbar https://www.home.hs-karlsruhe.de/~klal0001/download_frei/Externe%20Spice-Modelle%20in%20LTspice%20einbinden.pdf https://groups.io/g/LTspice/topic/50252518?p=,,,20,0,0,0::,,,0,0,0,50252518 https://github.com/kafana/ltspice-misc/blob/master/models/regulators.lib
