Forum: PC-Programmierung Struktur mit Zeigern anlegen
von StefL_ (Gast)
Hi, will ne Struktur mit Zeigern in C initialisieren.
Kann mal jemand kurz drüber schauen ob da so richtig geht.
typedef struct{
  PNIO_UINT32 dwHandle;
  PNIO_UINT8 NumOfIODevives;
  PNIO_UINT8 MaxLen;
  volatile PNIO_MODE_TYPE currentMode;
  volatile PNIO_IOXS localState;
  volatile PNIO_IOXS* deviceInputState;
  PNIO_ADDR* deviceInputAddress;
  PNIO_UINT32* deviceInputLength;
  PNIO_UINT8** deviceInputData;
  volatile PNIO_IOXS* deviceOutputState;
  PNIO_ADDR* deviceOutputAddress;
  PNIO_UINT32* deviceOutputLength;
  PNIO_UINT8** deviceOutputData;
}PNIO_init;
_declspec(dllexport)PNIO_init* setUpDevice(PNIO_UINT8 NumberOfDevices, PNIO_UINT8 MaxLen)//, PNIO_init* PNIO_init_struct)
  PNIO_init PNIO_init_struct;
  PNIO_init_struct.NumOfIODevives = NumberOfDevices;
  PNIO_init_struct.MaxLen = MaxLen;
  PNIO_init_struct.currentMode = g_currentMode;
  PNIO_init_struct.localState = PNIO_S_GOOD;
  PNIO_init_struct.deviceInputState = (PNIO_IOXS*)malloc( NumberOfDevices * sizeof( PNIO_IOXS ) );
  PNIO_init_struct.deviceInputState[NumberOfDevices];
  PNIO_init_struct.deviceInputAddress = (PNIO_ADDR*)malloc( NumberOfDevices * sizeof( PNIO_ADDR ) );
  PNIO_init_struct.deviceInputAddress[NumberOfDevices];
  PNIO_init_struct.deviceInputLength = (PNIO_UINT32*)malloc( NumberOfDevices * sizeof( PNIO_UINT32 ) );
  PNIO_init_struct.deviceInputLength[NumberOfDevices];
  PNIO_init_struct.deviceInputData = (PNIO_UINT8**)malloc( NumberOfDevices * sizeof( PNIO_UINT8 ) * MaxLen * sizeof( PNIO_UINT8 ) );
  PNIO_init_struct.deviceInputData[NumberOfDevices][MaxLen];
  PNIO_init_struct.deviceOutputState = (PNIO_IOXS*)malloc( NumberOfDevices * sizeof( PNIO_IOXS ) );
  PNIO_init_struct.deviceOutputState[NumberOfDevices];
  PNIO_init_struct.deviceOutputAddress = (PNIO_ADDR*)malloc( NumberOfDevices * sizeof( PNIO_ADDR ) );
  PNIO_init_struct.deviceOutputAddress[NumberOfDevices];
  PNIO_init_struct.deviceOutputLength = (PNIO_UINT32*)malloc( NumberOfDevices * sizeof( PNIO_UINT32 ) );
23
  PNIO_init_struct.deviceOutputLength[NumberOfDevices];
24
  PNIO_init_struct.deviceOutputData = (PNIO_UINT8**)malloc( NumberOfDevices * sizeof( PNIO_UINT8 ) * MaxLen * sizeof( PNIO_UINT8 ) );
25
  PNIO_init_struct.deviceOutputData[NumberOfDevices][MaxLen];
26
27
28
29
30
  return &PNIO_init_struct;
31
Oder kann ich mir das Speicherresrvieren mit malloc auch sparen.
Kann man aus einer dll eine Adresse einer Variable an C# übergeben und
vor allem, funktioniert das dann auch ;-)
Du legst eine Instanz der Struktur als lokale Variable an, d.h. auf
dem Stack, und gibst einen Pointer auf diese Variable zurück:
Sobald aber die Funktion zurückkehrt, ist der von ihr auf dem Stack
belegte Speicher freigegeben ...
Das geht in die Hose.
von StefL_ (Gast)
Ok, danke für die schnelle Antwort.
wie kann ich es dann machen?
  PNIO_init* PNIO_init_struct;
  PNIO_init_struct->NumOfIODevives = NumberOfDevices;
  return PNIO_init_struct;
_declspec(dllexport)void setUpDevice(PNIO_init* PNIO_init_struct, PNIO_UINT8 NumberOfDevices, PNIO_UINT8 MaxLen)
muss bei dieser Variante die Größe der Struktur nicht beim Aufruf der
Funktion schon bekannt sein!?
wie würdet ihr das machen?
von Markus V. (valvestino)
Es stellt sich mir die Frage, wieso Du in C Speicher allokierst und
diesen dann in C# verwenden willst. So wie ich das Code-Stück oben
überblicke passiert nichts weiter als Speicher zu allokieren (was, wie
Rufus bereits geschireben hat, nicht korrekt umgesetzt ist).
Du kannst diesen Speicher so nicht direkt in C# verwenden. Du mußt mit
Hilfe der Marshalling-Funktionen des .net-PInvoke entsprechende
Datenstrukturen in C# füllen. Solange Du keine weitere Funktionalität in
der C-Funktion hast, ist das reichlich sinnlos.
Markus
von StefL_ (Gast)
In der Funktion wird die Struktur noch mit Daten aufgefüllt. Ist nicht
so sinnlos ;-).
Problem ist folgendes, ich habe weitere Funktionen in der C-dll die die
gefüllte Struktur brauchen. Wollte das jetzt so machen:
in einer Funktion wird die Struktur gefüllt (siehe oben)
die Adresse der Struktur wird an C# geliefert
in C# werden weitere Funktionen der dll aufgerufen, denen übergebe ich
dann jeweils wieder die Adresse der Struktur.
Wollte das in C# mit einem void Zeiger erledigen.
Ist das so möglich?
Bin eigentlich in der C-Welt zu Hause. Erste Versuche mit C# :-)...
> PNIO_UINT8 MaxLen)
So gar nicht, wo ist der Speicher, auf den der Pointer PNIO_init_struct
zeigt?
> oder
Ja, genau so.
Das ist er doch.
von Arc N. (arc)
> so sinnlos ;-).
> Ist das so möglich?
PNIO klingt nach Profinet...dann gibt's das je nach Anwendungszweck auch
fertig...
Ansonsten für den Anfang:
http://msdn.microsoft.com/en-us/magazine/cc164123.aspx
http://msdn.microsoft.com/en-us/magazine/cc163910.aspx
http://msdn.microsoft.com/en-us/library/sd10k43k.aspx
von StefL_ (Gast)
Danke für die Hilfe...
