Hallo, kennt jemand eine Headerdatei mit einer Potenzfunktion, welche mit beliebigen Zahlen umgehen kann. Z.B.: 3,23^5,76
Du wirst nicht nur die Headerdatei brauchen ;) Aus Spass hier mal ein Code den ich noch bei mir rumfliegen hatte der direkt nach der Definition der Exponentialfunktion vorgeht, garantiert unoptimiert und unexakt (aufzurufen mit power (x, y)):
1 | #define PRECISION (10e-17)
2 | |
3 | double power_n (double x, unsigned int n) { |
4 | double mul = 1; |
5 | while (n > 1) { |
6 | if (n % 2 == 1) { |
7 | n = (n - 1) / 2; |
8 | mul *= x; |
9 | x *= x; |
10 | } else { |
11 | n /= 2; |
12 | x *= x; |
13 | }
14 | }
15 | return x * mul; |
16 | }
17 | |
18 | double logarithm (double x) { |
19 | unsigned int k; |
20 | const double m = (x - 1) / (x + 1); |
21 | double a = m, sum = 0; |
22 | for (k = 0; a > PRECISION || a < -PRECISION; k++) { |
23 | sum += a * (((double) 1) / ((double) (2 * k + 1))); |
24 | |
25 | a *= m * m; |
26 | }
27 | return 2*sum; |
28 | }
29 | |
30 | double expo (double x) { |
31 | unsigned int k = 0; |
32 | double sum = 0, add = 1; |
33 | for (;add > PRECISION || add < -PRECISION; k++) { |
34 | sum += add; |
35 | |
36 | add = add * x / (k + 1); |
37 | }
38 | return sum; |
39 | }
40 | |
41 | double power (double x, double y) { |
42 | return expo (y * logarithm (x)); |
43 | }
1 | POW(3) Linux Programmer’s Manual POW(3) |
2 | |
3 | NAME |
4 | pow, powf, powl - power functions |
5 | |
6 | SYNOPSIS |
7 | #include <math.h> |
8 | |
9 | double pow(double x, double y); |
10 | float powf(float x, float y); |
11 | long double powl(long double x, long double y); |
12 | |
13 | Link with -lm. |
14 | |
15 | DESCRIPTION |
16 | The pow() function returns the value of x raised to the power of y. |
17 | |
18 | ERRORS |
19 | EDOM The argument x is negative and y is not an integral value. This would |
20 | result in a complex number. |
21 | |
22 | CONFORMING TO |
23 | SVr4, 4.3BSD, C89. The float and long double variants are C99 requirements. |
24 | |
25 | SEE ALSO |
26 | cbrt(3), cpow(3), sqrt(3) |
27 | |
28 | COLOPHON |
29 | This page is part of release 3.05 of the Linux man-pages project. A description |
30 | of the project, and information about reporting bugs, can be found at |
31 | http://www.kernel.org/doc/man-pages/. |
@ Niklas Gürtler Vielen Dank für den Code. Steckt viel Arbeit da hinter, vermute deshalb auch, dass es soetwas noch nicht vorgefertigt in einer Headerdatei gab. Muss mir das mal in Ruhe anschauen. Aber der Ansatz scheint folgender zu sein: 2^7 = 10^(2*log(7)) @Klaus Wachtler Was möchtest du mir damit sagen? Den Header math.h kannte ich bereits.
A. R. schrieb: > @ Niklas Gürtler > > Vielen Dank für den Code. > Steckt viel Arbeit da hinter, vermute deshalb auch, dass es soetwas noch > nicht vorgefertigt in einer Headerdatei gab. Du beliebst zu scherzen > Was möchtest du mir damit sagen? > Den Header math.h kannte ich bereits. Und? Warum hast du dann nicht hineingeschaut? Was sagt dir die Funktion pow wie 'power'? Zitat vom Klaus-Zitat
1 | DESCRIPTION |
2 | The pow() function returns the value of x raised to the power of y. |
mit anderen Worten: x^y <==> pow( x, y ) (wobei ^ der Potenzoperator ist und nicht das C-spezifische XOR) AUsserdem: was verwendest du denn für ein Schmalspur-C-Buch, wenn da drinnen die Funktion pow() bei der Besprechung der Funktionen aus math.h nicht vorkommt? Schmeiss es weg und kauf dir ein Vernünftiges.
@ Karl heinz Buchegger >Du beliebst zu scherzen Könntest du das bitte etwas genauer erläutern? Das war ernst gemeint. Ironie oder einen Scherz hätte ich markiert. >AUsserdem: was verwendest du denn für ein Schmalspur-C-Buch, wenn da >drinnen die Funktion pow() bei der Besprechung der Funktionen aus math.h >nicht vorkommt? >Schmeiss es weg und kauf dir ein Vernünftiges. Diesen Kommentar würde ich gerne an den Absender zurückgeben! >double pow(double x, double y) xy. >Ein Argumentfehler liegt vor bei x=0 >und y<0, oder bei x<0 und y ist nicht >ganzzahlig. Mit anderen Worten: Der Exponent muss eine Ganzzahl sein. Der Titel des Threads hätte schon darauf hindeuten müssen, dass mir die Funktion "double pow(double x, double y)" nicht weiterhilft!
>>Diesen Kommentar würde ich gerne an den Absender zurückgeben! >double pow(double x, double y) xy. >Ein Argumentfehler liegt vor bei x=0 >und y<0, oder bei x<0 und y ist nicht >ganzzahlig. Kommentare an K. H. Buchegger zurückzugeben beinhaltet das Risiko sich ein wenig zu blamieren und über die Bedeutung des Wortes "und" belehrt zu werden. Nochmal lesen, tief durchatmen und nochmal lesen. Dann erst denken.
Du brauchst also "die" komplexe Wurzel? Dann sag das doch gleich...
>Kommentare an K. H. Buchegger zurückzugeben beinhaltet das Risiko sich >ein wenig zu blamieren Das Risiko muss man manchmal eingehen. >Nochmal lesen, tief durchatmen und nochmal lesen. Das hilft manchmal! Hatte im Kopf, dass man mit pow nur Ganzzahlen als Exponent verwenden darf. Dann hat sich das Problem erledigt. Danke für den Hinweis. Hiermit möchte ich mit bei Karl heinz Buchegger entschulden und mich für die Hilfe bedanken!
1 | int _tmain(int argc, _TCHAR* argv[]) |
2 | {
3 | double x = 5; |
4 | double y = 7.2; |
5 | double Ergebniss = pow(x,y); |
6 | printf("%f",Ergebniss); |
7 | system("pause"); |
8 | return 0; |
9 | }
Das Programm klappt wunderbar.
Nein
Mit (-5)^(7,2) wäre ich etwas überfordert.
Karl heinz Buchegger schrieb: > A. R. schrieb: >> @ Niklas Gürtler >> >> Vielen Dank für den Code. >> Steckt viel Arbeit da hinter, vermute deshalb auch, dass es soetwas noch >> nicht vorgefertigt in einer Headerdatei gab. > > Du beliebst zu scherzen Das setzt einfach nur die mathematische Definition von dem, was eine Potenz ist, um. und ist deswegen total simpel und wahrscheinlich fürchterlich ungenau und langsam. Wenn man die Formeln vorgegeben hat (was ich hatte, als ich das geschrieben hab) geht das ganz fix zu programmiern... Die Idee dahinter: Definition der Exponentialfunktion:
Definition der Logarithmusfunktion als Umkehrfunktion der Exponentialfunktion:
Definition der Potenz über die Exponentialfunktion:
Die Reihendarstellung die ich da für den Logarithmus verwendet habe weiß ich grad leider nicht auswendig...
Niklas Gürtler schrieb: > Die Idee dahinter: > Definition der Exponentialfunktion: >
Vorsicht, diese Definition der Exponentialfunktion ist zwar ganz nett, aber für den praktischen Einsatz nicht ohne weiteres empfehlenswert. Versuch zum Beispiel mal, damit
auszurechnen. Die dabei auftretenden Summanden sind betragsmässig irre groß, aber ihre Summe ist ≈0. Die bei den Additionen auftretenden Rundungsfehler der alternierewnden Summanden machen das Ergebnis zu einem Märchenwert. > Die Reihendarstellung die ich da für den Logarithmus verwendet habe weiß > ich grad leider nicht auswendig... Es ist i.w. die Reihenentwicklung des Areacotangenshyperbolicus :-) Ohne Skalierung liegen die Werte m in der Reihenentwicklung u.U. am Rande des Konvergenzkreises → Die Konvergenz ist Theorie, in der Praxis gibt's Märchenwerte, weil die Rundungsfehler bei weitem dominieren.
sachich ja, hab nie behauptet dass das genau ist :)
Niklas Gürtler schrieb: > sachich ja, hab nie behauptet dass das genau ist :) Naja, wenn man was ausrechnet (bzw. ausrechnen lässt) will man ja auch das gewünschte Ergebnis bekommen und nicht irgendwas mehr oder weniger zufälliges. Ein "klassisches" Beispiel ist die Leibnitz-Reihe
Die Rundungsfehler und die langsame Konvergenz machen die Reihe für einen praktischen Einsatz unbrauchbar — auch wenn die Formel selbst ganz einfach und hübsch ist. Was die Exponentialfunktion angeht, so hilft
Und für den Logarithmus ist Artanh ok (nicht wie ich oben schrieb Arcoth), sofern man die Eingangswerte so normiert, daß sie nicht an den Rand des Konvergenzkreises zu liegen kommen: http://de.wikipedia.org/wiki/Logarithmus#Berechnung_des_Logarithmus
