1 | //----------------------------------------
2 | // Reset DS18S20
3 | //----------------------------------------
4 | uint8_t ds1820_reset(uint8_t used_pin)
5 | {
6 | uint8_t err=100;
7 | DS1820_DDR |= 1<<used_pin; // define as ouput
8 | DS1820_PORT &= ~(1<<used_pin); //Pull low
9 | _delay_us(480); ; // 480 us
10 | DS1820_DDR &= ~(1<<used_pin); // define as input
11 | DS1820_PORT |= 1<<used_pin; //Pullup on
12 | _delay_us(80); // 66 us
13 | err = (DS1820_PIN & (1<<used_pin)) >> used_pin; // no presence detect --> err=1 otherwise err=0
14 | _delay_us(400); // 240 us
15 | if( (DS1820_PIN & (1<<used_pin)) == 0 ){ // short circuit --> err=2
16 | err = 2;
17 | }
18 | return err;
19 | }
20 | //-----------------------------------------
21 | // Write one bit to DS18S20
22 | //-----------------------------------------
23 | void ds1820_wr_bit(uint8_t wrbit,uint8_t used_pin)
24 | {
25 | if (wrbit ==0) {
26 | DS1820_DDR |= 1<<used_pin; // define as ouput
27 | DS1820_PORT &= ~(1<<used_pin); //Pull low
28 | _delay_us(60);
29 | DS1820_DDR &= ~(1<<used_pin); // define as input
30 | DS1820_PORT |= 1<<used_pin; //Pullup on
31 | _delay_us(4);
32 | }
33 | if (wrbit ==1) {
34 | DS1820_DDR |= 1<<used_pin; // define as ouput
35 | DS1820_PORT &= ~(1<<used_pin); //Pull low
36 | _delay_us(10);
37 | DS1820_DDR &= ~(1<<used_pin); // define as input
38 | DS1820_PORT |= 1<<used_pin; //Pullup on
39 | _delay_us(54);
40 | }
41 | }
42 | //-----------------------------------------
43 | // Read one bit from DS18S20
44 | //-----------------------------------------
45 | uint8_t ds1820_re_bit(uint8_t used_pin)
46 | {
47 | uint8_t rebit;
48 | DS1820_DDR |= 1<<used_pin; // define as ouput
49 | DS1820_PORT &= ~(1<<used_pin); //Pull low
50 | _delay_us(2);
51 | DS1820_DDR &= ~(1<<used_pin); // define as input
52 | DS1820_PORT |= 1<<used_pin; //Pullup on
53 | _delay_us(10);
54 | rebit = (DS1820_PIN & (1<<used_pin)) >> used_pin; //Read bit
55 | _delay_us(48);
56 | return rebit;
57 | }
58 | //-----------------------------------------
59 | // Read 1 byte from DS18S20
60 | //-----------------------------------------
61 | uint8_t ds1820_re_byte(uint8_t used_pin)
62 | {
63 | uint8_t rebyte =0x00;
64 | uint8_t rebit;
65 | uint8_t i;
66 |
67 | for (i=0;i<8;i++)
68 | {
69 | rebit=ds1820_re_bit(used_pin);
70 | _delay_us(2); //be on the save side
71 | if (rebit==1){
72 | rebyte|=(1<<i);
73 | }
74 | }
75 | return(rebyte);
76 | }
77 | //-----------------------------------------
78 | // Write 1 byte to DS18S20
79 | //-----------------------------------------
80 | void ds1820_wr_byte(uint8_t wrbyte,uint8_t used_pin)
81 | {
82 | uint8_t i;
83 | for (i=0; i<8; i++) // writes byte, one bit at a time
84 | {
85 | ds1820_wr_bit((wrbyte & 0b00000001),used_pin);
86 | wrbyte = wrbyte >> 1;
87 | }
88 | _delay_us(5);
89 | }
90 | //-----------------------------------------
91 | // Read temperature
92 | //-----------------------------------------
93 | float ds1820_read_temp(uint8_t used_pin)
94 | {
95 | uint8_t error;
96 | uint16_t i=0;
97 | uint8_t scratchpad[9];
98 | float temp=0;
99 |
100 | scratchpad[0]=0;
101 | scratchpad[1]=0;
102 | scratchpad[2]=0;
103 | scratchpad[3]=0;
104 | scratchpad[4]=0;
105 | scratchpad[5]=0;
106 | scratchpad[6]=0;
107 | scratchpad[7]=0;
108 | scratchpad[8]=0;
109 |
110 | error=ds1820_reset(used_pin);
111 | //1. Reset
112 | if (error==0){
113 | ds1820_wr_byte(0xCC,used_pin); //2. skip ROM
114 | ds1820_wr_byte(0x44,used_pin); //3. ask for temperature conversion
115 |
116 | for (i = 0;i < 760;i++){ //4. wait until conversion is finished
117 | _delay_ms(1);
118 | }
119 |
120 | // while (ds1820_re_byte(used_pin)!=0xFF){ //4. wait until conversion is finished
121 | // _delay_us(10);
122 | // i++;
123 | // }
124 |
125 | error=ds1820_reset(used_pin); //5. Reset
126 | ds1820_wr_byte(0xCC,used_pin); //6. skip ROM
127 | ds1820_wr_byte(0xBE,used_pin); //7. Read entire scratchpad 9 bytes
128 |
129 | for (i=0; i<9; i++) //8. Get scratchpad byte by byte
130 | {
131 | scratchpad[i]=ds1820_re_byte(used_pin); //9. read one DS18S20 byte
132 | }
133 |
134 | // scratchpad[1]=0b00000010; // Testbytes for Temperatur calculation
135 | // scratchpad[0]=0b01010001;
136 | }
137 | if((scratchpad[1]&0xF8)==0x00){ .
138 | temp = (float)(((scratchpad[1]<<8)+scratchpad[0]));
139 | temp *= 0.0625;
140 |
141 | }else{
142 | uint8_t tmp;
143 | tmp =scratchpad[0];
144 | tmp= ~ tmp;
145 | tmp= tmp >> 1;
146 | temp = (-1)*(tmp+1);
147 | if ((scratchpad[0]&0b00000001)==1){
148 | temp=temp+0.5;
149 | }
150 |
151 | }
152 |
153 | // temp=scratchpad[2]; // Return Scratchpad Byte X for Controll
154 |
155 | return temp;
156 |
157 | }
158 | //-----------------------------------------
159 | // Initialize DS18S20
160 | //-----------------------------------------
161 | uint8_t ds1820_init(uint8_t used_pin)
162 | {
163 | uint8_t error;
164 | error=ds1820_reset(used_pin); //1. Reset
165 | if (error==0){
166 | ds1820_wr_byte(0xCC,used_pin); //2. skip ROM
167 | ds1820_wr_byte(0x44,used_pin); //3. ask for temperature conversion
168 | for (i = 0;i < 1000;i++){ //4. wait until conversion is finished
169 | _delay_us(900);
170 | }
171 | error=ds1820_reset(used_pin); //5. Reset
172 | ds1820_wr_byte(0xCC,used_pin); //6. skip ROM
173 | ds1820_wr_byte(0xBE,used_pin); //7. Read entire scratchpad 9 bytes
174 | }
175 | return error;
176 |
177 | }
