1 | atmega2561/4Dboot.elf: file format elf32-avr
2 |
3 | Sections:
4 | Idx Name Size VMA LMA File off Algn
5 | 0 .data 00000256 00800200 0001fbd6 00000c6a 2**0
6 | CONTENTS, ALLOC, LOAD, DATA
7 | 1 .text 00000bd6 0001f000 0001f000 00000094 2**1
8 | CONTENTS, ALLOC, LOAD, READONLY, CODE
9 | 2 .bss 00000546 00800456 00800456 00000ec0 2**0
10 | ALLOC
11 | 3 .debug_aranges 00000070 00000000 00000000 00000ec0 2**0
12 | CONTENTS, READONLY, DEBUGGING
13 | 4 .debug_pubnames 0000027c 00000000 00000000 00000f30 2**0
14 | CONTENTS, READONLY, DEBUGGING
15 | 5 .debug_info 00000db3 00000000 00000000 000011ac 2**0
16 | CONTENTS, READONLY, DEBUGGING
17 | 6 .debug_abbrev 00000274 00000000 00000000 00001f5f 2**0
18 | CONTENTS, READONLY, DEBUGGING
19 | 7 .debug_line 0000089b 00000000 00000000 000021d3 2**0
20 | CONTENTS, READONLY, DEBUGGING
21 | 8 .debug_frame 000000c0 00000000 00000000 00002a70 2**2
22 | CONTENTS, READONLY, DEBUGGING
23 | 9 .debug_str 0000037d 00000000 00000000 00002b30 2**0
24 | CONTENTS, READONLY, DEBUGGING
25 | 10 .debug_loc 0000077b 00000000 00000000 00002ead 2**0
26 | CONTENTS, READONLY, DEBUGGING
27 | 11 .debug_ranges 000001b8 00000000 00000000 00003628 2**0
28 | CONTENTS, READONLY, DEBUGGING
29 |
30 | Disassembly of section .text:
31 |
32 | 0001f000 <__vectors>:
33 | // return -
34 | //-------------------------------------------------------------------------------
35 | void LCD_Wait( void )
36 | { //waits for SPI transfer is done
37 | while (!(SPSR & (_BV(SPIF))));
38 | }
39 | 1f000: 0c 94 66 f8 jmp 0x1f0cc ; 0x1f0cc <__ctors_end>
40 | 1f004: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
41 | 1f008: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
42 | 1f00c: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
43 | 1f010: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
44 | 1f014: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
45 | 1f018: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
46 | 1f01c: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
47 | 1f020: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
48 | 1f024: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
49 | 1f028: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
50 | 1f02c: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
51 | 1f030: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
52 | 1f034: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
53 | 1f038: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
54 | 1f03c: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
55 | 1f040: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
56 | 1f044: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
57 | 1f048: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
58 | 1f04c: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
59 | 1f050: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
60 | 1f054: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
61 | 1f058: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
62 | 1f05c: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
63 | 1f060: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
64 | 1f064: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
65 | 1f068: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
66 | 1f06c: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
67 | 1f070: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
68 | 1f074: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
69 | 1f078: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
70 | 1f07c: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
71 | 1f080: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
72 | 1f084: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
73 | 1f088: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
74 | 1f08c: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
75 | 1f090: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
76 | 1f094: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
77 | 1f098: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
78 | 1f09c: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
79 | 1f0a0: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
80 | 1f0a4: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
81 | 1f0a8: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
82 | 1f0ac: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
83 | 1f0b0: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
84 | 1f0b4: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
85 | 1f0b8: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
86 | 1f0bc: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
87 | 1f0c0: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
88 | 1f0c4: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
89 | 1f0c8: 0c 94 87 f8 jmp 0x1f10e ; 0x1f10e <__bad_interrupt>
90 |
91 | 0001f0cc <__ctors_end>:
92 | 1f0cc: 11 24 eor r1, r1
93 | 1f0ce: 1f be out 0x3f, r1 ; 63
94 | 1f0d0: cf ef ldi r28, 0xFF ; 255
95 | 1f0d2: d1 e2 ldi r29, 0x21 ; 33
96 | 1f0d4: de bf out 0x3e, r29 ; 62
97 | 1f0d6: cd bf out 0x3d, r28 ; 61
98 | 1f0d8: 00 e0 ldi r16, 0x00 ; 0
99 | 1f0da: 0c bf out 0x3c, r16 ; 60
100 |
101 | 0001f0dc <__do_copy_data>:
102 | 1f0dc: 14 e0 ldi r17, 0x04 ; 4
103 | 1f0de: a0 e0 ldi r26, 0x00 ; 0
104 | 1f0e0: b2 e0 ldi r27, 0x02 ; 2
105 | 1f0e2: e6 ed ldi r30, 0xD6 ; 214
106 | 1f0e4: fb ef ldi r31, 0xFB ; 251
107 | 1f0e6: 01 e0 ldi r16, 0x01 ; 1
108 | 1f0e8: 0b bf out 0x3b, r16 ; 59
109 | 1f0ea: 02 c0 rjmp .+4 ; 0x1f0f0 <__do_copy_data+0x14>
110 | 1f0ec: 07 90 elpm r0, Z+
111 | 1f0ee: 0d 92 st X+, r0
112 | 1f0f0: a6 35 cpi r26, 0x56 ; 86
113 | 1f0f2: b1 07 cpc r27, r17
114 | 1f0f4: d9 f7 brne .-10 ; 0x1f0ec <__do_copy_data+0x10>
115 |
116 | 0001f0f6 <__do_clear_bss>:
117 | 1f0f6: 19 e0 ldi r17, 0x09 ; 9
118 | 1f0f8: a6 e5 ldi r26, 0x56 ; 86
119 | 1f0fa: b4 e0 ldi r27, 0x04 ; 4
120 | 1f0fc: 01 c0 rjmp .+2 ; 0x1f100 <.do_clear_bss_start>
121 |
122 | 0001f0fe <.do_clear_bss_loop>:
123 | 1f0fe: 1d 92 st X+, r1
124 |
125 | 0001f100 <.do_clear_bss_start>:
126 | 1f100: ac 39 cpi r26, 0x9C ; 156
127 | 1f102: b1 07 cpc r27, r17
128 | 1f104: e1 f7 brne .-8 ; 0x1f0fe <.do_clear_bss_loop>
129 | 1f106: 0e 94 60 fa call 0x1f4c0 ; 0x1f4c0 <main>
130 | 1f10a: 0c 94 e9 fd jmp 0x1fbd2 ; 0x1fbd2 <_exit>
131 |
132 | 0001f10e <__bad_interrupt>:
133 | 1f10e: 0c 94 00 f8 jmp 0x1f000 ; 0x1f000 <__vectors>
134 |
135 | 0001f112 <LCD_SPI_Int>:
136 | void LCD_SPI_Int( uint16_t Value )
137 | { // send int by SPI
138 | 1f112: 28 2f mov r18, r24
139 | SPCR |= _BV(SPE);
140 | 1f114: 8c b5 in r24, 0x2c ; 44
141 | 1f116: 80 64 ori r24, 0x40 ; 64
142 | 1f118: 8c bd out 0x2c, r24 ; 44
143 | SPDR = (uint8_t)(Value >> 8);
144 | 1f11a: 9e bd out 0x2e, r25 ; 46
145 | // param ... zu sendende Daten
146 | // return -
147 | //-------------------------------------------------------------------------------
148 | void LCD_Wait( void )
149 | { //waits for SPI transfer is done
150 | while (!(SPSR & (_BV(SPIF))));
151 | 1f11c: 0d b4 in r0, 0x2d ; 45
152 | 1f11e: 07 fe sbrs r0, 7
153 | 1f120: fd cf rjmp .-6 ; 0x1f11c <LCD_SPI_Int+0xa>
154 | void LCD_SPI_Int( uint16_t Value )
155 | { // send int by SPI
156 | SPCR |= _BV(SPE);
157 | SPDR = (uint8_t)(Value >> 8);
158 | LCD_Wait();
159 | SPCR |= _BV(SPE);
160 | 1f122: 8c b5 in r24, 0x2c ; 44
161 | 1f124: 80 64 ori r24, 0x40 ; 64
162 | 1f126: 8c bd out 0x2c, r24 ; 44
163 | SPDR = (uint8_t)(Value & 0xff);
164 | 1f128: 2e bd out 0x2e, r18 ; 46
165 | // param ... zu sendende Daten
166 | // return -
167 | //-------------------------------------------------------------------------------
168 | ......
169 | ......
170 | 0001fb72 <__eerd_blraw_m2561>:
171 | 1fb72: fc 01 movw r30, r24
172 | 1fb74: f9 99 sbic 0x1f, 1 ; 31
173 | 1fb76: fe cf rjmp .-4 ; 0x1fb74 <__eerd_blraw_m2561+0x2>
174 | 1fb78: 06 c0 rjmp .+12 ; 0x1fb86 <__eerd_blraw_m2561+0x14>
175 | 1fb7a: f2 bd out 0x22, r31 ; 34
176 | 1fb7c: e1 bd out 0x21, r30 ; 33
177 | 1fb7e: f8 9a sbi 0x1f, 0 ; 31
178 | 1fb80: 31 96 adiw r30, 0x01 ; 1
179 | 1fb82: 00 b4 in r0, 0x20 ; 32
180 | 1fb84: 0d 92 st X+, r0
181 | 1fb86: 41 50 subi r20, 0x01 ; 1
182 | 1fb88: 50 40 sbci r21, 0x00 ; 0
183 | 1fb8a: b8 f7 brcc .-18 ; 0x1fb7a <__eerd_blraw_m2561+0x8>
184 | 1fb8c: 08 95 ret
185 |
186 | 0001fb8e <__udivmodsi4>:
187 | 1fb8e: a1 e2 ldi r26, 0x21 ; 33
188 | 1fb90: 1a 2e mov r1, r26
189 | 1fb92: aa 1b sub r26, r26
190 | 1fb94: bb 1b sub r27, r27
191 | 1fb96: fd 01 movw r30, r26
192 | 1fb98: 0d c0 rjmp .+26 ; 0x1fbb4 <__udivmodsi4_ep>
193 |
194 | 0001fb9a <__udivmodsi4_loop>:
195 | 1fb9a: aa 1f adc r26, r26
196 | 1fb9c: bb 1f adc r27, r27
197 | 1fb9e: ee 1f adc r30, r30
198 | 1fba0: ff 1f adc r31, r31
199 | 1fba2: a2 17 cp r26, r18
200 | 1fba4: b3 07 cpc r27, r19
201 | 1fba6: e4 07 cpc r30, r20
202 | 1fba8: f5 07 cpc r31, r21
203 | 1fbaa: 20 f0 brcs .+8 ; 0x1fbb4 <__udivmodsi4_ep>
204 | 1fbac: a2 1b sub r26, r18
205 | 1fbae: b3 0b sbc r27, r19
206 | 1fbb0: e4 0b sbc r30, r20
207 | 1fbb2: f5 0b sbc r31, r21
208 |
209 | 0001fbb4 <__udivmodsi4_ep>:
210 | 1fbb4: 66 1f adc r22, r22
211 | 1fbb6: 77 1f adc r23, r23
212 | 1fbb8: 88 1f adc r24, r24
213 | 1fbba: 99 1f adc r25, r25
214 | 1fbbc: 1a 94 dec r1
215 | 1fbbe: 69 f7 brne .-38 ; 0x1fb9a <__udivmodsi4_loop>
216 | 1fbc0: 60 95 com r22
217 | 1fbc2: 70 95 com r23
218 | 1fbc4: 80 95 com r24
219 | 1fbc6: 90 95 com r25
220 | 1fbc8: 9b 01 movw r18, r22
221 | 1fbca: ac 01 movw r20, r24
222 | 1fbcc: bd 01 movw r22, r26
223 | 1fbce: cf 01 movw r24, r30
224 | 1fbd0: 08 95 ret
225 |
226 | 0001fbd2 <_exit>:
227 | 1fbd2: f8 94 cli
228 |
229 | 0001fbd4 <__stop_program>:
230 | 1fbd4: ff cf rjmp .-2 ; 0x1fbd4 <__stop_program>
