Forum: Mikrocontroller und Digitale Elektronik Pointer Problem Wer kann Helfen?
von roxor (Gast)
Hallo liebe Community,
ich habe hier ein Code Besispiel von Silabs, leider sind da Fehler drin.
Kann mir jemand vielleicht helfen? Es hat auf jedenfall etwas mit
Pointer zutun!
unsigned char MMC_FLASH_Write (unsigned long address, unsigned char *scratch,
                          unsigned char *wdata, unsigned int length)
   idata unsigned long flash_page_1;   // First FLASH page address;
   idata unsigned long flash_page_2;   // Second FLASH page address;
   idata unsigned int card_status;     // Stores status returned from MMC;
   idata unsigned int counter;         // Byte counter used for writes to
                                       // local copy of data block;
   unsigned char xdata *index;         // Pointer into local copy of data
                                       // block, used during modification;
   MMC_FLASH_Clear(address,scratch,length); // Clear desired write space;
   if(length > 512) return 0;          // Check for valid data length;
                                       // Calculate first FLASH page address;
   flash_page_1 = address & ~(PHYSICAL_BLOCK_SIZE-1);
                                       // Calculate second FLASH page address;
   flash_page_2 = (address+length-1) & ~(PHYSICAL_BLOCK_SIZE-1);
   if(flash_page_1 == flash_page_2)    // Handle single FLASH block condition;
                                       // Set block length to default block
                                       // size (512 bytes);
      card_status = MMC_Command_Exec(SET_BLOCKLEN,
                                 (unsigned long)PHYSICAL_BLOCK_SIZE,
23
                                 EMPTY);
24
                                       // Read data block;
25
      card_status = MMC_Command_Exec(READ_SINGLE_BLOCK,flash_page_1,scratch);
26
      index = (unsigned int)(address % PHYSICAL_BLOCK_SIZE + scratch);
27
      counter = 0;
28
      while(counter<length)            // Modify write space in local copy;
29
30
         *index++ = *wdata++;
31
         counter++;
32
33
                                       // Write modified block back to MMC;
34
      card_status = MMC_Command_Exec(WRITE_BLOCK,flash_page_1,scratch);
35
36
   else                                // Handle multiple FLASH block
37
   {                                   // condition;
38
39
40
41
42
                                 EMPTY);
43
                                       // Read first data block;
44
45
46
      counter = (unsigned int)(flash_page_2 - address);
47
      while(counter > 0)               // Modify data in local copy of first
48
      {                                // block;
49
50
         counter--;
51
52
                                       // Write local copy back to MMC;
53
54
                                       // Read second data block;
55
      card_status = MMC_Command_Exec(READ_SINGLE_BLOCK,flash_page_2,scratch);
56
 @@@     index = scratch;
57
      counter = (unsigned int)(length - (flash_page_2 - address));
58
      while(counter > 0)               // Modify data in local copy of second
59
      {                                // block;
60
61
         counter--;
62
63
64
      card_status = MMC_Command_Exec(WRITE_BLOCK,flash_page_2,scratch);
65
66
an der Stelle @@@ streikt der Compiler:
MMC_DATALOGGER.C(1269): warning C259: '=': pointer: different mspace
von dunno.. (Gast)
und warum machst du das topic 2 mal auf..?
von Noname (Gast)
Was soll das denn?
Willst Du solange neue Threads aufmachen, bis Du nicht mehr aus eigener
Erkenntnis das Problem lösen musst?
Das Problem ist Dir doch nun schon erklärt worden. Verschiedene
Datentypen!
Beitrag "C pointer Problem : different mspace"
von roxor (Gast)
wie wäre es denn wenn sich jemand mal erbarmt und mir sagt wie man so
etwas löst. Ich habe wirklich keine Ahnung.
von Noname (Gast)
Wieder so ein "CopyNPaste"-Programmierer? ;-)
von roxor (Gast)
genau, man kann nicht alles können. ich hab mich zwar mal vor längerer
zeit mit den konzepten von pointer etc beschäftigt aber im moment haben
andere sachen prorität und das mc projekt ist eher so ne hobby sache.
von Noname (Gast)
>wie wäre es denn wenn sich jemand mal erbarmt...
Nö.
Wir reichen Dir gerne die Hand
wenn Du in unsere erlauchten Kreise
kraft Deiner eigenen Denke
und Aufwand an Nächten und Kaffee und Pizza
aufsteigen willst -
aber nur wenn Du uns die Eselsohren in Deinem K&R zeigst.
von roxor (Gast)
also,
ich weise dem pointer den wert der variablen scratch zu, was aber nicht
geht weil der pointer auf eine speicheradresse zeigt und scratch aber
eine varibale ist.
Was bezweckt der code an der stelle? vielleicht hilft mir das drauf zu
kommen. everygo!
von roxor (Gast)
das ist es nicht :
  *index = scratch;
von Noname (Gast)
Du hast ein ganz anderes Problem, denn beide Variablen sind Zeiger auf
den gleichen Typ. Aber sie zeigen auf verschiedene Speicherbereiche.
Google mal "different mspace".
von xyz (Gast)
Das Codebeispiel ist murks und wenn du es semantisch irgendwie durch
casts zum compilieren bringst wird sicher nicht funktionieren.
sorry, aber das ist meine Prognose
