1 | /*
2 | LCD Ausgabe für Hitachi HD44780 kompatible LCD Controller
3 |
4 | ATMEGA8/16/32 und kompatibel
5 |
6 | Dieses Beispiel sollte mit allen HD44780 kompatiblen LCD
7 | Displays funktionieren.
8 | */
9 |
10 | #define F_CPU 3686400
11 |
12 | #include <avr/io.h>
13 | #include <util/delay.h>
14 |
15 | /*
16 | * BITTE HIER IHRE VERWENDETEN PINS KONFIGURIEREN!
17 | *
18 | * Standardkonfiguration:
19 | * PORTD7 = LCD D7
20 | * PORTD6 = LCD D6
21 | * PORTD5 = LCD D5
22 | * PORTD4 = LCD D4
23 | *
24 | */
25 | #define LCDPORT PORTD
26 | #define LCDDDR DDRD
27 | #define LCD_PIN_RS 2
28 | #define LCD_PIN_E 3
29 | #define LCD_PIN_D4 4
30 | #define LCD_PIN_D5 5
31 | #define LCD_PIN_D6 6
32 | #define LCD_PIN_D7 7
33 |
34 |
35 | /* LCD STEUERBEFEHLE ********** */
36 |
37 | #define LCD_CLEAR 0x01
38 | #define LCD_HOME 0x02
39 | #define LCD_ON 0x0C /* 0x0C = Cursor unsichtbar */
40 | #define LCD_ON 0x0E /* 0x0E = Cursor sichtbar */
41 | #define LCD_OFF 0x08
42 |
43 | /* HILFSDEFINITIONEN ********** */
44 |
45 | #define BEFEHL 0
46 | #define DATEN 1
47 | #define sbi(sfr, bit) (sfr|=(1<<bit))
48 | #define cbi(sfr, bit) (sfr&=~(1<<bit))
49 |
50 |
51 | /****** Schickt ein Byte an den LCD Controller */
52 | void lcd_send(unsigned char type, unsigned char c)
53 | {
54 | if (type==BEFEHL)
55 | cbi(LCDPORT, LCD_PIN_RS); /* RS=0: Befehl folgt ... */
56 | else
57 | sbi(LCDPORT, LCD_PIN_RS); /* RS=1: Daten folgen ... */
58 |
59 |
60 | /* (1) ==== HIGH NIBBLE wird gesendet */
61 | if (bit_is_set(c, 7)) sbi(LCDPORT, LCD_PIN_D7); else cbi(LCDPORT, LCD_PIN_D7);
62 | if (bit_is_set(c, 6)) sbi(LCDPORT, LCD_PIN_D6); else cbi(LCDPORT, LCD_PIN_D6);
63 | if (bit_is_set(c, 5)) sbi(LCDPORT, LCD_PIN_D5); else cbi(LCDPORT, LCD_PIN_D5);
64 | if (bit_is_set(c, 4)) sbi(LCDPORT, LCD_PIN_D4); else cbi(LCDPORT, LCD_PIN_D4);
65 |
66 | /* Flanke zur Übernahme der Daten schicken ... */
67 | sbi(LCDPORT, LCD_PIN_E);
68 | cbi(LCDPORT, LCD_PIN_E);
69 |
70 |
71 | /* (2) ==== LOW NIBBLE wird gesendet */
72 | if (bit_is_set(c, 3)) sbi(LCDPORT, LCD_PIN_D7); else cbi(LCDPORT, LCD_PIN_D7);
73 | if (bit_is_set(c, 2)) sbi(LCDPORT, LCD_PIN_D6); else cbi(LCDPORT, LCD_PIN_D6);
74 | if (bit_is_set(c, 1)) sbi(LCDPORT, LCD_PIN_D5); else cbi(LCDPORT, LCD_PIN_D5);
75 | if (bit_is_set(c, 0)) sbi(LCDPORT, LCD_PIN_D4); else cbi(LCDPORT, LCD_PIN_D4);
76 |
77 | /* Flanke zur Übernahme der Daten schicken ... */
78 | sbi(LCDPORT, LCD_PIN_E);
79 | cbi(LCDPORT, LCD_PIN_E);
80 |
81 |
82 | /* (3) Auf den LCD Controller warten ...*/
83 | _delay_ms(5);
84 | }
85 |
86 |
87 | /****** Stellt eine Zeichenkette am LCD dar */
88 | void lcd_write(char *t)
89 | {
90 | unsigned char i;
91 | for (i=0;i<255;i++)
92 | {
93 | if (t[i]==0) // String-Ende? Dann raus hier ...
94 | return;
95 | else
96 | lcd_send(DATEN, t[i]);
97 | }
98 | }
99 |
100 |
101 | /****** Initialisierung des LCD Controllers */
102 | void lcd_init()
103 | {
104 | /* Port auf Ausgang schalten */
105 | LCDPORT = 0x00;
106 | LCDDDR = 0xFF;
107 |
108 | _delay_ms(50); // Warten bis LCD bereit ...
109 |
110 | /* 4-bit Modus konfigurieren */
111 | sbi(LCDPORT, LCD_PIN_D5);
112 | cbi(LCDPORT, LCD_PIN_D4);
113 |
114 | /* 4-Bit Modus starten ... */
115 | sbi(PORTD, LCD_PIN_E);
116 | cbi(PORTD, LCD_PIN_E);
117 | _delay_ms(5);
118 |
119 | /* 2 Zeilen, 4-Bit Modus */
120 | lcd_send(BEFEHL, 0x28);
121 |
122 | lcd_send(BEFEHL, LCD_OFF);
123 | lcd_send(BEFEHL, LCD_CLEAR);
124 |
125 | lcd_send(BEFEHL, 0x06);
126 | lcd_send(BEFEHL, LCD_ON);
127 | }
128 |
129 |
130 | /****** Hilfsfunktion: Warte i Sekunden */
131 | void sekunde(char i)
132 | {
133 | unsigned char k;
134 | for (;i>0;i--)
135 | {
136 | for (k=0;k<10;k++)
137 | _delay_ms(100);
138 | }
139 | }
140 |
141 |
142 | /****** HAUPTPROGRAMM *****/
143 |
144 | int main(void)
145 | {
146 | lcd_init();
147 | lcd_write("Starting...");
148 | int i=0;
149 | while (1)
150 | {
151 |
152 | sekunde(1);
153 | lcd_send(BEFEHL, LCD_CLEAR);
154 | if (i==0)
155 | lcd_write("0");
156 |
157 | sekunde(1);
158 | lcd_send(BEFEHL, LCD_CLEAR);
159 | lcd_write("1");
160 | }
161 | }
