1 | /*
2 | SDcard.c - functions to read content of an SD card
3 | utilizes FATfs (include in project, all but diskio.c, functions are implemented here, just add diskio.h)
4 | get it here: http://elm-chan.org/fsw/ff/00index_e.html
5 |
6 | Created by Damian Schneider, March 29th, 2013.
7 |
8 | code taken from "ronan" and adapted for CooCox STMf0, original posted here
9 | https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2FSTM32Discovery%2FDriver%20to%20use%20MicroSD%20card%20with%20SPI&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0F¤tviews=2201
10 |
11 | also mixed in with some ST-library parts and stuff of my own "until it works".
12 | */
13 |
14 | #include "stm32f0xx_spi.h"
15 | #include "stm32f0xx_gpio.h"
16 | #include "stm32f0xx_rcc.h"
17 | #include "stm32f0xx.h"
18 | #include "ffconf.h"
19 | #include "ff.h"
20 | #include "xprintf.h"
21 | #include "string.h"
22 | #include "diskio.h"
23 |
24 |
25 |
26 | /* SPIx Communication boards Interface */
27 | #define GPIO_AF_SPI2 GPIO_AF_0
28 | #define SPIx_SD SPI2
29 | #define SPIx_SD_CLK RCC_APB1Periph_SPI2
30 | #define SPIx_SD_CLK_INIT RCC_APB1PeriphClockCmd
31 | #define SPIx_SD_IRQn SPI2_IRQn
32 | #define SPIx_SD_IRQHANDLER SPI2_IRQHandler
33 |
34 | #define SPIx_SD_SCK_PIN GPIO_Pin_13
35 | #define SPIx_SD_SCK_GPIO_PORT GPIOB
36 | #define SPIx_SD_SCK_GPIO_CLK RCC_AHBPeriph_GPIOB
37 | #define SPIx_SD_SCK_SOURCE GPIO_PinSource13
38 | #define SPIx_SD_SCK_AF GPIO_AF_SPI2
39 |
40 | #define SPIx_SD_MISO_PIN GPIO_Pin_14
41 | #define SPIx_SD_MISO_GPIO_PORT GPIOB
42 | #define SPIx_SD_MISO_GPIO_CLK RCC_AHBPeriph_GPIOB
43 | #define SPIx_SD_MISO_SOURCE GPIO_PinSource14
44 | #define SPIx_SD_MISO_AF GPIO_AF_SPI2
45 |
46 | #define SPIx_SD_MOSI_PIN GPIO_Pin_15
47 | #define SPIx_SD_MOSI_GPIO_PORT GPIOB
48 | #define SPIx_SD_MOSI_GPIO_CLK RCC_AHBPeriph_GPIOB
49 | #define SPIx_SD_MOSI_SOURCE GPIO_PinSource15
50 | #define SPIx_SD_MOSI_AF GPIO_AF_SPI2
51 |
52 | #define SPIx_SD_NSS_PIN GPIO_Pin_12
53 | #define SPIx_SD_NSS_GPIO_PORT GPIOB
54 | #define SPIx_SD_NSS_GPIO_CLK RCC_AHBPeriph_GPIOB
55 | #define SPIx_SD_NSS_SOURCE GPIO_PinSource12
56 | #define SPIx_SD_NSS_AF GPIO_AF_SPI2
57 |
58 | #define SPIx_SD_BAUDRATE_SLOW SPI_BaudRatePrescaler_128
59 | #define SPIx_SD_BAUDRATE_FAST SPI_BaudRatePrescaler_2
60 |
61 | /* Definitions for SDC command --------------------------------------------*/
62 | #define CMD0 (0x40+0) /* GO_IDLE_STATE */
63 | #define CMD1 (0x40+1) /* SEND_OP_COND (MMC) */
64 | #define ACMD41 (0xC0+41) /* SEND_OP_COND (SDC) */
65 | #define CMD8 (0x40+8) /* SEND_IF_COND */
66 | #define CMD9 (0x40+9) /* SEND_CSD */
67 | #define CMD10 (0x40+10) /* SEND_CID */
68 | #define CMD12 (0x40+12) /* STOP_TRANSMISSION */
69 | #define ACMD13 (0xC0+13) /* SD_STATUS (SDC) */
70 | #define CMD16 (0x40+16) /* SET_BLOCKLEN */
71 | #define CMD17 (0x40+17) /* READ_SINGLE_BLOCK */
72 | #define CMD18 (0x40+18) /* READ_MULTIPLE_BLOCK */
73 | #define CMD23 (0x40+23) /* SET_BLOCK_COUNT (MMC) */
74 | #define ACMD23 (0xC0+23) /* SET_WR_BLK_ERASE_COUNT (SDC) */
75 | #define CMD24 (0x40+24) /* WRITE_BLOCK */
76 | #define CMD25 (0x40+25) /* WRITE_MULTIPLE_BLOCK */
77 | #define CMD55 (0x40+55) /* APP_CMD */
78 | #define CMD58 (0x40+58) /* READ_OCR */
79 |
80 | /* Definitions for card type --------------------------------------------*/
81 | #define SD2_BYTE 0x04 /* SD Ver.2 (Byte address) */
82 | #define SD2_BLOCK 0x0C /* SD Ver.2 (Block address) */
83 |
84 | //pin select
85 | #define SDSELECT() GPIOB->BRR = (1<<12) //pin low, MMC CS = L
86 | #define SDDESELECT() GPIOB->BSRR = (1<<12) //pin high,MMC CS = H
87 | /*--------------------------------------------------------------------------
88 |
89 | Module Private Functions and Variables
90 |
91 | ---------------------------------------------------------------------------*/
92 |
93 | static const uint32_t socket_state_mask_cp = (1 << 0);
94 | static const uint32_t socket_state_mask_wp = (1 << 1);
95 |
96 | static volatile DSTATUS Stat = STA_NOINIT; /* Disk status */
97 | static volatile uint32_t Timer1, Timer2; /* 100Hz decrement timers */
98 | static uint8_t CardType; /* Card type flags */
99 |
100 | enum speed_setting {
101 | INTERFACE_SLOW, INTERFACE_FAST
102 | };
103 |
104 | /*-----------------------------------------------------------------------*/
105 | /* @descr INTERFACE SPEED */
106 | /* @param speed INTERFACE_SLOW OR INTERFACE_FAST */
107 | /* @retval none */
108 | /*-----------------------------------------------------------------------*/
109 | static void interface_speed(enum speed_setting speed) {
110 | uint32_t tmp;
111 |
112 | /* Lecture du registre CR1 ------------------------------- */
113 | tmp = SPIx_SD->CR1;
114 |
115 | /* Test la configuration --- ----------------------------- */
116 | if (speed == INTERFACE_SLOW) {
117 | /* Set slow clock (100k-400k) ------------------------ */
118 | tmp = (tmp | SPIx_SD_BAUDRATE_SLOW);
119 | } else {
120 | /* Set fast clock (depends on the CSD) --------------- */
121 | tmp = (tmp & ~SPIx_SD_BAUDRATE_SLOW) | SPIx_SD_BAUDRATE_FAST;
122 | }
123 |
124 | /* Ecriture de la nouvelle config. sur le registre CR1 --- */
125 | SPIx_SD->CR1 = tmp;
126 | }
127 |
128 | /*-----------------------------------------------------------------------*/
129 | /* @descr TRANSMIT & RECEIVE BYTE via SPI */
130 | /* @param out octet à transemttre */
131 | /* @retval stm32_spi_rw octet reçu */
132 | /*-----------------------------------------------------------------------*/
133 | uint8_t stm32_spi_rw(uint8_t out) {
134 |
135 | /*!< Wait until the transmit buffer is empty */
136 | while (SPI_I2S_GetFlagStatus(SPIx_SD, SPI_I2S_FLAG_TXE) == RESET) {
137 | }
138 |
139 | /*!< Send the byte */
140 | SPI_SendData8(SPIx_SD, out);
141 |
142 | /*!< Wait to receive a byte*/
143 | while (SPI_I2S_GetFlagStatus(SPIx_SD, SPI_I2S_FLAG_RXNE) == RESET) {
144 | }
145 |
146 | /*!< Return the byte read from the SPI bus */
147 | return SPI_ReceiveData8(SPIx_SD);
148 |
149 | }
150 |
151 | /*-----------------------------------------------------------------------*/
152 | /* @descr RECEIVE A BYTE via SPI */
153 | /* @param None */
154 | /* @retval rcvr_spi octet reçu */
155 | /*-----------------------------------------------------------------------*/
156 | uint8_t rcvr_spi(void) {
157 | uint8_t Data = 0;
158 |
159 | /*!< Wait until the transmit buffer is empty */
160 | while (SPI_I2S_GetFlagStatus(SPIx_SD, SPI_I2S_FLAG_TXE) == RESET) {
161 | }
162 | /*!< Send the byte */
163 | SPI_SendData8(SPIx_SD, 0xFF);
164 |
165 | /*!< Wait until a data is received */
166 | while (SPI_I2S_GetFlagStatus(SPIx_SD, SPI_I2S_FLAG_RXNE) == RESET) {
167 | }
168 | /*!< Get the received data */
169 | Data = SPI_ReceiveData8(SPIx_SD);
170 |
171 | /*!< Return the shifted data */
172 | return Data;
173 | }
174 |
175 | /* Alternative macro to receive data fast */
176 | #define rcvr_spi_m(dst) *(dst)=stm32_spi_rw(0xff)
177 |
178 | /*-----------------------------------------------------------------------*/
179 | /* @descr Wait for card ready */
180 | /* @param None */
181 | /* @retval wait_ready octet reçu */
182 | /*-----------------------------------------------------------------------*/
183 | static uint8_t wait_ready(void) {
184 | uint8_t res;
185 | uint16_t timeout = 100; //try 100 times max.
186 | //Timer2 = 50; /* Wait for ready in timeout of 500ms */
187 | rcvr_spi();
188 |
189 | do {
190 | res = rcvr_spi();
191 | } while ((res != 0xFF && timeout--)); // && Timer2);
192 |
193 | return res;
194 | }
195 |
196 | /*-----------------------------------------------------------------------*/
197 | /* @descr Deselect the card and release SPI bus */
198 | /* @param None */
199 | /* @retval None */
200 | /*-----------------------------------------------------------------------*/
201 | static void release_spi(void) {
202 |
203 | SDDESELECT();
204 | rcvr_spi();
205 | }
206 |
207 | /*-----------------------------------------------------------------------*/
208 | /* @descr Power Control and interface-initialization */
209 | /* @param None */
210 | /* @retval None */
211 | /*-----------------------------------------------------------------------*/
212 | static void power_on(void) {
213 |
214 | SPI_InitTypeDef SPI_InitStructure;
215 | GPIO_InitTypeDef GPIO_InitStructure;
216 |
217 | /* Enable GPIO clocks */
218 | RCC_AHBPeriphClockCmd(
219 | SPIx_SD_SCK_GPIO_CLK | SPIx_SD_MISO_GPIO_CLK | SPIx_SD_MOSI_GPIO_CLK
220 | | SPIx_SD_NSS_GPIO_CLK, ENABLE);
221 |
222 | /* Enable the SPI clock */SPIx_SD_CLK_INIT(SPIx_SD_CLK, ENABLE);
223 |
224 | /* SPI GPIO Configuration --------------------------------------------------*/
225 |
226 | /* Configure I/O for Flash Chip select */
227 | GPIO_InitStructure.GPIO_Pin = SPIx_SD_NSS_PIN;
228 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
229 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
230 | GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
231 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
232 | GPIO_Init(SPIx_SD_NSS_GPIO_PORT, &GPIO_InitStructure);
233 |
234 | /* SPI SCK pin configuration */
235 | GPIO_InitStructure.GPIO_Pin = SPIx_SD_SCK_PIN;
236 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
237 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
238 | GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
239 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
240 | GPIO_Init(SPIx_SD_SCK_GPIO_PORT, &GPIO_InitStructure);
241 |
242 | /* SPI MOSI pin configuration */
243 | GPIO_InitStructure.GPIO_Pin = SPIx_SD_MOSI_PIN;
244 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
245 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
246 | GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
247 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
248 | GPIO_Init(SPIx_SD_MOSI_GPIO_PORT, &GPIO_InitStructure);
249 |
250 | /* SPI MISO pin configuration */
251 | GPIO_InitStructure.GPIO_Pin = SPIx_SD_MISO_PIN;
252 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
253 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
254 | GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
255 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
256 | GPIO_Init(SPIx_SD_MISO_GPIO_PORT, &GPIO_InitStructure);
257 |
258 | /* Connect SPI pins to AF0 */
259 | GPIO_PinAFConfig(SPIx_SD_SCK_GPIO_PORT, SPIx_SD_SCK_SOURCE, SPIx_SD_SCK_AF);
260 | GPIO_PinAFConfig(SPIx_SD_MOSI_GPIO_PORT, SPIx_SD_MOSI_SOURCE,
261 | SPIx_SD_MOSI_AF);
262 | GPIO_PinAFConfig(SPIx_SD_MISO_GPIO_PORT, SPIx_SD_MISO_SOURCE,
263 | SPIx_SD_MOSI_AF);
264 |
265 | /* SPI configuration */
266 | SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
267 | SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
268 | SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
269 | SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
270 | SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
271 | SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
272 | SPI_InitStructure.SPI_BaudRatePrescaler = SPIx_SD_BAUDRATE_SLOW; // 42000kHz/128=328kHz < 400kHz
273 | SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
274 | SPI_InitStructure.SPI_CRCPolynomial = 7;
275 |
276 | SPI_Init(SPIx_SD, &SPI_InitStructure);
277 | SPI_RxFIFOThresholdConfig(SPIx_SD, SPI_RxFIFOThreshold_QF);
278 |
279 | SPI_CalculateCRC(SPIx_SD, DISABLE);
280 | SPI_Cmd(SPIx_SD, ENABLE);
281 |
282 | /* drain SPI TX buffer,just in case*/
283 | while (SPI_I2S_GetFlagStatus(SPIx_SD, SPI_I2S_FLAG_TXE) == RESET) {
284 | ;
285 | }
286 | SPI_ReceiveData8(SPIx_SD);
287 |
288 | /* De-select the Card: Chip Select high */
289 | SDDESELECT();
290 |
291 | /*
292 | //DMA setup, in case dma is ever needed, code snipped, not working
293 | DMA_StructInit(&DMA_InitStructure);
294 | RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
295 | // reset DMA configuration
296 |
297 | //configure DMA
298 | DMA_InitStructure.DMA_MemoryBaseAddr = 0;
299 | DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t) &(SPI2->DR);
300 | DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
301 | DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
302 | DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
303 | DMA_InitStructure.DMA_BufferSize = 1;
304 | DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
305 | DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
306 | DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
307 | DMA_InitStructure.DMA_Priority = DMA_Priority_High;
308 | DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
309 | DMA_Init(SPI_PORT_TX_DMA_STREAM, &DMA_InitStructure);
310 |
311 | // Enable the DMA transfer complete interrupt
312 | DMA_ITConfig(SPI_PORT_TX_DMA_STREAM, DMA_IT_TC, ENABLE);
313 |
314 | // Enable SPI dma tx request.
315 | SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx, ENABLE);
316 |
317 | // Enable the interrupt in the NVIC
318 | NVIC_InitStructure.NVIC_IRQChannel = SPI_PORT_DMA_TX_IRQn;
319 | NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
320 | NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
321 | NVIC_Init(&NVIC_InitStructure);
322 | */
323 |
324 | }
325 |
326 | /*-----------------------------------------------------------------------*/
327 | /* @descr Power Off */
328 | /* @param None */
329 | /* @retval None */
330 | /*-----------------------------------------------------------------------*/
331 | static void power_off(void) {
332 |
333 | GPIO_InitTypeDef GPIO_InitStructure;
334 |
335 | if (!(Stat & STA_NOINIT)) {
336 | SDSELECT();
337 | wait_ready();
338 | release_spi();
339 | }
340 |
341 | SPI_I2S_DeInit(SPIx_SD);
342 | SPI_Cmd(SPIx_SD, DISABLE);
343 | SPIx_SD_CLK_INIT(SPIx_SD_CLK, DISABLE);
344 |
345 | /* All SPI-Pins to input with weak internal pull-downs */
346 | GPIO_InitStructure.GPIO_Pin = SPIx_SD_SCK_PIN | SPIx_SD_MISO_PIN
347 | | SPIx_SD_MOSI_PIN;
348 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
349 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
350 | GPIO_Init(SPIx_SD_SCK_GPIO_PORT, &GPIO_InitStructure);
351 |
352 | Stat |= STA_NOINIT; /* Set STA_NOINIT */
353 |
354 | }
355 |
356 | /*-----------------------------------------------------------------------*/
357 | /* @descr Receive a data packet from MMC */
358 | /* @param *buff Data buffer to store received data */
359 | /* @param btr Byte count (must be multiple of 4) */
360 | /* @retval None */
361 | /*-----------------------------------------------------------------------*/
362 | static uint8_t rcvr_datablock(uint8_t *buff, uint16_t btr) {
363 | uint8_t token;
364 |
365 | Timer1 = 10;
366 | do { /* Wait for data packet in timeout of 100ms */
367 | token = rcvr_spi();
368 | } while ((token == 0xFF) && Timer1);
369 |
370 | if (token != 0xFE)
371 | return 0; /* If not valid data token, return with error */
372 |
373 | do { /* Receive the data block into buffer */
374 | rcvr_spi_m(buff++);
375 | rcvr_spi_m(buff++);
376 | rcvr_spi_m(buff++);
377 | rcvr_spi_m(buff++);
378 | } while (btr -= 4);
379 |
380 | rcvr_spi(); /* Discard CRC */
381 | rcvr_spi();
382 |
383 | return 1; /* Return with success */
384 | }
385 |
386 | /*-----------------------------------------------------------------------*/
387 | /* @descr end a data packet to MMC */
388 | /* @param *buff 512 byte data block to be transmitted */
389 | /* @param token Data/Stop token */
390 | /* @retval None */
391 | /*-----------------------------------------------------------------------*/
392 | static uint8_t xmit_datablock(const uint8_t *buff, uint8_t token) {
393 | uint8_t resp;
394 | uint8_t wc;
395 |
396 | if (wait_ready() != 0xFF)
397 | return 0;
398 | stm32_spi_rw(token); /* transmit data token */
399 | if (token != 0xFD) { /* Is data token */
400 |
401 | wc = 0;
402 | do { /* transmit the 512 byte data block to MMC */
403 | stm32_spi_rw(*buff++);
404 | stm32_spi_rw(*buff++);
405 | } while (--wc);
406 |
407 | stm32_spi_rw(0xFF); /* CRC (Dummy) */
408 | stm32_spi_rw(0xFF);
409 | resp = rcvr_spi(); /* Receive data response */
410 | if ((resp & 0x1F) != 0x05) /* If not accepted, return with error */
411 | return 0;
412 | }
413 |
414 | return 1;
415 | }
416 |
417 | /*-----------------------------------------------------------------------*/
418 | /* @descr SEND A COMMAND PACKET (6 BYTES) */
419 | /* @param cmd Command byte */
420 | /* @param arg Argument */
421 | /* @retval None */
422 | /*-----------------------------------------------------------------------*/
423 | static uint8_t send_cmd(uint8_t cmd, uint32_t arg) {
424 |
425 | /* Declaration des variables ----------------------------- */
426 | uint8_t n, res;
427 |
428 | /* Test si c'est cmd ACDM -------------------------------- */
429 | if (cmd & 0x80) {
430 | cmd &= 0x7F;
431 | res = send_cmd(CMD55, 0); // envoie de la CMD55
432 | if (res > 1)
433 | return res;
434 | }
435 |
436 | /* Select the card --------------------------------------- */
437 | // SDDESELECT();
438 | SDSELECT();
439 |
440 | /* wait for ready ---------------------------------------- */
441 | if (wait_ready() != 0xFF) {
442 | return 0xFF;
443 | }
444 |
445 | /* Send command packet ----------------------------------- */
446 | stm32_spi_rw(cmd); // Send command index
447 |
448 | stm32_spi_rw((uint8_t)(arg >> 24)); // Send argument[31..24]
449 | stm32_spi_rw((uint8_t)(arg >> 16)); // Send argument[23..16]
450 | stm32_spi_rw((uint8_t)(arg >> 8)); // Send argument[15..8]
451 | stm32_spi_rw((uint8_t) arg); // Send argument[7..0]
452 |
453 | n = 0x01; // Stop : Dummy CRC
454 | if (cmd == CMD0)
455 | n = 0x95; // Valid CRC for CMD0(0)
456 | if (cmd == CMD8)
457 | n = 0x87; // Valid CRC for CMD8(0x1AA)
458 | stm32_spi_rw(n); // Send CRC
459 |
460 | /* Receive command response ------------------------------ */
461 | if (cmd == CMD12)
462 | rcvr_spi(); // Skip a stuff byte when stop reading
463 |
464 | /* Wait for a valid response in timeout of 10 attempts --- */
465 | n = 10;
466 | do
467 | res = rcvr_spi();
468 | while ((res & 0x80) && --n);
469 |
470 | /* Return with the response value ------------------------ */
471 | return res;
472 | }
473 |
474 | /*-----------------------------------------------------------------------*/
475 | /* @descr INITIALIZE DISK DRIVE */
476 | /* @param drv Physical drive numbre (0) */
477 | /* @retval DSTATUS Status of Disk Functions (BYTE) */
478 | /*-----------------------------------------------------------------------*/
479 | DSTATUS disk_initialize(uint8_t drv) {
480 |
481 | /* Declaration des variables ----------------------------- */
482 | uint8_t i, ocr[4], SDType;
483 |
484 | /* Supports only single drive ---------------------------- */
485 | if (drv)
486 | return STA_NOINIT;
487 |
488 | /* No card in the socket --------------------------------- */
489 | if (Stat & STA_NODISK)
490 | return Stat;
491 |
492 | /* Configure les broches & alimente la carte si necessaire */
493 | power_on();
494 |
495 | SDDESELECT();
496 |
497 | /* 80 dummy clocks --------------------------------------- */
498 | for (i = 10; i; i--) {
499 | stm32_spi_rw(0xff);
500 | }
501 |
502 | /* Initialise SDType ------------------------------------- */
503 | SDType = 0;
504 |
505 | /* Initialise la SDCard en mode SPI ---------------------- */
506 | if (send_cmd(CMD0, 0) == 1) {
507 |
508 | /* Verifie les conditions (tension,...) -------------- */
509 | if (send_cmd(CMD8, 0x1AA) == 1) {
510 | /* lecture des trames de réponses ---------------- */
511 | for (i = 0; i < 4; i++)
512 | ocr[i] = rcvr_spi();
513 |
514 | /* Verifie les tensions autorisées --------------- */
515 | if (ocr[2] == 0x01 && ocr[3] == 0xAA) {
516 | /* Attend de quitter l'état repos ------------ */
517 | while (send_cmd(ACMD41, 0x40000000))
518 | ;
519 |
520 | /* Envoie de la commande OCR ----------------- */
521 | if (send_cmd(CMD58, 0) == 0) {
522 | for (i = 0; i < 4; i++)
523 | ocr[i] = rcvr_spi();
524 |
525 | /* Control bit CCS dans le registre OCR -- */
526 | if (ocr[0] & 0x40) {
527 | SDType = SD2_BLOCK;
528 |
529 | } else {
530 | SDType = SD2_BYTE;
531 |
532 | }
533 | }
534 | }
535 | }
536 | }
537 |
538 | /* Erreur d'initialisation ------------------------------- */
539 | else {
540 | SDType = 0;
541 | }
542 |
543 | /* Deselectionne la liaison SPI -------------------------- */
544 | release_spi();
545 |
546 | /* Affecte le type de la carte a CardType ---------------- */
547 | CardType = SDType;
548 |
549 | /* Test si l'initialisation est valide ------------------- */
550 | if (SDType) {
551 | /* Initialization succeeded -------------------------- */
552 | Stat &= ~STA_NOINIT; /* Clear STA_NOINIT */
553 | interface_speed(INTERFACE_FAST);
554 | LED_ON;
555 |
556 | } else {
557 | /* Initialization failed ----------------------------- */
558 | power_off();
559 | }
560 |
561 | return Stat;
562 |
563 | }
564 |
565 | /*-----------------------------------------------------------------------*/
566 | /* @descr GET DISK STATUS */
567 | /* @param drv Physical drive numbre (0) */
568 | /* @retval DSTATUS Status of Disk Functions (BYTE) */
569 | /*-----------------------------------------------------------------------*/
570 | DSTATUS disk_status(uint8_t drv) {
571 | if (drv)
572 | return STA_NOINIT; /* Supports only single drive */
573 | return Stat;
574 | }
575 |
576 | /*-----------------------------------------------------------------------*/
577 | /* @descr READ SECTOR(S) */
578 | /* @param drv Physical drive numbre (0) */
579 | /* @param *buff Pointer to the data buffer to store read data */
580 | /* @param sector Start sector number (LBA) */
581 | /* @param count Sector count (1..255) */
582 | /* @retval DRESULT Results of Disk Functions */
583 | /*-----------------------------------------------------------------------*/
584 | DRESULT disk_read(uint8_t drv, uint8_t *buff, uint32_t sector, uint8_t count) {
585 | /* Check parameters -------------------------------------- */
586 | if (drv || !count)
587 | return RES_PARERR;
588 | if (Stat & STA_NOINIT)
589 | return RES_NOTRDY;
590 |
591 | /* Convert to byte address if needed --------------------- */
592 | if (!(CardType & CT_BLOCK))
593 | sector *= 512;
594 |
595 | /* Test : Single or Multiple block read ------------------ */
596 | if (count == 1) {
597 | /* Single block read */
598 | if (send_cmd(CMD17, sector) == 0) {
599 | /* READ_SINGLE_BLOCK */
600 | if (rcvr_datablock(buff, 512)) {
601 | count = 0;
602 | }
603 | }
604 | } else {
605 | /* Multiple block read */
606 | if (send_cmd(CMD18, sector) == 0) {
607 | /* READ_MULTIPLE_BLOCK */
608 | do {
609 | if (!rcvr_datablock(buff, 512)) {
610 | break;
611 | }
612 | buff += 512;
613 | } while (--count);
614 |
615 | /* STOP_TRANSMISSION */
616 | send_cmd(CMD12, 0);
617 | }
618 | }
619 | release_spi();
620 |
621 | return count ? RES_ERROR : RES_OK;
622 | }
623 |
624 | /*-----------------------------------------------------------------------*/
625 | /* @descr WRITE SECTOR(S) */
626 | /* @param drv Physical drive numbre (0) */
627 | /* @param *buff Pointer to the data to be written */
628 | /* @param sector Start sector number (LBA) */
629 | /* @param count Sector count (1..255) */
630 | /* @retval DRESULT Results of Disk Functions */
631 | /*-----------------------------------------------------------------------*/
632 | DRESULT disk_write(uint8_t drv, const uint8_t *buff, uint32_t sector,
633 | uint8_t count) {
634 | /* Check parameters -------------------------------------- */
635 | if (drv || !count)
636 | return RES_PARERR;
637 | if (Stat & STA_NOINIT)
638 | return RES_NOTRDY;
639 | if (Stat & STA_PROTECT)
640 | return RES_WRPRT;
641 |
642 | /* Convert to byte address if needed --------------------- */
643 | if (!(CardType & CT_BLOCK))
644 | sector *= 512;
645 |
646 | /* Test : Single or Multiple block write ----------------- */
647 | if (count == 1) {
648 | /* Single block write -------------------------------- */
649 | if ((send_cmd(CMD24, sector) == 0) /* WRITE_BLOCK */
650 | && xmit_datablock(buff, 0xFE))
651 | count = 0;
652 | } else {
653 | /* Multiple block write */
654 | if (CardType & CT_SDC)
655 | send_cmd(ACMD23, count);
656 | if (send_cmd(CMD25, sector) == 0) {
657 | /* WRITE_MULTIPLE_BLOCK */
658 | do {
659 | if (!xmit_datablock(buff, 0xFC))
660 | break;
661 | buff += 512;
662 | } while (--count);
663 |
664 | /* STOP_TRAN token */
665 | if (!xmit_datablock(0, 0xFD))
666 | count = 1;
667 | }
668 | }
669 | release_spi();
670 |
671 | return count ? RES_ERROR : RES_OK;
672 | }
673 |
674 | /*-----------------------------------------------------------------------*/
675 | /* @descr GET CURRENT TIME INTO A uint32_t VALUE */
676 | /* @param drv Physical drive number (0) */
677 | /* @param ctrl Control code */
678 | /* @param *buff Buffer to send/receive control data */
679 | /* @param DRESULT Results of Disk Functions */
680 | /*-----------------------------------------------------------------------*/
681 | DRESULT disk_ioctl(uint8_t drv, uint8_t ctrl, void *buff) {
682 | DRESULT res;
683 |
684 | res = RES_OK;
685 |
686 | return res;
687 | }
688 |
689 | /*-----------------------------------------------------------------------*/
690 | /* @descr GET CURRENT TIME INTO A uint32_t VALUE , used in FATfs */
691 | /* @param none */
692 | /* @retval uint32_t Results of Disk Functions */
693 | /*-----------------------------------------------------------------------*/
694 | uint32_t get_fattime(void) {
695 | uint32_t res;
696 | res = 42; //dummy time and date, RTC to be implemented
697 | /*
698 | RTC_TimeTypeDef RTC_TimeStructure;
699 | RTC_DateTypeDef RTC_DateStructure;
700 |
701 | RTC_GetTime(RTC_Format_BIN, &RTC_TimeStructure);
702 | RTC_GetDate(RTC_Format_BIN, &RTC_DateStructure);
703 |
704 | res = (((uint32_t)RTC_DateStructure.RTC_Year + 20) << 25) // bit31:25 Year from 1980 (0..127)
705 | | ((uint32_t)RTC_DateStructure.RTC_Month << 21) // bit24:21 Month (1..12)
706 | | ((uint32_t)RTC_DateStructure.RTC_Date << 16) // bit20:16 Day in month(1..31)
707 | | (uint16_t)(RTC_TimeStructure.RTC_Hours << 11) // bit15:11 Hour (0..23)
708 | | (uint16_t)(RTC_TimeStructure.RTC_Minutes << 5) // bit10:5 Minute (0..59)
709 | | (uint16_t)(RTC_TimeStructure.RTC_Seconds >> 1); // bit4:0 Second / 2 (0..29)
710 | */
711 |
712 | return res;
713 | }
714 |
715 |
716 | /*
717 | scan_files() function is an example from the FatFS library.
718 | if called with empty string as a path, it prints out all files on the card.
719 | */
720 |
721 | FRESULT scan_files(char* path) {
722 | FRESULT res;
723 | FILINFO fno;
724 | DIR dir;
725 | int i;
726 | char *fn; /* This function is assuming non-Unicode cfg. */
727 | #if _USE_LFN
728 | static char lfn[_MAX_LFN + 1];
729 | fno.lfname = lfn;
730 | fno.lfsize = sizeof lfn;
731 | #endif
732 |
733 | res = f_opendir(&dir, path); /* Open the directory */
734 | if (res == FR_OK) {
735 | i = strlen(path);
736 | for (;;) {
737 | xprintf("scan...");
738 | res = f_readdir(&dir, &fno); /* Read a directory item */
739 | if (res != FR_OK || (fno.fname[0] == 0))
740 | break; /* Break on error or end of dir */
741 | if (fno.fname[0] == '.')
742 | continue; /* Ignore dot entry */
743 | xprintf("file found\r\n");
744 | #if _USE_LFN
745 | fn = *fno.lfname ? fno.lfname : fno.fname;
746 | #else
747 | fn = fno.fname;
748 | #endif
749 | if (fno.fattrib & AM_DIR) { /* It is a directory */
750 | xsprintf(&path[i], "/%s", fn);
751 | res = scan_files(path);
752 | if (res != FR_OK)
753 | break;
754 | path[i] = 0;
755 | } else { /* It is a file. */
756 | xprintf("%s/%s\n", path, fn);
757 | }
758 | }
759 | }
760 |
761 | return res;
762 | }
763 |
764 |
765 | /*
766 | *
767 | * basic function test for debugging
768 | *
769 | */
770 | void SDtest(void) {
771 |
772 | FILINFO Finfo; /* Work register for fs command */
773 | FATFS Fatfs; //to mount the sd card
774 | DIR Dir; //current directory
775 | uint8_t res;
776 |
777 | // disk_initialize(0);//done when calling mount
778 |
779 | xprintf("mounting SD card: \r\n");
780 |
781 | /* Mount Fatfs Drive */
782 | f_mount(0, &Fatfs);
783 |
784 | const char newline[] = "\r\n";
785 | const char nullstring[] = "";
786 |
787 | if (f_opendir(&Dir, (const char*) nullstring) == FR_OK) {
788 |
789 | xprintf("root dir opened\r\n");
790 |
791 | while (((res = f_readdir(&Dir, &Finfo)) == FR_OK) && Finfo.fname[0]) {
792 | // xprintf("reading directory... ");
793 | // xprintf(Finfo.fname);
794 | // xprintf(newline);
795 | uint8_t i = 0;
796 | while (Finfo.fname[i] && Finfo.fname[i + 2]) //scan file name
797 | {
798 | if (Finfo.fname[i] == 'B' || Finfo.fname[i] == 'b') {
799 | if (Finfo.fname[i + 1] == 'M'
800 | || Finfo.fname[i + 1] == 'm') {
801 | if (Finfo.fname[i + 2] == 'P'
802 | || Finfo.fname[i + 2] == 'p') {
803 | //xprintf("BMP found! name: ");
804 | xprintf(Finfo.fname);
805 | xprintf(newline);
806 | showimage((char*) Finfo.fname); //display image
807 | break;
808 | }
809 | }
810 | }
811 | i++;
812 | }
813 |
814 | }
815 | }
816 |
817 | }
