1 | * V5.36 ---- STACK_USE_MPFS support has been removed
2 | ********************************************************************/
3 | #ifndef __TCPIPCONFIG_H
4 | #define __TCPIPCONFIG_H
5 |
6 | #include "GenericTypeDefs.h"
7 | #include "Compiler.h"
8 | #define GENERATED_BY_TCPIPCONFIG "Version 1.0.3383.23374"
9 |
10 | // =======================================================================
11 | // Application Options
12 | // =======================================================================
13 |
14 | // Note: For the PIC24FJ128GA010, due to code memory limitations, the following items
15 | // must be commented out: STACK_USE_ZEROCONF_LINK_LOCAL, STACK_USE_DNS_SERVER,
16 | // STACK_USE_NBNS, STACK_USE_ANNOUNCE, STACK_USE_ICMP_CLIENT, STACK_USE_REBOOT_SERVER
17 |
18 | /* Application Level Module Selection
19 | * Uncomment or comment the following lines to enable or
20 | * disabled the following high-level application modules.
21 | *
22 | * If certain compilations are enabled (eg STACK_USE_GENERIC_TCP_CLIENT_EXAMPLE),
23 | * check whether the files (eg GenericTCPClient.c) are located in folder (eg \TCPIP\WiFi EZConfig).
24 | * You may need to copy such files from the Demo App or WiFi Console folder.
25 | *
26 | */
27 | #define STACK_USE_UART // Application demo using UART for IP address display and stack configuration
28 | //#define STACK_USE_UART2TCP_BRIDGE // UART to TCP Bridge application example
29 | //#define STACK_USE_IP_GLEANING
30 | #define STACK_USE_ICMP_SERVER // Ping query and response capability
31 | //#define STACK_USE_ICMP_CLIENT // Ping transmission capability
32 | #define STACK_USE_HTTP2_SERVER // New HTTP server with POST, Cookies, Authentication, etc.
33 | //#define STACK_USE_SSL_SERVER // SSL server socket support (Requires SW300052)
34 | //#define STACK_USE_SSL_CLIENT // SSL client socket support (Requires SW300052)
35 | //#define STACK_USE_AUTO_IP // Dynamic link-layer IP address automatic configuration protocol
36 | #define STACK_USE_DHCP_CLIENT // Dynamic Host Configuration Protocol client for obtaining IP address and other parameters
37 | #define STACK_USE_DHCP_SERVER // Single host DHCP server
38 | //#define STACK_USE_FTP_SERVER // File Transfer Protocol (old)
39 | //#define STACK_USE_SMTP_CLIENT // Simple Mail Transfer Protocol for sending email
40 | //#define STACK_USE_SNMP_SERVER // Simple Network Management Protocol v2C Community Agent
41 | //#define STACK_USE_SNMPV3_SERVER // Simple Network Management Protocol v3 Agent
42 | //#define STACK_USE_TFTP_CLIENT // Trivial File Transfer Protocol client
43 | //#define STACK_USE_GENERIC_TCP_CLIENT_EXAMPLE // HTTP Client example in GenericTCPClient.c. If using EZConfig, need to copy this file from Demo App or WiFi Console.
44 | //#define STACK_USE_GENERIC_TCP_SERVER_EXAMPLE // ToUpper server example in GenericTCPServer.c. If using EZConfig, need to copy this file from Demo App or WiFi Console.
45 | //#define STACK_USE_TELNET_SERVER // Telnet server
46 | //#define STACK_USE_ANNOUNCE // Microchip Embedded Ethernet Device Discoverer server/client
47 | #define STACK_USE_DNS // Domain Name Service Client for resolving hostname strings to IP addresses
48 | //#define STACK_USE_DNS_SERVER // Domain Name Service Server for redirection to the local device
49 | //#define STACK_USE_NBNS // NetBIOS Name Service Server for repsonding to NBNS hostname broadcast queries
50 | //#define STACK_USE_REBOOT_SERVER // Module for resetting this PIC remotely. Primarily useful for a Bootloader.
51 | //#define STACK_USE_SNTP_CLIENT // Simple Network Time Protocol for obtaining current date/time from Internet
52 | //#define STACK_USE_UDP_PERFORMANCE_TEST // Module for testing UDP TX performance characteristics. NOTE: Enabling this will cause a huge amount of UDP broadcast packets to flood your network on the discard port. Use care when enabling this on production networks, especially with VPNs (could tunnel broadcast traffic across a limited bandwidth connection).
53 | //#define STACK_USE_TCP_PERFORMANCE_TEST // Module for testing TCP TX performance characteristics
54 | //#define STACK_USE_DYNAMICDNS_CLIENT // Dynamic DNS client updater module
55 | //#define STACK_USE_BERKELEY_API // Berekely Sockets APIs are available
56 |
57 | //#define STACK_USE_ZEROCONF_LINK_LOCAL // Zeroconf IPv4 Link-Local Addressing
58 | #define STACK_USE_ZEROCONF_MDNS_SD // Zeroconf mDNS and mDNS service discovery
59 | #if defined(CFG_INCLUDE_EX16_MRF24WG) && defined(__C32__)
60 | //#define STACK_USE_TCP_MOBILE_APP_SERVER // This is valid only with Explorer16 eval board and MRF24WG Wi-Fi module
61 | #ifdef STACK_USE_TCP_MOBILE_APP_SERVER
62 | #ifndef STACK_USE_ZEROCONF_LINK_LOCAL && !defined(__PIC24FJ128GA010__)
63 | //#define STACK_USE_ZEROCONF_LINK_LOCAL // Zeroconf IPv4 Link-Local Addressing
64 | #endif
65 | #ifndef STACK_USE_ZEROCONF_MDNS_SD
66 | #define STACK_USE_ZEROCONF_MDNS_SD // Zeroconf mDNS and mDNS service discovery
67 | #endif
68 | #endif /* STACK_USE_TCP_MOBILE_APP_SERVER */
69 | #endif /* CFG_INCLUDE_EX16_MRF24WG */
70 |
71 | // =======================================================================
72 | // Data Storage Options
73 | // =======================================================================
74 |
75 | /* MPFS Configuration
76 | * MPFS is automatically included when required for other
77 | * applications. If your custom application requires it
78 | * otherwise, uncomment the appropriate selection.
79 | */
80 | #define STACK_USE_MPFS2
81 |
82 | /* MPFS Storage Location
83 | * If html pages are stored in internal program memory,
84 | * comment both MPFS_USE_EEPROM and MPFS_USE_SPI_FLASH, then
85 | * include an MPFS image (.c or .s file) in the project.
86 | * If html pages are stored in external memory, uncomment the
87 | * appropriate definition.
88 | *
89 | * Supported serial flash parts include the SST25VFxxxB series.
90 | */
91 | #define MPFS_USE_EEPROM
92 | //#define MPFS_USE_SPI_FLASH
93 |
94 | /* EEPROM Addressing Selection
95 | * If using the 1Mbit EEPROM, uncomment this line
96 | */
97 | //#define USE_EEPROM_25LC1024
98 |
99 | /* EEPROM Reserved Area
100 | * Number of EEPROM bytes to be reserved before MPFS storage starts.
101 | * These bytes host application configurations such as IP Address,
102 | * MAC Address, and any other required variables.
103 | *
104 | * For MPFS Classic, this setting must match the Reserved setting
105 | * on the Advanced Settings page of the MPFS2 Utility.
106 | */
107 | #define MPFS_RESERVE_BLOCK (205ul)
108 |
109 | /* MPFS File Handles
110 | * Maximum number of simultaneously open MPFS2 files.
111 | * For MPFS Classic, this has no effect.
112 | */
113 | #define MAX_MPFS_HANDLES (7ul)
114 |
115 |
116 | // =======================================================================
117 | // Network Addressing Options
118 | // =======================================================================
119 |
120 | /* Default Network Configuration
121 | * These settings are only used if data is not found in EEPROM.
122 | * To clear EEPROM, hold BUTTON0, reset the board, and continue
123 | * holding until the LEDs flash. Release, and reset again.
124 | */
125 | #define MY_DEFAULT_HOST_NAME "MCHPBOARD"
126 |
127 | #define MY_DEFAULT_MAC_BYTE1 (0x00) // Use the default of 00-04-A3-00-00-00
128 | #define MY_DEFAULT_MAC_BYTE2 (0x04) // if using an ENCX24J600, MRF24W, or
129 | #define MY_DEFAULT_MAC_BYTE3 (0xA3) // PIC32MX6XX/7XX internal Ethernet
130 | #define MY_DEFAULT_MAC_BYTE4 (0x00) // controller and wish to use the
131 | #define MY_DEFAULT_MAC_BYTE5 (0x00) // internal factory programmed MAC
132 | #define MY_DEFAULT_MAC_BYTE6 (0x00) // address instead.
133 |
134 | #define MY_DEFAULT_IP_ADDR_BYTE1 (169ul)
135 | #define MY_DEFAULT_IP_ADDR_BYTE2 (254ul)
136 | #define MY_DEFAULT_IP_ADDR_BYTE3 (1ul)
137 | #define MY_DEFAULT_IP_ADDR_BYTE4 (1ul)
138 |
139 | #define MY_DEFAULT_MASK_BYTE1 (255ul)
140 | #define MY_DEFAULT_MASK_BYTE2 (255ul)
141 | #define MY_DEFAULT_MASK_BYTE3 (0ul)
142 | #define MY_DEFAULT_MASK_BYTE4 (0ul)
143 |
144 | #define MY_DEFAULT_GATE_BYTE1 (169ul)
145 | #define MY_DEFAULT_GATE_BYTE2 (254ul)
146 | #define MY_DEFAULT_GATE_BYTE3 (1ul)
147 | #define MY_DEFAULT_GATE_BYTE4 (1ul)
148 |
149 | #define MY_DEFAULT_PRIMARY_DNS_BYTE1 (169ul)
150 | #define MY_DEFAULT_PRIMARY_DNS_BYTE2 (254ul)
151 | #define MY_DEFAULT_PRIMARY_DNS_BYTE3 (1ul)
152 | #define MY_DEFAULT_PRIMARY_DNS_BYTE4 (1ul)
153 |
154 | #define MY_DEFAULT_SECONDARY_DNS_BYTE1 (0ul)
155 | #define MY_DEFAULT_SECONDARY_DNS_BYTE2 (0ul)
156 | #define MY_DEFAULT_SECONDARY_DNS_BYTE3 (0ul)
157 | #define MY_DEFAULT_SECONDARY_DNS_BYTE4 (0ul)
158 |
159 | // =======================================================================
160 | // PIC32MX7XX/6XX MAC Layer Options
161 | // If not using a PIC32MX7XX/6XX device, ignore this section.
162 | // =======================================================================
163 | #define ETH_CFG_LINK 0 // set to 1 if you need to config the link to specific following parameters
164 | // otherwise the default connection will be attempted
165 | // depending on the selected PHY
166 | #define ETH_CFG_AUTO 1 // use auto negotiation
167 | #define ETH_CFG_10 1 // use/advertise 10 Mbps capability
168 | #define ETH_CFG_100 1 // use/advertise 100 Mbps capability
169 | #define ETH_CFG_HDUPLEX 1 // use/advertise half duplex capability
170 | #define ETH_CFG_FDUPLEX 1 // use/advertise full duplex capability
171 | #define ETH_CFG_AUTO_MDIX 1 // use/advertise auto MDIX capability
172 | #define ETH_CFG_SWAP_MDIX 1 // use swapped MDIX. else normal MDIX
173 |
174 | #define EMAC_TX_DESCRIPTORS 2 // number of the TX descriptors to be created
175 | #define EMAC_RX_DESCRIPTORS 8 // number of the RX descriptors and RX buffers to be created
176 |
177 | #define EMAC_RX_BUFF_SIZE 1536 // size of a RX buffer. should be multiple of 16
178 | // this is the size of all receive buffers processed by the ETHC
179 | // The size should be enough to accomodate any network received packet
180 | // If the packets are larger, they will have to take multiple RX buffers
181 | // The current implementation does not handle this situation right now and the packet is discarded.
182 |
183 |
184 | // =======================================================================
185 | // Transport Layer Options
186 | // =======================================================================
187 |
188 | /* Transport Layer Configuration
189 | * The following low level modules are automatically enabled
190 | * based on module selections above. If your custom module
191 | * requires them otherwise, enable them here.
192 | */
193 | #define STACK_USE_TCP
194 | #define STACK_USE_UDP
195 |
196 | /* Client Mode Configuration
197 | * Uncomment following line if this stack will be used in CLIENT
198 | * mode. In CLIENT mode, some functions specific to client operation
199 | * are enabled.
200 | */
201 | #if defined(STACK_USE_DHCP_CLIENT) || defined(STACK_USE_ICMP_CLIENT)
202 | #define STACK_CLIENT_MODE
203 | #endif
204 |
205 | /* TCP Socket Memory Allocation
206 | * TCP needs memory to buffer incoming and outgoing data. The
207 | * amount and medium of storage can be allocated on a per-socket
208 | * basis using the example below as a guide.
209 | */
210 | // Allocate how much total RAM (in bytes) you want to allocate
211 | // for use by your TCP TCBs, RX FIFOs, and TX FIFOs.
212 | #define TCP_ETH_RAM_SIZE (8192ul)
213 | #define TCP_PIC_RAM_SIZE (0ul)
214 | #define TCP_SPI_RAM_SIZE (0ul)
215 | #define TCP_SPI_RAM_BASE_ADDRESS (0x00)
216 |
217 | // Define names of socket types
218 | #define TCP_SOCKET_TYPES
219 | #define TCP_PURPOSE_GENERIC_TCP_CLIENT 0
220 | #define TCP_PURPOSE_GENERIC_TCP_SERVER 1
221 | #define TCP_PURPOSE_TELNET 2
222 | #define TCP_PURPOSE_FTP_COMMAND 3
223 | #define TCP_PURPOSE_FTP_DATA 4
224 | #define TCP_PURPOSE_TCP_PERFORMANCE_TX 5
225 | #define TCP_PURPOSE_TCP_PERFORMANCE_RX 6
226 | #define TCP_PURPOSE_UART_2_TCP_BRIDGE 7
227 | #define TCP_PURPOSE_HTTP_SERVER 8
228 | #define TCP_PURPOSE_DEFAULT 9
229 | #define TCP_PURPOSE_BERKELEY_SERVER 10
230 | #define TCP_PURPOSE_BERKELEY_CLIENT 11
231 | #define TCP_PURPOSE_MOBILE_APP_SERVER 12
232 | #define END_OF_TCP_SOCKET_TYPES
233 |
234 | #if defined(__TCP_C)
235 | // Define what types of sockets are needed, how many of
236 | // each to include, where their TCB, TX FIFO, and RX FIFO
237 | // should be stored, and how big the RX and TX FIFOs should
238 | // be. Making this initializer bigger or smaller defines
239 | // how many total TCP sockets are available.
240 | //
241 | // Each socket requires up to 56 bytes of PIC RAM and
242 | // 48+(TX FIFO size)+(RX FIFO size) bytes of TCP_*_RAM each.
243 | //
244 | // Note: The RX FIFO must be at least 1 byte in order to
245 | // receive SYN and FIN messages required by TCP. The TX
246 | // FIFO can be zero if desired.
247 | #define TCP_CONFIGURATION
248 | ROM struct
249 | {
250 | BYTE vSocketPurpose;
251 | BYTE vMemoryMedium;
252 | WORD wTXBufferSize;
253 | WORD wRXBufferSize;
254 | } TCPSocketInitializer[] =
255 | {
256 | {TCP_PURPOSE_GENERIC_TCP_CLIENT, TCP_ETH_RAM, 1024, 20},
257 | {TCP_PURPOSE_GENERIC_TCP_SERVER, TCP_ETH_RAM, 20, 1024},
258 | //{TCP_PURPOSE_TELNET, TCP_ETH_RAM, 200, 150},
259 | //{TCP_PURPOSE_TELNET, TCP_ETH_RAM, 200, 150},
260 | //{TCP_PURPOSE_TELNET, TCP_ETH_RAM, 200, 150},
261 | //{TCP_PURPOSE_FTP_COMMAND, TCP_ETH_RAM, 100, 40},
262 | //{TCP_PURPOSE_FTP_DATA, TCP_ETH_RAM, 0, 128},
263 | //{TCP_PURPOSE_TCP_PERFORMANCE_TX, TCP_ETH_RAM, 200, 1},
264 | //{TCP_PURPOSE_TCP_PERFORMANCE_RX, TCP_ETH_RAM, 40, 1500},
265 | //{TCP_PURPOSE_UART_2_TCP_BRIDGE, TCP_ETH_RAM, 256, 256},
266 | {TCP_PURPOSE_HTTP_SERVER, TCP_ETH_RAM, 1000, 1000},
267 | {TCP_PURPOSE_HTTP_SERVER, TCP_ETH_RAM, 1000, 1000},
268 | #if defined(STACK_USE_TCP_MOBILE_APP_SERVER)
269 | {TCP_PURPOSE_MOBILE_APP_SERVER, TCP_ETH_RAM, 1000, 1000},
270 | #endif
271 | //{TCP_PURPOSE_DEFAULT, TCP_ETH_RAM, 1000, 1000},
272 | //{TCP_PURPOSE_BERKELEY_SERVER, TCP_ETH_RAM, 25, 20},
273 | //{TCP_PURPOSE_BERKELEY_SERVER, TCP_ETH_RAM, 25, 20},
274 | //{TCP_PURPOSE_BERKELEY_SERVER, TCP_ETH_RAM, 25, 20},
275 | //{TCP_PURPOSE_BERKELEY_CLIENT, TCP_ETH_RAM, 125, 100},
276 | };
277 | #define END_OF_TCP_CONFIGURATION
278 | #endif
279 |
280 | /* UDP Socket Configuration
281 | * Define the maximum number of available UDP Sockets, and whether
282 | * or not to include a checksum on packets being transmitted.
283 | */
284 | #define MAX_UDP_SOCKETS (8u)
285 | //#define UDP_USE_TX_CHECKSUM // This slows UDP TX performance by nearly 50%, except when using the ENCX24J600 or PIC32MX6XX/7XX, which have a super fast DMA and incurs virtually no speed pentalty.
286 |
287 |
288 | /* Berkeley API Sockets Configuration
289 | * Note that each Berkeley socket internally uses one TCP or UDP socket
290 | * defined by MAX_UDP_SOCKETS and the TCPSocketInitializer[] array.
291 | * Therefore, this number MUST be less than or equal to MAX_UDP_SOCKETS + the
292 | * number of TCP sockets defined by the TCPSocketInitializer[] array
293 | * (i.e. sizeof(TCPSocketInitializer)/sizeof(TCPSocketInitializer[0])).
294 | * This define has no effect if STACK_USE_BERKELEY_API is not defined and
295 | * Berkeley Sockets are disabled. Set this value as low as your application
296 | * requires to avoid waisting RAM.
297 | */
298 | #define BSD_SOCKET_COUNT (5u)
299 |
300 |
301 | // =======================================================================
302 | // Application-Specific Options
303 | // =======================================================================
304 |
305 | // -- HTTP2 Server options -----------------------------------------------
306 |
307 | // Maximum numbers of simultaneous HTTP connections allowed.
308 | // Each connection consumes 2 bytes of RAM and a TCP socket
309 | #define MAX_HTTP_CONNECTIONS (2u)
310 |
311 | // Optional setting to use PIC RAM instead of Ethernet/Wi-Fi RAM for
312 | // storing HTTP Connection Context variables (HTTP_CONN structure for each
313 | // HTTP connection). Undefining this macro results in the Ethernet/Wi-Fi
314 | // RAM being used (minimum PIC RAM usage, lower performance). Defining
315 | // this macro results in PIC RAM getting used (higher performance, but uses
316 | // PIC RAM). This option should not be enabled on PIC18 devices. The
317 | // performance increase of having this option defined is only apparent when
318 | // the HTTP server is servicing multiple connections simultaneously.
319 | //#define HTTP_SAVE_CONTEXT_IN_PIC_RAM
320 |
321 | // Indicate what file to serve when no specific one is requested
322 | #define HTTP_DEFAULT_FILE "index.htm"
323 | #define HTTPS_DEFAULT_FILE "index.htm"
324 | #define HTTP_DEFAULT_LEN (10u) // For buffer overrun protection.
325 | // Set to longest length of above two strings.
326 |
327 | // Configure MPFS over HTTP updating
328 | // Comment this line to disable updating via HTTP
329 | #define HTTP_MPFS_UPLOAD "mpfsupload"
330 | //#define HTTP_MPFS_UPLOAD_REQUIRES_AUTH // Require password for MPFS uploads
331 | // Certain firewall and router combinations cause the MPFS2 Utility to fail
332 | // when uploading. If this happens, comment out this definition.
333 |
334 | // Define which HTTP modules to use
335 | // If not using a specific module, comment it to save resources
336 | #define HTTP_USE_POST // Enable POST support
337 | //#define HTTP_USE_COOKIES // Enable cookie support
338 | //#define HTTP_USE_AUTHENTICATION // Enable basic authentication support
339 |
340 | //#define HTTP_NO_AUTH_WITHOUT_SSL // Uncomment to require SSL before requesting a password
341 |
342 | // Define the listening port for the HTTP server
343 | #define HTTP_PORT (80u)
344 |
345 | // Define the listening port for the HTTPS server (if STACK_USE_SSL_SERVER is enabled)
346 | #define HTTPS_PORT (443u)
347 |
348 | // Define the maximum data length for reading cookie and GET/POST arguments (bytes)
349 | #define HTTP_MAX_DATA_LEN (100u)
350 |
351 | // Define the minimum number of bytes free in the TX FIFO before executing callbacks
352 | #define HTTP_MIN_CALLBACK_FREE (16u)
353 |
354 | //#define STACK_USE_HTTP_APP_RECONFIG // Use the AppConfig web page in the Demo App (~2.5kb ROM, ~0b RAM)
355 | //#define STACK_USE_HTTP_MD5_DEMO // Use the MD5 Demo web page (~5kb ROM, ~160b RAM)
356 | //#define STACK_USE_HTTP_EMAIL_DEMO // Use the e-mail demo web page
357 |
358 | // -- SSL Options --------------------------------------------------------
359 |
360 | #define MAX_SSL_CONNECTIONS (2ul) // Maximum connections via SSL
361 | #define MAX_SSL_SESSIONS (2ul) // Max # of cached SSL sessions
362 | #define MAX_SSL_BUFFERS (4ul) // Max # of SSL buffers (2 per socket)
363 | #define MAX_SSL_HASHES (5ul) // Max # of SSL hashes (2 per, plus 1 to avoid deadlock)
364 |
365 | // Bits in SSL RSA key. This parameter is used for SSL sever
366 | // connections only. The only valid value is 512 bits (768 and 1024
367 | // bits do not work at this time). Note, however, that SSL client
368 | // operations do currently work up to 1024 bit RSA key length.
369 | #define SSL_RSA_KEY_SIZE (512ul)
370 |
371 |
372 | // -- Telnet Options -----------------------------------------------------
373 |
374 | // Number of simultaneously allowed Telnet sessions. Note that you
375 | // must have an equal number of TCP_PURPOSE_TELNET type TCP sockets
376 | // declared in the TCPSocketInitializer[] array above for multiple
377 | // connections to work. If fewer sockets are available than this
378 | // definition, then the the lesser of the two quantities will be the
379 | // actual limit.
380 | #define MAX_TELNET_CONNECTIONS (1u)
381 |
382 | // Default local listening port for the Telnet server. Port 23 is the
383 | // protocol default.
384 | #define TELNET_PORT 23
385 |
386 | // Default local listening port for the Telnet server when SSL secured.
387 | // Port 992 is the telnets protocol default.
388 | #define TELNETS_PORT 992
389 |
390 | // Force all connecting clients to be SSL secured and connected via
391 | // TELNETS_PORT. Connections on port TELNET_PORT will be ignored. If
392 | // STACK_USE_SSL_SERVER is undefined, this entire setting is ignored
393 | // (server will accept unsecured connections on TELNET_PORT and won't even
394 | // listen on TELNETS_PORT).
395 | //#define TELNET_REJECT_UNSECURED
396 |
397 | // Default username and password required to login to the Telnet server.
398 | #define TELNET_USERNAME "admin"
399 | #define TELNET_PASSWORD "microchip"
400 |
401 |
402 | // -- SNMP Options -------------------------------------------------------
403 |
404 | // Comment following line if SNMP TRAP support is needed
405 | //#define SNMP_TRAP_DISABLED
406 |
407 | //#define SNMP_STACK_USE_V2_TRAP
408 | #if defined(STACK_USE_SNMPV3_SERVER)
409 | #define SNMP_V1_V2_TRAP_WITH_SNMPV3
410 | #endif
411 |
412 | // This is the maximum length for community string.
413 | // Application must ensure that this length is observed.
414 | // SNMP module adds one byte extra after SNMP_COMMUNITY_MAX_LEN
415 | // for adding '\0' NULL character.
416 | #define SNMP_COMMUNITY_MAX_LEN (8u)
417 | #define SNMP_MAX_COMMUNITY_SUPPORT (3u)
418 | #define NOTIFY_COMMUNITY_LEN (SNMP_COMMUNITY_MAX_LEN)
419 |
420 | // Default SNMPv2C community names. These can be overridden at run time if
421 | // alternate strings are present in external EEPROM or Flash (actual
422 | // strings are stored in AppConfig.readCommunity[] and
423 | // AppConfig.writeCommunity[] arrays). These strings are case sensitive.
424 | // An empty string means disabled (not matchable).
425 | // For application security, these default community names should not be
426 | // used, but should all be disabled to force the end user to select unique
427 | // community names. These defaults are provided only to make it easier to
428 | // start development. Specifying more strings than
429 | // SNMP_MAX_COMMUNITY_SUPPORT will result in the later strings being
430 | // ignored (but still wasting program memory). Specifying fewer strings is
431 | // legal, as long as at least one is present. A string larger than
432 | // SNMP_COMMUNITY_MAX_LEN bytes will be ignored.
433 | #define SNMP_READ_COMMUNITIES {"public", "read", ""}
434 | #define END_OF_SNMP_READ_COMMUNITIES
435 | #define SNMP_WRITE_COMMUNITIES {"private", "write", "public"}
436 | #define END_OF_SNMP_WRITE_COMMUNITIES
437 | #endif
