1 | /**************************************************************************//*****
2 | * @file printf.c
3 | * @brief Implementation of several stdio.h methods, such as printf(),
4 | * sprintf() and so on. This reduces the memory footprint of the
5 | * binary when using those methods, compared to the libc implementation.
6 | ********************************************************************************/
7 | #include <stdio.h>
8 | #include <stdarg.h>
9 | #include <stm32f4xx_usart.h>
10 |
11 |
12 | /**
13 | * @brief Transmit a char, if you want to use printf(),
14 | * you need implement this function
15 | *
16 | * @param pStr Storage string.
17 | * @param c Character to write.
18 | */
19 | void PrintChar(char c)
20 | {
21 | if (c == '\n') {
22 | while (!(USART1->SR & 0x0080));
23 | USART1->DR = 0x0D;
24 | }
25 | while (!(USART1->SR & 0x0080));
26 | USART1->DR = (c & 0x1FF);
27 | }
28 |
29 | /** Maximum string size allowed (in bytes). */
30 | #define MAX_STRING_SIZE 100
31 |
32 |
33 | /** Required for proper compilation. */
34 | struct _reent r = {0, (FILE *) 0, (FILE *) 1, (FILE *) 0};
35 | //struct _reent *_impure_ptr = &r;
36 |
37 | /**
38 | * @brief Writes a character inside the given string. Returns 1.
39 | *
40 | * @param pStr Storage string.
41 | * @param c Character to write.
42 | */
43 | signed int PutChar(char *pStr, char c)
44 | {
45 | *pStr = c;
46 | return 1;
47 | }
48 |
49 |
50 | /**
51 | * @brief Writes a string inside the given string.
52 | *
53 | * @param pStr Storage string.
54 | * @param pSource Source string.
55 | * @return The size of the written
56 | */
57 | signed int PutString(char *pStr, const char *pSource)
58 | {
59 | signed int num = 0;
60 |
61 | while (*pSource != 0) {
62 |
63 | *pStr++ = *pSource++;
64 | num++;
65 | }
66 |
67 | return num;
68 | }
69 |
70 |
71 | /**
72 | * @brief Writes an unsigned int inside the given string, using the provided fill &
73 | * width parameters.
74 | *
75 | * @param pStr Storage string.
76 | * @param fill Fill character.
77 | * @param width Minimum integer width.
78 | * @param value Integer value.
79 | */
80 | signed int PutUnsignedInt(
81 | char *pStr,
82 | char fill,
83 | signed int width,
84 | unsigned int value)
85 | {
86 | signed int num = 0;
87 |
88 | /* Take current digit into account when calculating width */
89 | width--;
90 |
91 | /* Recursively write upper digits */
92 | if ((value / 10) > 0) {
93 |
94 | num = PutUnsignedInt(pStr, fill, width, value / 10);
95 | pStr += num;
96 | }
97 |
98 | /* Write filler characters */
99 | else {
100 |
101 | while (width > 0) {
102 |
103 | PutChar(pStr, fill);
104 | pStr++;
105 | num++;
106 | width--;
107 | }
108 | }
109 |
110 | /* Write lower digit */
111 | num += PutChar(pStr, (value % 10) + '0');
112 |
113 | return num;
114 | }
115 |
116 |
117 | /**
118 | * @brief Writes a signed int inside the given string, using the provided fill & width
119 | * parameters.
120 | *
121 | * @param pStr Storage string.
122 | * @param fill Fill character.
123 | * @param width Minimum integer width.
124 | * @param value Signed integer value.
125 | */
126 | signed int PutSignedInt(
127 | char *pStr,
128 | char fill,
129 | signed int width,
130 | signed int value)
131 | {
132 | signed int num = 0;
133 | unsigned int absolute;
134 |
135 | /* Compute absolute value */
136 | if (value < 0) {
137 |
138 | absolute = -value;
139 | }
140 | else {
141 |
142 | absolute = value;
143 | }
144 |
145 | /* Take current digit into account when calculating width */
146 | width--;
147 |
148 | /* Recursively write upper digits */
149 | if ((absolute / 10) > 0) {
150 |
151 | if (value < 0) {
152 |
153 | num = PutSignedInt(pStr, fill, width, -(absolute / 10));
154 | }
155 | else {
156 |
157 | num = PutSignedInt(pStr, fill, width, absolute / 10);
158 | }
159 | pStr += num;
160 | }
161 | else {
162 |
163 | /* Reserve space for sign */
164 | if (value < 0) {
165 |
166 | width--;
167 | }
168 |
169 | /* Write filler characters */
170 | while (width > 0) {
171 |
172 | PutChar(pStr, fill);
173 | pStr++;
174 | num++;
175 | width--;
176 | }
177 |
178 | /* Write sign */
179 | if (value < 0) {
180 |
181 | num += PutChar(pStr, '-');
182 | pStr++;
183 | }
184 | }
185 |
186 | /* Write lower digit */
187 | num += PutChar(pStr, (absolute % 10) + '0');
188 |
189 | return num;
190 | }
191 |
192 |
193 | /**
194 | * @brief Writes an hexadecimal value into a string, using the given fill, width &
195 | * capital parameters.
196 | *
197 | * @param pStr Storage string.
198 | * @param fill Fill character.
199 | * @param width Minimum integer width.
200 | * @param maj Indicates if the letters must be printed in lower- or upper-case.
201 | * @param value Hexadecimal value.
202 | *
203 | * @return The number of char written
204 | */
205 | signed int PutHexa(
206 | char *pStr,
207 | char fill,
208 | signed int width,
209 | unsigned char maj,
210 | unsigned int value)
211 | {
212 | signed int num = 0;
213 |
214 | /* Decrement width */
215 | width--;
216 |
217 | /* Recursively output upper digits */
218 | if ((value >> 4) > 0) {
219 |
220 | num += PutHexa(pStr, fill, width, maj, value >> 4);
221 | pStr += num;
222 | }
223 | /* Write filler chars */
224 | else {
225 |
226 | while (width > 0) {
227 |
228 | PutChar(pStr, fill);
229 | pStr++;
230 | num++;
231 | width--;
232 | }
233 | }
234 |
235 | /* Write current digit */
236 | if ((value & 0xF) < 10) {
237 |
238 | PutChar(pStr, (value & 0xF) + '0');
239 | }
240 | else if (maj) {
241 |
242 | PutChar(pStr, (value & 0xF) - 10 + 'A');
243 | }
244 | else {
245 |
246 | PutChar(pStr, (value & 0xF) - 10 + 'a');
247 | }
248 | num++;
249 |
250 | return num;
251 | }
252 |
253 |
254 |
255 | /* Global Functions ----------------------------------------------------------- */
256 |
257 |
258 | /**
259 | * @brief Stores the result of a formatted string into another string. Format
260 | * arguments are given in a va_list instance.
261 | *
262 | * @param pStr Destination string.
263 | * @param length Length of Destination string.
264 | * @param pFormat Format string.
265 | * @param ap Argument list.
266 | *
267 | * @return The number of characters written.
268 | */
269 | signed int vsnprintf(char *pStr, size_t length, const char *pFormat, va_list ap)
270 | {
271 | char fill;
272 | unsigned char width;
273 | signed int num = 0;
274 | signed int size = 0;
275 |
276 | /* Clear the string */
277 | if (pStr) {
278 |
279 | *pStr = 0;
280 | }
281 |
282 | /* Phase string */
283 | while (*pFormat != 0 && size < length) {
284 |
285 | /* Normal character */
286 | if (*pFormat != '%') {
287 |
288 | *pStr++ = *pFormat++;
289 | size++;
290 | }
291 | /* Escaped '%' */
292 | else if (*(pFormat+1) == '%') {
293 |
294 | *pStr++ = '%';
295 | pFormat += 2;
296 | size++;
297 | }
298 | /* Token delimiter */
299 | else {
300 |
301 | fill = ' ';
302 | width = 0;
303 | pFormat++;
304 |
305 | /* Parse filler */
306 | if (*pFormat == '0') {
307 |
308 | fill = '0';
309 | pFormat++;
310 | }
311 |
312 | /* Parse width */
313 | while ((*pFormat >= '0') && (*pFormat <= '9')) {
314 |
315 | width = (width*10) + *pFormat-'0';
316 | pFormat++;
317 | }
318 |
319 | /* Check if there is enough space */
320 | if (size + width > length) {
321 |
322 | width = length - size;
323 | }
324 |
325 | /* Parse type */
326 | switch (*pFormat) {
327 | case 'd':
328 | case 'i': num = PutSignedInt(pStr, fill, width, va_arg(ap, signed int)); break;
329 | case 'u': num = PutUnsignedInt(pStr, fill, width, va_arg(ap, unsigned int)); break;
330 | case 'x': num = PutHexa(pStr, fill, width, 0, va_arg(ap, unsigned int)); break;
331 | case 'X': num = PutHexa(pStr, fill, width, 1, va_arg(ap, unsigned int)); break;
332 | case 's': num = PutString(pStr, va_arg(ap, char *)); break;
333 | case 'c': num = PutChar(pStr, va_arg(ap, unsigned int)); break;
334 | default:
335 | return EOF;
336 | }
337 |
338 | pFormat++;
339 | pStr += num;
340 | size += num;
341 | }
342 | }
343 |
344 | /* NULL-terminated (final \0 is not counted) */
345 | if (size < length) {
346 |
347 | *pStr = 0;
348 | }
349 | else {
350 |
351 | *(--pStr) = 0;
352 | size--;
353 | }
354 |
355 | return size;
356 | }
357 |
358 |
359 | /**
360 | * @brief Stores the result of a formatted string into another string. Format
361 | * arguments are given in a va_list instance.
362 | *
363 | * @param pStr Destination string.
364 | * @param length Length of Destination string.
365 | * @param pFormat Format string.
366 | * @param ... Other arguments
367 | *
368 | * @return The number of characters written.
369 | */
370 | signed int snprintf(char *pString, size_t length, const char *pFormat, ...)
371 | {
372 | va_list ap;
373 | signed int rc;
374 |
375 | va_start(ap, pFormat);
376 | rc = vsnprintf(pString, length, pFormat, ap);
377 | va_end(ap);
378 |
379 | return rc;
380 | }
381 |
382 |
383 | /**
384 | * @brief Stores the result of a formatted string into another string. Format
385 | * arguments are given in a va_list instance.
386 | *
387 | * @param pString Destination string.
388 | * @param length Length of Destination string.
389 | * @param pFormat Format string.
390 | * @param ap Argument list.
391 | *
392 | * @return The number of characters written.
393 | */
394 | signed int vsprintf(char *pString, const char *pFormat, va_list ap)
395 | {
396 | return vsnprintf(pString, MAX_STRING_SIZE, pFormat, ap);
397 | }
398 |
399 | /**
400 | * @brief Outputs a formatted string on the given stream. Format arguments are given
401 | * in a va_list instance.
402 | *
403 | * @param pStream Output stream.
404 | * @param pFormat Format string
405 | * @param ap Argument list.
406 | */
407 | signed int vfprintf(FILE *pStream, const char *pFormat, va_list ap)
408 | {
409 | char pStr[MAX_STRING_SIZE];
410 | char pError[] = "stdio.c: increase MAX_STRING_SIZE\n\r";
411 |
412 | /* Write formatted string in buffer */
413 | if (vsprintf(pStr, pFormat, ap) >= MAX_STRING_SIZE) {
414 |
415 | fputs(pError, stderr);
416 | while (1); /* Increase MAX_STRING_SIZE */
417 | }
418 |
419 | /* Display string */
420 | return fputs(pStr, pStream);
421 | }
422 |
423 |
424 | /**
425 | * @brief Outputs a formatted string on the DBGU stream. Format arguments are given
426 | * in a va_list instance.
427 | *
428 | * @param pFormat Format string.
429 | * @param ap Argument list.
430 | */
431 | signed int vprintf(const char *pFormat, va_list ap)
432 | {
433 | return vfprintf(stdout, pFormat, ap);
434 | }
435 |
436 |
437 | /**
438 | * @brief Outputs a formatted string on the given stream, using a variable
439 | * number of arguments.
440 | *
441 | * @param pStream Output stream.
442 | * @param pFormat Format string.
443 | */
444 | signed int fprintf(FILE *pStream, const char *pFormat, ...)
445 | {
446 | va_list ap;
447 | signed int result;
448 |
449 | /* Forward call to vfprintf */
450 | va_start(ap, pFormat);
451 | result = vfprintf(pStream, pFormat, ap);
452 | va_end(ap);
453 |
454 | return result;
455 | }
456 |
457 |
458 | /**
459 | * @brief Outputs a formatted string on the DBGU stream, using a variable number of
460 | * arguments.
461 | *
462 | * @param pFormat Format string.
463 | */
464 | signed int printf(const char *pFormat, ...)
465 | {
466 | va_list ap;
467 | signed int result;
468 |
469 | /* Forward call to vprintf */
470 | va_start(ap, pFormat);
471 | result = vprintf(pFormat, ap);
472 | va_end(ap);
473 |
474 | return result;
475 | }
476 |
477 |
478 | /**
479 | * @brief Writes a formatted string inside another string.
480 | *
481 | * @param pStr torage string.
482 | * @param pFormat Format string.
483 | */
484 | signed int sprintf(char *pStr, const char *pFormat, ...)
485 | {
486 | va_list ap;
487 | signed int result;
488 |
489 | // Forward call to vsprintf
490 | va_start(ap, pFormat);
491 | result = vsprintf(pStr, pFormat, ap);
492 | va_end(ap);
493 |
494 | return result;
495 | }
496 |
497 |
498 | /**
499 | * @brief Outputs a string on stdout.
500 | *
501 | * @param pStr String to output.
502 | */
503 | signed int puts(const char *pStr)
504 | {
505 | return fputs(pStr, stdout);
506 | }
507 |
508 |
509 | /**
510 | * @brief Implementation of fputc using the DBGU as the standard output. Required
511 | * for printf().
512 | *
513 | * @param c Character to write.
514 | * @param pStream Output stream.
515 | * @param The character written if successful, or -1 if the output stream is
516 | * not stdout or stderr.
517 | */
518 | signed int fputc(signed int c, FILE *pStream)
519 | {
520 | if ((pStream == stdout) || (pStream == stderr)) {
521 |
522 | PrintChar(c);
523 |
524 | return c;
525 | }
526 | else {
527 |
528 | return EOF;
529 | }
530 | }
531 |
532 |
533 | /**
534 | * @brief Implementation of fputs using the DBGU as the standard output. Required
535 | * for printf().
536 | *
537 | * @param pStr String to write.
538 | * @param pStream Output stream.
539 | *
540 | * @return Number of characters written if successful, or -1 if the output
541 | * stream is not stdout or stderr.
542 | */
543 | signed int fputs(const char *pStr, FILE *pStream)
544 | {
545 | signed int num = 0;
546 |
547 | while (*pStr != 0) {
548 |
549 | if (fputc(*pStr, pStream) == -1) {
550 |
551 | return -1;
552 | }
553 | num++;
554 | pStr++;
555 | }
556 |
557 | return num;
558 | }
559 |
560 | /* --------------------------------- End Of File ------------------------------ */
