1 | library UNISIM; -- für SRAM Template
2 | use UNISIM.vcomponents.all; -- für SRAM Template
3 | library ieee;
4 | use ieee.std_logic_1164.all;
5 | use ieee.std_logic_unsigned.all;
6 |
7 | entity RAM_4096x16 is
8 | port (CLK, EN, RST, WE: in std_logic;
9 | A: in std_logic_vector(11 downto 0);
10 | DOUT: out std_logic_vector(15 downto 0);
11 | DIN: in std_logic_vector(15 downto 0));
12 | end RAM_4096x16;
13 |
14 | architecture Struktur of RAM_4096x16 is
15 |
16 | signal ENABLE: std_logic_vector(15 downto 0);
17 | signal HADR: std_logic_vector(3 downto 0);
18 | signal LADR: std_logic_vector(7 downto 0);
19 |
20 | begin
21 |
22 | HADR <= A(11 downto 8);
23 | LADR <= A(7 downto 0);
24 |
25 | Decoder: process(HADR)
26 | variable ENABLE_VAR: std_logic_vector(15 downto 0);
27 | variable INT: integer range 0 to 15;
28 | begin
29 | ENABLE_VAR := (others => '0');
30 | INT := conv_integer(HADR);
31 | ENABLE_VAR(INT) := '1';
32 | ENABLE <= ENABLE_VAR;
33 | end process Decoder;
34 |
35 | -- <-----Cut code below this line and paste into the architecture
36 | body---->
37 |
38 | -- RAMB4_S16: Virtex/E, Spartan-II/IIE 256 x 16 Single-Port RAM
39 | -- Xilinx HDL Language Template version 7.1i
40 |
41 | GEN: for I in 15 downto 0 generate
42 | RAMB4_S16_inst_01 : RAMB4_S16
43 | generic map (
44 | INIT_00 =>
45 | X"0000000000000000000000000000000000000000000000000000000000000000",
46 | INIT_01 =>
47 | X"0000000000000000000000000000000000000000000000000000000000000000",
48 | INIT_02 =>
49 | X"0000000000000000000000000000000000000000000000000000000000000000",
50 | INIT_03 =>
51 | X"0000000000000000000000000000000000000000000000000000000000000000",
52 | INIT_04 =>
53 | X"0000000000000000000000000000000000000000000000000000000000000000",
54 | INIT_05 =>
55 | X"0000000000000000000000000000000000000000000000000000000000000000",
56 | INIT_06 =>
57 | X"0000000000000000000000000000000000000000000000000000000000000000",
58 | INIT_07 =>
59 | X"0000000000000000000000000000000000000000000000000000000000000000",
60 | INIT_08 =>
61 | X"0000000000000000000000000000000000000000000000000000000000000000",
62 | INIT_09 =>
63 | X"0000000000000000000000000000000000000000000000000000000000000000",
64 | INIT_0A =>
65 | X"0000000000000000000000000000000000000000000000000000000000000000",
66 | INIT_0B =>
67 | X"0000000000000000000000000000000000000000000000000000000000000000",
68 | INIT_0C =>
69 | X"0000000000000000000000000000000000000000000000000000000000000000",
70 | INIT_0D =>
71 | X"0000000000000000000000000000000000000000000000000000000000000000",
72 | INIT_0E =>
73 | X"0000000000000000000000000000000000000000000000000000000000000000",
74 | INIT_0F =>
75 | X"0000000000000000000000000000000000000000000000000000000000000000")
76 | port map (
77 | DO => DOUT, -- 16-bit data output
78 | ADDR => LADR, -- 8-bit address input
79 | CLK => CLK, -- Clock input
80 | DI => DIN, -- 16-bit data input
81 | EN => ENABLE(I), -- RAM enable input
82 | RST => RST, -- Synchronous reset input
83 | WE => WE -- RAM write enable input
84 | );
85 |
86 | end generate;
87 |
88 | end Struktur;
