Hallo, ich habe eine RAM-Compenente gebastelt.
Die Datenübergabe findet sofort statt, nachdem ich es in den DE1 geladen
habe, ohne den Schiebeschalter SW(0) zu betätigen.
Woran liegt das bitte ?
Danke.
Gruss
Diese VHDL bindet die Sync_ram.vhdl ein:
1 | library ieee;
2 | use ieee.std_logic_1164.all;
3 | use ieee.numeric_std.all;
4 |
5 | entity c_sync_ram is port(
6 | clock : in std_logic;
7 | led_g : out STD_LOGIC_VECTOR(7 downto 0);
8 | sw : in STD_LOGIC_VECTOR(0 downto 0)
9 | );
10 | end c_sync_ram;
11 |
12 | architecture Behavioral of c_sync_ram is
13 |
14 | signal we : STD_LOGIC;
15 | signal address : std_logic_vector (7 downto 0);
16 | signal datain : std_logic_vector (7 downto 0);
17 | signal dataout : std_logic_vector (7 downto 0);
18 | signal read_address : std_logic_vector(7 downto 0);
19 |
20 | component sync_ram port(
21 | we : in STD_LOGIC;
22 | address : in std_logic_vector (7 downto 0);
23 | datain : in std_logic_vector (7 downto 0);
24 | dataout : inout std_logic_vector (7 downto 0);
25 | clock : in std_logic;
26 | read_address : in std_logic_vector(7 downto 0)
27 | );
28 | end component;
29 |
30 | begin
31 | io1 : sync_ram port map(we,address,datain,dataout,clock,read_address);
32 |
33 | process(clock)
34 | begin
35 | if rising_edge(clock) then
36 | if sw(0)='1' then
37 | we <='1';
38 | address<="00001111";
39 | datain<="11000011";
40 | else
41 | we<='0';
42 | read_address<="00001111";
43 | end if;
44 | end if;
45 | end process;
46 |
47 | led_g<=dataout;
48 |
49 | end Behavioral;
sync_ram:
1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.all;
3 | use IEEE.Numeric_Std.all;
4 |
5 | entity sync_ram is
6 | port (
7 | clock : in std_logic;
8 | we : in std_logic;
9 | address : in std_logic_vector (7 downto 0);
10 | datain : in std_logic_vector (7 downto 0);
11 | dataout : out std_logic_vector (7 downto 0);
12 | read_address : in std_logic_vector(7 downto 0)
13 | );
14 | end entity sync_ram;
15 |
16 | architecture RTL of sync_ram is
17 |
18 | type ram_type is array (0 to 255) of std_logic_vector(datain'range);
19 | signal ram : ram_type;
20 |
21 | begin
22 |
23 | process(clock) is
24 | begin
25 | if rising_edge(clock) then
26 | if we = '1' then
27 | ram(to_integer(unsigned(address))) <= datain;
28 | else
29 | dataout <= ram(to_integer(unsigned(read_address)));
30 | end if;
31 | end if;
32 | end process;
33 |
34 | end architecture RTL;
