1 | /*
2 | *****************************************************************************
3 | **
4 | ** File : stm32_flash.ld
5 | **
6 | ** Abstract : Linker script for STM32F103VB Device with
7 | ** 128KByte FLASH, 20KByte RAM
8 | **
9 | ** Set heap size, stack size and stack location according
10 | ** to application requirements.
11 | **
12 | ** Set memory bank area and size if external memory is used.
13 | **
14 | ** Target : STMicroelectronics STM32
15 | **
16 | ** Environment : Atollic TrueSTUDIO(R)
17 | **
18 | ** Distribution: The file is distributed “as is,” without any warranty
19 | ** of any kind.
20 | **
21 | ** (c)Copyright Atollic AB.
22 | ** You may use this file as-is or modify it according to the needs of your
23 | ** project. Distribution of this file (unmodified or modified) is not
24 | ** permitted. Atollic AB permit registered Atollic TrueSTUDIO(R) users the
25 | ** rights to distribute the assembled, compiled & linked contents of this
26 | ** file as part of an application binary file, provided that it is built
27 | ** using the Atollic TrueSTUDIO(R) toolchain.
28 | **
29 | *****************************************************************************
30 | */
31 |
32 | /* Entry Point */
33 | ENTRY(Reset_Handler)
34 |
35 | /* Highest address of the user mode stack */
36 | _estack = 0x20005000; /* end of 20K RAM */
37 |
38 | /* Generate a link error if heap and stack don't fit into RAM */
39 | _Min_Heap_Size = 0; /* required amount of heap */
40 | _Min_Stack_Size = 0x100; /* required amount of stack */
41 |
42 | /* Specify the memory areas */
43 | MEMORY
44 | {
45 | FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 128K
46 | RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 20K
47 | MEMORY_B1 (rx) : ORIGIN = 0x60000000, LENGTH = 0K
48 | }
49 |
50 | /* Define output sections */
51 | SECTIONS
52 | {
53 |
54 |
55 |
56 | /* The startup code goes first into FLASH */
57 | .isr_vector :
58 | {
59 | . = ALIGN(4);
60 | KEEP(*(.isr_vector)) /* Startup code */
61 | . = ALIGN(4);
62 | } >FLASH
63 |
64 | /* The program code and other data goes into FLASH */
65 | .text :
66 | {
67 | . = ALIGN(4);
68 | *(.text) /* .text sections (code) */
69 | *(.text*) /* .text* sections (code) */
70 | *(.rodata) /* .rodata sections (constants, strings, etc.) */
71 | *(.rodata*) /* .rodata* sections (constants, strings, etc.) */
72 | *(.glue_7) /* glue arm to thumb code */
73 | *(.glue_7t) /* glue thumb to arm code */
74 |
75 | KEEP (*(.init))
76 | KEEP (*(.fini))
77 |
78 | . = ALIGN(4);
79 | _etext = .; /* define a global symbols at end of code */
80 | } >FLASH
81 |
82 |
83 | .ARM.extab : { *(.ARM.extab* .gnu.linkonce.armextab.*) } >FLASH
84 | .ARM : {
85 | __exidx_start = .;
86 | *(.ARM.exidx*)
87 | __exidx_end = .;
88 | } >FLASH
89 |
90 | .ARM.attributes : { *(.ARM.attributes) } > FLASH
91 |
92 | .preinit_array :
93 | {
94 | PROVIDE_HIDDEN (__preinit_array_start = .);
95 | KEEP (*(.preinit_array*))
96 | PROVIDE_HIDDEN (__preinit_array_end = .);
97 | } >FLASH
98 | .init_array :
99 | {
100 | PROVIDE_HIDDEN (__init_array_start = .);
101 | KEEP (*(SORT(.init_array.*)))
102 | KEEP (*(.init_array*))
103 | PROVIDE_HIDDEN (__init_array_end = .);
104 | } >FLASH
105 | .fini_array :
106 | {
107 | PROVIDE_HIDDEN (__fini_array_start = .);
108 | KEEP (*(.fini_array*))
109 | KEEP (*(SORT(.fini_array.*)))
110 | PROVIDE_HIDDEN (__fini_array_end = .);
111 | } >FLASH
112 |
113 | /* used by the startup to initialize data */
114 | _sidata = .;
115 |
116 | /* Initialized data sections goes into RAM, load LMA copy after code */
117 | .data : AT ( _sidata )
118 | {
119 | . = ALIGN(4);
120 | _sdata = .; /* create a global symbol at data start */
121 | *(.data) /* .data sections */
122 | *(.data*) /* .data* sections */
123 |
124 | . = ALIGN(4);
125 | _edata = .; /* define a global symbol at data end */
126 | } >RAM
127 |
128 | /* Uninitialized data section */
129 | . = ALIGN(4);
130 | .bss :
131 | {
132 | /* This is used by the startup in order to initialize the .bss secion */
133 | _sbss = .; /* define a global symbol at bss start */
134 | __bss_start__ = _sbss;
135 | *(.bss)
136 | *(.bss*)
137 | *(COMMON)
138 |
139 | . = ALIGN(4);
140 | _ebss = .; /* define a global symbol at bss end */
141 | __bss_end__ = _ebss;
142 | } >RAM
143 |
144 | PROVIDE ( end = _ebss );
145 | PROVIDE ( _end = _ebss );
146 |
147 | /* User_heap_stack section, used to check that there is enough RAM left */
148 | ._user_heap_stack :
149 | {
150 | . = ALIGN(4);
151 | . = . + _Min_Heap_Size;
152 | . = . + _Min_Stack_Size;
153 | . = ALIGN(4);
154 | } >RAM
155 |
156 | /* MEMORY_bank1 section, code must be located here explicitly */
157 | /* Example: extern int foo(void) __attribute__ ((section (".mb1text"))); */
158 | .memory_b1_text :
159 | {
160 | *(.mb1text) /* .mb1text sections (code) */
161 | *(.mb1text*) /* .mb1text* sections (code) */
162 | *(.mb1rodata) /* read-only data (constants) */
163 | *(.mb1rodata*)
164 | } >MEMORY_B1
165 |
166 | /* Remove information from the standard libraries */
167 | /DISCARD/ :
168 | {
169 | libc.a ( * )
170 | libm.a ( * )
171 | libgcc.a ( * )
172 | libgcc.a
173 | libg.a
174 | libnosys.a
175 | }
176 | }
