1 | Library ieee;
2 | use ieee.std_logic_1164.all;
3 | use ieee.std_logic_arith.all;
4 | use ieee.std_logic_unsigned.all;
5 |
6 | entity Bubblesort is
7 | end Bubblesort;
8 |
9 | architecture Behavioral of Bubblesort is
10 |
11 | -- Signals RAM
12 | signal addra : std_logic_vector(5 downto 0) := (others => '0');
13 | signal addrb : std_logic_vector(5 downto 0) := (others => '0');
14 | signal addrb_d1 : std_logic_vector(5 downto 0) := (others => '0');
15 | signal addrb_d2 : std_logic_vector(5 downto 0) := (others => '0');
16 | signal addrb_d3 : std_logic_vector(5 downto 0) := (others => '0');
17 | signal addrb_d4 : std_logic_vector(5 downto 0) := (others => '0');
18 | signal dout_a : std_logic_vector(15 downto 0) := (others => '0');
19 | signal din_a : std_logic_vector(15 downto 0) := (others => '0');
20 | signal din_b : std_logic_vector(15 downto 0) := (others => '0');
21 | signal we_a : std_logic_vector(0 downto 0) := (others => '0');
22 | signal we_b : std_logic_vector(0 downto 0) := (others => '0');
23 |
24 | -- Signals Bubble
25 | signal busy : std_logic := '0';
26 | signal value1 : std_logic_vector(15 downto 0) := (others => '0');
27 | signal value2 : std_logic_vector(15 downto 0) := (others => '0');
28 | signal temp : std_logic_vector(15 downto 0) := (others => '0');
29 | signal n : integer range 0 to 64;
30 | signal start : std_logic := '0';
31 | signal clk : std_logic := '0';
32 | signal enable : std_logic := '0';
33 | signal done : std_logic := '0';
34 | signal reset : std_logic := '0';
35 | signal reset_count : std_logic_vector(1 downto 0) := (others => '0');
36 | signal i : std_logic_vector(5 downto 0) := (others => '0');
37 |
38 |
39 | begin
40 |
41 |
42 | -------------------------------------------------------------------
43 | -- TESTBENCH
44 | -------------------------------------------------------------------
45 | clk <= not clk after 20 ns; -- 25 MHz Taktfrequenz
46 | enable <= '1';
47 | start <= '1';
48 |
49 | -------------------------------------------------------------------
50 | -- INSTANTIATE BUBBLE_RAM
51 | -------------------------------------------------------------------
52 | BUBBLE : entity work.BUBBLE
53 | port map
54 | (
55 | clka => clk,
56 | wea => "0",
57 | addra => i,
58 | dina => din_a,
59 | douta => value2,
60 | clkb => clk,
61 | web => we_b,
62 | addrb => addrb_d4,
63 | dinb => din_b,
64 | doutb => open
65 | );
66 |
67 | -------------------------------------------------------------------
68 | -- DELAYS
69 | -------------------------------------------------------------------
70 | p_del: process(clk) is
71 | begin
72 | if rising_edge(clk) then
73 | value1 <= value2;
74 | end if;
75 | end process;
76 |
77 | p_adrb_del1: process(clk) is
78 | begin
79 | if rising_edge(clk) then
80 | addrb_d1 <= addrb;
81 | end if;
82 | end process;
83 |
84 | p_adrb_del2: process(clk) is
85 | begin
86 | if rising_edge(clk) then
87 | addrb_d2 <= addrb_d1;
88 | end if;
89 | end process;
90 |
91 | p_adrb_del3: process(clk) is
92 | begin
93 | if rising_edge(clk) then
94 | addrb_d3 <= addrb_d2;
95 | end if;
96 | end process;
97 |
98 |
99 | p_adrb_del4: process(clk) is
100 | begin
101 | if rising_edge(clk) then
102 | addrb_d4 <= addrb_d3;
103 | end if;
104 | end process;
105 |
106 | -------------------------------------------------------------------
107 | -- GENERATE RESET
108 | -------------------------------------------------------------------
109 | p_reset_count: process(clk) is
110 | begin
111 | if rising_edge(clk) then
112 | if (reset_count < "10") then
113 | reset <= '1';
114 | reset_count <= reset_count + 1;
115 | else
116 | reset <= '0';
117 | reset_count <= "11";
118 | end if;
119 | end if;
120 | end process;
121 |
122 | -------------------------------------------------------------------
123 | -- BUBBLE ALGORITHM
124 | -------------------------------------------------------------------
125 | p_bubble: process(clk) is
126 | begin
127 | if rising_edge(clk) then
128 | if (busy = '0') then
129 | if (start = '1') then
130 | busy <= '1';
131 | n <= 0;
132 | i <= "000000";
133 | end if;
134 | else
135 | if (n < 64) then
136 | if (i < "111111") then -- (n -1) = 63
137 | if value1 > value2 then
138 | TEMP <= value2;
139 |
140 | we_b <= "1";
141 | addrb <= addra + 1;
142 | din_b <= TEMP;
143 | else
144 | we_b <= "0";
145 | addrb <= addra + 1;
146 | end if;
147 | i <= i+1; -- addra
148 | else
149 | i <= (others => '0');
150 | n <= n + 1;
151 | end if;
152 | else
153 | busy <= '0';
154 | --do <= din;
155 | end if;
156 | end if;
157 | end if;
158 | end process;
159 |
160 | done <= '1' when start = '0' and busy = '0' else '0';
161 |
162 | end Behavioral;
