1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 |
4 | entity spi_transceiver is
5 | Port (
6 | SCLK_IN : in STD_LOGIC; -- Base frequency clock.
7 |
8 | SCLK : out STD_LOGIC; -- Master Clock for SPI-Slave.
9 | CSB : out STD_LOGIC; -- Chip select to enable/disable data transfers.
10 | SDI : out STD_LOGIC; -- Serial data stream to DAC SPI-Interface.
11 | SDO : in STD_LOGIC; -- Serial data stream from DAC SPI-Interface
12 |
13 | start : in STD_LOGIC; -- Start tx/rx process.
14 | reset : in STD_LOGIC; -- Reset to default state.
15 | done : out STD_LOGIC; -- Status bit to indicate end of tx/rx process.
16 |
17 | tx_address_vector : in STD_LOGIC_VECTOR (11 downto 0); -- Address vector inluding R/W-Bit.
18 | tx_data_vector : in STD_LOGIC_VECTOR (7 downto 0); -- Data vector to send to DAC-SPI.
19 | rx_data_vector : out STD_LOGIC_VECTOR (7 downto 0); -- Received data from SPI-slave.
20 |
21 | test_led0 : out STD_LOGIC; -- LED for indicating successfull write and read operation.
22 | test_led1 : out STD_LOGIC;
23 | test_led2 : out STD_LOGIC;
24 | test_led3 : out STD_LOGIC;
25 | push_button2 : in STD_LOGIC
26 |
27 | );
28 | end spi_transceiver;
29 |
30 | architecture Behavioral of spi_transceiver is
31 |
32 | signal SPI_counter : integer range 0 to 43 := 0;
33 | signal SPI_enable : std_logic := '0';
34 |
35 | type state is (IDLE, SENDING_ADDRESS_BITS);
36 | signal sig_state : state := IDLE;
37 |
38 | -- Debug-signals
39 | signal tmp_test_led0 : std_logic := '0';
40 | signal tmp_test_led1 : std_logic := '0';
41 | signal tmp_test_led2 : std_logic := '0';
42 | signal tmp_test_led3 : std_logic := '0';
43 | signal ready_state : std_logic_vector(1 downto 0) := (others => '0');
44 |
45 | begin
46 |
47 | test_led0 <= tmp_test_led0;
48 | test_led1 <= tmp_test_led1;
49 | test_led2 <= tmp_test_led2;
50 | test_led3 <= tmp_test_led3;
51 | ready_state <= start & SPI_enable;
52 |
53 | process(SCLK_IN)
54 | begin
55 |
56 | -- Connect output SCLK synchronously to SCLK_IN
57 | SCLK <= SCLK_IN;
58 |
59 | -- Reset logic
60 | if(reset = '1') then
61 | CSB <= '1'; -- Make SPI closed to communication.
62 | done <= '0';
63 | SDI <= '0';
64 |
65 | SPI_counter <= 0;
66 | SPI_enable <= '0';
67 | sig_state <= IDLE;
68 |
69 | tmp_test_led0 <= '1';
70 | tmp_test_led1 <= '0';
71 | tmp_test_led2 <= '0';
72 | tmp_test_led3 <= '0';
73 |
74 | else
75 |
76 | case sig_state is
77 | when IDLE =>
78 | -- ready_state <= start & SPI_enable;
79 | case ready_state is
80 | when "00" => -- NOT RESET, NOT STARTED YET = IDLE - DEBUG-LEDs: 0010
81 | tmp_test_led0 <= '0';
82 | tmp_test_led1 <= '0';
83 | tmp_test_led2 <= '1';
84 | tmp_test_led3 <= '0';
85 | when "01" => -- ERROR-STATE - DEBUG-LEDs: 1010
86 | tmp_test_led0 <= '1';
87 | tmp_test_led1 <= '0';
88 | tmp_test_led2 <= '1';
89 | tmp_test_led3 <= '0';
90 |
91 | when "10" => -- Enable tx/rx-process - DEBUG-LEDs: 0100
92 | SPI_counter <= 0;
93 | SPI_enable <= '1'; -- Start the tx/rx-process.
94 | sig_state <= SENDING_ADDRESS_BITS; -- Address-Bits-Transmission is always the first thing to do.
95 |
96 | tmp_test_led0 <= '0';
97 | tmp_test_led1 <= '1';
98 | tmp_test_led2 <= '0';
99 | tmp_test_led3 <= '0';
100 |
101 | when "11" => -- ERROR-STATE - DEBUG-LEDs: 1100
102 | tmp_test_led0 <= '1';
103 | tmp_test_led1 <= '1';
104 | tmp_test_led2 <= '0';
105 | tmp_test_led3 <= '0';
106 |
107 | when others => -- ERROR-STATE
108 |
109 | end case; -- ready_state
110 |
111 | when SENDING_ADDRESS_BITS =>
112 |
113 | if(push_button2 = '1') then
114 | sig_state <= IDLE;
115 | end if;
116 | -- DEBUG: 0110
117 | tmp_test_led0 <= '0';
118 | tmp_test_led1 <= '1';
119 | tmp_test_led2 <= '1';
120 | tmp_test_led3 <= '0';
121 |
122 | when others =>
123 | -- It should not occur to come into this state here.
124 | sig_state <= IDLE;
125 | SDI <= '0';
126 | SPI_enable <= '0';
127 |
128 | -- DEBUG: 0101
129 | tmp_test_led0 <= '0';
130 | tmp_test_led1 <= '1';
131 | tmp_test_led2 <= '0';
132 | tmp_test_led3 <= '1';
133 | end case;
134 |
135 | end if; --RESET
136 |
137 | end process;
138 |
139 | end Behavioral;
