Forum: Mikrocontroller und Digitale Elektronik Mikrobasic Programm Grösse optimieren
von Seppi (Gast)
Hallo Leute,
Habe bereits im Mikroelektronika Forum gepostet.
Leider ist dieses schlecht besucht, bzw. intressiert sich jeder nur für
sein eigenes Problem.
Daher habe ich mich entschieden, aauch hier mal zu posten.
Es geht um die Optimierung eines Codes, um die Grösse zu minimieren.
Kann mir da jemand Tipps geben?
program Flash_Test
'Used PIC is a PIC12F1572
'INTOSC is set to 32Mhz
'Program writes dummys to the HEF Flashcell and give it out over UART.
'After this, program fall into a endless loop.
Const Row1 as Word = 0x780
Const Row2 as Word = 0x7A0
Const Row3 as Word = 0x7C0
Const Row4 as Word = 0x7E0
dim UART_Data_Out as char[5]
dim MyMemory as word[16]
dim i as byte
Sub Procedure Init
    ANSELA = 0                           'All Pins are digital
    WPUA = 0                             'No Pullups
23
    INLVLA = 0x0                         'All Inputs are TTL
24
    OSCCON = 0xF6                        'Configure 32Mhz internal OSC
25
    UART1_Init(9600)                     'Init Uart
26
    Delay_ms(100)                        'Wait until Uart stable
27
End sub
28
29
sub procedure Flash_Unlock
30
    PMCON2 = 0x55
31
    PMCON2 = 0xAA
32
    PMCON1.WR = 1
33
    NOP
34
    NOP
35
end sub
36
37
sub procedure FlashEraseRow (dim Address as word)
38
    INTCON.GIE = 0                       'disable all interrupts
39
    PMCON1.CFGS = 0                      'set program memory space
40
    PMCON1.PMADR = Address
41
    PMCON1.FREE = 1
42
    PMCON1.WREN = 1
43
    Flash_unlock
44
    'processor stalls until operation is complete (2 mS typical)
45
    PMCON1.WREN = 0
46
    INTCON.GIE = 1                       'restore old value of GIE bit
47
end sub
48
49
sub procedure FlashWriteRow(dim Address as word, dim byref datas as word[16])
50
dim i as byte
51
52
53
54
    PMCON1.FREE = 0
55
    PMCON1.LWLO = 1                        'only write to the latches
56
    PMCON1.WREN = 1
57
    for i =0 to 15
58
        PMCON1.PMADR = Address + i
59
        PMCON1.PMDAT = datas[i]
60
        Flash_unlock
61
    next i
62
    PMCON1.LWLO = 0                        'write latches to flash
63
    Flash_unlock
64
65
    PMCON1.WREN = 0
66
67
end sub
68
69
sub function FlashReadWord (dim Address as word) as word
70
71
    PMCON1.PMADRH = Address
72
    PMCON1.RD = 1                        'set read
73
    NOP
74
    NOP
75
    FlashReadWord = PMCON1.PMDAT
76
end sub
77
78
sub procedure FlashReadRow (dim Address as word,dim byref datas as word[16])
79
dim i as byte
80
    for i =0 to 15
81
        datas[i] = FlashReadWord(Address +i)
82
    next i
83
end sub
84
85
Sub Procedure WriteDummysToFlash
86
    for i = 0 to 15
87
        MyMemory[i] = i
88
    next i
89
    FlashWriteRow(Row1,MyMemory)
90
    for i = 0 to 15
91
        MyMemory[i] = i +16
92
    next i
93
    FlashWriteRow(Row2,MyMemory)
94
    for i = 0 to 15
95
        MyMemory[i] = i +32
96
    next i
97
    FlashWriteRow(Row3,MyMemory)
98
    for i = 0 to 15
99
        MyMemory[i] = i +48
100
    next i
101
    FlashWriteRow(Row4,MyMemory)
102
end sub
103
104
Sub Procedure SendMyMemoryToPC
105
    for i = 0 to 15
106
        WordToStr(MyMemory[i],UART_Data_Out)
107
        UART1_Write_Text(UART_Data_Out)
108
    next i
109
end sub
110
111
main:
112
Init
113
WriteDummysToFlash
114
FlashReadRow(Row1,MyMemory)
115
SendMyMemoryToPC
116
FlashReadRow(Row2,MyMemory)
117
SendMyMemoryToPC
118
FlashReadRow(Row3,MyMemory)
119
SendMyMemoryToPC
120
FlashReadRow(Row4,MyMemory)
121
SendMyMemoryToPC
122
123
while 1
124
      clrwdt
125
wend
126
127
end.
von ttl (Gast)
schreibs halt in C, da kriegst du auch mehr Hilfe
von Seppi (Gast)
OK. Dann werde ich mal schnell C lernen, und den vorhandenen Compiler,
welchenn ich bezahlt habe, verwerfen.
Ernsthaft: Es wird beim Mikrobasic bleiben.
von ttl (Gast)
dann such halt nach den 1% die auch unbedingt Basic nehmen wollen
von Andreas K. (andreasmc)
Ich kenne mich mit PIC&MicroBasic nicht aus, aber dein Program an sich
scheint jetzt nicht sooo umfangreich zu sein.
Ein paar Bytes könntest du vermutlich einsparen, indem du Row1-Row4 in
ein Array packst und dann die entsprechenden vierfachen Aufrufe durch
Schleifen ersetzt.
Eventuell kannst du noch Platz sparen, indem du statt
Bibliotheks-Aufrufen für UART eigene Subs schreibst - k.A. wie
MicroBasic das linken handhabt.
Wie groß ist das Programm denn und wie groß soll es werden?
von Seppi (Gast)
Naja. Das Problem ist, das es jetzt schon 1/3 des Speichers (Flash)
braucht.
Darum habe ich Zweifel, wenn ich noch etwas dazupacke, dass mir der
Flash ausgeht.
Ich wollte generell fragen, ob das Programm scheisse ist, oder nicht.
von слюнотечение Тролль (Gast)
3.5k Flash, 256Byte RAM, 8 pins ... soll das ein Witz sein?
So eine Maschine ist fuer Spezialisten, die die Stueckzahl
haben, und auch vernuenftig Programmieren koennen. Heisst hier,
die Architektur genau kennen, und jedes Byte aus dem Code
rauspressen koennen. Irgendwelche Library funktionen sind
dann nicht mehr dabei.
Weg damit. Brauchts nicht. Eine Delay
Funktion verwendet man generell nie !!! NIE.
Wahrscheinlich Muell. Das muss man viel, viel dichter Packen.
Fazit. Dass die Maschine schon gegen Voll geht hat schon seine
Reichtigkeit. Gegen Basic ist nicht viel zu sagen. Benoetigt eben auch
seine Einarbeitung, und genaue Kenntnis der Library Funktionen.
Ich schreib zwar auch in einer Hochsprache, verwende aber trotzdem keine
Library funktionen.
von Stefan (Gast)
Ist doch grad mal zu 1/3 voll.
Schreib doch erst mal weiter dein Programm.
Dann siehste wieviel du brauchst. Wenn zu wenig
dann nimmste halt einen mit mehr Speicher.
von Seppi (Gast)
Habe mir mal die Routine WordToStr nachgebaut.
Verbraucht noch mehr Flash als die Originale eingebaute Lib :-((
sub procedure WordToString (dim InputWord as Word,dim byref OutputString as char[5])
    OutputString[0] = (InputWord/10000)+ 48
    OutputString[1] = ((InputWord/1000)mod 10)+ 48
    OutputString[2] = ((InputWord/100)mod 10)+ 48
    OutputString[3] = ((InputWord/10)mod 10)+ 48
    OutputString[4] = (InputWord mod 10)+ 48
end sub
von Bernd K. (prof7bit)
> braucht.
Das passt nicht.
Entweder Du programmierst BASIC oder andere exotische Hochsprachen was
automatisch impliziert daß Du mehr Wert auf Abstraktion legst als auf
Ressourcenverbrauch oder Du legst Wert auf minimalen
Ressourcenverbrauch, dann verwendest Du Programmiersprachen die speziell
in dieser Disziplin glänzen.
Einen Tod musst Du sterben. Such Dir aus welcher das sein soll.
von Stefan F. (Gast)
BASIC auf 3,5kB Flash - wie niedlich.
So kleine Controller würde ich in Assembler programmieren, oder notfalls
in C. Aber sicher nicht in BASIC.
von Kenner (Gast)
Bei Mikroe gibt es gibt kein unterschied zwischen C und basic.Also wenn
er das in C schreibt wird der code genau so lang sein. Aber um ihn zu
optimieren sollte man wo es moglich ist word durch char oder byte
ersetzen.
von Christian M. (Gast)
Ich programmiere meine PIC's auch alle mit MikroBASIC, ausser die 10F...
Wenn man die Libs nicht nutzt, ist das fast wie Assembler, ausser dass
man sich nicht um's Banking kümmern muss. Wenn ich eine Lib benutze,
schaue ich auf jeden Fall ins Assembler Listing, wie er das macht. Ggf.
optimieren oder eigene Routine verwenden (z.B. I2C).
Gruss Chregu
