1 | entity IDG is
2 | port( CLK, RESET, ENABLE : in bit; -- sekundäre Eingangssignale
3 | PHI :in bit_vector(1 downto 0); -- Eingangsvektor
4 | A :out bit_vector(1 downto 0) ); -- Ausgangsvektor
5 | end IDG;
6 |
7 | architecture SEQUENZ of IDG is
8 | type ZUSTAENDE is (V00, V00I, V10, V10I, V11, V11I, V01, V01I, R01, R01I, R00, R00I, R10, R10I, R11, R11I, Fehler); -- Aufzählungstyp
9 | signal ZUSTAND,FOLGE_Z: ZUSTAENDE ; -- Prozess-Kommunikation
10 | begin
11 |
12 | Z_SPEICHER: process(CLK, RESET) -- Zustandsaktualisierung
13 | begin
14 | if RESET = '1' then ZUSTAND <= V10 after 20 ns;
15 | elsif CLK = '1' and CLK'event then
16 | if ENABLE = '1' then ZUSTAND <= FOLGE_Z after 20 ns;
17 | end if;
18 | end if;
19 | end process Z_SPEICHER;
20 |
21 | UE_SN: process(PHI, ZUSTAND) -- Folgezustandsberechnung
22 | begin
23 |
24 | case ZUSTAND is
25 | when V00 => if PHI = "10" then FOLGE_Z <= V10I;
26 | else if PHI = "01" then FOLGE_Z <= R01I;
27 | else if PHI = "00" then FOLGE_Z <= V00;
28 | else if PHI = "11" then FOLGE_Z <= Fehler;
29 | end if;
30 | when V10 => if PHI = "10" then FOLGE_Z <= V10;
31 | else if PHI = "01" then FOLGE_Z <= Fehler;
32 | else if PHI = "00" then FOLGE_Z <= R00I;
33 | else if PHI = "11" then FOLGE_Z <= V11I;
34 | end if;
35 | when V11 => if PHI = "10" then FOLGE_Z <= R01I;
36 | else if PHI = "01" then FOLGE_Z <= V01I;
37 | else if PHI = "00" then FOLGE_Z <= Fehler;
38 | else if PHI = "11" then FOLGE_Z <= V11;
39 | end if;
40 | when V01 => if PHI = "10" then FOLGE_Z <= Fehler;
41 | else if PHI = "01" then FOLGE_Z <= V01;
42 | else if PHI = "00" then FOLGE_Z <= V00I;
43 | else if PHI = "11" then FOLGE_Z <= R11I;
44 | end if;
45 | when R00 => if PHI = "10" then FOLGE_Z <= V10I;
46 | else if PHI = "01" then FOLGE_Z <= R01I;
47 | else if PHI = "00" then FOLGE_Z <= R00;
48 | else if PHI = "11" then FOLGE_Z <= Fehler;
49 | end if;
50 | when R10 => if PHI = "10" then FOLGE_Z <= R10;
51 | else if PHI = "01" then FOLGE_Z <= Fehler;
52 | else if PHI = "00" then FOLGE_Z <= R00I;
53 | else if PHI = "11" then FOLGE_Z <= V11I;
54 | end if;
55 | when R11 => if PHI = "10" then FOLGE_Z <= R01I;
56 | else if PHI = "01" then FOLGE_Z <= V01I;
57 | else if PHI = "00" then FOLGE_Z <= Fehler;
58 | else if PHI = "11" then FOLGE_Z <= R11;
59 | end if;
60 | when R01 => if PHI = "10" then FOLGE_Z <= Fehler;
61 | else if PHI = "01" then FOLGE_Z <= R01;
62 | else if PHI = "00" then FOLGE_Z <= V00I;
63 | else if PHI = "11" then FOLGE_Z <= R11I;
64 | end if;
65 | when V00I => FOLGE_Z <= V00;
66 | when V01I => FOLGE_Z <= V01;
67 | when V11I => FOLGE_Z <= V11;
68 | when V10I => FOLGE_Z <= V10;
69 | when R00I => FOLGE_Z <= R00;
70 | when R01I => FOLGE_Z <= R01;
71 | when R11I => FOLGE_Z <= R11;
72 | when R10I => FOLGE_Z <= R10;
73 | end case;
74 | end process UE_SN;
75 |
76 | AUS_SN: process(ZUSTAND) -- Ausgangssignalberechung
77 | begin
78 | case ZUSTAND is
79 | when V00 => A <= '10' after 20 ns;
80 | when others => A <= '00' after 20 ns;
81 | end case;
82 | end process AUS_SN;
83 | end SEQUENZ;
