1 | #=============================================================================#
2 | # ARM makefile
3 | #
4 | # author: Freddie Chopin, http://www.freddiechopin.info/
5 | # last change: 2012-03-22
6 | #
7 | # this makefile is based strongly on many examples found in the network
8 | #=============================================================================#
9 |
10 | #=============================================================================#
11 | # toolchain configuration
12 | #=============================================================================#
13 |
14 | ##Zum Testen:
15 | $ TOOLCHAIN = C:\ARMtoolchains\arm-none-eabi-gcc\bin\arm-none-eabi-
16 | #$ TOOLCHAIN = arm-none-eabi-
17 |
18 | CXX = $(TOOLCHAIN)g++
19 | CC = $(TOOLCHAIN)gcc
20 | AS = $(TOOLCHAIN)gcc -x assembler-with-cpp
21 | OBJCOPY = $(TOOLCHAIN)objcopy
22 | OBJDUMP = $(TOOLCHAIN)objdump
23 | SIZE = $(TOOLCHAIN)size
24 | RM = rm -f
25 |
26 | #=============================================================================#
27 | # project configuration
28 | #=============================================================================#
29 |
30 | # project name
31 | PROJECT = STemWinTest
32 |
33 | # core type
34 | CORE = cortex-m4
35 |
36 | # linker script
37 | LD_SCRIPT = STM32F429G.ld
38 |
39 | # output folder (absolute or relative path, leave empty for in-tree compilation)
40 | OUT_DIR = out
41 |
42 | # global definitions for C++, C and ASM (e.g. "symbol_with_value=0xDEAD symbol_without_value")
43 | GLOBAL_DEFS = STM32F429_439xx
44 |
45 | # C++ definitions
46 | CXX_DEFS =
47 |
48 | # C definitions
49 | C_DEFS =
50 |
51 | # ASM definitions
52 | AS_DEFS =
53 |
54 | # include directories (absolute or relative paths to additional folders with
55 | # headers, current folder is always included)
56 | INC_DIRS = inc GUI/Config GUI/Inc
57 |
58 | # library directories (absolute or relative paths to additional folders with
59 | # libraries)
60 | LIB_DIRS =
61 |
62 | # libraries (additional libraries for linking, e.g. "-lm -lsome_name" to link
63 | # math library libm.a and libsome_name.a)
64 | LIBS = GUI/Lib/STemWin522_CM4_GCC.a
65 |
66 | # additional directories with source files (absolute or relative paths to
67 | # folders with source files, current folder is always included)
68 | SRCS_DIRS = GUI/Config
69 |
70 | # extension of C++ files
71 | CXX_EXT = cpp
72 |
73 | # wildcard for C++ source files (all files with CXX_EXT extension found in
74 | # current folder and SRCS_DIRS folders will be compiled and linked)
75 | CXX_SRCS = $(wildcard $(patsubst %, %/*.$(CXX_EXT), . $(SRCS_DIRS)))
76 |
77 | # extension of C files
78 | C_EXT = c
79 |
80 | # wildcard for C source files (all files with C_EXT extension found in current
81 | # folder and SRCS_DIRS folders will be compiled and linked)
82 | C_SRCS = $(wildcard $(patsubst %, %/*.$(C_EXT), . $(SRCS_DIRS)))
83 |
84 | # extension of ASM files
85 | AS_EXT = S
86 |
87 | # wildcard for ASM source files (all files with AS_EXT extension found in
88 | # current folder and SRCS_DIRS folders will be compiled and linked)
89 | AS_SRCS = $(wildcard $(patsubst %, %/*.$(AS_EXT), . $(SRCS_DIRS)))
90 |
91 | # optimization flags ("-O0" - no optimization, "-O1" - optimize, "-O2" -
92 | # optimize even more, "-Os" - optimize for size or "-O3" - optimize yet more)
93 | OPTIMIZATION = -O0
94 |
95 | # set to 1 to optimize size by removing unused code and data during link phase
96 | REMOVE_UNUSED = 1
97 |
98 | # set to 1 to compile and link additional code required for C++
99 | USES_CXX = 0
100 |
101 | # define warning options here
102 | CXX_WARNINGS = -Wall -Wextra
103 | C_WARNINGS = -Wall -Wstrict-prototypes -Wextra
104 |
105 | # C++ language standard ("c++98", "gnu++98" - default, "c++0x", "gnu++0x")
106 | CXX_STD = gnu++98
107 |
108 | # C language standard ("c89" / "iso9899:1990", "iso9899:199409",
109 | # "c99" / "iso9899:1999", "gnu89" - default, "gnu99")
110 | C_STD = gnu89
111 |
112 | #=============================================================================#
113 | # set the VPATH according to SRCS_DIRS
114 | #=============================================================================#
115 |
116 | VPATH = $(SRCS_DIRS)
117 |
118 | #=============================================================================#
119 | # when using output folder, append trailing slash to its name
120 | #=============================================================================#
121 |
122 | ifeq ($(strip $(OUT_DIR)), )
123 | OUT_DIR_F =
124 | else
125 | OUT_DIR_F = $(strip $(OUT_DIR))/
126 | endif
127 |
128 | #=============================================================================#
129 | # various compilation flags
130 | #=============================================================================#
131 |
132 | # core flags
133 | CORE_FLAGS = -mcpu=$(CORE) -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -ffast-math
134 |
135 | # flags for C++ compiler
136 | CXX_FLAGS = -std=$(CXX_STD) -g -ggdb3 -fno-rtti -fno-exceptions -fverbose-asm -Wa,-ahlms=$(OUT_DIR_F)$(notdir $(<:.$(CXX_EXT)=.lst))
137 |
138 | # flags for C compiler
139 | C_FLAGS = -std=$(C_STD) -g -ggdb3 -fverbose-asm -Wa,-ahlms=$(OUT_DIR_F)$(notdir $(<:.$(C_EXT)=.lst))
140 |
141 | # flags for assembler
142 | AS_FLAGS = -g -ggdb3 -Wa,-amhls=$(OUT_DIR_F)$(notdir $(<:.$(AS_EXT)=.lst))
143 |
144 | # flags for linker
145 | LD_FLAGS = -T$(LD_SCRIPT) -g -Wl,-Map=$(OUT_DIR_F)$(PROJECT).map,--cref,--no-warn-mismatch
146 |
147 | # process option for removing unused code
148 | ifeq ($(REMOVE_UNUSED), 1)
149 | LD_FLAGS += -Wl,--gc-sections
150 | OPTIMIZATION += -ffunction-sections -fdata-sections
151 | endif
152 |
153 | # if __USES_CXX is defined for ASM then code for global/static constructors /
154 | # destructors is compiled; if -nostartfiles option for linker is added then C++
155 | # initialization / finalization code is not linked
156 | ifeq ($(USES_CXX), 1)
157 | AS_DEFS += __USES_CXX
158 | else
159 | LD_FLAGS += -nostartfiles
160 | endif
161 |
162 | #=============================================================================#
163 | # do some formatting
164 | #=============================================================================#
165 |
166 | CXX_OBJS = $(addprefix $(OUT_DIR_F), $(notdir $(CXX_SRCS:.$(CXX_EXT)=.o)))
167 | C_OBJS = $(addprefix $(OUT_DIR_F), $(notdir $(C_SRCS:.$(C_EXT)=.o)))
168 | AS_OBJS = $(addprefix $(OUT_DIR_F), $(notdir $(AS_SRCS:.$(AS_EXT)=.o)))
169 | OBJS = $(AS_OBJS) $(C_OBJS) $(CXX_OBJS) $(USER_OBJS)
170 | DEPS = $(OBJS:.o=.d)
171 | INC_DIRS_F = -I. $(patsubst %, -I%, $(INC_DIRS))
172 | LIB_DIRS_F = $(patsubst %, -L%, $(LIB_DIRS))
173 | GLOBAL_DEFS_F = $(patsubst %, -D%, $(GLOBAL_DEFS))
174 | CXX_DEFS_F = $(patsubst %, -D%, $(CXX_DEFS))
175 | C_DEFS_F = $(patsubst %, -D%, $(C_DEFS))
176 | AS_DEFS_F = $(patsubst %, -D%, $(AS_DEFS))
177 |
178 | ELF = $(OUT_DIR_F)$(PROJECT).elf
179 | HEX = $(OUT_DIR_F)$(PROJECT).hex
180 | BIN = $(OUT_DIR_F)$(PROJECT).bin
181 | LSS = $(OUT_DIR_F)$(PROJECT).lss
182 | DMP = $(OUT_DIR_F)$(PROJECT).dmp
183 |
184 | # format final flags for tools, request dependancies for C++, C and asm
185 | CXX_FLAGS_F = $(CORE_FLAGS) $(OPTIMIZATION) $(CXX_WARNINGS) $(CXX_FLAGS) $(GLOBAL_DEFS_F) $(CXX_DEFS_F) -MD -MP -MF $(OUT_DIR_F)$(@F:.o=.d) $(INC_DIRS_F)
186 | C_FLAGS_F = $(CORE_FLAGS) $(OPTIMIZATION) $(C_WARNINGS) $(C_FLAGS) $(GLOBAL_DEFS_F) $(C_DEFS_F) -MD -MP -MF $(OUT_DIR_F)$(@F:.o=.d) $(INC_DIRS_F)
187 | AS_FLAGS_F = $(CORE_FLAGS) $(AS_FLAGS) $(GLOBAL_DEFS_F) $(AS_DEFS_F) -MD -MP -MF $(OUT_DIR_F)$(@F:.o=.d) $(INC_DIRS_F)
188 | LD_FLAGS_F = $(CORE_FLAGS) $(LD_FLAGS) $(LIB_DIRS_F)
189 |
190 | #contents of output directory
191 | GENERATED = $(wildcard $(patsubst %, $(OUT_DIR_F)*.%, bin d dmp elf hex lss lst map o))
192 |
193 | #=============================================================================#
194 | # make all
195 | #=============================================================================#
196 |
197 | all : make_output_dir $(ELF) $(LSS) $(DMP) $(HEX) $(BIN) print_size
198 |
199 | # make object files dependent on Makefile
200 | $(OBJS) : Makefile
201 | # make .elf file dependent on linker script
202 | $(ELF) : $(LD_SCRIPT)
203 |
204 | #-----------------------------------------------------------------------------#
205 | # linking - objects -> elf
206 | #-----------------------------------------------------------------------------#
207 |
208 | $(ELF) : $(OBJS)
209 | @echo 'Linking target: $(ELF)'
210 | $(CXX) $(LD_FLAGS_F) $(OBJS) $(LIBS) -o $@
211 | @echo ' '
212 |
213 | #-----------------------------------------------------------------------------#
214 | # compiling - C++ source -> objects
215 | #-----------------------------------------------------------------------------#
216 |
217 | $(OUT_DIR_F)%.o : %.$(CXX_EXT)
218 | @echo 'Compiling file: $<'
219 | $(CXX) -c $(CXX_FLAGS_F) $< -o $@
220 | @echo ' '
221 |
222 | #-----------------------------------------------------------------------------#
223 | # compiling - C source -> objects
224 | #-----------------------------------------------------------------------------#
225 |
226 | $(OUT_DIR_F)%.o : %.$(C_EXT)
227 | @echo 'Compiling file: $<'
228 | $(CC) -c $(C_FLAGS_F) $< -o $@
229 | @echo ' '
230 |
231 | #-----------------------------------------------------------------------------#
232 | # assembling - ASM source -> objects
233 | #-----------------------------------------------------------------------------#
234 |
235 | $(OUT_DIR_F)%.o : %.$(AS_EXT)
236 | @echo 'Assembling file: $<'
237 | $(AS) -c $(AS_FLAGS_F) $< -o $@
238 | @echo ' '
239 |
240 | #-----------------------------------------------------------------------------#
241 | # memory images - elf -> hex, elf -> bin
242 | #-----------------------------------------------------------------------------#
243 |
244 | $(HEX) : $(ELF)
245 | @echo 'Creating IHEX image: $(HEX)'
246 | $(OBJCOPY) -O ihex $< $@
247 | @echo ' '
248 |
249 | $(BIN) : $(ELF)
250 | @echo 'Creating binary image: $(BIN)'
251 | $(OBJCOPY) -O binary $< $@
252 | @echo ' '
253 |
254 | #-----------------------------------------------------------------------------#
255 | # memory dump - elf -> dmp
256 | #-----------------------------------------------------------------------------#
257 |
258 | $(DMP) : $(ELF)
259 | @echo 'Creating memory dump: $(DMP)'
260 | $(OBJDUMP) -x --syms $< > $@
261 | @echo ' '
262 |
263 | #-----------------------------------------------------------------------------#
264 | # extended listing - elf -> lss
265 | #-----------------------------------------------------------------------------#
266 |
267 | $(LSS) : $(ELF)
268 | @echo 'Creating extended listing: $(LSS)'
269 | $(OBJDUMP) -S $< > $@
270 | @echo ' '
271 |
272 | #-----------------------------------------------------------------------------#
273 | # print the size of the objects and the .elf file
274 | #-----------------------------------------------------------------------------#
275 |
276 | print_size : $(ELF)
277 | @echo 'Size of modules:'
278 | $(SIZE) -B -t --common $(OBJS) $(USER_OBJS)
279 | @echo ' '
280 | @echo 'Size of target .elf file:'
281 | $(SIZE) -B $(ELF)
282 | @echo ' '
283 |
284 | #-----------------------------------------------------------------------------#
285 | # create the desired output directory
286 | #-----------------------------------------------------------------------------#
287 |
288 | make_output_dir :
289 | $(shell mkdir $(OUT_DIR_F) 2>/dev/null)
290 |
291 | #=============================================================================#
292 | # make clean
293 | #=============================================================================#
294 |
295 | clean:
296 | ifeq ($(strip $(OUT_DIR_F)), )
297 | @echo 'Removing all generated output files'
298 | else
299 | @echo 'Removing all generated output files from output directory: $(OUT_DIR_F)'
300 | endif
301 | ifneq ($(strip $(GENERATED)), )
302 | $(RM) $(GENERATED)
303 | else
304 | @echo 'Nothing to remove...'
305 | endif
306 |
307 | #=============================================================================#
308 | # global exports
309 | #=============================================================================#
310 |
311 | .PHONY: all clean dependents
312 |
313 | .SECONDARY:
314 |
315 | # include dependancy files
316 | -include $(DEPS)
