1 | /* _ _ _ _ _ _ _ _ _ _
2 | * /\ \ /\ \ /\ \ /\_\ / /\ /\ \ /\ \ /\_\/\_\ _ /\ \
3 | * / \ \ \_\ \ / \ \ / / / _ / / \ \_\ \ / \ \ / / / / //\_\ / \ \
4 | * / /\ \ \ /\__ \ / /\ \ \ \ \ \__ /\_\ / / /\ \__ /\__ \ / /\ \ \ /\ \/ \ \/ / /__/ /\ \ \
5 | * / / /\ \_\ / /_ \ \ / / /\ \ \ \ \___\ / / // / /\ \___\ / /_ \ \ / / /\ \ \ / \____\__/ //___/ /\ \ \
6 | * / / /_/ / / / / /\ \ \ / / / \ \_\ \__ / / / / \ \ \ \/___// / /\ \ \ / / / \ \_\ / /\/________/ \___\/ / / /
7 | * / / /__\/ / / / / \/_// / / \/_/ / / / / / / \ \ \ / / / \/_// / / / / // / /\/_// / / / / /
8 | * / / /_____/ / / / / / / / / / / / /_ \ \ \ / / / / / / / / // / / / / / / / / _
9 | * / / /\ \ \ / / / / / /________ / / /___/ / //_/\__/ / / / / / / / /___/ / // / / / / / \ \ \__/\_\
10 | * / / / \ \ \/_/ / / / /_________\/ / /____\/ / \ \/___/ / /_/ / / / /____\/ / \/_/ / / / \ \___\/ /
11 | * \/_/ \_\/\_\/ \/____________/\/_________/ \_____\/ \_\/ \/_________/ \/_/ \/___/_/
12 | *
13 | *
14 | * DMX Receiver for ATxMega
15 | * Tested with ATxMega256A3U
16 | * Uses external 16 MHz oscillator together with internal PLL to generate 32MHz system clock
17 | *
18 | *
19 | *
20 | * Released under the "Don't care" license
21 | * Feel free to use this code in any way you want
22 | * Also no support will be given in any way
23 | *
24 | * Code V1.0
25 | * 25.09.2015
26 | */
27 |
28 | #include <avr/io.h>
29 | #include <stdio.h>
30 | #include <avr/interrupt.h>
31 |
32 | //Buffer to store the DMX stream (start code + 512 channels)
33 | volatile unsigned int dmx_buffer[513];
34 |
35 | void Clock_init(void){
36 | //Xosc Bit 7&6 to 11 | Bit 3 to 0 as 1011
37 | OSC.XOSCCTRL = OSC_FRQRANGE_12TO16_gc | OSC_XOSCSEL_XTAL_16KCLK_gc;
38 | //Bit 3 to 1 to enable external oscillator
39 | OSC.CTRL |= OSC_XOSCEN_bm;
40 | //wait for stable clock
41 | while(!(OSC.STATUS & OSC_XOSCRDY_bm));
42 | //Disable register protection for 4 clocks
43 | CCP = CCP_IOREG_gc;
44 | //Set Bit 2:0 to 011 for external oscillator
45 | CLK.CTRL = CLK_SCLKSEL_XOSC_gc;
46 | }
47 |
48 | void PLL_init(void){
49 | //Bit 7:0 to 11 for external oscillator as PLL source | 2 as multiplication value
50 | OSC.PLLCTRL = OSC_PLLSRC_XOSC_gc | 0x02;
51 | //enable PLL
52 | OSC.CTRL |= OSC_PLLEN_bm;
53 | //wait for stable oscillation
54 | while (!(OSC.STATUS & OSC_PLLRDY_bm));
55 | //Disable register protection for 4 clocks
56 | CCP = CCP_IOREG_gc;
57 | //Set Bit 2:0 for PLL as clock source
58 | CLK.CTRL = CLK_SCLKSEL_PLL_gc;
59 | }
60 |
61 | void UART_init(void){
62 | // Pin from USARTC0 TxD C3 set to input
63 | PORTC.DIRCLR = PIN6_bm;
64 | // Asynchronous Modus
65 | USARTC1.CTRLC = (USARTC0.CTRLC & ~USART_CMODE_gm ) | USART_CMODE_ASYNCHRONOUS_gc;
66 | // No parity
67 | USARTC1.CTRLC = (USARTC0.CTRLC & ~USART_PMODE_gm ) | USART_PMODE_DISABLED_gc;
68 | // 8 data bits
69 | USARTC1.CTRLC = (USARTC0.CTRLC & ~USART_CHSIZE_gm ) | USART_CHSIZE_8BIT_gc;
70 | // 2 stop bits
71 | USARTC1.CTRLC = (USARTC0.CTRLC & ~USART_SBMODE_bm) | (0x01<<3);
72 | // 250 kBaud
73 | USARTC1.BAUDCTRLA = 07;
74 | // 250 kBaud
75 | USARTC1.BAUDCTRLB =(0 << USART_BSCALE0_bp)|(07 >> 8);
76 | // Set interrupt level of RX Int to low
77 | USARTC1.CTRLA = (USARTC1.CTRLA & ~USART_RXCINTLVL_gm) | USART_RXCINTLVL_LO_gc;
78 | // activate USARTC1
79 | USARTC1.CTRLB = USART_RXEN_bm;
80 |
81 | }
82 |
83 | int main (void){
84 |
85 | //Start-Up external crystal
86 | Clock_init();
87 | //Use PLL to generate 32 MHz tact from external crystal
88 | PLL_init();
89 | //Init UART
90 | UART_init();
91 |
92 | /* Enable LO interrupt level. */
93 | PMIC.CTRL |= PMIC_LOLVLEN_bm;
94 | //Global Interrupts Enable
95 | sei();
96 |
97 | while (1)
98 | {
99 | }
100 |
101 | return 0;
102 | }
103 |
104 | //Interupt vector for USART C1 RX complete
105 | ISR (USARTC1_RXC_vect){
106 | //Let's count the dmx channels
107 | static unsigned int dmx_channel_rx_count = 0;
108 | //And check if dmx is valid
109 | static unsigned char dmx_valid = 0;
110 | //Tmp is never wrong
111 | unsigned char tmp = 0;
112 |
113 | //Store currently received byte into tmp variable
114 | tmp = USARTC1.DATA;
115 |
116 | //Check for framing error as start of dmx transmission
117 | if(USARTC1.STATUS & USART_FERR_bm)
118 | {
119 | //Start to count at first channel
120 | dmx_channel_rx_count = 0;
121 | //Copy tmp into our dmx buffer at position 0
122 | dmx_buffer[0] = tmp;
123 | //now check if this value was a 0 which is the start code for normal dmx transmissions
124 | if(dmx_buffer[0] == 0)
125 | {
126 | //ok dmx was valid
127 | dmx_valid = 1;
128 | //increase count to first dmx channel containing information
129 | dmx_channel_rx_count++;
130 | }
131 | else
132 | {
133 | //sorry but first byte was not a dmx start code, let's wait for the next frame error
134 | dmx_valid = 0;
135 | }
136 | return;
137 | }
138 |
139 | //yippy dmx was valid so we can process the other 512 channels
140 | if(dmx_valid)
141 | {
142 | //copy the received channel byte into the correct position of our dmx reception buffer
143 | dmx_buffer[dmx_channel_rx_count] = tmp;
144 | //repeat until we have gathered all 512 channels
145 | if(dmx_channel_rx_count < 513)
146 | {
147 | dmx_channel_rx_count++;
148 | }
149 | return;
150 | }
151 | }
