1 | #include <SPI.h> //Library for Adafruit communication to display
2 | #include <Wire.h> //I2C communication library
3 | #include "ds3231.h" //Real Time Clock library
4 | #include "DHT.h" //DHT Sensor Library
5 | #include <Adafruit_GFX.h> //Graphics library
6 | #include <Adafruit_PCD8544.h> //Display library
7 |
8 | //PCD pin setting
9 | Adafruit_PCD8544 display = Adafruit_PCD8544(2, 3, 4, 5, 6);
10 |
11 | //DHT setting
12 | #define DHTPIN 9
13 | #define DHTTYPE DHT11
14 | DHT dht(DHTPIN, DHTTYPE);
15 |
16 | uint8_t secset = 0; //Index for second RTC setting
17 | uint8_t minset = 1; //Index for minute RTC setting
18 | uint8_t hourset = 2; //Index for hour RTC setting
19 | uint8_t wdayset = 3; //Index for weekday RTC setting
20 | uint8_t mdayset = 4; //Index for date RTC setting
21 | uint8_t monset = 5; //Index for month RTC setting
22 | uint8_t yearset = 6; //Index for year RTC setting
23 |
24 | //Alarm 1 time variables
25 | uint8_t wake_HOUR_1 = 0;
26 | uint8_t wake_MINUTE_1 = 0;
27 | uint8_t wake_SECOND_1 = 0;
28 | uint8_t wake_SET_1 = 1; //Default alarm to ON in case of power failure or reset
29 |
30 | //Alarm 2 time variables
31 | uint8_t wake_HOUR_2 = 0;
32 | uint8_t wake_MINUTE_2 = 0;
33 | uint8_t wake_SECOND_2 = 0;
34 | uint8_t wake_SET_2 = 1; //Default alarm to ON in case of power failure or reset
35 |
36 | unsigned long prev, interval = 100; //Variables for display/clock update rate
37 | byte flash = 0; //Flag for display flashing - toggle once per update interval
38 | byte mode = 0; //Mode for time and date setting
39 | int tempset; //Temporary variable for setting time/date
40 | int beepcount = 0; //Variable for number of 100ms intervals since alarm started sounding
41 |
42 | void setup()
43 | {
44 | Serial.begin(9600); //Initialize serial port, if needed (not used)
45 |
46 | Wire.begin(); //Initialize I2C communication library
47 |
48 | dht.begin();
49 |
50 | DS3231_init(0x00); //Initialize Real Time Clock for 1Hz square wave output (no RTC alarms on output pin)
51 |
52 | pinMode(7, INPUT); //Set pin for time/date mode button to input
53 | digitalWrite(7, HIGH); //Turn on pullup resistors
54 |
55 | pinMode(8, INPUT); //Set pin for time/date set button to input
56 | digitalWrite(8, HIGH); //Turn on pullup resistors
57 |
58 | pinMode(10, OUTPUT); //Set pin for alarm 1 relay
59 | digitalWrite(10, LOW); //Initialize alarm 1 relay to off-state
60 |
61 | pinMode(11, OUTPUT); //Set pin for alarm 2 relay
62 | digitalWrite(11, LOW); //Initialize alarm 2 relay to off-state
63 |
64 | display.begin(); // Initialize display
65 | display.setTextSize(1); //Set default font size to the smalles
66 | display.setTextColor(BLACK); //Set font to display color on black background
67 | }
68 |
69 | void loop()
70 | {
71 | unsigned long now = millis();
72 | struct ts t; //Time-structure for retrieving and storing time and date data RTC
73 |
74 | //Draw and update display every refresh period (100ms)
75 | if ((now - prev > interval)) { //Determine whether to start a time and screen update
76 | if (flash == 0) {
77 | flash = 1; //Toggle flash flag for cursor blinking later
78 | } else {
79 | flash = 0;
80 | }
81 |
82 | DS3231_get(&t); //Get time and date and save in t structure
83 |
84 | get_alarm_1(); //Retrieve current alarm setting
85 |
86 | get_alarm_2(); //Retrieve current alarm setting
87 |
88 | digitalWrite(10, LOW); //Turn off external alarm for flashing
89 |
90 | display.clearDisplay(); //Clear display buffer from last refresh
91 |
92 | //Alarm 1 trigger
93 |
94 | if (wake_SET_1 && DS3231_triggered_a1()) { //Display/sound alarm if enabled and triggered
95 | beepcount = beepcount + 1;
96 | if (beepcount <= 600) { //Sound alarm for 60 seconds
97 | if (!flash) { //Flash display and sound interrupted beeper
98 | digitalWrite(10, HIGH); //Flash external alarm if alarm triggered, regardless of mode
99 | }
100 | }
101 | else {
102 | beepcount = 0; //If alarm has sounded for 1 minute, reset alarm timer -counter and -flag
103 | DS3231_clear_a1f();
104 | }
105 | }
106 |
107 | //Alarm 2 trigger
108 |
109 | if (wake_SET_2 && DS3231_triggered_a2()) { //Display/sound alarm if enabled and triggered
110 | beepcount = beepcount + 1;
111 | if (beepcount <= 600) { //Sound alarm for 60 seconds
112 | if (!flash) { //Flash display and sound interrupted beeper
113 | digitalWrite(10, LOW); //Flash external alarm if alarm triggered, regardless of mode
114 | }
115 | }
116 | else {
117 | beepcount = 0; //If alarm has sounded for 1 minute, reset alarm timer -counter and -flag
118 | DS3231_clear_a2f();
119 | }
120 | }
121 |
122 | //DISPLAY TIME, ALARM, TEMPERATURE AND HUMIDITY
123 |
124 | //Display time
125 |
126 | if (mode <= 9) {
127 |
128 | display.setCursor(16, 0); //Position text cursor for time display
129 |
130 | if (t.hour < 10) {
131 | display.print(" "); //Add leading space if single-digit hour
132 | }
133 | display.print(t.hour);
134 |
135 | display.print(":"); //Display hour-minute separator
136 |
137 | if (t.min < 10) {
138 | display.print("0"); //Add leading zero if single-digit minute
139 | }
140 | display.print(t.min); //Display retrieved minutes
141 |
142 | display.print(":"); //Display minute-seconds separator
143 |
144 | if (t.sec < 10) {
145 | display.print("0"); //Add leading zero for single-digit seconds
146 | }
147 | display.print(t.sec); //Display retrieved seconds
148 |
149 | //Display Alarm
150 |
151 | if (mode > 9) {
152 |
153 | display.setCursor(0, 9); //Position text cursor for alarm 1 display
154 |
155 | if (wake_HOUR_1 < 10) {
156 | display.print(" "); //Add leading space if single-digit hour
157 | }
158 | display.print(wake_HOUR_1);
159 |
160 | display.print(":"); //Display hour-minute separator
161 |
162 | if (wake_MINUTE_1 < 10) {
163 | display.print("0"); //Add leading zero if single-digit minute
164 | }
165 | display.print(wake_MINUTE_1); //Display retrieved minutes
166 |
167 | display.setCursor(40, 9); //Position text cursor for alarm 2 display
168 |
169 | if (wake_HOUR_2 < 10) {
170 | display.print(" "); //Add leading space if single-digit hour
171 | }
172 | display.print(wake_HOUR_2);
173 |
174 | display.print(":"); //Display hour-minute separator
175 |
176 | if (wake_MINUTE_2 < 10) {
177 | display.print("0"); //Add leading zero if single-digit minute
178 | }
179 | display.print(wake_MINUTE_2); //Display retrieved minutes
180 | }
181 |
182 | // Reading DHT sensor
183 | float hum = dht.readHumidity();
184 | float tmp = dht.readTemperature(); // Read temperature as Celsius (the default)
185 | float fh = dht.readTemperature(true); // Read temperature as Fahrenheit (isFahrenheit = true)
186 |
187 | // Check if any reads failed and exit early (to try again).
188 | if (isnan(hum) || isnan(tmp) || isnan(fh)) {
189 | Serial.println("Fehler: Klimasensor");
190 | display.setCursor(1, 20);
191 | display.print("Fehler: Klimasensor");
192 | return;
193 | }
194 |
195 | //Display temperature and humidity
196 |
197 | display.setCursor(1, 20);
198 | display.print("Tmp.:");
199 | display.print(tmp, 1);
200 | display.print((char)247);
201 | display.print("C");
202 | display.setCursor(1, 28);
203 | display.print("Hum.:");
204 | display.print(hum, 0);
205 | display.print("%");
206 |
207 | }
208 |
209 | //Time, alarm, temperature and humidity settings button processing and settings cursor flashing
210 | //Digital and analog time/date display updates with new settings at 5Hz as settings are changed
211 |
212 | switch (mode)
213 | {
214 | case 0: break;
215 |
216 | case 1: //Hour setting
217 | if (flash) {
218 | display.drawRect(15, 0, 12, 8, BLACK); //Flash cursor (5Hz)
219 | }
220 | if (!digitalRead(9) && (!flash)) { //Update setting at 5Hz rate if button held down
221 | tempset = t.hour; //Get the current hour and save in temporary variable
222 | tempset = tempset + 1; //Increment the hour at 5Hz rate
223 | if (tempset > 23) {
224 | tempset = 0; //Roll over hour after 23rd hour (setting done in 24-hour mode)
225 | }
226 | t.hour = tempset; //After each update, write the hour to the time structure
227 | set_rtc_field(t, hourset); //Write the set field only to the RTC after each update
228 | }
229 | break;
230 |
231 | case 2: //Minute setting
232 | if (flash) {
233 | display.drawRect(33, 0, 12, 8, BLACK); //Flash cursor (5Hz)
234 | }
235 | if (!digitalRead(9) && (!flash)) { //Update setting at 5Hz rate if button held down
236 | tempset = t.min; //Get the current minute and save in temporary variable
237 | tempset = tempset + 1; //Increment the minute at 5Hz rate
238 | if (tempset > 59) {
239 | tempset = 0; //Roll over minute to zero after 59th minute
240 | }
241 | t.min = tempset; //After each update, write the minute to the time structure
242 | set_rtc_field(t, minset); //Write the set field only to the RTC after each update
243 | }
244 | break;
245 |
246 | //Set clock + 1 minute, then press and hold to freeze second setting.
247 | //Release button at 00 seconds to synchronize clock to external time source.
248 |
249 | case 3: //Second synchronization
250 | if (flash) {
251 | display.drawRect(51, 0, 12, 8, BLACK); //Flash cursor (5Hz)
252 | }
253 | if (!digitalRead(9) && (!flash)) { //Reset second to zero at 5Hz rate if button held down
254 | t.sec = 0; //After each update, write the zeroed second to the time structure
255 | set_rtc_field(t, secset); //Write the set field only to the RTC after each update
256 | }
257 | break;
258 |
259 | case 4: //Alarm 1 hour setting
260 | if (flash) {
261 | display.drawRect(0, 9, 12, 8, BLACK); //Flash cursor (5Hz)
262 | }
263 | if (!digitalRead(9) && (!flash)) { //Update setting at 5Hz rate if button held down
264 | tempset = wake_HOUR_1; //Get the current hour and save in temporary variable
265 | tempset = tempset + 1; //Increment the hour at 5Hz rate
266 | if (tempset > 23) {
267 | tempset = 0; //Roll over hour after 23rd hour (setting done in 24-hour mode)
268 | }
269 | wake_HOUR_1 = tempset; //Write the hour to the alarm variable after each update
270 | set_alarm_1(); //Write the alarm setting to the RTC after each update
271 | }
272 | break;
273 |
274 | case 5: //Alarm 1 minute setting
275 | if (flash) {
276 | display.drawRect(18, 9, 12, 8, BLACK); //Flash cursor (5Hz)
277 | }
278 | if (!digitalRead(9) && (!flash)) { //Update setting at 5Hz rate if button held down
279 | tempset = wake_MINUTE_1; //Get the current minute and save in temporary variable
280 | tempset = tempset + 1; //Increment the minute at 5Hz rate
281 | if (tempset > 59) {
282 | tempset = 0; //Roll over minute to zero after 59th minute
283 | }
284 | wake_MINUTE_1 = tempset; //Write the minute to the alarm variable after each update
285 | set_alarm_1(); //Write the alarm setting to the RTC after each update
286 | }
287 | break;
288 |
289 | case 6: //Alarm 1 enable/disable
290 | if (flash) {
291 | display.drawRect(0, 0, 6, 8, BLACK); //Display rectangle cursor every other display update (5Hz)
292 | }
293 | if (!digitalRead(9) && (!flash)) { //Update setting at 5Hz rate if button held down
294 | if (wake_SET_1) {
295 | wake_SET_1 = 0; //Toggle alarm on/of variable at 5 Hz
296 | } else {
297 | wake_SET_1 = 1;
298 | }
299 | }
300 | break;
301 |
302 | case 7: //Alarm 2 hour setting
303 | if (flash) {
304 | display.drawRect(40, 9, 12, 8, BLACK); //Flash cursor (5Hz)
305 | }
306 | if (!digitalRead(9) && (!flash)) { //Update setting at 5Hz rate if button held down
307 | tempset = wake_HOUR_2; //Get the current hour and save in temporary variable
308 | tempset = tempset + 1; //Increment the hour at 5Hz rate
309 | if (tempset > 23) {
310 | tempset = 0; //Roll over hour after 23rd hour (setting done in 24-hour mode)
311 | }
312 | wake_HOUR_2 = tempset; //After each update, write the hour back to the alarm variable
313 | set_alarm_2(); //Write the alarm setting back to the RTC after each update
314 | }
315 | break;
316 |
317 | case 8: //Alarm 2 minute setting
318 | if (flash) {
319 | display.drawRect(58, 9, 12, 8, BLACK); //Display rectangle cursor every other display update (5Hz blink)
320 | }
321 | if (!digitalRead(9) && (!flash)) { //Update setting at 5Hz rate if button held down
322 | tempset = wake_MINUTE_2; //Get the current minute and save in temporary variable
323 | tempset = tempset + 1; //Increment the minute at 5Hz rate
324 | if (tempset > 59) {
325 | tempset = 0; //Roll over minute to zero after 59th minute
326 | }
327 | wake_MINUTE_2 = tempset; //After each update, write the minute back to the alarm variable
328 | set_alarm_2(); //Write the alarm setting back to the RTC after each update
329 | }
330 |
331 | break;
332 |
333 | case 9: //Alarm 2 enable/disable
334 | if (flash) {
335 | display.drawRect(0, 0, 6, 8, BLACK); //Display rectangle cursor every other display update (5Hz blink)
336 | }
337 | if (!digitalRead(9) && (!flash)) { //Update setting at 5Hz rate if button held down
338 | if (wake_SET_2) {
339 | wake_SET_2 = 0; //Toggle alarm on/of variable at 5 Hz
340 | } else {
341 | wake_SET_2 = 1;
342 | }
343 | }
344 | break;
345 |
346 | prev = now; //Reset variable for display and time update rate
347 | display.display(); //Display the constructed frame buffer for this framecount
348 | }
349 |
350 | //Clock setting mode set - outside time/display update processing for faster button response
351 | if (!digitalRead(8)) { //Read setting mode button
352 | delay(25); //25ms debounce time
353 | if (!digitalRead(8)) { //Activate setting mode change after 100ms button press
354 | mode = mode + 1; //Increment the time setting mode on each button press
355 | if (mode > 9) {
356 | mode = 0; //Roll the mode setting after 9th mode
357 | }
358 | while (!digitalRead(8)) {} //Wait for button release
359 | }
360 | }
361 |
362 | if (!digitalRead(9)) { //Reset alarm flag if set button pressed
363 | delay(25); //25ms debounce time
364 | if (!digitalRead(9)) {
365 | DS3231_clear_a1f(); //Clear alarm flag if set button pressed - insures alarm reset when turning alarm on
366 | }
367 | }
368 | }
369 | }
370 | //Subroutine to adjust a single date/time field in the RTC
371 | void set_rtc_field(struct ts t, uint8_t index)
372 | {
373 | uint8_t century;
374 |
375 | if (t.year > 2000) {
376 | century = 0x80;
377 | t.year_s = t.year - 2000;
378 | } else {
379 | century = 0;
380 | t.year_s = t.year - 1900;
381 | }
382 |
383 | uint8_t TimeDate[7] = { t.sec, t.min, t.hour, t.wday, t.mday, t.mon, t.year_s };
384 |
385 | Wire.beginTransmission(DS3231_I2C_ADDR);
386 | Wire.write(index);
387 | TimeDate[index] = dectobcd(TimeDate[index]);
388 | if (index == 5) {
389 | TimeDate[5] += century;
390 | }
391 | Wire.write(TimeDate[index]);
392 | Wire.endTransmission();
393 |
394 | //Adjust the month setting, per data sheet, if the year is changed
395 | if (index == 6) {
396 | Wire.beginTransmission(DS3231_I2C_ADDR);
397 | Wire.write(5);
398 | TimeDate[5] = dectobcd(TimeDate[5]);
399 | TimeDate[5] += century;
400 | Wire.write(TimeDate[5]);
401 | Wire.endTransmission();
402 | }
403 | }
404 |
405 | //Subroutine to set alarm 1
406 | void set_alarm_1()
407 | {
408 |
409 | // flags define what calendar component to be checked against the current time in order
410 | // to trigger the alarm - see datasheet
411 | // A1M1 (seconds) (0 to enable, 1 to disable)
412 | // A1M2 (minutes) (0 to enable, 1 to disable)
413 | // A1M3 (hour) (0 to enable, 1 to disable)
414 | // A1M4 (day) (0 to enable, 1 to disable)
415 | // DY/DT (dayofweek == 1/dayofmonth == 0)
416 | byte flags[5] = { 0, 0, 0, 1, 1 }; //Set alarm to trigger every 24 hours on time match
417 |
418 | // set Alarm1
419 | DS3231_set_a1(0, wake_MINUTE_1, wake_HOUR_1, 0, flags); //Set alarm 1 RTC registers
420 |
421 | }
422 |
423 | //Subroutine to set alarm 2
424 | void set_alarm_2()
425 | {
426 |
427 | // flags define what calendar component to be checked against the current time in order
428 | // to trigger the alarm - see datasheet
429 | // A1M1 (seconds) (0 to enable, 1 to disable)
430 | // A1M2 (minutes) (0 to enable, 1 to disable)
431 | // A1M3 (hour) (0 to enable, 1 to disable)
432 | // A1M4 (day) (0 to enable, 1 to disable)
433 | // DY/DT (dayofweek == 1/dayofmonth == 0)
434 | byte flags[5] = { 0, 0, 0, 1, 1 }; //Set alarm to trigger every 24 hours on time match
435 |
436 | // set Alarm2
437 | DS3231_set_a2(0, wake_MINUTE_2, wake_HOUR_2, flags); //Set alarm 2 RTC registers
438 |
439 | }
440 |
441 | //Subroutine to get alarm 1
442 | void get_alarm_1()
443 | {
444 | uint8_t n[4];
445 | uint8_t t[4]; //second,minute,hour,day
446 | uint8_t f[5]; // flags
447 | uint8_t i;
448 |
449 | Wire.beginTransmission(DS3231_I2C_ADDR);
450 | Wire.write(DS3231_ALARM1_ADDR);
451 | Wire.endTransmission();
452 |
453 | Wire.requestFrom(DS3231_I2C_ADDR, 4);
454 |
455 | for (i = 0; i <= 3; i++) {
456 | n[i] = Wire.read();
457 | f[i] = (n[i] & 0x80) >> 7;
458 | t[i] = bcdtodec(n[i] & 0x7F);
459 | }
460 |
461 | f[4] = (n[3] & 0x40) >> 6;
462 | t[3] = bcdtodec(n[3] & 0x3F);
463 |
464 | wake_SECOND_1 = t[0];
465 | wake_MINUTE_1 = t[1];
466 | wake_HOUR_1 = t[2];
467 | }
468 |
469 | //Subroutine to get alarm 2
470 | void get_alarm_2()
471 | {
472 | uint8_t n[3];
473 | uint8_t t[3]; //second,minute,hour,day
474 | uint8_t f[4]; // flags
475 | uint8_t i;
476 |
477 | Wire.beginTransmission(DS3231_I2C_ADDR);
478 | Wire.write(DS3231_ALARM2_ADDR);
479 | Wire.endTransmission();
480 |
481 | Wire.requestFrom(DS3231_I2C_ADDR, 3);
482 |
483 | for (i = 0; i <= 2; i++) {
484 | n[i] = Wire.read();
485 | f[i] = (n[i] & 0x80) >> 7;
486 | t[i] = bcdtodec(n[i] & 0x7F);
487 | }
488 |
489 | f[3] = (n[2] & 0x40) >> 6;
490 | t[2] = bcdtodec(n[3] & 0x3F);
491 |
492 | wake_SECOND_2 = t[0];
493 | wake_MINUTE_2 = t[1];
494 | wake_HOUR_2 = t[2];
495 | }
