Hi, since Windows 8 and 10 I have Problems with my USB HID. I'm using the STM USB HID Stack and the demo VB project from JANAXELSON.COM. If I connect the STM32F407 via USB the connection works for ~1sec. Afterwards the USB_HID_STATUS changes from USB_HID_CONNECTED to USB_HID_DETACHED. Workaround (not practically) is to change the variables in the registry from 1 to 0: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB AllowIdleIrpInD3 = 0 DeviceSelectiveSuspended = 0 EnhancedPowerManagementEnabled = 0 SelectiveSuspendEnabled = 0 In Windows (Printers and Devices) the device is correct registered, but in a kind of suspend mode. If I start the software before I plugg the USB cable, the Software recognizes this and connects to STM32F4. Afterwards the device remains 'online' and do not go to the suspend mode. I'm looking for a solution either on PC side, or on the STM32F4 USB stack: PC Side (Preferred, I'm using Visual Studio Express 2015 - VB.Net) Are there functions that checks the power state of the USB HID and somehow 'wake up' the device before writing/reading via fileStreamdevicedata? Or, to deactivate the USB Selective Suspend for this device (not all USB devices) to avoid the device to suspend. USB Stack Can the desciptors be changed to avoid Windows 8/8.1/10 to set the device into other mode than D0 (eg. D3 DeviceSelectiveSuspended).
>Are there functions that checks the power state of the USB HID and >somehow 'wake up' >the device before writing/reading via fileStreamdevicedata? I think IO-Requests initiated from the host should automatically ensure that the driver wakes the device up. Maybe the device is not waking up properly? usb30cv/usb20cv could be used to test the device, or "Windows HCK" "All USB devices must support the Suspended state (refer to Chapter 9). The device is placed into the Suspended state via control of the hub port to which the device is attached. Normal device operation ceases in the Suspend State; however, if the device is capable of wakeup signaling and the device is enabled for remote wakeup, it may generate resume signaling in response to external events. The power management system may transition a device to the Suspended state or power-off the device in order to control and conserve power. The USB provides neither requirements nor commands for the device state to be saved and restored across these transitions." (USB 2.0 Specification) A common workaround to prevent getting suspended is to just send dummy data to the host every few ms so the driver will not think that the device is idle.
Mig schrieb: > Workaround (not practically) is to change the variables in the registry > from 1 to 0: > HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB > AllowIdleIrpInD3 = 0 > DeviceSelectiveSuspended = 0 > EnhancedPowerManagementEnabled = 0 > SelectiveSuspendEnabled = 0 There exists a mechanism to automatically set these registry values: "Microsoft OS 2.0 Descriptors Specification" 1). The spec also includes some examples demonstrating how to set SelectiveSuspendEnabled (page 15) 1) https://msdn.microsoft.com/de-de/library/windows/hardware/dn385747.aspx
Hi Guys, many thanks for your help. Fortunately is was a stupid bug in my FW and luckily I do not need to play around with further descriptors. Problem solved. It was a bug in the user section of the FW in my function where I used the disconnected flag instead of connected. void USBD_USR_DeviceResumed(void)
